First of all. Thank you for you time Manjaro community. English is not my first language, spanish is. Sorry about that. Please just watch this video i captured with OBS. Watch it at fullscreen to see that strange “mirror effect” bar at the bottom of my screen, you could clearly see that the cursor movement can be seen in the bar after moving it at the top of the screen. This glitch appears after some minutes or hours of using the desktop normally for some browser stuff and file management. I’m using KDE plasma. What can be happening here? Any ideas? D: PSDT: i can’t show the glitch with a screenshot because it does not show on it. weird. the best way is to show it from a video.
w w w .you tub e. com
/w at c h?v = 6 -o Z ogx 6 u 4Q
Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=cf8fef2c-03ad-4ff8-909d-f3266e5880b0 rw quiet apparmor=1
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Dell product: G3 3579 v: N/A serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: Dell model: 03TF0Y v: A00 serial: <filter> UEFI: Dell v: 1.13.0
date: 07/03/2020
ID-1: BAT0 charge: 33.4 Wh condition: 33.4/56.0 Wh (60%) volts: 16.9/15.2
model: Samsung SDI DELL W7NKD85 type: Li-ion serial: <filter> status: Full
Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE L2 cache: 9 MiB
bogomips: 52815
Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 801 11: 800 12: 800
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: nvidia
v: 460.32.03 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c8c
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-5:3 chip ID: 1bcf:28c1
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: intel,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.3
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Sound Server: ALSA v: k5.10.7-3-MANJARO
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
port: 5000 bus ID: 00:14.3 chip ID: 8086:a370
vendor: Dell driver: r8168 v: 8.048.03-NAPI modules: r8169 port: 3000
bus ID: 02:00.0 chip ID: 10ec:8168
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus ID: 00:17.0 chip ID: 8086.282a rev: 10
Local Storage: total: 1.03 TiB used: 325.94 GiB (31.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: SDM3
ID-2: /dev/sdb maj-min: 8:16 vendor: SK Hynix model: SC311 SATA 128GB
size: 119.24 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 0P10
ID-1: / raw size: 50 GiB size: 48.96 GiB (97.93%) used: 11.24 GiB (23.0%)
fs: ext4 dev: /dev/sdb5 maj-min: 8:21
ID-2: /boot/efi raw size: 99 MiB size: 95 MiB (95.96%) used: 49 MiB (51.6%)
fs: vfat dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 283 Uptime: 1h 14m wakeups: 1 Memory: 7.62 GiB
used: 4.01 GiB (52.6%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1284 lib: 375 flatpak: 0 Shell: Zsh v: 5.8 running in: konsole
inxi: 3.2.02
