I just booted Manjaro Gnome and it only connects to ethernet. Doesn’t connect to wi-fi no matter what I try. Can somebody help me with this? Thanks.
Please post the output of inxi -Fazy
and lspci -k
inxi -Fazy
Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=801f1b7c-ea73-42f0-9a80-b2174b26a2ea rw quiet apparmor=1
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Laptop System: HP product: HP Laptop 14-dk0xxx v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: HP model: 85E0 v: 84.42 serial: <filter> UEFI: AMI v: F.42
date: 07/03/2019
ID-1: BAT0 charge: 23.4 Wh condition: 42.2/42.2 Wh (100%) volts: 11.2/11.6
model: Hewlett-Packard Primary type: Li-ion serial: <filter>
status: Discharging
Topology: Dual Core model: AMD Ryzen 3 3200U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108102 L2 cache: 1024 KiB
bogomips: 20770
Speed: 1304 MHz min/max: 1400/2600 MHz boost: enabled Core speeds (MHz):
1: 1225 2: 1249 3: 1222 4: 1222
disabled, RSB filling
Device-1: AMD Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel
bus ID: 03:00.0 chip ID: 1002:15d8
Device-2: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera
type: USB driver: uvcvideo bus ID: 1-4:2 chip ID: 05c8:03d2
Display: wayland server: X.org 1.20.9 compositor: gnome-shell driver: amdgpu
note: display driver n/a - try sudo/root display ID: 0
resolution: <xdpyinfo missing>
OpenGL: renderer: AMD RAVEN2 (DRM 3.38.0 5.8.16-2-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.8 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 03:00.1 chip ID: 1002:15de
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x bus ID: 03:00.5 chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 03:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.16-2-MANJARO
vendor: Hewlett-Packard driver: r8169 v: kernel port: f000 bus ID: 01:00.0
chip ID: 10ec:8168
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: N/A port: e000 bus ID: 02:00.0
chip ID: 10ec:c821
Local Storage: total: 1.82 TiB used: 7.73 GiB (0.4%)
ID-1: /dev/sda vendor: Seagate model: ST2000LM007-1R8174 size: 1.82 TiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: RDM4 scheme: GPT
ID-1: / raw size: 1.82 TiB size: 1.79 TiB (98.38%) used: 7.73 GiB (0.4%)
fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 39.2 C mobo: N/A gpu: amdgpu temp: 0 C
Processes: 245 Uptime: 28m Memory: 29.37 GiB used: 1.50 GiB (5.1%)
Init: systemd v: 246 Compilers: gcc: 10.1.0 Packages: pacman: 1177 lib: 330
flatpak: 0 Shell: Bash v: 5.0.18 default: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.05</pre>
<pre>lspci -k
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Root Complex
Subsystem: Hewlett-Packard Company Device 85e0
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:01.6 PCI bridge: Advanced Micro Devices, Inc. [AMD] Zeppelin Switch Upstream (PCIE SW.US)
Kernel driver in use: pcieport
00:01.7 PCI bridge: Advanced Micro Devices, Inc. [AMD] Zeppelin Switch Upstream (PCIE SW.US)
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus B
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 7
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
DeviceName: Realtek PCIe FE Family Controller
Kernel driver in use: r8169
Kernel modules: r8169
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter
Subsystem: Hewlett-Packard Company Device 831a
03:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Picasso (rev c4)
DeviceName: Onboard IGD
Kernel driver in use: amdgpu
Kernel modules: amdgpu
03:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio Controller
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
03:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
Kernel driver in use: ccp
Kernel modules: ccp
03:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Raven2 USB 3.1
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
03:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor
Kernel driver in use: snd_rn_pci_acp3x
Kernel modules: snd_pci_acp3x, snd_rn_pci_acp3x
03:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
04:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 61)
Kernel driver in use: ahci
Install dkms if this isn’t already installed.
The driver is in the AUR, so install rtl8821ce-dkms-git
Reboot.
I’ve tried doing so but it fails to build the file and shows some errors about kernel headers and modules. Do I have to install something before that?
You need to install the kernel headers first. Install the linux58-headers
package first and try again.
Sorry, thought you might have the headers already installed.
After installing linux58-headers it still fails to build and says kernel headers are missing. I installed a and built a package called linux58-headers from “add or remove software” app.
This is the full error when installing the adapter.
==> Unable to remove module rtl8821ce/1.0.5.r109.gfe97b50 for kernel 5.8.16-2-MANJARO: Not found in dkms status output.
==> Unable to remove module rtl8821ce/1.0.5.r109.gfe97b50 for kernel 5.8.0-1-MANJARO: Not found in dkms status output.
Reinstalling rtl8821ce-dkms-git (1.0.5.r109.gfe97b50-1)…
Running post-transaction hooks…
Arming ConditionNeedsUpdate…
Install DKMS modules
==> Unable to install module rtl8821ce/1.0.5.r109.gfe97b50 for kernel 5.8.16-2-MANJARO: Missing kernel headers.
==> Unable to install module rtl8821ce/1.0.5.r109.gfe97b50 for kernel 5.8.0-1-MANJARO: Missing kernel modules tree.
You also need to install the Please post the output dkms
package.ls /lib/modules/*/build
/lib/modules/5.8.0-1-MANJARO/build:
arch crypto include kernel mm samples sound virt
block drivers init lib Module.symvers scripts tools
certs fs Kconfig Makefile net security usr
/lib/modules/5.8.16-2-MANJARO/build:
vmlinux
What’s the output of mhwd-kernel -li
The output for ls /lib/modules/*/build just showed the above.
The output for mhwd-kernel -li: 5.8.16-2-MANJARO (linux58)
- linux58
You did reboot after installing the headers?
Yes. I did.
Please run
sudo pacman -Fy
pacman -F /usr/lib/modules/5.8.0-1-MANJARO/build/
pacman -F /usr/lib/modules/5.8.16-2-MANJARO/build/
and post the output.
It says failed to synchronize databases. Not sure why.
Well that’s a problem. Does sudo pacman -Syu
work?
Nope. Still says the same.
What does it say exactly?
error: failed to update core (unable to lock database)
error: failed to update extra (unable to lock database)
error: failed to update community (unable to lock database)
error: failed to update multilib (unable to lock database)
error: failed to synchronize all databases
