Thank you the instructions, I’ve missed it
There is some more info:
LANG=C inxi --admin --verbosity=7 --filter --width ✔
Kernel: 5.15.91-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=81c28827-d36a-4261-86b3-70b91c90601e rw quiet
resume=UUID=d78c49ea-69ce-4083-8fe7-11753674d7e6 udev.log_priority=3
acpi_backlight=vendor video.use_native_backlight=1
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Micro-Star product: Modern 15 A5M v: REV:1.0
Mobo: Micro-Star model: MS-155L v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: E155LAMS.113 date: 08/30/2022
ID-1: BAT1 charge: 42.4 Wh (88.1%) condition: 48.1/52.4 Wh (91.8%)
volts: 12.7 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
status: charging
RAM: total: 30.72 GiB used: 8.95 GiB (29.1%)
Info: model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1628 high: 3425 min/max: 1400/4370 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1510 2: 2477
3: 3425 4: 1397 5: 1397 6: 1397 7: 1397 8: 1658 9: 1397 10: 1397 11: 1397
12: 1397 13: 1600 14: 1416 15: 1397 16: 1397 bogomips: 57504
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Lucienne vendor: Micro-Star MSI driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 40.0 C
Device-2: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 1-4:2
chip-ID: 5986:211c class-ID: 0e02
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x2e8d built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.42 5.15.91-1-MANJARO) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Micro-Star MSI
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound API: ALSA v: k5.15.91-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 14c3:0608
class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 4-2:2 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp4s0f4u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: lxcbr0 state: down mac: <filter>
IF-ID-2: virbr0 state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
Device-1: MediaTek Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-3:2 chip-ID: 0e8d:0608 class-ID: e001 serial: <filter>
Local Storage: total: 953.88 GiB used: 552.02 GiB (57.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AI1
lanes: 4 type: SSD serial: <filter> rev: ECFK52.8 temp: 30.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HP model: SSD S700 Pro 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0D scheme: GPT
ID-1: / raw-size: 442.85 GiB size: 434.83 GiB (98.19%)
used: 228.04 GiB (52.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 81c28827-d36a-4261-86b3-70b91c90601e
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 17F8-3433
ID-3: /mnt/old raw-size: 460.64 GiB size: 452.34 GiB (98.20%)
used: 323.98 GiB (71.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: c1388b79-f291-4f65-9876-c75e2894a4b4
ID-1: swap-1 type: partition size: 33.79 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: d78c49ea-69ce-4083-8fe7-11753674d7e6
ID-1: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: vfat label: NO_LABEL
uuid: D658-6FA3
ID-2: /dev/sda3 maj-min: 8:3 size: 16 GiB fs: swap label: N/A
uuid: 1407866b-992d-4328-a3dc-78176292255f
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-4:2 info: Acer HD Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:211c
class-ID: 0e02
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: MediaTek Wireless_Device type: Bluetooth
driver: btusb interfaces: 3 rev: 2.1 speed: 480 Mb/s power: 100mA
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 4-2:2 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 288mA
System Temperatures: cpu: 48.5 C mobo: N/A gpu: amdgpu temp: 40.0 C
Processes: 404 Uptime: 13h 0m wakeups: 11 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1685 libs: 391 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Zsh v: 5.9 running-in: yakuake inxi: 3.3.24
Some additional informations i managed to find in dmesg when fiddling with acpi:
[ 6601.022171] ACPI Error: No handler for Region [VRTC] (000000006f2c3d34) [SystemCMOS] (20210730/evregion-130)
[ 6601.022186] ACPI Error: Region SystemCMOS (ID=5) has no handler (20210730/exfldio-261)
[ 6601.022201] ACPI Error: Aborting method \_SB.PCI0.SBRG.EC._Q9A due to previous error (AE_NOT_EXIST) (20210730/psparse-529)
[ 6603.042117] ACPI Error: No handler for Region [VRTC] (000000006f2c3d34) [SystemCMOS] (20210730/evregion-130)
[ 6603.042132] ACPI Error: Region SystemCMOS (ID=5) has no handler (20210730/exfldio-261)
[ 6603.042148] ACPI Error: Aborting method \_SB.PCI0.SBRG.EC._Q9A due to previous error (AE_NOT_EXIST) (20210730/psparse-529)
[ 6605.058794] ACPI Error: No handler for Region [VRTC] (000000006f2c3d34) [SystemCMOS] (20210730/evregion-130)
[ 6605.058808] ACPI Error: Region SystemCMOS (ID=5) has no handler (20210730/exfldio-261)
[ 6605.058822] ACPI Error: Aborting method \_SB.PCI0.SBRG.EC._Q9A due to previous error (AE_NOT_EXIST) (20210730/psparse-529)
And another one that does not always happen, but happened at least once:
[ 6654.118946] ACPI: button: The lid device is not compliant to SW_LID.
I have now manually started the disabled acpid service, because it seems to produce some debug info related to the problem, even though starting acpid does not fix the problem, and does not prevent the workaround from working either
After starting acpid, there is no, or no meanigfull output from journalctl -f
This part of output from journalctl -f that happens immadiately after applying my workaround ( running “watch cat /proc/acpi/button/lid/LID0/state” ), this happens after starting the command, BEFORE I do anything with the lid:
lut 08 15:55:48 gst-modern15a5m root[56676]: ACPI group/action undefined: button/left / LEFT
lut 08 15:55:48 gst-modern15a5m root[56678]: ACPI group/action undefined: button/left / LEFT
lut 08 15:55:49 gst-modern15a5m root[56680]: ACPI group/action undefined: button/up / UP
lut 08 15:55:49 gst-modern15a5m plasmashell[6826]: qml: temp unit: 0
lut 08 15:55:49 gst-modern15a5m root[56682]: ACPI group/action undefined: button/up / UP
lut 08 15:55:50 gst-modern15a5m root[56684]: ACPI group/action undefined: button/down / DOWN
lut 08 15:55:50 gst-modern15a5m root[56689]: ACPI group/action undefined: video/brightnessdown / BRTDN
lut 08 15:55:51 gst-modern15a5m root[56691]: ACPI group/action undefined: button/right / RIGHT
lut 08 15:55:51 gst-modern15a5m root[56693]: ACPI group/action undefined: button/right / RIGHT
lut 08 15:55:51 gst-modern15a5m root[56695]: ACPI group/action undefined: video/brightnessdown / BRTDN
lut 08 15:55:52 gst-modern15a5m root[56700]: ACPI group/action undefined: video/brightnessdown / BRTDN
lut 08 15:55:52 gst-modern15a5m root[56702]: ACPI group/action undefined: video/brightnessdown / BRTDN
lut 08 15:55:52 gst-modern15a5m kernel: ACPI Error: No handler for Region [VRTC] (000000006f2c3d34) [SystemCMOS] (20210730/evregion-130)
lut 08 15:55:52 gst-modern15a5m kernel: ACPI Error: Region SystemCMOS (ID=5) has no handler (20210730/exfldio-261)
lut 08 15:55:52 gst-modern15a5m kernel: ACPI Error: Aborting method \_SB.PCI0.SBRG.EC._Q9A due to previous error (AE_NOT_EXIST) (20210730/psparse-529)
lut 08 15:55:52 gst-modern15a5m plasmashell[6826]: qml: temp unit: 0
lut 08 15:55:54 gst-modern15a5m kernel: ACPI Error: No handler for Region [VRTC] (000000006f2c3d34) [SystemCMOS] (20210730/evregion-130)
lut 08 15:55:54 gst-modern15a5m kernel: ACPI Error: Region SystemCMOS (ID=5) has no handler (20210730/exfldio-261)
lut 08 15:55:54 gst-modern15a5m kernel: ACPI Error: Aborting method \_SB.PCI0.SBRG.EC._Q9A due to previous error (AE_NOT_EXIST) (20210730/psparse-529)
With my workaround running, this is from the output of journalctl -f, immadiately after i close the lid:
lut 08 15:55:58 gst-modern15a5m systemd-logind[658]: Lid closed.
lut 08 15:55:58 gst-modern15a5m systemd-logind[658]: Suspending...
I have now stopped the acpid service that i manually started previously AND I have stopped my workaround command
There is no / no related output from journalctl -f.
I have started my workaround again, and there is no / no related output from journalctl -f.
Now when i close the lid, with the workaround running, and the acpi disabled/stopped, journalctl -f immadiately produces :
lut 08 16:06:23 gst-modern15a5m systemd-logind[658]: Lid closed.
lut 08 16:06:23 gst-modern15a5m systemd-logind[658]: Suspending...
And the system goes to sleep properly.
I have ommited the output of journalctl -f that happens AFTER “lid closed” because there is a lot of it and things seem to react to the sleep request properly with no errors.
Xorg logs only complain about acpid not running, but the acpid service was disabled by default.
If I missed something let me know, i will happily provide any info that will help solving this.
EDIT:
There are some logs saying “ACPI undefined button LEFT” or something like that. I have determined that acpid service picks up arrow keys from my keyboard, and that is the reason, this does not happen acpid service is not running or when I’m not touching the keyboard. It is in the logs because i was switching between terminals with arrow keys, while writing this.
