Tried using 5.8 kernels in Manjaro…but problems every time…even if I can use 5.8, sometimes when rebooting it gets stuck with black screen with motherboard logo!
So I tried arch…with 5.8.10 and 5.8.11(updated yesterday)
Everything working perfectly…not a single problem
So why I was facing issues with Manjaro!!??
Is this a driver or software conflict or something else??!!
Well, Manjaro’s 5.8 kernel currently still sits at 5.8.6 for the Stable branch, whereas the Arch kernels you’ve tried are newer ─ Arch is much more bleeding edge than Manjaro Stable, and the closest thing we have to that is Manjaro Unstable.
The bottom line is that you may indeed have stumbled upon a bug in Manjaro’s current 5.8 kernel. But this should then be remedied when the next Stable update arrives, which won’t be long anymore. (Don’t ask when ─ it’ll be ready when it’s ready. )
I switched to manjaro testing today and installed 5.8.11
Bt with no luck!
Same issue
I really want to use manjaro with latest kernels (I understand I don’t need the latest version…lts is fine for me…but I want to use the latest kernels with Manjaro)
Well, without proper information regarding your hardware, I doubt whether there’s anything anyone can do. And if there’s a proprietary Nvidia driver involved, then all bets are off, because proprietary drivers cannot be debugged by the community.
If you really insist on running the latest kernels ─ although I cannot see why ─ and you want more help, then you’re going to have to give us more information, like for instance the output of the following command…
I’m afraid so. There have recently been some changes upstream ─ meaning with the development of the Linux kernel itself ─ with regard to how the Nvidia driver must interface with the kernel, and we’ve been seeing lots of stability problems since then.
Oh, I absolutely agree, and I too am not buying Nvidia anymore. My previous computer had an AMD GPU, and this one here has an Intel GPU. Works like a charm.
My advice to you would be to stick to the 5.4 LTS kernel with that machine. It’s not a very recent machine, and the 5.4 LTS kernel would be better suited for that hardware.
My own machine is more recent than yours, and I too am running the 5.4 LTS kernel. It’s rock-solid.
Well, the Manjaro kernels are compiled by the Manjaro developers and have some Manjaro-specific settings and patches. They are not the same as the Arch kernels.
I don’t think it’s the microcode, because Manjaro Unstable is on par with Arch Stable, and the intel-ucode package currently stands at the same version across all three Manjaro branches.
