I have set my language Regional Language settings to Deutsch/German as default, American English and finally francais.
Expected behavior:
- Show Everything in German
- Use English as fallback
- Use French if English is also not available / basically ignore this setting since English is always available
e.g.
Actual behavior:
- Most applications that are availible in German show up with german text
- most show up in english
- Some show up completely or partly in french even though they are availible in english
e.g. see Minecraft Flatpak:
some other examples I found, though most show up as expected:
This happens even if I set English as Default language,
and also if I set German>American English>British English>French, the only way to not show anything in french that is available in German or English is to completely remove french from the list.
This issue has persisted since a few updates or since I initially added french to the list, but since its not really a major issue I didn’t bother until now.
So is there any way to fix this without removing french as an additional language? Or is this a package issue since the English descriptions aren’t always marked as 100% correct so it fallback to the french version or so?
My system infos if it matters:
Summary
KDE Plasma Version: 5.24.6
KDE Frameworks Version: 5.96.0
Qt Version: 5.15.5
Kernel Version: 5.18.11-1-MANJARO (64-bit)
Graphics Platform: X11
CPU: AMD
GPU: AMD
Manjaro-Testing Branch
