I was working in `workspace 1` .
I opened `system settings` app from taskbar shortcut.
Now I switched to workspace 2.
And tried to open system settings by clicking its icon in taskbar. Instead of opening new window ofsystem settingsin same workspace, it just switched workspace toworkspace 1, and opens existingsystem settings window.
I want it to be open as new instance in current workspace.
And could not find any settings under system settings > workspace behavior
or system settings > window management
for desired behavior.
Other apps work fine in current workspace, but some apps can not be open as second instance. For example system settings app is always only one instance. Useless, you can not open new instance.
Chromium has some weird behavior.
When I move to new workspace and open chromium, it will open with latest profile.
But when I choose different profile, if that profile is open in other workspace then it switches to that workspace .
