Every time when I boot dolphin resets its settings which is annoying. How do I stop it from doing that. What I want to happen is every time I load dolphin I want it to go to my home directory, not the last directory I was in. I know I can set it in settings. Every time I keep going here and switching it out and clicking apply which is annoying.
Have you checked the settings in Manjaro Settings Manager > Start and shutdown > Desktop session
Set it to start with empty session
(Wording could be slightly different as the above has been translated from my language)
Thats manjaro settings manager. “MSM”
It is embedded in, but not the same as, “System Settings” from KDE/Plasma.
@Wollie wording was misleading as they guessed.
Here is my reference:
System Settings > Workspace > Startup and Shutdown > Desktop Session
Unfortunately, changing that in the settings did nothing. Dolphin still goes to the previous location I was at not the home directory. Also, some shortcut keys don’t get saved either, for example, ctrl + alt + T to open the terminal always gets reset and set to nothing which is annoying and some of my custom ones also get reset too.
