Yes I responded yes to everything using a
as a response. How should I proceed now? Thank you!
ok so hopefully your file system got fixed⌠so just type systemctl reboot
I tried systemctl reboot
but it says the command is not found. Should I proceed with exit
? Thank you!
If I was you, I start with a new fresh install.
Wouldnât it wipe out everything? I have data stored at the moment and they are really important. Thank you!
so type exit and hopfully you boot normally
Godsent! Thank you very much for your advise! Fixed it! Worked like a charm!
do you have a SDD or hdd?
I have HDD at the moment and hoping I can upgrade to SDD in the future. Thank you!
all right, but just to be safe back up your data âŚ
Yep gotta be safe than sorry. Iâll make this a lesson Thanks btw!
youre welcome
