hi
I have that old bug when the pc just reboot when idle for a bit of time
i have a R7 5700U
full updated
kernel 6 (stable)
kde plasma
model : tuxedo aura 15 gen 2 with latest bios
give the output of inxi -Fazy
and journalctl -b -p err|less
. did this happen with kernel 5.15? maybe try disabling baloo
inxi gives
Kernel: 6.0.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.0-x86_64
root=UUID=53f66e59-d4e2-4e7c-9522-5dd3d0bca096 rw rootflags=subvol=@ quiet
cryptdevice=UUID=53a7a72e-a7d3-4fd9-97b0-d836722d25d0:luks-53a7a72e-a7d3-4fd9-97b0-d836722d25d0
root=/dev/mapper/luks-53a7a72e-a7d3-4fd9-97b0-d836722d25d0
resume=/dev/mapper/luks-2e084c7f-4f64-465b-8168-5eab469badcd
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_wayland vt: 2
Type: Laptop System: TUXEDO product: TUXEDO Aura 15 Gen2 v: N/A
Mobo: NB01 model: NL5xNU serial: <superuser required> UEFI: INSYDE
v: 1.07.15RTR2 date: 09/29/2022
ID-1: BAT0 charge: 50.4 Wh (100.0%) condition: 50.4/48.3 Wh (104.4%)
volts: 17.2 min: 15.2 model: Notebook BAT type: Li-ion serial: <filter>
status: full
Use of uninitialized value $value[0] in string ne at /usr/bin/inxi line 9195.
Info: model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 503 high: 653 min/max: 400/4372 boost: enabled scaling:
driver: amd-pstate governor: ondemand cores: 1: 505 2: 440 3: 653 4: 512
5: 479 6: 479 7: 480 8: 479 bogomips: 28752
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Lucienne vendor: CLEVO/KAPOK driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: DP-1,DP-2 bus-ID: 05:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 42.0 C
Device-2: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 3-4:3
chip-ID: 5986:9102 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 22.2.4 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.48 6.0.11-1-MANJARO) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: CLEVO/KAPOK
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: CLEVO/KAPOK
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_sof_amd_renoir pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: CLEVO/KAPOK
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound API: ALSA v: k6.0.11-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.61 running: yes
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:2
Local Storage: total: 465.76 GiB used: 101.25 GiB (21.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 2B4QFXO7 temp: 32.9 C scheme: GPT
ID-1: / raw-size: 450.62 GiB size: 450.62 GiB (100.00%)
used: 101.25 GiB (22.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-53a7a72e-a7d3-4fd9-97b0-d836722d25d0
used: 752 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 450.62 GiB size: 450.62 GiB (100.00%)
ID-4: /var/log raw-size: 450.62 GiB size: 450.62 GiB (100.00%)
ID-1: swap-1 type: partition size: 14.84 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-2e084c7f-4f64-465b-8168-5eab469badcd
System Temperatures: cpu: 49.2 C mobo: N/A gpu: amdgpu temp: 43.0 C
Processes: 387 Uptime: 1h 0m wakeups: 558 Memory: 13.49 GiB
used: 3.08 GiB (22.8%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1639
pm: pacman pkgs: 1622 libs: 473 tools: pamac pm: flatpak pkgs: 17 Shell: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
journal :
déc. 13 21:07:17 richou-tuxedoaura15gen2 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPC0.EC0], AE_NOT_FOUND (20220331/dswload2-162)
déc. 13 21:07:17 richou-tuxedoaura15gen2 kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20220331/psobject-220)
déc. 13 21:07:17 richou-tuxedoaura15gen2 kernel: ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_SB_.PCI0.LPC0.EC0_ (20220331/dspkginit-438)
déc. 13 21:07:17 richou-tuxedoaura15gen2 kernel: tuxedo_keyboard: no active interface while read addr 0x0740
déc. 13 21:07:17 richou-tuxedoaura15gen2 kernel: ryzen_smu: CPUID: Unknown Zen/Zen+/Zen2 processor model: 0x68 (CPUID: 0x00860F81)
déc. 13 21:07:17 richou-tuxedoaura15gen2 kernel: ryzen_smu: Failed to initialize the SMU for use
déc. 13 21:07:18 richou-tuxedoaura15gen2 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPC0.EC0.OKEC], AE_NOT_FOUND (20220331/psargs-330)
déc. 13 21:07:18 richou-tuxedoaura15gen2 kernel: ACPI Error: Aborting method \_SB.UBTC.M318 due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
déc. 13 21:07:18 richou-tuxedoaura15gen2 kernel: ACPI Error: Aborting method \_SB.UBTC._DSM due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
déc. 13 21:07:18 richou-tuxedoaura15gen2 kernel: ucsi_acpi USBC000:00: ucsi_acpi_dsm: failed to evaluate _DSM 2
déc. 13 21:07:19 richou-tuxedoaura15gen2 bluetoothd[602]: src/plugin.c:plugin_init() Failed to init vcp plugin
déc. 13 21:07:19 richou-tuxedoaura15gen2 bluetoothd[602]: src/plugin.c:plugin_init() Failed to init mcp plugin
déc. 13 21:07:19 richou-tuxedoaura15gen2 bluetoothd[602]: src/plugin.c:plugin_init() Failed to init bap plugin
déc. 13 21:07:20 richou-tuxedoaura15gen2 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
déc. 13 21:07:23 richou-tuxedoaura15gen2 systemd[748]: Failed to start Update XDG user dir configuration.
déc. 13 21:07:31 richou-tuxedoaura15gen2 kwin_wayland[892]: kwin_wayland_drm: Atomic modeset commit failed! Argument invalide
déc. 13 21:07:40 richou-tuxedoaura15gen2 bluetoothd[602]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
when i installed manjaro i directly switched to 6 , do you think in 5.15 it isnt gonna happend anymore ?
i d’ont think it is baloo because i got this too on manjaro gnome and even more and agressive , like i was typing text on libreoffice , i open brave and it reboot, it looks common on old ryzen
i read that by putting
idle=nomwait acpi_osi='Windows 2019'
as boot param it helps
