Still booting to blank screen
System:    Kernel: 5.12.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: GNOME 3.38.4
Machine:   Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05 serial: <filter>
           Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <filter>
           UEFI-[Legacy]: LENOVO v: EUCN19WW date: 05/12/2020
Battery:   ID-1: BAT0 charge: 50.0 Wh (95.1%) condition: 52.6/60.0 Wh (87.7%) volts: 16.5
           min: 15.4 model: Celxpert L19C4PC0 status: Discharging
CPU:       Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
           arch: Zen 2 rev: 1 cache: L2: 4 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 92666
           Speed: 1397 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz): 1: 1397
           2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1428 10: 1397 11: 1293
           12: 1299 13: 1372 14: 1397 15: 1399 16: 1397
Graphics:  Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo driver: nvidia
           v: 465.31 bus-ID: 01:00.0
           Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 05:00.0
           Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:2
           Display: x11 server: X.org 1.20.11 driver: loaded: amdgpu,nvidia
           OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.12.8-1-MANJARO LLVM 11.1.0)
           v: 4.6 Mesa 21.1.2 direct render: Yes
Audio:     Device-1: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo driver: N/A
           bus-ID: 05:00.5
           Device-2: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           bus-ID: 05:00.6
           Sound Server-1: ALSA v: k5.12.8-1-MANJARO running: yes
           Sound Server-4: PipeWire v: 0.3.28 running: no
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
           driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0
           Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000 bus-ID: 04:00.0
           IF: wlp4s0 state: down mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:3
           Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Drives:    Local Storage: total: 476.94 GiB used: 298.21 GiB (62.5%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB
Partition: ID-1: / size: 459.79 GiB used: 298.21 GiB (64.9%) fs: ext4 dev: /dev/nvme0n1p1
Swap:      ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p2
Sensors:   System Temperatures: cpu: 36.8 C mobo: 0 C gpu: amdgpu temp: 35.0 C
Info:      Processes: 379 Uptime: 2m Memory: 15.08 GiB used: 3.15 GiB (20.9%) Init: systemd
           Compilers: gcc: 11.1.0 Packages: 1480 Client: shell wrapper v: 5.1.8-release
           inxi: 3.3.04
sudo mhwd-kernel -i linux510
mhwd -li
cat /var/log/Xorg.0.log
           video-linux            2018.05.04                true            PCI
video-hybrid-amd-nvidia-prime            2020.11.30               false            PCI
[     4.222] (--) Log file renamed from "/var/log/Xorg.pid-847.log" to "/var/log/Xorg.0.log"
[     4.223] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[     4.223]
X.Org X Server 1.20.10
[     4.223] Build Operating System: Linux Manjaro Linux
[     4.223] Current Operating System: Linux magicpotion 5.11.10-1-MANJARO #1 SMP PREEMPT Thu Mar 25 17:14:55 UTC 2021 x86_64
[     4.223] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=260c331a-ce37-421e-b75f-696a4df21616 rw nowatchdog zswap.enabled=0 mitigations=off quiet resume=UUID=8b3f4d8e-89ca-47ef-800c-08fce76aa125 udev.log_priority=3 sysrq_always_enabled=1
[     4.223] Build Date: 16 December 2020  10:33:32PM
[     4.223]
[     4.223] Current version of pixman: 0.40.0
[     4.223] 	Before reporting problems, check http://wiki.x.org
[     4.223] Markers: (--) probed, (**) from config file, (==) default setting,
[     4.224] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Apr 18 20:35:35 2021
[     4.225] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     4.225] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     4.226] (==) ServerLayout "layout"
[     4.226] (**) |-->Screen "amd" (0)
[     4.226] (**) |   |-->Monitor "<default monitor>"
[     4.226] (**) |   |-->Device "amd"
[     4.226] (**) |   |-->GPUDevice "nvidia"
[     4.226] (==) No monitor specified for screen "amd".
[     4.226] (==) Automatically adding devices
[     4.226] (==) Automatically enabling devices
[     4.226] (==) Automatically adding GPU devices
[     4.226] (==) Automatically binding GPU devices
[     4.226] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     4.228] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     4.228] 	Entry deleted from font path.
[     4.228] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     4.228] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     4.228] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     4.228] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[     4.228] (==) ModulePath set to "/usr/lib/xorg/modules"
[     4.228] (II) The server relies on udev to provide the list of input devices.
[     4.228] (II) Module ABI versions:
[     4.228] 	X.Org ANSI C Emulation: 0.4
[     4.228] 	X.Org Video Driver: 24.1
[     4.228] 	X.Org XInput driver : 24.1
[     4.228] 	X.Org Server Extension : 10.0
[     4.228] (++) using VT number 1
[     4.230] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[     4.231] (II) xfree86: Adding drm device (/dev/dri/card1)
[     4.231] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 11 paused 0
[     4.232] (II) xfree86: Adding drm device (/dev/dri/card0)
[     4.232] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[     4.234] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     4.234] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     4.584] (--) PCI: (1@0:0:0) 10de:1f95:17aa:3a3e rev 161, Mem @ 0xc1000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
[     4.584] (--) PCI:*(5@0:0:0) 1002:1636:17aa:3a3e rev 198, Mem @ 0xb0000000/268435456, 0xc0000000/2097152, 0xc2500000/524288, I/O @ 0x00001000/256, BIOS @ 0x????????/131072
[     4.584] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     4.584] (II) LoadModule: "glx"
[     4.587] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     4.591] (II) Module glx: vendor="X.Org Foundation"
[     4.591] 	compiled for 1.20.10, module version = 1.0.0
[     4.591] 	ABI class: X.Org Server Extension, version 10.0
[     4.591] (II) LoadModule: "amdgpu"
[     4.592] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[     4.594] (II) Module amdgpu: vendor="X.Org Foundation"
[     4.594] 	compiled for 1.20.8, module version = 19.1.0
[     4.594] 	Module class: X.Org Video Driver
[     4.594] 	ABI class: X.Org Video Driver, version 24.1
[     4.594] (II) LoadModule: "nvidia"
[     4.595] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[     4.597] (II) Module nvidia: vendor="NVIDIA Corporation"
[     4.598] 	compiled for 1.6.99.901, module version = 1.0.0
[     4.598] 	Module class: X.Org Video Driver
[     4.598] (II) AMDGPU: Driver for AMD Radeon:
	All GPUs supported by the amdgpu kernel driver
[     4.598] (II) NVIDIA dlloader X Driver  460.67  Thu Mar 11 00:09:07 UTC 2021
[     4.598] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[     4.599] (II) systemd-logind: releasing fd for 226:1
[     4.600] (II) Loading sub module "fb"
[     4.600] (II) LoadModule: "fb"
[     4.601] (II) Loading /usr/lib/xorg/modules/libfb.so
[     4.601] (II) Module fb: vendor="X.Org Foundation"
[     4.601] 	compiled for 1.20.10, module version = 1.0.0
[     4.601] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     4.601] (II) Loading sub module "wfb"
[     4.601] (II) LoadModule: "wfb"
[     4.601] (II) Loading /usr/lib/xorg/modules/libwfb.so
[     4.602] (II) Module wfb: vendor="X.Org Foundation"
[     4.602] 	compiled for 1.20.10, module version = 1.0.0
[     4.602] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     4.602] (II) Loading sub module "ramdac"
[     4.602] (II) LoadModule: "ramdac"
[     4.602] (II) Module "ramdac" already built-in
[     4.640] (II) AMDGPU(0): Creating default Display subsection in Screen section
	"amd" for depth/fbbpp 24/32
[     4.640] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[     4.640] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[     4.640] (==) AMDGPU(0): Default visual is TrueColor
[     4.640] (==) AMDGPU(0): RGB weight 888
[     4.640] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[     4.640] (--) AMDGPU(0): Chipset: "Unknown AMD Radeon GPU" (ChipID = 0x1636)
[     4.640] (II) Loading sub module "fb"
[     4.640] (II) LoadModule: "fb"
[     4.640] (II) Loading /usr/lib/xorg/modules/libfb.so
[     4.640] (II) Module fb: vendor="X.Org Foundation"
[     4.640] 	compiled for 1.20.10, module version = 1.0.0
[     4.640] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     4.641] (II) Loading sub module "dri2"
[     4.641] (II) LoadModule: "dri2"
[     4.641] (II) Module "dri2" already built-in
[     4.759] (II) Loading sub module "glamoregl"
[     4.759] (II) LoadModule: "glamoregl"
[     4.759] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[     4.763] (II) Module glamoregl: vendor="X.Org Foundation"
[     4.763] 	compiled for 1.20.10, module version = 1.0.1
[     4.763] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     4.789] (II) AMDGPU(0): glamor X acceleration enabled on AMD RENOIR (DRM 3.40.0, 5.11.10-1-MANJARO, LLVM 11.1.0)
[     4.789] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[     4.789] (==) AMDGPU(0): TearFree property default: auto
[     4.789] (==) AMDGPU(0): VariableRefresh: disabled
[     4.789] (II) AMDGPU(0): KMS Pageflipping: enabled
[     4.790] (II) AMDGPU(0): Output eDP has no monitor section
[     4.795] (II) AMDGPU(0): EDID for output eDP
[     4.795] (II) AMDGPU(0): Manufacturer: AUO  Model: d1ed  Serial#: 0
[     4.795] (II) AMDGPU(0): Year: 2019  Week: 34
[     4.795] (II) AMDGPU(0): EDID Version: 1.4
[     4.795] (II) AMDGPU(0): Digital Display Input
[     4.795] (II) AMDGPU(0): 8 bits per channel
[     4.795] (II) AMDGPU(0): Digital interface is DisplayPort
[     4.795] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 34  vert.: 19
[     4.795] (II) AMDGPU(0): Gamma: 2.20
[     4.795] (II) AMDGPU(0): No DPMS capabilities specified
[     4.795] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4
[     4.795] (II) AMDGPU(0): First detailed timing is preferred mode
[     4.795] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[     4.795] (II) AMDGPU(0): Display is continuous-frequency
[     4.795] (II) AMDGPU(0): redX: 0.560 redY: 0.340   greenX: 0.350 greenY: 0.570
[     4.795] (II) AMDGPU(0): blueX: 0.160 blueY: 0.120   whiteX: 0.313 whiteY: 0.329
[     4.795] (II) AMDGPU(0): Manufacturer's mask: 0
[     4.795] (II) AMDGPU(0): Supported detailed timing:
[     4.795] (II) AMDGPU(0): clock: 285.0 MHz   Image Size:  344 x 193 mm
[     4.795] (II) AMDGPU(0): h_active: 1920  h_sync: 2028  h_sync_end 2076 h_blank_end 2076 h_border: 0
[     4.795] (II) AMDGPU(0): v_active: 1080  v_sync: 1090  v_sync_end 1100 v_blanking: 1142 v_border: 0
[     4.795] (II) AMDGPU(0): Unknown vendor-specific block f
[     4.795] (II) AMDGPU(0): Ranges: V min: 60 V max: 120 Hz, H min: 138 H max: 138 kHz, PixClock max 295 MHz
[     4.795] (II) AMDGPU(0):  B156HAN13.1
[     4.795] (II) AMDGPU(0): EDID (in hex):
[     4.795] (II) AMDGPU(0): 	00ffffffffffff0006afedd100000000
[     4.795] (II) AMDGPU(0): 	221d0104a52213780348358f57599229
[     4.795] (II) AMDGPU(0): 	1e505400000001010101010101010101
[     4.795] (II) AMDGPU(0): 	010101010101546f809c70383e406c30
[     4.795] (II) AMDGPU(0): 	aa0058c1100000180000000f00000000
[     4.795] (II) AMDGPU(0): 	00000000000000000020000000fd003c
[     4.795] (II) AMDGPU(0): 	788a8a1d010a202020202020000000fe
[     4.795] (II) AMDGPU(0): 	004231353648414e31332e31200a00a9
[     4.795] (II) AMDGPU(0): Printing probed modes for output eDP
[     4.795] (II) AMDGPU(0): Modeline "1920x1080"x120.2  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[     4.795] (II) AMDGPU(0): Modeline "1680x1050"x120.2  285.00  1680 2028 2076 2076  1050 1090 1100 1142 -hsync -vsync (137.3 kHz e)
[     4.795] (II) AMDGPU(0): Modeline "1280x1024"x120.2  285.00  1280 2028 2076 2076  1024 1090 1100 1142 -hsync -vsync (137.3 kHz e)
[     4.795] (II) AMDGPU(0): Modeline "1440x900"x120.2  285.00  1440 2028 2076 2076  900 1090 1100 1142 -hsync -vsync (137.3 kHz e)
[     4.795] (II) AMDGPU(0): Modeline "1280x800"x120.2  285.00  1280 2028 2076 2076  800 1090 1100 1142 -hsync -vsync (137.3 kHz e)
[     4.795] (II) AMDGPU(0): Modeline "1280x720"x120.2  285.00  1280 2028 2076 2076  720 1090 1100 1142 -hsync -vsync (137.3 kHz e)
[     4.795] (II) AMDGPU(0): Modeline "1024x768"x120.2  285.00  1024 2028 2076 2076  768 1090 1100 1142 -hsync -vsync (137.3 kHz e)
[     4.795] (II) AMDGPU(0): Modeline "800x600"x120.2  285.00  800 2028 2076 2076  600 1090 1100 1142 -hsync -vsync (137.3 kHz e)
[     4.795] (II) AMDGPU(0): Modeline "640x480"x120.2  285.00  640 2028 2076 2076  480 1090 1100 1142 -hsync -vsync (137.3 kHz e)
[     4.795] (II) AMDGPU(0): Output eDP connected
[     4.795] (II) AMDGPU(0): Using exact sizes for initial modes
[     4.795] (II) AMDGPU(0): Output eDP using initial mode 1920x1080 +0+0
[     4.795] (II) AMDGPU(0): mem size init: gart size :bf69f000 vram size: s:1deed000 visible:1deed000
[     4.795] (==) AMDGPU(0): DPI set to (96, 96)
[     4.795] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[     4.795] (II) Loading sub module "ramdac"
[     4.795] (II) LoadModule: "ramdac"
[     4.795] (II) Module "ramdac" already built-in
[     4.795] (==) NVIDIA(G0): Depth 24, (==) framebuffer bpp 32
[     4.795] (==) NVIDIA(G0): RGB weight 888
[     4.795] (==) NVIDIA(G0): Default visual is TrueColor
[     4.795] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[     4.795] (**) Option "AllowNVIDIAGpuScreens"
[     4.795] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[     4.795] (**) NVIDIA(G0): Option "AllowEmptyInitialConfiguration"
[     4.795] (**) NVIDIA(G0): Enabling 2D acceleration
[     4.796] (II) Loading sub module "glxserver_nvidia"
[     4.796] (II) LoadModule: "glxserver_nvidia"
[     4.796] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[     4.811] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[     4.811] 	compiled for 1.6.99.901, module version = 1.0.0
[     4.811] 	Module class: X.Org Server Extension
[     4.811] (II) NVIDIA GLX Module  460.67  Thu Mar 11 00:06:44 UTC 2021
[     4.811] (II) NVIDIA: The X server supports PRIME Render Offload.
[     6.088] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[     6.088] (--) NVIDIA(0):     DFP-0
[     6.088] (--) NVIDIA(0):     DFP-1
[     6.088] (--) NVIDIA(0):     DFP-2
[     6.088] (--) NVIDIA(0):     DFP-3
[     6.089] (II) NVIDIA(G0): NVIDIA GPU GeForce GTX 1650 Ti (TU117-A) at PCI:1:0:0 (GPU-0)
[     6.089] (--) NVIDIA(G0): Memory: 4194304 kBytes
[     6.089] (--) NVIDIA(G0): VideoBIOS: 90.17.4e.00.1c
[     6.089] (II) NVIDIA(G0): Detected PCI Express Link width: 16X
[     6.089] (--) NVIDIA(GPU-0): DFP-0: disconnected
[     6.089] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[     6.089] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[     6.089] (--) NVIDIA(GPU-0): DFP-1: disconnected
[     6.089] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[     6.089] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[     6.089] (--) NVIDIA(GPU-0): DFP-2: disconnected
[     6.089] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[     6.089] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[     6.089] (--) NVIDIA(GPU-0): DFP-3: disconnected
[     6.089] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[     6.089] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
[     6.090] (II) NVIDIA(G0): Validated MetaModes:
[     6.090] (II) NVIDIA(G0):     "NULL"
[     6.090] (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
[     6.090] (WW) NVIDIA(G0): Unable to get display device for DPI computation.
[     6.090] (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
[     6.090] (II) AMDGPU(0): [DRI2] Setup complete
[     6.090] (II) AMDGPU(0): [DRI2]   DRI driver: radeonsi
[     6.090] (II) AMDGPU(0): [DRI2]   VDPAU driver: radeonsi
[     6.141] (II) AMDGPU(0): Front buffer pitch: 7680 bytes
[     6.142] (II) AMDGPU(0): SYNC extension fences enabled
[     6.142] (II) AMDGPU(0): Present extension enabled
[     6.142] (==) AMDGPU(0): DRI3 enabled
[     6.142] (==) AMDGPU(0): Backing store enabled
[     6.142] (II) AMDGPU(0): Direct rendering enabled
[     6.163] (II) AMDGPU(0): Use GLAMOR acceleration.
[     6.163] (II) AMDGPU(0): Acceleration enabled
[     6.163] (==) AMDGPU(0): DPMS enabled
[     6.163] (==) AMDGPU(0): Silken mouse disabled
[     6.163] (II) AMDGPU(0): Set up textured video (glamor)
[     6.167] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[     6.167] (II) NVIDIA:     access.
[     6.175] (II) NVIDIA(G0): ACPI: failed to connect to the ACPI event daemon; the daemon
[     6.175] (II) NVIDIA(G0):     may not be running or the "AcpidSocketPath" X
[     6.175] (II) NVIDIA(G0):     configuration option may not be set correctly.  When the
[     6.175] (II) NVIDIA(G0):     ACPI event daemon is available, the NVIDIA X driver will
[     6.175] (II) NVIDIA(G0):     try to use it to receive ACPI event notifications.  For
[     6.175] (II) NVIDIA(G0):     details, please see the "ConnectToAcpid" and
[     6.175] (II) NVIDIA(G0):     "AcpidSocketPath" X configuration options in Appendix B: X
[     6.175] (II) NVIDIA(G0):     Config Options in the README.
[     6.194] (II) NVIDIA(G0): Setting mode "NULL"
[     6.206] (==) NVIDIA(G0): Disabling shared memory pixmaps
[     6.206] (==) NVIDIA(G0): Backing store enabled
[     6.206] (==) NVIDIA(G0): Silken mouse disabled
[     6.206] (==) NVIDIA(G0): DPMS enabled
[     6.207] (II) Loading sub module "dri2"
[     6.207] (II) LoadModule: "dri2"
[     6.207] (II) Module "dri2" already built-in
[     6.207] (II) NVIDIA(G0): [DRI2] Setup complete
[     6.207] (II) NVIDIA(G0): [DRI2]   VDPAU driver: nvidia
[     6.207] (II) Initializing extension Generic Event Extension
[     6.207] (II) Initializing extension SHAPE
[     6.207] (II) Initializing extension MIT-SHM
[     6.207] (II) Initializing extension XInputExtension
[     6.207] (II) Initializing extension XTEST
[     6.207] (II) Initializing extension BIG-REQUESTS
[     6.207] (II) Initializing extension SYNC
[     6.207] (II) Initializing extension XKEYBOARD
[     6.207] (II) Initializing extension XC-MISC
[     6.207] (II) Initializing extension SECURITY
[     6.207] (II) Initializing extension XFIXES
[     6.207] (II) Initializing extension RENDER
[     6.207] (II) Initializing extension RANDR
[     6.207] (II) Initializing extension COMPOSITE
[     6.207] (II) Initializing extension DAMAGE
[     6.207] (II) Initializing extension MIT-SCREEN-SAVER
[     6.207] (II) Initializing extension DOUBLE-BUFFER
[     6.207] (II) Initializing extension RECORD
[     6.207] (II) Initializing extension DPMS
[     6.207] (II) Initializing extension Present
[     6.207] (II) Initializing extension DRI3
[     6.207] (II) Initializing extension X-Resource
[     6.207] (II) Initializing extension XVideo
[     6.207] (II) Initializing extension XVideo-MotionCompensation
[     6.207] (II) Initializing extension GLX
[     6.208] (II) Initializing extension GLX
[     6.208] (II) Indirect GLX disabled.
[     6.215] (II) AIGLX: Loaded and initialized radeonsi
[     6.215] (II) GLX: Initialized DRI2 GL provider for screen 0
[     6.215] (II) Initializing extension XFree86-VidModeExtension
[     6.215] (II) Initializing extension XFree86-DGA
[     6.215] (II) Initializing extension XFree86-DRI
[     6.215] (II) Initializing extension DRI2
[     6.215] (II) Initializing extension NV-GLX
[     6.215] (II) Initializing extension NV-CONTROL
[     6.218] (II) AMDGPU(0): Setting screen physical size to 508 x 285
[     6.235] (EE) AMDGPU(0): Failed to make import prime FD as pixmap: 22
[     6.279] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[     6.279] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     6.279] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     6.279] (**) Power Button: Applying InputClass "system-keyboard"
[     6.279] (II) LoadModule: "libinput"
[     6.279] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     6.283] (II) Module libinput: vendor="X.Org Foundation"
[     6.283] 	compiled for 1.20.8, module version = 0.30.0
[     6.283] 	Module class: X.Org XInput Driver
[     6.283] 	ABI class: X.Org XInput driver, version 24.1
[     6.283] (II) Using input driver 'libinput' for 'Power Button'
[     6.284] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 37 paused 0
[     6.284] (**) Power Button: always reports core events
[     6.284] (**) Option "Device" "/dev/input/event2"
[     6.284] (**) Option "_source" "server/udev"
[     6.288] (II) event2  - Power Button: is tagged by udev as: Keyboard
[     6.288] (II) event2  - Power Button: device is a keyboard
[     6.288] (II) event2  - Power Button: device removed
[     6.288] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[     6.288] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     6.288] (**) Option "xkb_model" "pc105"
[     6.288] (**) Option "xkb_layout" "us"
[     6.289] (II) event2  - Power Button: device is a keyboard
[     6.289] (II) config/udev: Adding input device Video Bus (/dev/input/event4)
[     6.289] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[     6.289] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     6.289] (**) Video Bus: Applying InputClass "system-keyboard"
[     6.289] (II) Using input driver 'libinput' for 'Video Bus'
[     6.290] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 40 paused 0
[     6.290] (**) Video Bus: always reports core events
[     6.290] (**) Option "Device" "/dev/input/event4"
[     6.290] (**) Option "_source" "server/udev"
[     6.290] (II) event4  - Video Bus: is tagged by udev as: Keyboard
[     6.290] (II) event4  - Video Bus: device is a keyboard
[     6.290] (II) event4  - Video Bus: device removed
[     6.290] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input4/event4"
[     6.290] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[     6.290] (**) Option "xkb_model" "pc105"
[     6.290] (**) Option "xkb_layout" "us"
[     6.291] (II) event4  - Video Bus: is tagged by udev as: Keyboard
[     6.291] (II) event4  - Video Bus: device is a keyboard
[     6.291] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[     6.291] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[     6.291] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     6.291] (**) Video Bus: Applying InputClass "system-keyboard"
[     6.291] (II) Using input driver 'libinput' for 'Video Bus'
[     6.292] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 41 paused 0
[     6.292] (**) Video Bus: always reports core events
[     6.292] (**) Option "Device" "/dev/input/event5"
[     6.292] (**) Option "_source" "server/udev"
[     6.292] (II) event5  - Video Bus: is tagged by udev as: Keyboard
[     6.292] (II) event5  - Video Bus: device is a keyboard
[     6.293] (II) event5  - Video Bus: device removed
[     6.293] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0e/LNXVIDEO:01/input/input5/event5"
[     6.293] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[     6.293] (**) Option "xkb_model" "pc105"
[     6.293] (**) Option "xkb_layout" "us"
[     6.293] (II) event5  - Video Bus: is tagged by udev as: Keyboard
[     6.293] (II) event5  - Video Bus: device is a keyboard
[     6.294] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     6.294] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     6.294] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     6.294] (**) Power Button: Applying InputClass "system-keyboard"
[     6.294] (II) Using input driver 'libinput' for 'Power Button'
[     6.294] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 42 paused 0
[     6.294] (**) Power Button: always reports core events
[     6.294] (**) Option "Device" "/dev/input/event1"
[     6.294] (**) Option "_source" "server/udev"
[     6.295] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     6.295] (II) event1  - Power Button: device is a keyboard
[     6.295] (II) event1  - Power Button: device removed
[     6.295] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[     6.295] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[     6.295] (**) Option "xkb_model" "pc105"
[     6.295] (**) Option "xkb_layout" "us"
[     6.296] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     6.296] (II) event1  - Power Button: device is a keyboard
[     6.296] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[     6.296] (II) No input driver specified, ignoring this device.
[     6.296] (II) This device may have been added with another device file.
[     6.296] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event13)
[     6.296] (**) Integrated Camera: Integrated C: Applying InputClass "evdev keyboard catchall"
[     6.296] (**) Integrated Camera: Integrated C: Applying InputClass "libinput keyboard catchall"
[     6.296] (**) Integrated Camera: Integrated C: Applying InputClass "system-keyboard"
[     6.296] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated C'
[     6.297] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 43 paused 0
[     6.297] (**) Integrated Camera: Integrated C: always reports core events
[     6.297] (**) Option "Device" "/dev/input/event13"
[     6.297] (**) Option "_source" "server/udev"
[     6.298] (II) event13 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[     6.298] (II) event13 - Integrated Camera: Integrated C: device is a keyboard
[     6.298] (II) event13 - Integrated Camera: Integrated C: device removed
[     6.298] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-3/1-3:1.0/input/input15/event13"
[     6.298] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated C" (type: KEYBOARD, id 10)
[     6.298] (**) Option "xkb_model" "pc105"
[     6.298] (**) Option "xkb_layout" "us"
[     6.299] (II) event13 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[     6.299] (II) event13 - Integrated Camera: Integrated C: device is a keyboard
[     6.300] (II) config/udev: Adding input device Lenovo Lenovo Legion M300 RGB Gaming Mouse (/dev/input/mouse2)
[     6.300] (II) No input driver specified, ignoring this device.
[     6.300] (II) This device may have been added with another device file.
[     6.300] (II) config/udev: Adding input device USB Keyboard (/dev/input/event20)
[     6.300] (**) USB Keyboard: Applying InputClass "evdev keyboard catchall"
[     6.300] (**) USB Keyboard: Applying InputClass "libinput keyboard catchall"
[     6.300] (**) USB Keyboard: Applying InputClass "system-keyboard"
[     6.300] (II) Using input driver 'libinput' for 'USB Keyboard'
[     6.301] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 44 paused 0
[     6.301] (**) USB Keyboard: always reports core events
[     6.301] (**) Option "Device" "/dev/input/event20"
[     6.301] (**) Option "_source" "server/udev"
[     6.302] (II) event20 - USB Keyboard: is tagged by udev as: Keyboard
[     6.302] (II) event20 - USB Keyboard: device is a keyboard
[     6.303] (II) event20 - USB Keyboard: device removed
[     6.303] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3:1.0/0003:0C45:7603.0006/input/input22/event20"
[     6.303] (II) XINPUT: Adding extended input device "USB Keyboard" (type: KEYBOARD, id 11)
[     6.303] (**) Option "xkb_model" "pc105"
[     6.303] (**) Option "xkb_layout" "us"
[     6.304] (II) event20 - USB Keyboard: is tagged by udev as: Keyboard
[     6.304] (II) event20 - USB Keyboard: device is a keyboard
[     6.304] (II) config/udev: Adding input device USB Keyboard Consumer Control (/dev/input/event21)
[     6.304] (**) USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[     6.304] (**) USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[     6.304] (**) USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[     6.304] (II) Using input driver 'libinput' for 'USB Keyboard Consumer Control'
[     6.305] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 45 paused 0
[     6.305] (**) USB Keyboard Consumer Control: always reports core events
[     6.305] (**) Option "Device" "/dev/input/event21"
[     6.305] (**) Option "_source" "server/udev"
[     6.306] (II) event21 - USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[     6.306] (II) event21 - USB Keyboard Consumer Control: device is a keyboard
[     6.306] (II) event21 - USB Keyboard Consumer Control: device removed
[     6.306] (II) libinput: USB Keyboard Consumer Control: needs a virtual subdevice
[     6.306] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3:1.1/0003:0C45:7603.0007/input/input23/event21"
[     6.306] (II) XINPUT: Adding extended input device "USB Keyboard Consumer Control" (type: MOUSE, id 12)
[     6.306] (**) Option "AccelerationScheme" "none"
[     6.306] (**) USB Keyboard Consumer Control: (accel) selected scheme none/0
[     6.306] (**) USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[     6.306] (**) USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[     6.307] (II) event21 - USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[     6.307] (II) event21 - USB Keyboard Consumer Control: device is a keyboard
[     6.308] (II) config/udev: Adding input device USB Keyboard System Control (/dev/input/event22)
[     6.308] (**) USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[     6.308] (**) USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[     6.308] (**) USB Keyboard System Control: Applying InputClass "system-keyboard"
[     6.308] (II) Using input driver 'libinput' for 'USB Keyboard System Control'
[     6.308] (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 46 paused 0
[     6.309] (**) USB Keyboard System Control: always reports core events
[     6.309] (**) Option "Device" "/dev/input/event22"
[     6.309] (**) Option "_source" "server/udev"
[     6.310] (II) event22 - USB Keyboard System Control: is tagged by udev as: Keyboard
[     6.310] (II) event22 - USB Keyboard System Control: device is a keyboard
[     6.310] (II) event22 - USB Keyboard System Control: device removed
[     6.310] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3:1.1/0003:0C45:7603.0007/input/input24/event22"
[     6.310] (II) XINPUT: Adding extended input device "USB Keyboard System Control" (type: KEYBOARD, id 13)
[     6.310] (**) Option "xkb_model" "pc105"
[     6.310] (**) Option "xkb_layout" "us"
[     6.311] (II) event22 - USB Keyboard System Control: is tagged by udev as: Keyboard
[     6.311] (II) event22 - USB Keyboard System Control: device is a keyboard
[     6.312] (II) config/udev: Adding input device USB Keyboard (/dev/input/event23)
[     6.312] (**) USB Keyboard: Applying InputClass "evdev keyboard catchall"
[     6.312] (**) USB Keyboard: Applying InputClass "libinput keyboard catchall"
[     6.312] (**) USB Keyboard: Applying InputClass "system-keyboard"
[     6.312] (II) Using input driver 'libinput' for 'USB Keyboard'
[     6.312] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 47 paused 0
[     6.312] (**) USB Keyboard: always reports core events
[     6.312] (**) Option "Device" "/dev/input/event23"
[     6.312] (**) Option "_source" "server/udev"
[     6.314] (II) event23 - USB Keyboard: is tagged by udev as: Keyboard
[     6.314] (II) event23 - USB Keyboard: device is a keyboard
[     6.314] (II) event23 - USB Keyboard: device removed
[     6.314] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3:1.1/0003:0C45:7603.0007/input/input26/event23"
[     6.314] (II) XINPUT: Adding extended input device "USB Keyboard" (type: KEYBOARD, id 14)
[     6.314] (**) Option "xkb_model" "pc105"
[     6.314] (**) Option "xkb_layout" "us"
[     6.315] (II) event23 - USB Keyboard: is tagged by udev as: Keyboard
[     6.315] (II) event23 - USB Keyboard: device is a keyboard
[     6.316] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Keyboard (/dev/input/event14)
[     6.316] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "evdev keyboard catchall"
[     6.316] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "libinput keyboard catchall"
[     6.316] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "system-keyboard"
[     6.316] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Keyboard'
[     6.317] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 48 paused 0
[     6.317] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: always reports core events
[     6.317] (**) Option "Device" "/dev/input/event14"
[     6.317] (**) Option "_source" "server/udev"
[     6.318] (II) event14 - ITE Tech. Inc. ITE Device(8910) Keyboard: is tagged by udev as: Keyboard
[     6.318] (II) event14 - ITE Tech. Inc. ITE Device(8910) Keyboard: device is a keyboard
[     6.318] (II) event14 - ITE Tech. Inc. ITE Device(8910) Keyboard: device removed
[     6.318] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0002/input/input16/event14"
[     6.318] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Keyboard" (type: KEYBOARD, id 15)
[     6.318] (**) Option "xkb_model" "pc105"
[     6.318] (**) Option "xkb_layout" "us"
[     6.319] (II) event14 - ITE Tech. Inc. ITE Device(8910) Keyboard: is tagged by udev as: Keyboard
[     6.319] (II) event14 - ITE Tech. Inc. ITE Device(8910) Keyboard: device is a keyboard
[     6.320] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Consumer Control (/dev/input/event15)
[     6.320] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "evdev keyboard catchall"
[     6.320] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "libinput keyboard catchall"
[     6.320] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "system-keyboard"
[     6.320] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Consumer Control'
[     6.321] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 49 paused 0
[     6.321] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: always reports core events
[     6.321] (**) Option "Device" "/dev/input/event15"
[     6.321] (**) Option "_source" "server/udev"
[     6.322] (II) event15 - ITE Tech. Inc. ITE Device(8910) Consumer Control: is tagged by udev as: Keyboard
[     6.322] (II) event15 - ITE Tech. Inc. ITE Device(8910) Consumer Control: device is a keyboard
[     6.322] (II) event15 - ITE Tech. Inc. ITE Device(8910) Consumer Control: device removed
[     6.322] (II) libinput: ITE Tech. Inc. ITE Device(8910) Consumer Control: needs a virtual subdevice
[     6.322] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0002/input/input17/event15"
[     6.322] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Consumer Control" (type: MOUSE, id 16)
[     6.322] (**) Option "AccelerationScheme" "none"
[     6.322] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: (accel) selected scheme none/0
[     6.322] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: (accel) acceleration factor: 2.000
[     6.322] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: (accel) acceleration threshold: 4
[     6.323] (II) event15 - ITE Tech. Inc. ITE Device(8910) Consumer Control: is tagged by udev as: Keyboard
[     6.323] (II) event15 - ITE Tech. Inc. ITE Device(8910) Consumer Control: device is a keyboard
[     6.324] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Wireless Radio Control (/dev/input/event16)
[     6.324] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "evdev keyboard catchall"
[     6.324] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
[     6.324] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "system-keyboard"
[     6.324] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Wireless Radio Control'
[     6.325] (II) systemd-logind: got fd for /dev/input/event16 13:80 fd 50 paused 0
[     6.325] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: always reports core events
[     6.325] (**) Option "Device" "/dev/input/event16"
[     6.325] (**) Option "_source" "server/udev"
[     6.326] (II) event16 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: is tagged by udev as: Keyboard
[     6.327] (II) event16 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device is a keyboard
[     6.327] (II) event16 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device removed
[     6.327] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0002/input/input18/event16"
[     6.327] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Wireless Radio Control" (type: KEYBOARD, id 17)
[     6.327] (**) Option "xkb_model" "pc105"
[     6.327] (**) Option "xkb_layout" "us"
[     6.329] (II) event16 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: is tagged by udev as: Keyboard
[     6.329] (II) event16 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device is a keyboard
[     6.329] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event10)
[     6.329] (II) No input driver specified, ignoring this device.
[     6.329] (II) This device may have been added with another device file.
[     6.329] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event11)
[     6.330] (II) config/udev: Adding input device HD-Audio Generic Headphone (/dev/input/event12)
[     6.330] (II) No input driver specified, ignoring this device.
[     6.330] (II) This device may have been added with another device file.
[     6.330] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event6)
[     6.330] (**) Ideapad extra buttons: Applying InputClass "evdev keyboard catchall"
[     6.330] (**) Ideapad extra buttons: Applying InputClass "libinput keyboard catchall"
[     6.330] (**) Ideapad extra buttons: Applying InputClass "system-keyboard"
[     6.330] (II) Using input driver 'libinput' for 'Ideapad extra buttons'
[     6.331] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 51 paused 0
[     6.331] (**) Ideapad extra buttons: always reports core events
[     6.331] (**) Option "Device" "/dev/input/event6"
[     6.331] (**) Option "_source" "server/udev"
[     6.331] (II) event6  - Ideapad extra buttons: is tagged by udev as: Keyboard
[     6.331] (II) event6  - Ideapad extra buttons: device is a keyboard
[     6.332] (II) event6  - Ideapad extra buttons: device removed
[     6.332] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.3/PNP0C09:00/VPC2004:00/input/input6/event6"
[     6.332] (II) XINPUT: Adding extended input device "Ideapad extra buttons" (type: KEYBOARD, id 18)
[     6.332] (**) Option "xkb_model" "pc105"
[     6.332] (**) Option "xkb_layout" "us"
[     6.332] (II) event6  - Ideapad extra buttons: is tagged by udev as: Keyboard
[     6.332] (II) event6  - Ideapad extra buttons: device is a keyboard
[     6.333] (II) config/udev: Adding input device MSFT0001:00 04F3:3140 Mouse (/dev/input/event8)
[     6.333] (**) MSFT0001:00 04F3:3140 Mouse: Applying InputClass "evdev pointer catchall"
[     6.333] (**) MSFT0001:00 04F3:3140 Mouse: Applying InputClass "libinput pointer catchall"
[     6.333] (II) Using input driver 'libinput' for 'MSFT0001:00 04F3:3140 Mouse'
[     6.333] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 52 paused 0
[     6.333] (**) MSFT0001:00 04F3:3140 Mouse: always reports core events
[     6.333] (**) Option "Device" "/dev/input/event8"
[     6.333] (**) Option "_source" "server/udev"
[     6.334] (II) event8  - MSFT0001:00 04F3:3140 Mouse: is tagged by udev as: Mouse Pointingstick
[     6.334] (II) event8  - MSFT0001:00 04F3:3140 Mouse: device is a pointer
[     6.335] (II) event8  - MSFT0001:00 04F3:3140 Mouse: device removed
[     6.335] (**) Option "NaturalScrolling" "on"
[     6.335] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:04F3:3140.0001/input/input11/event8"
[     6.335] (II) XINPUT: Adding extended input device "MSFT0001:00 04F3:3140 Mouse" (type: MOUSE, id 19)
[     6.335] (**) Option "AccelerationScheme" "none"
[     6.335] (**) MSFT0001:00 04F3:3140 Mouse: (accel) selected scheme none/0
[     6.335] (**) MSFT0001:00 04F3:3140 Mouse: (accel) acceleration factor: 2.000
[     6.335] (**) MSFT0001:00 04F3:3140 Mouse: (accel) acceleration threshold: 4
[     6.336] (II) event8  - MSFT0001:00 04F3:3140 Mouse: is tagged by udev as: Mouse Pointingstick
[     6.336] (II) event8  - MSFT0001:00 04F3:3140 Mouse: device is a pointer
[     6.337] (II) config/udev: Adding input device MSFT0001:00 04F3:3140 Mouse (/dev/input/mouse0)
[     6.337] (II) No input driver specified, ignoring this device.
[     6.337] (II) This device may have been added with another device file.
[     6.337] (II) config/udev: Adding input device MSFT0001:00 04F3:3140 Touchpad (/dev/input/event9)
[     6.337] (**) MSFT0001:00 04F3:3140 Touchpad: Applying InputClass "evdev touchpad catchall"
[     6.337] (**) MSFT0001:00 04F3:3140 Touchpad: Applying InputClass "libinput touchpad catchall"
[     6.337] (II) Using input driver 'libinput' for 'MSFT0001:00 04F3:3140 Touchpad'
[     6.338] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 53 paused 0
[     6.338] (**) MSFT0001:00 04F3:3140 Touchpad: always reports core events
[     6.338] (**) Option "Device" "/dev/input/event9"
[     6.338] (**) Option "_source" "server/udev"
[     6.339] (II) event9  - MSFT0001:00 04F3:3140 Touchpad: is tagged by udev as: Touchpad
[     6.341] (II) event9  - MSFT0001:00 04F3:3140 Touchpad: device is a touchpad
[     6.341] (II) event9  - MSFT0001:00 04F3:3140 Touchpad: device removed
[     6.342] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:04F3:3140.0001/input/input12/event9"
[     6.342] (II) XINPUT: Adding extended input device "MSFT0001:00 04F3:3140 Touchpad" (type: TOUCHPAD, id 20)
[     6.343] (**) Option "AccelerationScheme" "none"
[     6.343] (**) MSFT0001:00 04F3:3140 Touchpad: (accel) selected scheme none/0
[     6.343] (**) MSFT0001:00 04F3:3140 Touchpad: (accel) acceleration factor: 2.000
[     6.343] (**) MSFT0001:00 04F3:3140 Touchpad: (accel) acceleration threshold: 4
[     6.344] (II) event9  - MSFT0001:00 04F3:3140 Touchpad: is tagged by udev as: Touchpad
[     6.344] (II) event9  - MSFT0001:00 04F3:3140 Touchpad: device is a touchpad
[     6.345] (II) config/udev: Adding input device MSFT0001:00 04F3:3140 Touchpad (/dev/input/mouse1)
[     6.345] (II) No input driver specified, ignoring this device.
[     6.345] (II) This device may have been added with another device file.
[     6.345] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[     6.345] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[     6.345] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[     6.345] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[     6.345] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[     6.346] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 54 paused 0
[     6.346] (**) AT Translated Set 2 keyboard: always reports core events
[     6.346] (**) Option "Device" "/dev/input/event3"
[     6.346] (**) Option "_source" "server/udev"
[     6.346] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     6.347] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[     6.347] (II) event3  - AT Translated Set 2 keyboard: device removed
[     6.347] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[     6.347] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 21)
[     6.347] (**) Option "xkb_model" "pc105"
[     6.347] (**) Option "xkb_layout" "us"
[     6.348] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     6.348] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[     6.349] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[     6.349] (II) No input driver specified, ignoring this device.
[     6.349] (II) This device may have been added with another device file.
[     6.362] (**) USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[     6.362] (**) USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[     6.362] (**) USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[     6.362] (II) Using input driver 'libinput' for 'USB Keyboard Consumer Control'
[     6.362] (II) systemd-logind: returning pre-existing fd for /dev/input/event21 13:85
[     6.362] (**) USB Keyboard Consumer Control: always reports core events
[     6.362] (**) Option "Device" "/dev/input/event21"
[     6.362] (**) Option "_source" "_driver/libinput"
[     6.362] (II) libinput: USB Keyboard Consumer Control: is a virtual subdevice
[     6.362] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3:1.1/0003:0C45:7603.0007/input/input23/event21"
[     6.362] (II) XINPUT: Adding extended input device "USB Keyboard Consumer Control" (type: KEYBOARD, id 22)
[     6.362] (**) Option "xkb_model" "pc105"
[     6.362] (**) Option "xkb_layout" "us"
[     6.363] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "evdev keyboard catchall"
[     6.363] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "libinput keyboard catchall"
[     6.363] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "system-keyboard"
[     6.363] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Consumer Control'
[     6.363] (II) systemd-logind: returning pre-existing fd for /dev/input/event15 13:79
[     6.363] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: always reports core events
[     6.363] (**) Option "Device" "/dev/input/event15"
[     6.363] (**) Option "_source" "_driver/libinput"
[     6.363] (II) libinput: ITE Tech. Inc. ITE Device(8910) Consumer Control: is a virtual subdevice
[     6.363] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0002/input/input17/event15"
[     6.363] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Consumer Control" (type: KEYBOARD, id 23)
[     6.363] (**) Option "xkb_model" "pc105"
[     6.363] (**) Option "xkb_layout" "us"
[     6.363] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event11)
[     6.363] (II) No input driver specified, ignoring this device.
[     6.363] (II) This device may have been added with another device file.
[     6.363] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event10)
[     6.363] (II) config/udev: Adding input device HD-Audio Generic Headphone (/dev/input/event12)
[     6.364] (II) config/udev: removing device MSFT0001:00 04F3:3140 Mouse
[     6.364] (**) Option "fd" "52"
[     6.364] (II) event8  - MSFT0001:00 04F3:3140 Mouse: device removed
[     6.364] (II) UnloadModule: "libinput"
[     6.364] (II) systemd-logind: releasing fd for 13:72
[     6.402] (II) config/udev: Adding input device MSFT0001:00 04F3:3140 Mouse (/dev/input/event8)
[     6.402] (**) MSFT0001:00 04F3:3140 Mouse: Applying InputClass "evdev pointer catchall"
[     6.402] (**) MSFT0001:00 04F3:3140 Mouse: Applying InputClass "libinput pointer catchall"
[     6.402] (II) Using input driver 'libinput' for 'MSFT0001:00 04F3:3140 Mouse'
[     6.403] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 57 paused 0
[     6.403] (**) MSFT0001:00 04F3:3140 Mouse: always reports core events
[     6.403] (**) Option "Device" "/dev/input/event8"
[     6.403] (**) Option "_source" "server/udev"
[     6.404] (II) event8  - MSFT0001:00 04F3:3140 Mouse: is tagged by udev as: Mouse Pointingstick
[     6.404] (II) event8  - MSFT0001:00 04F3:3140 Mouse: device is a pointer
[     6.405] (II) event8  - MSFT0001:00 04F3:3140 Mouse: device removed
[     6.405] (**) Option "NaturalScrolling" "on"
[     6.406] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:04F3:3140.0001/input/input11/event8"
[     6.406] (II) XINPUT: Adding extended input device "MSFT0001:00 04F3:3140 Mouse" (type: MOUSE, id 19)
[     6.406] (**) Option "AccelerationScheme" "none"
[     6.406] (**) MSFT0001:00 04F3:3140 Mouse: (accel) selected scheme none/0
[     6.406] (**) MSFT0001:00 04F3:3140 Mouse: (accel) acceleration factor: 2.000
[     6.406] (**) MSFT0001:00 04F3:3140 Mouse: (accel) acceleration threshold: 4
[     6.406] (II) event8  - MSFT0001:00 04F3:3140 Mouse: is tagged by udev as: Mouse Pointingstick
[     6.406] (II) event8  - MSFT0001:00 04F3:3140 Mouse: device is a pointer
[     6.407] (II) config/udev: removing device MSFT0001:00 04F3:3140 Touchpad
[     6.407] (**) Option "fd" "53"
[     6.407] (II) event9  - MSFT0001:00 04F3:3140 Touchpad: device removed
[     6.407] (II) UnloadModule: "libinput"
[     6.407] (II) systemd-logind: releasing fd for 13:73
[     6.459] (II) config/udev: Adding input device MSFT0001:00 04F3:3140 Touchpad (/dev/input/event9)
[     6.459] (**) MSFT0001:00 04F3:3140 Touchpad: Applying InputClass "evdev touchpad catchall"
[     6.459] (**) MSFT0001:00 04F3:3140 Touchpad: Applying InputClass "libinput touchpad catchall"
[     6.459] (II) Using input driver 'libinput' for 'MSFT0001:00 04F3:3140 Touchpad'
[     6.460] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 53 paused 0
[     6.460] (**) MSFT0001:00 04F3:3140 Touchpad: always reports core events
[     6.460] (**) Option "Device" "/dev/input/event9"
[     6.460] (**) Option "_source" "server/udev"
[     6.461] (II) event9  - MSFT0001:00 04F3:3140 Touchpad: is tagged by udev as: Touchpad
[     6.462] (II) event9  - MSFT0001:00 04F3:3140 Touchpad: device is a touchpad
[     6.462] (II) event9  - MSFT0001:00 04F3:3140 Touchpad: device removed
[     6.462] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:04F3:3140.0001/input/input12/event9"
[     6.462] (II) XINPUT: Adding extended input device "MSFT0001:00 04F3:3140 Touchpad" (type: TOUCHPAD, id 20)
[     6.463] (**) Option "AccelerationScheme" "none"
[     6.463] (**) MSFT0001:00 04F3:3140 Touchpad: (accel) selected scheme none/0
[     6.463] (**) MSFT0001:00 04F3:3140 Touchpad: (accel) acceleration factor: 2.000
[     6.463] (**) MSFT0001:00 04F3:3140 Touchpad: (accel) acceleration threshold: 4
[     6.463] (II) event9  - MSFT0001:00 04F3:3140 Touchpad: is tagged by udev as: Touchpad
[     6.464] (II) event9  - MSFT0001:00 04F3:3140 Touchpad: device is a touchpad
[     6.465] (II) config/udev: Adding input device MSFT0001:00 04F3:3140 Touchpad (/dev/input/mouse1)
[     6.465] (II) No input driver specified, ignoring this device.
[     6.465] (II) This device may have been added with another device file.
[     6.465] (II) config/udev: Adding input device MSFT0001:00 04F3:3140 Mouse (/dev/input/mouse0)
[     6.466] (II) config/udev: removing device Integrated Camera: Integrated C
[     6.466] (**) Option "fd" "43"
[     6.466] (II) event13 - Integrated Camera: Integrated C: device removed
[     6.466] (II) UnloadModule: "libinput"
[     6.466] (II) systemd-logind: releasing fd for 13:77
[     6.516] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event13)
[     6.516] (**) Integrated Camera: Integrated C: Applying InputClass "evdev keyboard catchall"
[     6.516] (**) Integrated Camera: Integrated C: Applying InputClass "libinput keyboard catchall"
[     6.516] (**) Integrated Camera: Integrated C: Applying InputClass "system-keyboard"
[     6.516] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated C'
[     6.516] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 59 paused 0
[     6.516] (**) Integrated Camera: Integrated C: always reports core events
[     6.516] (**) Option "Device" "/dev/input/event13"
[     6.516] (**) Option "_source" "server/udev"
[     6.518] (II) event13 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[     6.518] (II) event13 - Integrated Camera: Integrated C: device is a keyboard
[     6.518] (II) event13 - Integrated Camera: Integrated C: device removed
[     6.518] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-3/1-3:1.0/input/input15/event13"
[     6.518] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated C" (type: KEYBOARD, id 10)
[     6.518] (**) Option "xkb_model" "pc105"
[     6.518] (**) Option "xkb_layout" "us"
[     6.519] (II) event13 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[     6.519] (II) event13 - Integrated Camera: Integrated C: device is a keyboard
[     6.519] (II) config/udev: removing device ITE Tech. Inc. ITE Device(8910) Wireless Radio Control
[     6.519] (**) Option "fd" "50"
[     6.519] (II) event16 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device removed
[     6.519] (II) UnloadModule: "libinput"
[     6.519] (II) systemd-logind: releasing fd for 13:80
[     6.552] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Wireless Radio Control (/dev/input/event16)
[     6.552] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "evdev keyboard catchall"
[     6.552] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
[     6.552] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "system-keyboard"
[     6.552] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Wireless Radio Control'
[     6.553] (II) systemd-logind: got fd for /dev/input/event16 13:80 fd 50 paused 0
[     6.554] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: always reports core events
[     6.554] (**) Option "Device" "/dev/input/event16"
[     6.554] (**) Option "_source" "server/udev"
[     6.555] (II) event16 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: is tagged by udev as: Keyboard
[     6.555] (II) event16 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device is a keyboard
[     6.555] (II) event16 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device removed
[     6.555] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0002/input/input18/event16"
[     6.555] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Wireless Radio Control" (type: KEYBOARD, id 17)
[     6.555] (**) Option "xkb_model" "pc105"
[     6.555] (**) Option "xkb_layout" "us"
[     6.556] (II) event16 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: is tagged by udev as: Keyboard
[     6.556] (II) event16 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device is a keyboard
[     6.556] (II) config/udev: removing device ITE Tech. Inc. ITE Device(8910) Keyboard
[     6.556] (**) Option "fd" "48"
[     6.556] (II) event14 - ITE Tech. Inc. ITE Device(8910) Keyboard: device removed
[     6.556] (II) UnloadModule: "libinput"
[     6.556] (II) systemd-logind: releasing fd for 13:78
[     6.576] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Keyboard (/dev/input/event14)
[     6.576] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "evdev keyboard catchall"
[     6.576] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "libinput keyboard catchall"
[     6.576] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "system-keyboard"
[     6.576] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Keyboard'
[     6.577] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 48 paused 0
[     6.577] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: always reports core events
[     6.577] (**) Option "Device" "/dev/input/event14"
[     6.577] (**) Option "_source" "server/udev"
[     6.578] (II) event14 - ITE Tech. Inc. ITE Device(8910) Keyboard: is tagged by udev as: Keyboard
[     6.578] (II) event14 - ITE Tech. Inc. ITE Device(8910) Keyboard: device is a keyboard
[     6.579] (II) event14 - ITE Tech. Inc. ITE Device(8910) Keyboard: device removed
[     6.579] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0002/input/input16/event14"
[     6.579] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Keyboard" (type: KEYBOARD, id 15)
[     6.579] (**) Option "xkb_model" "pc105"
[     6.579] (**) Option "xkb_layout" "us"
[     6.580] (II) event14 - ITE Tech. Inc. ITE Device(8910) Keyboard: is tagged by udev as: Keyboard
[     6.580] (II) event14 - ITE Tech. Inc. ITE Device(8910) Keyboard: device is a keyboard
[     6.581] (II) config/udev: removing device ITE Tech. Inc. ITE Device(8910) Consumer Control
[     6.581] (**) Option "fd" "49"
[     6.581] (II) UnloadModule: "libinput"
[     6.581] (II) systemd-logind: not releasing fd for 13:79, still in use
[     6.581] (II) event15 - ITE Tech. Inc. ITE Device(8910) Consumer Control: device removed
[     6.581] (II) systemd-logind: releasing fd for 13:79
[     6.609] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Consumer Control (/dev/input/event15)
[     6.610] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "evdev keyboard catchall"
[     6.610] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "libinput keyboard catchall"
[     6.610] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "system-keyboard"
[     6.610] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Consumer Control'
[     6.611] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 49 paused 0
[     6.611] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: always reports core events
[     6.611] (**) Option "Device" "/dev/input/event15"
[     6.611] (**) Option "_source" "server/udev"
[     6.612] (II) event15 - ITE Tech. Inc. ITE Device(8910) Consumer Control: is tagged by udev as: Keyboard
[     6.612] (II) event15 - ITE Tech. Inc. ITE Device(8910) Consumer Control: device is a keyboard
[     6.612] (II) event15 - ITE Tech. Inc. ITE Device(8910) Consumer Control: device removed
[     6.612] (II) libinput: ITE Tech. Inc. ITE Device(8910) Consumer Control: needs a virtual subdevice
[     6.612] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0002/input/input17/event15"
[     6.612] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Consumer Control" (type: MOUSE, id 16)
[     6.612] (**) Option "AccelerationScheme" "none"
[     6.612] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: (accel) selected scheme none/0
[     6.612] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: (accel) acceleration factor: 2.000
[     6.612] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: (accel) acceleration threshold: 4
[     6.613] (II) event15 - ITE Tech. Inc. ITE Device(8910) Consumer Control: is tagged by udev as: Keyboard
[     6.613] (II) event15 - ITE Tech. Inc. ITE Device(8910) Consumer Control: device is a keyboard
[     6.613] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "evdev keyboard catchall"
[     6.613] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "libinput keyboard catchall"
[     6.613] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "system-keyboard"
[     6.613] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Consumer Control'
[     6.613] (II) systemd-logind: returning pre-existing fd for /dev/input/event15 13:79
[     6.613] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: always reports core events
[     6.613] (**) Option "Device" "/dev/input/event15"
[     6.613] (**) Option "_source" "_driver/libinput"
[     6.613] (II) libinput: ITE Tech. Inc. ITE Device(8910) Consumer Control: is a virtual subdevice
[     6.613] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0002/input/input17/event15"
[     6.613] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Consumer Control" (type: KEYBOARD, id 23)
[     6.613] (**) Option "xkb_model" "pc105"
[     6.613] (**) Option "xkb_layout" "us"
[     6.614] (II) config/udev: Adding input device Lenovo Lenovo Legion M300 RGB Gaming Mouse (/dev/input/mouse2)
[     6.614] (II) No input driver specified, ignoring this device.
[     6.614] (II) This device may have been added with another device file.
[     6.614] (II) config/udev: removing device USB Keyboard
[     6.614] (**) Option "fd" "47"
[     6.614] (II) event23 - USB Keyboard: device removed
[     6.614] (II) UnloadModule: "libinput"
[     6.614] (II) systemd-logind: releasing fd for 13:87
[     6.633] (II) config/udev: Adding input device USB Keyboard (/dev/input/event23)
[     6.633] (**) USB Keyboard: Applying InputClass "evdev keyboard catchall"
[     6.633] (**) USB Keyboard: Applying InputClass "libinput keyboard catchall"
[     6.633] (**) USB Keyboard: Applying InputClass "system-keyboard"
[     6.633] (II) Using input driver 'libinput' for 'USB Keyboard'
[     6.634] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 47 paused 0
[     6.634] (**) USB Keyboard: always reports core events
[     6.634] (**) Option "Device" "/dev/input/event23"
[     6.634] (**) Option "_source" "server/udev"
[     6.635] (II) event23 - USB Keyboard: is tagged by udev as: Keyboard
[     6.635] (II) event23 - USB Keyboard: device is a keyboard
[     6.635] (II) event23 - USB Keyboard: device removed
[     6.635] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3:1.1/0003:0C45:7603.0007/input/input26/event23"
[     6.635] (II) XINPUT: Adding extended input device "USB Keyboard" (type: KEYBOARD, id 14)
[     6.635] (**) Option "xkb_model" "pc105"
[     6.635] (**) Option "xkb_layout" "us"
[     6.636] (II) event23 - USB Keyboard: is tagged by udev as: Keyboard
[     6.636] (II) event23 - USB Keyboard: device is a keyboard
[     6.637] (II) config/udev: removing device USB Keyboard System Control
[     6.637] (**) Option "fd" "46"
[     6.637] (II) event22 - USB Keyboard System Control: device removed
[     6.637] (II) UnloadModule: "libinput"
[     6.637] (II) systemd-logind: releasing fd for 13:86
[     6.656] (II) config/udev: Adding input device USB Keyboard System Control (/dev/input/event22)
[     6.656] (**) USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[     6.656] (**) USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[     6.656] (**) USB Keyboard System Control: Applying InputClass "system-keyboard"
[     6.656] (II) Using input driver 'libinput' for 'USB Keyboard System Control'
[     6.657] (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 46 paused 0
[     6.657] (**) USB Keyboard System Control: always reports core events
[     6.657] (**) Option "Device" "/dev/input/event22"
[     6.657] (**) Option "_source" "server/udev"
[     6.658] (II) event22 - USB Keyboard System Control: is tagged by udev as: Keyboard
[     6.658] (II) event22 - USB Keyboard System Control: device is a keyboard
[     6.659] (II) event22 - USB Keyboard System Control: device removed
[     6.659] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3:1.1/0003:0C45:7603.0007/input/input24/event22"
[     6.659] (II) XINPUT: Adding extended input device "USB Keyboard System Control" (type: KEYBOARD, id 13)
[     6.659] (**) Option "xkb_model" "pc105"
[     6.659] (**) Option "xkb_layout" "us"
[     6.660] (II) event22 - USB Keyboard System Control: is tagged by udev as: Keyboard
[     6.660] (II) event22 - USB Keyboard System Control: device is a keyboard
[     6.660] (II) config/udev: removing device USB Keyboard Consumer Control
[     6.660] (**) Option "fd" "45"
[     6.660] (II) UnloadModule: "libinput"
[     6.660] (II) systemd-logind: not releasing fd for 13:85, still in use
[     6.660] (II) event21 - USB Keyboard Consumer Control: device removed
[     6.660] (II) systemd-logind: releasing fd for 13:85
[     6.683] (II) config/udev: Adding input device USB Keyboard Consumer Control (/dev/input/event21)
[     6.683] (**) USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[     6.683] (**) USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[     6.683] (**) USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[     6.683] (II) Using input driver 'libinput' for 'USB Keyboard Consumer Control'
[     6.684] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 45 paused 0
[     6.684] (**) USB Keyboard Consumer Control: always reports core events
[     6.684] (**) Option "Device" "/dev/input/event21"
[     6.684] (**) Option "_source" "server/udev"
[     6.685] (II) event21 - USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[     6.685] (II) event21 - USB Keyboard Consumer Control: device is a keyboard
[     6.685] (II) event21 - USB Keyboard Consumer Control: device removed
[     6.685] (II) libinput: USB Keyboard Consumer Control: needs a virtual subdevice
[     6.685] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3:1.1/0003:0C45:7603.0007/input/input23/event21"
[     6.685] (II) XINPUT: Adding extended input device "USB Keyboard Consumer Control" (type: MOUSE, id 12)
[     6.685] (**) Option "AccelerationScheme" "none"
[     6.685] (**) USB Keyboard Consumer Control: (accel) selected scheme none/0
[     6.685] (**) USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[     6.685] (**) USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[     6.686] (II) event21 - USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[     6.686] (II) event21 - USB Keyboard Consumer Control: device is a keyboard
[     6.687] (**) USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[     6.687] (**) USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[     6.687] (**) USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[     6.687] (II) Using input driver 'libinput' for 'USB Keyboard Consumer Control'
[     6.687] (II) systemd-logind: returning pre-existing fd for /dev/input/event21 13:85
[     6.687] (**) USB Keyboard Consumer Control: always reports core events
[     6.687] (**) Option "Device" "/dev/input/event21"
[     6.687] (**) Option "_source" "_driver/libinput"
[     6.687] (II) libinput: USB Keyboard Consumer Control: is a virtual subdevice
[     6.687] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3:1.1/0003:0C45:7603.0007/input/input23/event21"
[     6.687] (II) XINPUT: Adding extended input device "USB Keyboard Consumer Control" (type: KEYBOARD, id 22)
[     6.687] (**) Option "xkb_model" "pc105"
[     6.687] (**) Option "xkb_layout" "us"
[     6.687] (II) config/udev: removing device USB Keyboard
[     6.687] (**) Option "fd" "44"
[     6.687] (II) event20 - USB Keyboard: device removed
[     6.687] (II) UnloadModule: "libinput"
[     6.687] (II) systemd-logind: releasing fd for 13:84
[     6.720] (II) config/udev: Adding input device USB Keyboard (/dev/input/event20)
[     6.720] (**) USB Keyboard: Applying InputClass "evdev keyboard catchall"
[     6.720] (**) USB Keyboard: Applying InputClass "libinput keyboard catchall"
[     6.720] (**) USB Keyboard: Applying InputClass "system-keyboard"
[     6.720] (II) Using input driver 'libinput' for 'USB Keyboard'
[     6.721] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 44 paused 0
[     6.721] (**) USB Keyboard: always reports core events
[     6.721] (**) Option "Device" "/dev/input/event20"
[     6.721] (**) Option "_source" "server/udev"
[     6.722] (II) event20 - USB Keyboard: is tagged by udev as: Keyboard
[     6.722] (II) event20 - USB Keyboard: device is a keyboard
[     6.722] (II) event20 - USB Keyboard: device removed
[     6.722] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3:1.0/0003:0C45:7603.0006/input/input22/event20"
[     6.722] (II) XINPUT: Adding extended input device "USB Keyboard" (type: KEYBOARD, id 11)
[     6.722] (**) Option "xkb_model" "pc105"
[     6.722] (**) Option "xkb_layout" "us"
[     6.723] (II) event20 - USB Keyboard: is tagged by udev as: Keyboard
[     6.723] (II) event20 - USB Keyboard: device is a keyboard
[     6.724] (II) config/udev: Adding input device Lenovo Lenovo Legion M300 RGB Gaming Mouse (/dev/input/event17)
[     6.724] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: Applying InputClass "evdev pointer catchall"
[     6.724] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: Applying InputClass "libinput pointer catchall"
[     6.724] (II) Using input driver 'libinput' for 'Lenovo Lenovo Legion M300 RGB Gaming Mouse'
[     6.725] (II) systemd-logind: got fd for /dev/input/event17 13:81 fd 60 paused 0
[     6.725] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: always reports core events
[     6.725] (**) Option "Device" "/dev/input/event17"
[     6.725] (**) Option "_source" "server/udev"
[     6.726] (II) event17 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: is tagged by udev as: Mouse
[     6.726] (II) event17 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: device is a pointer
[     6.726] (II) event17 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: device removed
[     6.726] (**) Option "NaturalScrolling" "on"
[     6.726] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.2/3-1.1.2:1.0/0003:17EF:60E4.0003/input/input19/event17"
[     6.726] (II) XINPUT: Adding extended input device "Lenovo Lenovo Legion M300 RGB Gaming Mouse" (type: MOUSE, id 24)
[     6.726] (**) Option "AccelerationScheme" "none"
[     6.726] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: (accel) selected scheme none/0
[     6.726] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: (accel) acceleration factor: 2.000
[     6.726] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: (accel) acceleration threshold: 4
[     6.727] (II) event17 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: is tagged by udev as: Mouse
[     6.727] (II) event17 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: device is a pointer
[     6.728] (II) config/udev: Adding input device Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control (/dev/input/event18)
[     6.728] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[     6.728] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[     6.728] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
[     6.728] (II) Using input driver 'libinput' for 'Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control'
[     6.728] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 61 paused 0
[     6.729] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: always reports core events
[     6.729] (**) Option "Device" "/dev/input/event18"
[     6.729] (**) Option "_source" "server/udev"
[     6.730] (II) event18 - Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[     6.730] (II) event18 - Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: device is a keyboard
[     6.730] (II) event18 - Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: device removed
[     6.730] (II) libinput: Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: needs a virtual subdevice
[     6.730] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.2/3-1.1.2:1.0/0003:17EF:60E4.0003/input/input20/event18"
[     6.730] (II) XINPUT: Adding extended input device "Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control" (type: MOUSE, id 25)
[     6.730] (**) Option "AccelerationScheme" "none"
[     6.730] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: (accel) selected scheme none/0
[     6.730] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: (accel) acceleration factor: 2.000
[     6.730] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: (accel) acceleration threshold: 4
[     6.731] (II) event18 - Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[     6.731] (II) event18 - Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: device is a keyboard
[     6.731] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[     6.731] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[     6.731] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
[     6.731] (II) Using input driver 'libinput' for 'Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control'
[     6.731] (II) systemd-logind: returning pre-existing fd for /dev/input/event18 13:82
[     6.731] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: always reports core events
[     6.731] (**) Option "Device" "/dev/input/event18"
[     6.731] (**) Option "_source" "_driver/libinput"
[     6.731] (II) libinput: Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: is a virtual subdevice
[     6.731] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.2/3-1.1.2:1.0/0003:17EF:60E4.0003/input/input20/event18"
[     6.731] (II) XINPUT: Adding extended input device "Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control" (type: KEYBOARD, id 26)
[     6.731] (**) Option "xkb_model" "pc105"
[     6.731] (**) Option "xkb_layout" "us"
[     6.732] (II) config/udev: Adding input device Lenovo Lenovo Legion M300 RGB Gaming Mouse (/dev/input/event19)
[     6.732] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: Applying InputClass "evdev keyboard catchall"
[     6.732] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: Applying InputClass "libinput keyboard catchall"
[     6.732] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: Applying InputClass "system-keyboard"
[     6.732] (II) Using input driver 'libinput' for 'Lenovo Lenovo Legion M300 RGB Gaming Mouse'
[     6.733] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 62 paused 0
[     6.733] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: always reports core events
[     6.733] (**) Option "Device" "/dev/input/event19"
[     6.733] (**) Option "_source" "server/udev"
[     6.734] (II) event19 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: is tagged by udev as: Keyboard
[     6.734] (II) event19 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: device is a keyboard
[     6.734] (II) event19 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: device removed
[     6.734] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.2/3-1.1.2:1.1/0003:17EF:60E4.0004/input/input21/event19"
[     6.734] (II) XINPUT: Adding extended input device "Lenovo Lenovo Legion M300 RGB Gaming Mouse" (type: KEYBOARD, id 27)
[     6.734] (**) Option "xkb_model" "pc105"
[     6.734] (**) Option "xkb_layout" "us"
[     6.735] (II) event19 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: is tagged by udev as: Keyboard
[     6.735] (II) event19 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: device is a keyboard
[     7.044] (II) AMDGPU(0): EDID vendor "AUO", prod id 53741
[     7.044] (II) AMDGPU(0): Using EDID range info for horizontal sync
[     7.044] (II) AMDGPU(0): Using EDID range info for vertical refresh
[     7.044] (II) AMDGPU(0): Printing DDC gathered Modelines:
[     7.044] (II) AMDGPU(0): Modeline "1920x1080"x0.0  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[     7.044] (II) AMDGPU(0): Using hsync ranges from config file
[     7.044] (II) AMDGPU(0): Using vrefresh ranges from config file
[     7.044] (--) NVIDIA(GPU-0): DFP-0: disconnected
[     7.044] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[     7.044] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[     7.044] (--) NVIDIA(GPU-0): DFP-1: disconnected
[     7.044] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[     7.044] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[     7.044] (--) NVIDIA(GPU-0): DFP-2: disconnected
[     7.044] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[     7.044] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[     7.044] (--) NVIDIA(GPU-0): DFP-3: disconnected
[     7.044] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[     7.044] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
[    13.612] (**) Option "fd" "37"
[    13.612] (II) event2  - Power Button: device removed
[    13.613] (**) Option "fd" "40"
[    13.613] (II) event4  - Video Bus: device removed
[    13.613] (**) Option "fd" "41"
[    13.613] (II) event5  - Video Bus: device removed
[    13.613] (**) Option "fd" "42"
[    13.613] (II) event1  - Power Button: device removed
[    13.614] (**) Option "fd" "51"
[    13.614] (II) event6  - Ideapad extra buttons: device removed
[    13.614] (**) Option "fd" "54"
[    13.614] (II) event3  - AT Translated Set 2 keyboard: device removed
[    13.615] (**) Option "fd" "57"
[    13.615] (II) event8  - MSFT0001:00 04F3:3140 Mouse: device removed
[    13.615] (**) Option "fd" "53"
[    13.615] (II) event9  - MSFT0001:00 04F3:3140 Touchpad: device removed
[    13.616] (**) Option "fd" "59"
[    13.616] (II) event13 - Integrated Camera: Integrated C: device removed
[    13.616] (**) Option "fd" "50"
[    13.616] (II) event16 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device removed
[    13.616] (**) Option "fd" "48"
[    13.617] (II) event14 - ITE Tech. Inc. ITE Device(8910) Keyboard: device removed
[    13.617] (**) Option "fd" "49"
[    13.617] (II) event15 - ITE Tech. Inc. ITE Device(8910) Consumer Control: device removed
[    13.618] (**) Option "fd" "47"
[    13.618] (II) event23 - USB Keyboard: device removed
[    13.618] (**) Option "fd" "46"
[    13.618] (II) event22 - USB Keyboard System Control: device removed
[    13.619] (**) Option "fd" "45"
[    13.619] (II) event21 - USB Keyboard Consumer Control: device removed
[    13.619] (**) Option "fd" "44"
[    13.619] (II) event20 - USB Keyboard: device removed
[    13.620] (**) Option "fd" "60"
[    13.620] (II) event17 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: device removed
[    13.620] (**) Option "fd" "61"
[    13.620] (II) event18 - Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: device removed
[    13.621] (**) Option "fd" "62"
[    13.621] (II) event19 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: device removed
[    13.621] (II) AIGLX: Suspending AIGLX clients for VT switch
[    13.711] (EE) AMDGPU(0): failed to set mode: Permission denied
[    13.712] (II) systemd-logind: got pause for 13:77
[    13.712] (II) systemd-logind: got pause for 13:84
[    13.712] (II) systemd-logind: got pause for 13:85
[    13.712] (II) systemd-logind: got pause for 13:78
[    13.712] (II) systemd-logind: got pause for 13:70
[    13.712] (II) systemd-logind: got pause for 13:68
[    13.712] (II) systemd-logind: got pause for 13:79
[    13.712] (II) systemd-logind: got pause for 13:69
[    13.712] (II) systemd-logind: got pause for 13:67
[    13.712] (II) systemd-logind: got pause for 13:72
[    13.712] (II) systemd-logind: got pause for 13:65
[    13.712] (II) systemd-logind: got pause for 13:86
[    13.712] (II) systemd-logind: got pause for 13:81
[    13.712] (II) systemd-logind: got pause for 13:83
[    13.712] (II) systemd-logind: got pause for 13:73
[    13.712] (II) systemd-logind: got pause for 226:0
[    13.712] (II) systemd-logind: got pause for 13:82
[    13.712] (II) systemd-logind: got pause for 13:66
[    13.712] (II) systemd-logind: got pause for 13:87
[    13.712] (II) systemd-logind: got pause for 13:80
[    17.701] (II) UnloadModule: "libinput"
[    17.701] (II) systemd-logind: releasing fd for 13:83
[    17.723] (II) UnloadModule: "libinput"
[    17.723] (II) systemd-logind: not releasing fd for 13:82, still in use
[    17.723] (II) systemd-logind: releasing fd for 13:82
[    17.759] (II) UnloadModule: "libinput"
[    17.759] (II) systemd-logind: releasing fd for 13:81
[    17.799] (II) UnloadModule: "libinput"
[    17.799] (II) systemd-logind: releasing fd for 13:84
[    17.853] (II) UnloadModule: "libinput"
[    17.853] (II) systemd-logind: not releasing fd for 13:85, still in use
[    17.853] (II) systemd-logind: releasing fd for 13:85
[    17.892] (II) UnloadModule: "libinput"
[    17.893] (II) systemd-logind: releasing fd for 13:86
[    17.959] (II) UnloadModule: "libinput"
[    17.959] (II) systemd-logind: releasing fd for 13:87
[    17.999] (II) UnloadModule: "libinput"
[    17.999] (II) systemd-logind: not releasing fd for 13:79, still in use
[    17.999] (II) systemd-logind: releasing fd for 13:79
[    18.036] (II) UnloadModule: "libinput"
[    18.036] (II) systemd-logind: releasing fd for 13:78
[    18.079] (II) UnloadModule: "libinput"
[    18.079] (II) systemd-logind: releasing fd for 13:80
[    18.139] (II) UnloadModule: "libinput"
[    18.139] (II) systemd-logind: releasing fd for 13:77
[    18.186] (II) UnloadModule: "libinput"
[    18.186] (II) systemd-logind: releasing fd for 13:73
[    18.239] (II) UnloadModule: "libinput"
[    18.239] (II) systemd-logind: releasing fd for 13:72
[    18.279] (II) UnloadModule: "libinput"
[    18.279] (II) systemd-logind: releasing fd for 13:67
[    18.333] (II) UnloadModule: "libinput"
[    18.333] (II) systemd-logind: releasing fd for 13:70
[    18.373] (II) UnloadModule: "libinput"
[    18.373] (II) systemd-logind: releasing fd for 13:65
[    18.439] (II) UnloadModule: "libinput"
[    18.439] (II) systemd-logind: releasing fd for 13:69
[    18.479] (II) UnloadModule: "libinput"
[    18.479] (II) systemd-logind: releasing fd for 13:68
[    18.547] (II) UnloadModule: "libinput"
[    18.547] (II) systemd-logind: releasing fd for 13:66
[    18.588] (WW) NVIDIA(G0): Failed to set the display configuration
[    18.588] (WW) NVIDIA(G0):  - Setting a mode on head 0 failed: Insufficient permissions
[    18.588] (WW) NVIDIA(G0):  - Setting a mode on head 1 failed: Insufficient permissions
[    18.588] (WW) NVIDIA(G0):  - Setting a mode on head 2 failed: Insufficient permissions
[    18.588] (WW) NVIDIA(G0):  - Setting a mode on head 3 failed: Insufficient permissions
[    18.596] (II) NVIDIA(GPU-0): Deleting GPU-0
[    18.598] (II) Server terminated successfully (0). Closing log file.
I’ve tried 5.10, 5.11 and 5.4. Same results. This issue happens every update and hasn’t been fixed since the last couple of updates. Occasionally it works but most of the time I have to TTY in. After getting in subsequent reboots will bring me to the login, but after shutting it down, the next day the issue is back.
Looks like a timing issue… make the drivers load very early:
Replace MODULES=() with:
MODULES=(amdgpu nvidia)
at /etc/mkinitcpio.conf
Then run sudo mkinitcpio -P to update the initramfs.
Reason of this is that the driver scheduled late and therefore the display-manager does not start at first time when switching from basic video mode to the graphical mode
Thanks! So far seems to be working but the problem usually happens after a long shutdown. I’ll get back to you after turning it off for a while.
It’s still booting up to a blank screen. I’ve tried other kernels (5.4, 5.10, 5.11, 5.12), all have the same result.
You could try that:
https://wiki.archlinux.org/title/GDM#GDM_shows_black_screen_with_blinking_white_cursor
Just adding some extra time to the gdm service.
How do I do this exactly? The instructions are unclear.
There is link to https://wiki.archlinux.org/title/Systemd#Editing_provided_units, there it is explained. Read it carefully.
Here you go:
sudo systemctl edit --full gdm
(this will create a new alternative service file. The original file will not be touched)
There you add between [Service] and ExecStart=/usr/bin/gdm: ExecStartPre=/bin/sleep 2 like this:
[Service]
and save it with CTRL+S and close it with CTRL+X.
sleep 2 stands for “wait 2 seconds”. Add more time if needed.
OR
add change the type to idle:
[Service]
Type=idle
(this will wait not more than 5 seconds)
You can revert it any time with:
sudo systemctl revert gdm
Thanks. I did read the link but I was confused with the instructions. I’ll try it again and let you know how it goes.
So I’ve booted it up after shutting it down for the night and it seems to fix the problem. Thanks a bunch!
