Stellarium 1.2-1 in AUR does not work. (Error:)
stellarium: error while loading shared libraries: libgps.so.29: cannot open shared object file: No such file or directory
Version 1.2-2 from Arch4Edu (Third Party…) is working:
https://archlinux.pkgs.org/rolling/arch4edu-x86_64/stellarium-1.2-2-x86_64.pkg.tar.zst.html
gpsd
3.25-1 provides libgps.so.30
. stellarium
needs to be rebuilt on it.
❯ pacman -Fx libgps.so
community/gpsd 3.25-1
usr/lib/libgps.so
usr/lib/libgps.so.30
usr/lib/libgps.so.30.0.0
That is done by Version 1.2-2 from Arch4Edu
Thank You!!!
Disclaimers for posterity:
Third-party repos are not supported.
It’s a user’s own responsibility to rebuild AUR packages when required.
