Random system freezes Intel i5 + NVIDIA graphics?
I recently experienced multiple random freezing (keyboard and mouse no longer work and screen freezes) on both XFCE and Budgie running various kernels (5.10 LTS, 5.13). What can be the problem?
Though I do not have an AMD GPU I wanted to share that I have had no more freezes since upgrading MESA to the latest version (I forced an upgrade by using the Downgrade option as explained on an AMD GPU thread (system-frequently-crashing-after-gpu-drivers-update/62139)
Since installing 21.1.5 MESA I have no more freezes (Believe 21.1.4 may also workā€¦). Just wanted to share this if it helps people experiencing freezing on intel i5 plus NVIDIA GPU combinations.
Ok, after 2 days of running, I have had 2 freezes within the first 5 minutes of booting up. I have the latest linux firmware, Nvidia drivers, Kennel LTS 5.10. I am at a loss as to what this can be. Any help would be appreciated. Freezes also happened on 5.13 (running now 5.13.4.1)
  Kernel: 5.13.4-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=857f084c-0a80-4130-816a-b684c710b657 rw quiet apparmor=1
  Desktop: Budgie 10.5.3 info: budgie-panel wm: budgie-wm dm: LightDM 1.30.0
  Type: Desktop System: ZOTAC product: ZBOX-EN760 v: XX serial: <filter>
  Mobo: ZOTAC model: ZBOX-EN760 v: XX serial: <filter>
  UEFI: American Megatrends v: B248P002 date: 06/17/2014
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
  serial: <filter> charge: 100% (should be ignored) rechargeable: yes
  status: Discharging
  RAM: total: 15.59 GiB used: 2.33 GiB (15.0%)
  Info: Dual Core model: Intel Core i5-4200U bits: 64 type: MT MCP
  arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26 cache:
  L2: 3 MiB bogomips: 18360
  Speed: 1596 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 1596 2: 1593
  3: 1673 4: 1596
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
  clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
  dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
  fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
  monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
  pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
  sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave
  xsaveopt xtopology xtpr
  Type: l1tf
  Device-1: NVIDIA GM107M [GeForce GTX 860M] vendor: ZOTAC driver: nvidia
  v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 04:00.0
  chip-ID: 10de:1392 class-ID: 0300
  Display: x11 server: X.Org 1.20.11 compositor: budgie-wm driver:
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
  s-diag: 777mm (30.6")
  Monitor-1: HDMI-0 res: 2560x1440 hz: 60 dpi: 118
  size: 553x311mm (21.8x12.2") diag: 634mm (25")
  OpenGL: renderer: NVIDIA GeForce GTX 860M/PCIe/SSE2
  v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
  Device-1: Intel 8 Series HD Audio vendor: ZOTAC driver: snd_hda_intel
  v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
  Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX] vendor: ZOTAC
  driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 10de:0fbc
  class-ID: 0403
  Device-3: Comtrue E1DA #9038D PCM32/384 DSD256 type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 2-2:3 chip-ID: 2fc6:6013
  class-ID: 0300 serial: <filter>
  Sound Server-1: ALSA v: k5.13.4-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 14.2 running: no
  Sound Server-4: PipeWire v: 0.3.32 running: yes
  Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel port: f000
  bus-ID: 02:00.0 chip-ID: 8086:08b3 class-ID: 0280
  IF: wlp2s0 state: down mac: <filter>
  vendor: ZOTAC driver: r8168 v: 8.049.02-NAPI modules: r8169 port: e000
  bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  vendor: ZOTAC driver: r8168 v: 8.049.02-NAPI modules: r8169 port: c000
  bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  IF-ID-2: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
  IP v4: <filter> type: noprefixroute scope: global
  IP v6: <filter> virtual: stable-privacy scope: link
  bus-ID: 2-6:7 chip-ID: 8087:07dc class-ID: e001
  Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
  Local Storage: total: 698.65 GiB used: 53.45 GiB (7.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
  model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
  logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 20WD
  scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Samsung
  model: Portable SSD T3 size: 232.89 GiB block-size: physical: 512 B
  logical: 512 B type: SSD serial: <filter> scheme: MBR
  ID-1: / raw-size: 68.61 GiB size: 67.29 GiB (98.07%) used: 53.42 GiB (79.4%)
  fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
  uuid: 857f084c-0a80-4130-816a-b684c710b657
  used: 25.8 MiB (26.9%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 12D4-94FA
  ID-1: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: ntfs label: Wiederherstellung
  uuid: 3440D41A40D3E122
  ID-2: /dev/sda3 maj-min: 8:3 size: 128 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-3: /dev/sda4 maj-min: 8:4 size: 153.94 GiB fs: ntfs label: N/A
  uuid: D0B8D959B8D93EA2
  ID-4: /dev/sda5 maj-min: 8:5 size: 510 MiB fs: ntfs label: N/A
  uuid: 287284A0728473FA
  ID-5: /dev/sdb1 maj-min: 8:17 size: 232.88 GiB fs: exfat label: Samsung_T3
  uuid: 9C6E-2E4D
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
  Device-1: 2-2:3 info: Comtrue E1DA #9038D PCM32/384 DSD256 type: Audio,HID
  driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
  speed: 480 Mb/s chip-ID: 2fc6:6013 class-ID: 0300 serial: <filter>
  Hub-4: 2-4:4 info: Alcor Micro USB Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  power: 100mA chip-ID: 058f:6254 class-ID: 0900
  Device-1: 2-4.3:6 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
  power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 2-4.4:8 info: Holtek type: Keyboard,HID driver: hid-generic,usbhid
  interfaces: 2 rev: 2.0 speed: 1.5 Mb/s power: 100mA chip-ID: 04d9:a088
  class-ID: 0300
  Device-3: 2-5:5 info: Realtek RTS5129 Card Reader Controller
  interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
  class-ID: ff00 serial: <filter>
  Device-4: 2-6:7 info: Intel Bluetooth wireless interface type: Bluetooth
  Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  Device-1: 3-1:2 info: Samsung Portable SSD T3 (MU-PT250B MU-PT500B)
  type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s
  power: 896mA chip-ID: 04e8:61f3 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 47 C
  Processes: 282 Uptime: 24m wakeups: 4 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1612 pacman: 1564 lib: 353
  flatpak: 36 snap: 12 Shell: Bash v: 5.1.8 running-in: gnome-terminal
  inxi: 3.3.06
When the system freezes, nothing works. I cannot SSH into the machine. I have to hard reset.
Suggestions would be appreciated.
I checked journal and dmesg for obvious errors and I could not spot anything of noteā€¦
I have run a memory test with multiple passes and RAM is fine.
Depending on how hard your hard reset was, please read this:
and after the next crash:
  • REISUB
  • provide the output to
    journalctl --system --boot=0 --priority=3 | tail --lines=50
Thanks a lot. All your tips have been really helpful. I now know what REISUB is :slight_smile: and I just reconfigured grub and tested it. Works. However, when my system freezes normally the keyboard becomes totally unresponsive (caps lock for example does not work and no lights), so I am curious to see if REISUB will work. I have read reddit forums where numerous people have had random freezes with NVIDIA drivers where the keyboard also becomes unresponsive so I pretty sure it is a driver issueā€¦
I should add that some of the crashes happened when using Thunderbird (at least 3 of the recent crashes) and Thunderbird is built using Firefox functionality with hardware acceleration on as default. Another crash happened when starting Firefox browser. I have for now disabled all hardware acceleration on email/browsers but this is not a permanent solution.
Another day, another crashā€¦REISUSB did not work. Keyboard totally frozen
I ran journalctl --system --boot=0 --priority=3 | tail --lines=50
Also did boot=-1
Both logs had identical outputs.
Aug 03 07:32:37 cm-zboxen760 kernel:
Aug 03 07:32:41 cm-zboxen760 systemd[662]: PAM failed: Authentication service cannot retrieve authentication info
Aug 03 07:32:41 XXXX systemd[662]: user@971.service: Failed to set up PAM session: Operation not permitted
Aug 03 07:32:41 XXX systemd[662]: user@971.service: Failed at step PAM spawning /usr/lib/systemd/systemd: Operation not permitted
Aug 03 07:32:41 XXX systemd[1]: Failed to start User Manager for UID 971.
Aug 03 07:32:56 XXX lightdm[1200]: gkr-pam: unable to locate daemon control file
This is it. Almost every day I get a crash. Latest updates installed. Crash happens on both 5.10 and 5.13 kernels. So frustrating. This time the crash happened when opening Brave (a chromium based browser and acceleration was turned on, but crashes happen when it is off as well).
System was stable for about 5 days and again crashed. Running Librecad this time caused the crash.
I come to this forum from time to time to check if this problem is already solved, andā€¦ well I see that is not, at least if your problem is the same as mine.
The problem has been around for almost a year already, and still no solution.
The thing is that the Arch kernel, from 5.2 or so, freezes randomly in Haswell CPUs (at least, that ones).
This is probably because of the scheduler or something like that (the thing that changes the CPU power from ā€œenergyā€ to ā€œperformanceā€) which is broken for the Haswell CPUs afaik.
The solution is to use 4.19 kernel and hope to have an usable kernel in the future before this kernel becomes too old.
Another solution could be to set the CPU always to performance, I donā€™t like to do that, so what I do is to open something in Lutris so the Lutris scripts set the CPU to performance automatically until you close Lutris, itā€™s a temporal solution but it works for me (no more freezes). There are probably better ways to do so, but idk them.
Also all of this is supposing that your problem is the same as mine, I canā€™t guarantee that butā€¦ freezes + firefox + no REISUB + Haswell + Nvidia driversā€¦ is the same situation for me.
Iā€™m sorry if my explanations were not ā€œtechnicalā€ but Iā€™m not a Linux proā€¦
Why donā€™t you install TLP or slimbook battery :wink: ?
True, thatā€™s the solution I didnā€™t know XD.
I mean, I knew about that programs, but I never thought of using them on a desktop PC, but for this purpose it would be useful, thanks.
Thanks for the suggestions. Really appreciate itā€¦
I tried the CPU setting. Makes no difference. Still have random freezes. This time though the machine will restart after a few minutes on its own (but not gently, like a hard reset). Before it just froze.
Iā€™m using Lenovo Ideapad Gaming 3 (AMD CPU with integrated GPU and NVDIA VGA) and notice that it always freeze, usually first 10 or 15 minutes after booting up. I notice that the problem will not occur if Iā€™m using only integrated GPU (config this by using optimus-manager).
This is the log collection from ~/.xsession_errors. Iā€™m using XFCE by the way
[1534:1:1026/173153.981941:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
[1122:1122:1026/173154.014048:ERROR:gpu_process_host.cc(979)] GPU process exited unexpectedly: exit_code=512
[16392:16392:1026/173154.387588:ERROR:sandbox_linux.cc(374)] InitializeSandbox() called with multiple threads in process gpu-process.
