The Steam Client will not start when I try to call it up. When using the Terminal this is what I get:
steam
steam.sh[34711]: Running Steam on manjarolinux 21.2.6 64-bit
steam.sh[34711]: STEAM_RUNTIME is enabled automatically
setup.sh[34785]: Steam runtime environment up-to-date!
steam.sh[34711]: Steam client's requirements are satisfied
[2022-05-13 10:00:54] Startup - updater built May 10 2022 16:10:17
[2022-05-13 10:00:54] Opted in to client beta 'publicbeta' via beta file
You are in the 'publicbeta' client beta.
Installing breakpad exception handler for appid(steam)/version(1652308694)
SteamUpdateUI: An X Error occurred
X Error of failed request: BadValue (integer parameter out of range for operation)
This is after I updated Manjaro this morning. Does using the Public Beta matter, is so how do I change this manually?
