whm1974
December 31, 2020, 4:35am
1
I want to play Game that I started playing after a few of playing due being stuck in the Game. I merely desired to play a game before going to sleep. And this is the Errors I’m getting.
’ Running Steam on manjarolinux 20.2 64-bit
STEAM_RUNTIME is enabled by the user
Pins up-to-date!
Steam client’s requirements are satisfied
/home/william/.local/share/Steam/ubuntu12_32/steam ’
Thanks for any Help with this. Should I uninstall both Manjaro and Native? Then reinstall one of them or both?
Sorry forgot how to post Code.
omano
December 31, 2020, 1:03pm
2
How do you start Steam? What happens if you try to start steam from a terminal?
steam
Also maybe always give your system information it can always have good info for later
inxi -Fazy
whm1974
December 31, 2020, 2:09pm
3
While it was working fine until I did the updates and reboot. I tried uninstalling, rebooting, and reinstalling, and rebooted again.
I even turn off the computer, went to bed and trued again. This is what I got,
steam
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
[2020-12-31 08:05:07] Startup - updater built Dec 28 2020 22:10:02
[2020-12-31 08:05:07] Opted in to client beta ‘publicbeta’ via beta file
You are in the ‘publicbeta’ client beta.
Installing breakpad exception handler for appid(steam)/version(1609211032)
SteamUpdateUI: An X Error occurred
X Error of failed request: BadValue (integer parameter out of range for operation)
No matter if I steam. or, STEAM_RUNTIME=1 steam , either 1 or 2.
whm1974
December 31, 2020, 3:03pm
4
this what I got when I Typed: inxi -Fazy
Kernel: 5.4.85-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=1a0a0cfd-5864-4f2c-a234-2c68123345f3 rw quiet apparmor=1
security=apparmor resume=UUID=71d36dd7-2f3d-4818-b32c-2b6569961193
udev.log_priority=3
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: Z87 Pro3 serial: <filter>
BIOS: American Megatrends v: P2.90 date: 07/11/2014
Info: Quad Core model: Intel Core i5-4670 bits: 64 type: MCP arch: Haswell
family: 6 model-id: 3C (60) stepping: 3 microcode: 28 L2 cache: 6 MiB
bogomips: 27200
Speed: 2140 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 2140 2: 2308
3: 2006 4: 3116
Type: l1tf
Device-1: NVIDIA GK104 [GeForce GTX 760] vendor: eVga.com. driver: nvidia
v: 450.80.02 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1187
Display: x11 server: X.Org 1.20.10 driver: nvidia unloaded: nouveau
display ID: :0.0 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.7x16.7")
s-diag: 798mm (31.4")
Monitor-1: DVI-I-1 res: 2560x1600 hz: 60 dpi: 101
size: 641x401mm (25.2x15.8") diag: 756mm (29.8")
OpenGL: renderer: GeForce GTX 760/PCIe/SSE2 v: 4.6.0 NVIDIA 450.80.02
direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
Device-2: NVIDIA GK104 HDMI Audio vendor: eVga.com. driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:0e0a
Sound Server: ALSA v: k5.4.85-1-MANJARO
Device-1: Intel Ethernet I217-V vendor: ASRock driver: e1000e v: 3.2.6-k
port: f040 bus ID: 00:19.0 chip ID: 8086:153b
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 4.48 TiB used: 679.25 GiB (14.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT960M500SSD1
size: 894.25 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: MU02
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT960M500SSD1
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: Expansion Desk
size: 2.73 TiB block size: physical: 4096 B logical: 4096 B serial: <filter>
rev: 0711
ID-1: / raw size: 55.88 GiB size: 54.75 GiB (97.98%) used: 32.78 GiB (59.9%)
fs: ext4 dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw size: 836.47 GiB size: 823.22 GiB (98.42%)
used: 646.47 GiB (78.5%) fs: ext4 dev: /dev/sdb6 maj-min: 8:22
ID-1: swap-1 type: partition size: 1.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb5 maj-min: 8:21
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 74 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 42%
Processes: 189 Uptime: 23m wakeups: 0 Memory: 15.57 GiB
used: 1.65 GiB (10.6%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.0 Packages: pacman: 1774 lib: 522 flatpak: 0 Shell: Bash
v: 5.1.0 running in: xfce4-terminal inxi: 3.2.01
How are User supposed to post Error Properly?
BTW I did notice I’m using the Steam Pubic Beta. Anyway to force the Steam Client to change back to Standard?
According to this Arch Wiki page https://wiki.archlinux.org/index.php/Steam/Troubleshooting#Steam:_An_X_Error_occurred
Your nvidia
package has to match the version of: lib32-nvidia-utils
In my case I ran pacman -Qs nvidia
to get these versions (I’m currently using the 5.4 Kernel like you):
local/lib32-nvidia-utils 455.45.01-3
local/linux54-nvidia 455.45.01-6 (linux54-extramodules)
If the versions don’t match up, just run sudo pacman -S linux54-nvidia
. This should replace the old 440 driver package and make Steam work again.
I wish you a happy new year, I hope this helped. It certainly fixed the Steam issue for me
whm1974
December 31, 2020, 5:51pm
6
Thanks I just chroot into my system and use pacman to correct my mistake.
I’ll let know if it worked or not.
whm1974
December 31, 2020, 5:57pm
7
Thanks it worked. Now to to properly set up the 5.10 kernel…
whm1974
December 31, 2020, 6:11pm
8
Steam now runs. before I rebooted and after I installed and booted from the 5.10 Kernel.
Thanks again for your help.
system
Closed
January 15, 2021, 6:11pm
9
