Steam no longer runs
steam no longer opens I tried uninstalling and reinstalling and still
running steam from the terminal gives this
Running Steam on manjarolinux 18.1.2 64-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
if you fully exit steam and run
steam --console
from the terminal it will output a lot of launch data, it will also get dumped to /tmp/dumps/$username_stdout
can you see any thing weird there?
If it just prints the same as whats in your initial post it means steam is running somewhere.
so you can use ps -aux | grep steam to find the process then use kill $pid where $pid is the pid of the steam process. then try launching from the terminal again to get the output.
Please, open a terminal and run:
STEAM_RUNTIME_HEAVY=1 steam
Then copy here everything.
I had issues with Steam running on the Nvidia 440xx drivers and had to revert to 435xx. Maybe that'll help you too?
It strangely went away with a reboot. Everything is working now. Maybe a combination of reinstall and rebooting was the solution
update 2 apperntly running it from the start menu is what dosn't work for some reason autostart works and running it the term with steam --console works
Update it came back it seems to randomly work or not work running steam --console gives this
andres  andres-pc  ~  steam --console
Pins up-to-date!
Installing breakpad exception handler for appid(steam)/version(1572467527)
Gtk-Message: 17:16:17.283: Failed to load module "appmenu-gtk-module"
Gtk-Message: 17:16:17.289: Failed to load module "appmenu-gtk-module"
(steam:31973): Gtk-WARNING **: 17:16:17.291: Unable to locate theme engine in module_path: "adwaita",
(steam:31973): Gtk-WARNING **: 17:16:17.295: Unable to locate theme engine in module_path: "murrine",
(steam:31973): Gtk-WARNING **: 17:16:17.296: Unable to locate theme engine in module_path: "murrine",
(steam:31973): Gtk-WARNING **: 17:16:17.297: Unable to locate theme engine in module_path: "murrine",
STEAM_RUNTIME_HEAVY: ./steam-runtime-heavy
[1101/171618.494800:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: browser
[1101/171618.537632:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[1101/171618.537753:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1572466106
[1101/171618.537761:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[1101/171618.537768:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
CAppInfoCacheReadFromDiskThread took 149 milliseconds to initialize
[1101/171618.630970:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[1101/171618.631067:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1572466106
[1101/171618.631071:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[1101/171618.631074:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[1101/171618.631672:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: gpu-process
CApplicationManagerPopulateThread took 393 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
Local Device Found
type: 9886 0025
path: 0005:0002:03
serial_number: - 0
Manufacturer:
Product:
Release: 71
Interface: 3
Unable to open local device: 0005:0002:03
Local Device Found
type: 9886 0025
path: 0005:0002:04
serial_number: - 0
Manufacturer:
Product:
Release: 71
Interface: 4
Unable to open local device: 0005:0002:04
Local Device Found
type: 045e 028e
path: sdl://1
serial_number: - 0
Manufacturer:
Product: X360 Controller
Release: 110
Interface: -1
!! Steam controller device opened for index 0.
Steam Controller reserving XInput slot 0
[1101/171619.312887:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[1101/171619.312941:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1572466106
[1101/171619.312945:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[1101/171619.312950:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[1101/171619.313530:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: utility
Fontconfig warning: "/home/andres/.local/share/Steam/bin/panorama/etc/fonts/conf.d/41-repl-os-win.conf", line 148: Having multiple values in isn't supported and may not work as expected
Fontconfig warning: "/home/andres/.local/share/Steam/bin/panorama/etc/fonts/conf.d/41-repl-os-win.conf", line 160: Having multiple values in isn't supported and may not work as expected
Compiled against SDL version 2.0.11 and linked against SDL version 2.0.11
COpenGLSurface::BInitialize: Current session is 6
sh: /usr/bin/alienware_wmi_control.sh: No such file or directory
defaultfocus=DummyInput not found within layout file for welcome_nocontroller
Opted-in Controller Mask for AppId 0: 7
Controller 0 connected, configuring it now...
Controller has an Invalid or missing unit serial number, setting to '45e-28e-72d64f9'
(steam:31973): Gtk-WARNING **: 17:16:22.175: gtk_disable_setlocale() must be called before gtk_init()
Controller device closed after hid_read failure
DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 51 (53 input number was)
!! Controller 0 attributes:
Type: 31
ProductID: 654
Serial: 45e-28e-72d64f9
Capabilities: 001843ff
Firmware Version: 0
Firmware Build Time: 2147483647 (Tue, 19 Jan 2038 03:14:07 GMT)
Bootloader Build Time: 2147483647 (Tue, 19 Jan 2038 03:14:07 GMT)
Could not load local selection (), local override (/home/andres/.local/share/Steam//controller_config/bigpicture_gamepad.vdf), or user path (/home/andres/.local/share/Steam/userdata/120415481/config/controller_configs/bigpicture_gamepad.vdf), checking last resort path: /home/andres/.local/share/Steam//controller_base/bigpicture_gamepad.vdf
Loaded Config for Last Resort Path for App ID 413090, Controller 0: /home/andres/.local/share/Steam//controller_base/bigpicture_gamepad.vdf
[413090]Non-Steam Controller Configs Enabled: 1
Loaded Config for Local Override Path for App ID 413080, Controller 0: /home/andres/.local/share/Steam//controller_base/empty.vdf
[413080]Non-Steam Controller Configs Enabled: 1
Controller 0 disconnected
DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 55 (57 input number was)
Slow image load - /home/andres/.local/share/Steam/tenfoot/resource/images/mainmenu_bg_2.png (dimensions 1920x1080, took 50 msec)
Fossilize INFO: Overriding serialization path: "/home/andres/.local/share/Steam/shader_cache_temp_dir_vk_64/fozpipelinesv4/steamapprun_pipeline_cache".
Local Device Found
type: 9886 0025
path: 0005:0002:03
serial_number: - 0
Manufacturer:
Product:
Release: 71
Interface: 3
Local Device Found
type: 9886 0025
path: 0005:0002:04
serial_number: - 0
Manufacturer:
Product:
Release: 71
Interface: 4
Local Device Found
type: 045e 028e
path: sdl://1
serial_number: - 0
Manufacturer:
Product: dev:ps4:Astro C40
Release: 110
Interface: -1
Type: 34
ProductID: 654
Firmware Version: 0
Loaded Config for Local Selection Path for App ID 413090, Controller 0: /home/andres/.local/share/Steam/steamapps/workshop/content/241100/1689651975/1007024772344596662_legacy.bin
BYieldingQueryAccountsRegisteredToController
Loaded Config for Local Selection Path for App ID 413090, Controller 0: /home/andres/.local/share/Steam/steamapps/workshop/content/241100/1557869049/956347096063717719_legacy.bin
Local Device Found
type: 9886 0025
path: 0005:0002:03
serial_number: - 0
Manufacturer:
Product:
Release: 71
Interface: 3
Local Device Found
type: 9886 0025
path: 0005:0002:04
serial_number: - 0
Manufacturer:
Product:
Release: 71
Interface: 4
defaultfocus=Cancel not found within layout file for LoginProgress
roaming config store loaded successfully - 31395 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 10ms
[1101/171629.948320:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[1101/171630.033145:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[1101/171630.134875:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
ExecCommandLine: "'/home/andres/.local/share/Steam/ubuntu12_32/steam' '--console'"
[1101/171631.689571:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
System startup time: 16.04 seconds
Type: 34
ProductID: 654
Firmware Version: 0
Fetching Config Sets 0
CClientJobFetchPersonalizationFileID
[1101/171631.716294:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[1101/171631.722000:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 2345 (2347 input number was)
DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 1334 (2380 input number was)
Slow image load - /home/andres/.local/share/Steam/tenfoot/resource/images/profile/activity_bg_wash.png (dimensions 1879x928, took 32 msec)
Slow image load - /home/andres/.local/share/Steam/tenfoot/resource/images/profile/profile_bg_wash.png (dimensions 1879x928, took 32 msec)
Slow image load - /home/andres/.local/share/Steam/tenfoot/resource/images/systemmenu/capsule_glow.png (dimensions 1920x1080, took 55 msec)
DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 688 (1448 input number was)
Slow image load - /home/andres/.local/share/Steam/tenfoot/resource/images/background_alpha_mask.png (dimensions 1920x1080, took 24 msec)
DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 79 (755 input number was)
Slow image load - /home/andres/.local/share/Steam/tenfoot/resource/images/panel_background.png (dimensions 1920x1080, took 62 msec)
BuildCompleteAppOverviewChange: 286
(steam:31973): Gtk-WARNING **: 17:16:32.531: gtk_disable_setlocale() must be called before gtk_init()
(steam:31973): Gtk-WARNING **: 17:16:32.533: gtk_disable_setlocale() must be called before gtk_init()
(steam:31973): Gtk-WARNING **: 17:16:32.535: gtk_disable_setlocale() must be called before gtk_init()
(steam:31973): Gtk-WARNING **: 17:16:32.536: gtk_disable_setlocale() must be called before gtk_init()
(steam:31973): Gtk-WARNING **: 17:16:32.537: gtk_disable_setlocale() must be called before gtk_init()
(steam:31973): Gtk-WARNING **: 17:16:32.539: gtk_disable_setlocale() must be called before gtk_init()
(steam:31973): Gtk-WARNING **: 17:16:32.540: gtk_disable_setlocale() must be called before gtk_init()
(steam:31973): Gtk-WARNING **: 17:16:32.541: gtk_disable_setlocale() must be called before gtk_init()
RegisterForAppOverview 1: 21ms
RegisterForAppOverview 2: 22ms
**** Panel FavoritePages has fill-parent-flow for height, but isn't in a flowing down or up layout
DeleteFBOFreeList: Removing 73 FBO objects, total 0
[1101/171636.603494:ERROR:frame_sink_video_capturer_impl.cc(197)] Invalid resolutions constraints: 0x0 must not be greater than 0x0; and also within media::limits.
Server communication taking a long time
[1101/171638.684993:ERROR:nss_ocsp.cc(584)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1101/171638.685067:ERROR:nss_ocsp.cc(584)] No URLRequestContext for NSS HTTP handler. host: crl4.digicert.com
[1101/171638.686065:ERROR:nss_ocsp.cc(584)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1101/171638.686087:ERROR:nss_ocsp.cc(584)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1101/171638.686100:ERROR:nss_ocsp.cc(584)] No URLRequestContext for NSS HTTP handler. host: crl4.digicert.com
Exiting workitem thread
[2019-11-01 17:16:15] Startup - updater built Oct 30 2019 20:05:18
[2019-11-01 17:16:15] Opted in to client beta 'publicbeta' via beta file
You are in the 'publicbeta' client beta.
[2019-11-01 17:16:15] Verifying installation...
[2019-11-01 17:16:15] Verification complete
[2019-11-01 17:16:39] Shutdown
I am having an issue as well.
STEAM_RUNTIME_HEAVY=1 steam and steam --console show:
Pins up-to-date!
 grahamd  ~ 
any chance you are running Manjaro in a VM?
also over here the solution was to log in to your account via the browser and disable family view.
https://support.steampowered.com/kb_article.php?ref=5149-eopc-9918
no I running it on physical hardware
family view is disabled for me
that's about the best I have sorry, we will need to hope some one with more know how comes along.
its okay I figured it out apparently my steam install got corrupted probably because I was using steam LSI anyway I deleted the steam folder and reinstalled the steam-manjaro package and everything works fine
