Steam isn't preinstalled
I installed Manjaro Gnome and steam isn’t preinstalled and I’m not sure how to install it. I tried using
lutris instead but got a error saying “expected str, bytes or os.PathLike object, not NoneType”
https://wiki.manjaro.org/index.php/Pamac
Install steam-manjaro if you want to use Steam’s bundled libraries (recommended) or steam-native if you want it to use the system libraries instead (might break some games).
Thank you
