Steam games won't launch (launches and instantly dies)
I have steam installed and I can open the application, but no games will launch. I found a solution by using flatpak to install steam on run games this way but it is pretty unreliable since games don’t always launch correctly, and for some reason i couldn’t use prime-run to use my nvidia card to run my games.
I have no clue on what’s happening so i’m looking for a new solution. Ideally I would like my games to be ran on my Nvidia graphics card. Thank you for your time.
Here is the output of steam steam.//rungameid/291550
steam.sh[5839]: Running Steam on manjarolinux 21.2.6 64-bit
steam.sh[5839]: STEAM_RUNTIME is enabled automatically
setup.sh[5913]: Steam runtime environment up-to-date!
steam.sh[5839]: Steam client's requirements are satisfied
[2022-04-24 16:12:08] Startup - updater built Mar 14 2022 19:48:46
Installing breakpad exception handler for appid(steam)/version(1647446817)
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2022-04-24 16:12:09] Loading cached metrics from disk (/home/maxime/.local/share/Steam/package/steam_client_metrics.bin)
[2022-04-24 16:12:09] Using the following download hosts for Public, Realm steamglobal
[2022-04-24 16:12:09] 1. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-04-24 16:12:09] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-04-24 16:12:09] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2022-04-24 16:12:09] Checking for update on startup
[2022-04-24 16:12:09] Checking for available updates...
[2022-04-24 16:12:09] Downloading manifest: https://cdn.akamai.steamstatic.com/client/steam_client_ubuntu12
[2022-04-24 16:12:09] Download skipped: /client/steam_client_ubuntu12 version 1647446817, installed version 1647446817, existing pending version 0
[2022-04-24 16:12:09] Nothing to do
[2022-04-24 16:12:09] Verifying installation...
[2022-04-24 16:12:09] Performing checksum verification of executable files
[2022-04-24 16:12:16] Verification complete
Loaded SDL version 2.0.21-7140709
(steam:5977): Gtk-WARNING **: 16:12:17.152: Unable to locate theme engine in module_path: "adwaita",
(steam:5977): Gtk-WARNING **: 16:12:17.170: Unable to locate theme engine in module_path: "murrine",
(steam:5977): Gtk-WARNING **: 16:12:17.171: Unable to locate theme engine in module_path: "murrine",
(steam:5977): Gtk-WARNING **: 16:12:17.191: Unable to locate theme engine in module_path: "murrine",
(steam:5977): Gtk-WARNING **: 16:12:17.192: Unable to locate theme engine in module_path: "murrine",
steamwebhelper.sh[6011]: Runtime for steamwebhelper: defaulting to /home/maxime/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[6011]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 115 milliseconds to initialize
(steam:5977): GLib-CRITICAL **: 16:12:24.269: g_main_context_push_thread_default: assertion 'acquired_context' failed
(steam:5977): GLib-CRITICAL **: 16:12:24.270: g_main_context_pop_thread_default: assertion 'g_queue_peek_head (stack) == context' failed
(steam:5977): Gtk-WARNING **: 16:12:24.462: gtk_disable_setlocale() must be called before gtk_init()
Connectivity test: result=Connected, in progress=0
BuildCompleteAppOverviewChange: 1
roaming config store loaded successfully - 2558 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 81ms
MESA-INTEL: warning: Performance support disabled, consider sysctl dev.i915.perf_stream_paranoid=0
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/maxime/.local/share/Steam/ubuntu12_32/steam' 'steam://rungameid/291550'"
ExecuteSteamURL: "steam://rungameid/291550"
System startup time: 27.92 seconds
GameAction [AppID 291550, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
BuildCompleteAppOverviewChange: 111
RegisterForAppOverview 1: 15ms
RegisterForAppOverview 2: 16ms
fsync: up and running.
wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
wine: Unhandled page fault on execute access to 00007F36B0EFA3B0 at address 00007F36B0EFA3B0 (thread 00d0), starting debugger...
GameAction [AppID 291550, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 291550, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 291550, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 291550, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/maxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=291550 -- '/home/maxime/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/maxime/.local/share/Steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun  '/home/maxime/.local/share/Steam/steamapps/common/Brawlhalla/Brawlhalla.exe' -framefixunbounded\0
Game process added : AppID 291550 "/home/maxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=291550 -- '/home/maxime/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/maxime/.local/share/Steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun  '/home/maxime/.local/share/Steam/steamapps/common/Brawlhalla/Brawlhalla.exe' -framefixunbounded", ProcID 6748, IP 0.0.0.0:0
chdir /home/maxime/.local/share/Steam/steamapps/common/Brawlhalla
ERROR: ld.so: object '/home/maxime/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
GameAction [AppID 291550, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 291550, ActionID 1] : LaunchApp changed task to Completed with ""
ERROR: ld.so: object '/home/maxime/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
pid 6753 != 6750, skipping destruction (fork without exec?)
ThreadGetProcessExitCode: no such process 6944
ThreadGetProcessExitCode: no such process 6942
ThreadGetProcessExitCode: no such process 6941
ThreadGetProcessExitCode: no such process 6940
ThreadGetProcessExitCode: no such process 6751
ThreadGetProcessExitCode: no such process 6947
wine: Unhandled page fault on execute access to 00007F5C6E0A13B0 at address 00007F5C6E0A13B0 (thread 00d0), starting debugger...
Game process updated : AppID 291550 "/home/maxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=291550 -- '/home/maxime/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/maxime/.local/share/Steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun  '/home/maxime/.local/share/Steam/steamapps/common/Brawlhalla/Brawlhalla.exe' -framefixunbounded", ProcID 6943, IP 0.0.0.0:0
Setting breakpad minidump AppID = 291550
Steam_SetMinidumpSteamID:  Caching Steam ID:  76561198341276603 [API loaded no]
ThreadGetProcessExitCode: no such process 6997
ThreadGetProcessExitCode: no such process 6986
pid 6945 != 6944, skipping destruction (fork without exec?)
Game process removed: AppID 291550 "/home/maxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=291550 -- '/home/maxime/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/maxime/.local/share/Steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun  '/home/maxime/.local/share/Steam/steamapps/common/Brawlhalla/Brawlhalla.exe' -framefixunbounded", ProcID 6943
ThreadGetProcessExitCode: no such process 7000
ThreadGetProcessExitCode: no such process 6980
ThreadGetProcessExitCode: no such process 6974
ThreadGetProcessExitCode: no such process 6961
ThreadGetProcessExitCode: no such process 6952
ThreadGetProcessExitCode: no such process 6949
ThreadGetProcessExitCode: no such process 6943
ThreadGetProcessExitCode: no such process 6939
ThreadGetProcessExitCode: no such process 6750
Game 291550 created interface STEAMAPPLIST_INTERFACE_VERSION001 / AppList
Game 291550 created interface STEAMAPPS_INTERFACE_VERSION008 / Apps
Game 291550 created interface STEAMHTMLSURFACE_INTERFACE_VERSION_004 / HTMLSurface
Game 291550 created interface STEAMHTTP_INTERFACE_VERSION002 / HTTP
Game 291550 created interface STEAMINVENTORY_INTERFACE_V002 / Inventory
Game 291550 created interface STEAMMUSICREMOTE_INTERFACE_VERSION001 / MusicRemote
Game 291550 created interface STEAMMUSIC_INTERFACE_VERSION001 / Music
Game 291550 created interface STEAMPARENTALSETTINGS_INTERFACE_VERSION001 / ParentalSettings
Game 291550 created interface STEAMREMOTESTORAGE_INTERFACE_VERSION014 / RemoteStorage
Game 291550 created interface STEAMSCREENSHOTS_INTERFACE_VERSION003 / Screenshots
Game 291550 created interface STEAMUGC_INTERFACE_VERSION010 / UGC
Game 291550 created interface STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
Game 291550 created interface STEAMVIDEO_INTERFACE_V002 / Video
Game 291550 created interface SteamController006 / Controller
Game 291550 created interface SteamFriends015 / Friends
Game 291550 created interface SteamMatchMaking009 / Matchmaking
Game 291550 created interface SteamMatchMakingServers002 / MatchmakingServers
Game 291550 created interface SteamNetworking005 / Networking
Game 291550 created interface SteamUser019 / User
Game 291550 created interface SteamUtils009 / Utils
Game 291550 method call count for IClientAppManager::GetAppInstallState : 2
Game 291550 method call count for IClientUtils::RecordSteamInterfaceCreation : 22
Game 291550 method call count for IClientUtils::GetSteamUILanguage : 1
Game 291550 method call count for IClientUtils::GetAppID : 24
Game 291550 method call count for IClientUser::GetSteamID : 1
Uploaded AppInterfaceStats to Steam
System info : (output of inxi --admin --verbosity=7 --filter --width
  Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    root=UUID=f4c74f99-4d25-41cc-ab23-54fd74606ad3 rw nouveau.modset=0 quiet
  Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
    v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: Dell product: Latitude E5450 v: N/A
    serial: <superuser required> Chassis: type: 9 serial: <superuser required>
  Mobo: Dell model: 06J17N v: A00 serial: <superuser required>
    UEFI-[Legacy]: Dell v: A15 date: 05/09/2017
  ID-1: BAT0 charge: 38.2 Wh (100.0%) condition: 38.2/51.7 Wh (73.9%)
    volts: 8.4 min: 7.6 model: Samsung SDI DELL 1KY05D9 type: Li-poly
    serial: <filter> status: full
  RAM: total: 3.72 GiB used: 2.2 GiB (59.1%)
  RAM Report:
  Info: model: Intel Core i5-5300U bits: 64 type: MT MCP arch: Broadwell
    family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1952 high: 2295 min/max: 500/2900 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1443 2: 1778 3: 2295
    4: 2295 bogomips: 18365
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fxsr hle ht ibpb ibrs ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
    pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good rtm sdbg sep
    smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    xsave xsaveopt xtopology xtpr
  Type: l1tf
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
  Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel ports:
    active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:1616 class-ID: 0300
  Device-2: NVIDIA GM108M [GeForce 830M] vendor: Dell driver: nvidia
    v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s
    lanes: 4 link-max: gen: 2 speed: 5 GT/s bus-ID: 03:00.0 chip-ID: 10de:1340
    class-ID: 0302
  Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
    bus-ID: 1-1.6:4 chip-ID: 0c45:6709 class-ID: 0e02
  Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
    X: loaded: modesetting gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
  Monitor-1: eDP-1 model: BOE Display 0x05f3 built: 2013 res: 1366x768
    hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
    ratio: 16:9 modes: 1366x768
  OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 21.3.8
    direct render: Yes
  Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
    class-ID: 0403
  Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.49 running: yes
  Device-1: Intel Ethernet I218-LM driver: N/A modules: e1000e port: f080
    bus-ID: 00:19.0 chip-ID: 8086:155a class-ID: 0200
  Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
    bus-ID: 1-1.3:3 chip-ID: 8087:0a2a class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 port: f060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 465.76 GiB used: 85.85 GiB (18.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LM030-2E717D
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: MBR
  ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 85.85 GiB (18.8%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: f4c74f99-4d25-41cc-ab23-54fd74606ad3
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
  Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s
    chip-ID: 8087:8001 class-ID: 0900
  Device-1: 1-1.3:3 info: Intel Bluetooth wireless interface type: Bluetooth
  Device-2: 1-1.6:4 info: Microdia Integrated_Webcam_HD type: Video
  Device-3: 1-1.7:5 info: Broadcom BCM5880 Secure Applications Processor
    with fingerprint swipe sensor
    type: Smart Card driver: N/A interfaces: 4 rev: 1.1 speed: 12 Mb/s
    power: 100mA chip-ID: 0a5c:5804 class-ID: 0b00 serial: <filter>
  Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 11 rev: 2.0
  Device-1: 2-2:2 info: Lite-On USB Optical Mouse type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
    power: 100mA chip-ID: 04ca:0061 class-ID: 0301
  Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 48.0 C mobo: 45.0 C sodimm: SODIMM C
  Fan Speeds (RPM): cpu: 0
  Processes: 221 Uptime: 18m wakeups: 1 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1347 pacman: 1318 lib: 448
  flatpak: 12 snap: 17 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
  inxi: 3.3.15
I would suggest to switch to 470xx driver with your GPU.
Also if there is no specific reason to use Proton Experimental, switch the regular Proton 7 (may or may not require to wipe the prefix at ~/.local/share/Steam/steamapps/compatdata/).
do you have manghud installed? the previous stable update broke mangohud and steam. try disabling mangohud with goverlay and remove the launch option from the game.
