Which itself links to other issues/commits.
One thread suggests trying env var
SDL_VIDEO_MINIMIZE_ON_FOCUS_LOSS=0
I will try that later, thanks!
@Yochanan hello! This can be marked as a issue from the last stable update (04/06/2023)?
The problem seems be with this version of Mutter.
I am facing the same issue that is showing in the previous links that I posted.
If necessary, I can post more details.
Thanks!
Hello, folks.
I still have the same problem.
I am thinking in downgrade Mutter ou install a AUR version just to test, but, I am not a expert, and if something goes wrong, I probably won’t know how to fix.
Meanwhile, still hopping for some solution or for the next update…
As I mostly play games via Lutris, as of late, I finally tested Steam too.
I have somewhat similar issue with glxinfo: not found
and having mesa-utils
package installed - in my case disabling mangohud
overlay with MANGOHUD=0
in Steam launch options solved my issue of Steam games not starting.
Here are my Steam launch options:
gamemoderun MANGOHUD=0 %command%
Update:
mangohud
with Lutris works just fine.
Hello, everybody.
Last update.
On the last stable update (2023-07-10), the issue gone away.
I really don’t have a very precise diagnosis, but mutter
was updated, so, probably my theory was correct. Steam games are launching correctly.
One problem remain: caffeine-ng
still crashing or with bad behavior.
But, for the problem on this thread, I assume that the issue was solved by just updating.
