hi.
after resent upgrade, my manjaro gnome started experiencing this issue.
i would be very thankful, if anyone could help me with this issue. here are my specs:
OS: Manjaro Linux x86_64
Host: GF65 Thin 10SDR REV:1.0
Kernel: 6.1.7-1-MANJARO
Uptime: 3 hours, 5 mins
Packages: 1705 (pacman)
Shell: zsh 5.9
Resolution: 1920x1080 @ 144.15Hz, 1920x1080 @ 143.98Hz
DE: GNOME 43.2
WM: Mutter
WM Theme: Matcha-sea
Theme: Matcha-light-sea [GTK2/3]
Icons: Papirus-Maia [GTK2/3]
Terminal: gnome-terminal
CPU: Intel i7-10750H (12) @ 5.000GHz
GPU: NVIDIA GeForce GTX 1660 Ti Mobile
Memory: 14.66GiB / 31.17GiB
Disk (/): 35G / 48G (77%)
Disk (home): 71G / 420G (18%)
Disk (disk): 500G / 916G (58%)
i got dual GPU on my laptop! integrated and nvidia.
if i change the display settings from my laptop, i get the primary to unfreeze. also re-plugging the monitor cable helps. sometimes it freezes for few seconds, sometimes completely. i have no idea, how to debug it.
i was using kernel 5.15 and upgraded to latest to see if this fixes the problem.
i’ll provide more information as you ask!
keevitaja:
here are my specs
We’ll need a little more information than that.
Please see:
what type of information you need? i’ll gladly provide additional information. i am just a simple user. do not know how to dig any deeper.
First of all your full system information as described in the link I already provided:
The wiki and tutorials are there for a reason. Please read them. If you have any questions, feel free to ask.
tnx! here is the requested information
Kernel: 6.1.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=1edf72db-d3e8-47d1-9201-a5cfa27e1efb rw quiet
udev.log_priority=3
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Micro-Star product: GF65 Thin 10SDR v: REV:1.0
Mobo: Micro-Star model: MS-16W1 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16W1IMS.50B date: 05/19/2020
ID-1: BAT1 charge: 50.7 Wh (100.0%) condition: 50.7/51.3 Wh (98.9%)
volts: 12.8 min: 11.4 model: MSI Corp. MS-16W1 type: Li-ion serial: N/A
status: full
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 31.17 GiB used: 3.19 GiB (10.2%)
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0xF4
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2000 high: 2600 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 2600 2: 2600 3: 800
4: 2600 5: 2600 6: 800 7: 2600 8: 800 9: 2600 10: 2600 11: 800 12: 2600
bogomips: 62431
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Micro-Star MSI
driver: nvidia v: 525.85.05 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:2191
class-ID: 0300
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :1
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: HDMI-1-0 pos: primary,left res: 1920x1080 hz: 144 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: eDP-1 pos: right res: 1920x1080 hz: 144 dpi: 142
size: 344x193mm (13.54x7.6") diag: 394mm (15.53") modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: Mesa Intel UHD Graphics (CML GT2)
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Sound API: ALSA v: k6.1.7-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.64 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
IF-ID-1: br-28fa11b00737 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: veth2f20346 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-4: veth7e9f65e state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: vethd13a04e state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-6: vethded97e3 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-7: vetheb85bf0 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:5
chip-ID: 8087:0026 class-ID: e001
Device-1: luks-cab6c7fd-4b0a-4197-8b19-d8f2119cc7e4 maj-min: 254:0
type: LUKS dm: dm-0 size: 427.62 GiB
Components:
p-1: nvme1n1p3 maj-min: 259:4 size: 427.62 GiB
Local Storage: total: 1.38 TiB used: 605.28 GiB (43.0%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 3B2QEXM7 temp: 33.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1032 size: 476.94 GiB block-size: physical: 512 B
rev: 21111000 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 34.89 GiB (73.1%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:3 label: N/A
uuid: 1edf72db-d3e8-47d1-9201-a5cfa27e1efb
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
label: NO_LABEL uuid: 3ED8-9B8B
ID-3: /disk raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
used: 499.82 GiB (54.6%) fs: ext4 dev: /dev/nvme0n1 maj-min: 259:1
label: disk uuid: fd9709f4-de6f-4289-b2e3-61b5ac58233e
ID-4: /home raw-size: 427.62 GiB size: 419.83 GiB (98.18%)
used: 70.57 GiB (16.8%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-cab6c7fd-4b0a-4197-8b19-d8f2119cc7e4 label: N/A
uuid: a62fb052-0601-468e-81d4-1fd028bc804b
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-3:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-4:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
Device-3: 1-14:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-4: 2-2:2 info: Genesys Logic Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0626 class-ID: 0900
System Temperatures: cpu: 44.0 C pch: 51.0 C mobo: N/A
Processes: 375 Uptime: 2m wakeups: 5 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1705 libs: 476 tools: gnome-software,pamac,yay pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.24
e[1me[31m> e[m0000:01:00.0 (0300:10de:2191) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.11.04 false PCI
video-hybrid-intel-nvidia-470xx-prime 2021.11.04 false PCI
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
e[1me[31m> e[m0000:04:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
e[1me[31m> e[m0000:00:02.0 (0300:8086:9bc4) Display controller Intel Corporation:
e[32mCurrently running:e[0m 6.1.7-1-MANJARO (linux61)
* linux510
* linux515
* linux61
ManjaroLinux 22.0.1 Sikaris
It appears the proper drivers are installed.
Change the display settings how?
Maybe your Xorg log could provide more details.
Run this command to upload it to 0x0.st and paste the generated link here:
curl -F 'file=@-' 0x0.st < ~/.local/share/xorg/Xorg.0.log
i have a file Xorg.1.log → http://0x0.st/oFqQ.txt
here’s a journal → http://0x0.st/oFqe.txt
also i noticed, that nvidia.conf is empty
➜ xorg cat /etc/X11/mhwd.d/nvidia.conf
## Generated by mhwd - Manjaro Hardware Detection
➜ xorg
edit: by changing the display setting i mean putting monitors in mirror mode and/or change the primary monitor. that usually unfreezes the primary external monitor.
That’s normal with hybrid graphics.
keevitaja:
Xorg.1.log
Close, but no cigar. Notice I said the Xorg.0.log
However, since you posted your boot log, it’s printed there as well.
Not sure what’s happening, but this looks a bit suspect:
jaan 26 00:25:09 laptop /usr/lib/gdm-x-session[1524]: (WW) NVIDIA(G0): Failed to set the display configuration
jaan 26 00:25:09 laptop /usr/lib/gdm-x-session[1524]: (WW) NVIDIA(G0): - Setting a mode on head 0 failed: Insufficient permissions
jaan 26 00:25:09 laptop /usr/lib/gdm-x-session[1524]: (WW) NVIDIA(G0): - Setting a mode on head 1 failed: Insufficient permissions
jaan 26 00:25:09 laptop /usr/lib/gdm-x-session[1524]: (WW) NVIDIA(G0): - Setting a mode on head 2 failed: Insufficient permissions
jaan 26 00:25:09 laptop /usr/lib/gdm-x-session[1524]: (WW) NVIDIA(G0): - Setting a mode on head 3 failed: Insufficient permissions
jaan 26 00:25:11 laptop /usr/lib/gdm-x-session[3737]: (II) event11 - Logitech MX Master 3: SYN_DROPPED event - some input events have been lost.
jaan 26 00:25:11 laptop kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000c57e:0:0:1128
jaan 26 00:25:11 laptop /usr/lib/gdm-x-session[1524]: (II) NVIDIA(GPU-0): Deleting GPU-0
jaan 26 00:25:11 laptop /usr/lib/gdm-x-session[1524]: (II) Server terminated successfully (0). Closing log file.
jaan 26 00:25:11 laptop gnome-session-f[4276]: Cannot open display:
It detects it properly after you do your fiddling as you mentioned, but I’m a bit stumped why it’s happening. Perhaps someone else has an idea.
Xorg.0.log file does not exist
It does, but for some reason it did not write it to ~/.local/share/xorg/
. It’s in /var/log/
jaan 26 00:24:47 laptop /usr/lib/gdm-x-session[1524]: (--) Log file renamed from "/var/log/Xorg.pid-1524.log" to "/var/log/Xorg.0.log"
i hope someone helps me out here or i have to do a reinstall (hopefully it works), but linux should be flexible enough to fix problems.
there’s more of a mulder and scully going on. this morning external primary monitor was switched off from display settings. i am 110% sure i did not do that last night!
i think disabling google chrome chrome’s hardware acceleration (read the nvidia forum topic) fixed the majority of the issue. no more freezing of the external monitor while working. but somehow gnome will not let me move the external monitor to the left in display settings. when i try to do this, the monitor will freeze.
any feedback is much appriciated!
Linus
2 March 2023 09:43
14
came across this thread since I think I have the same issue on Ubuntu 22.04, I posted a question titled “External displays freezing” on askubuntu as well (I’m not allowed to post links). Did you make any progress?
