I don’t know if it’s related, but since steam-manjaro was updated a while ago, steam stopped detecting my dedicated nvidia video card. I confirmed it because “nvidia-smi” returned error.
What I did was downgrade steam-manjaro to version 1.0.0.61-7, which is the one that my dedicated card correctly detects.
You can downgrade using pacman -U [thepackage]
The package should be backed up in /var/cache/pacman/pkg/steam-manjaro-1.0.0.61-7-x86_64.pkg.tar.xz or something closer to that version.
I believe it’s come down to the application. I went on their forums for help but the super moderator wasn’t familiar enough with Linux to determine the cause. They believe it’s a module, but I’m not sure how to determine which one it is.
omano
18 September 2020 02:31
24
Run Steam from terminal so you have the console output directly. It can help troubleshooting Steam games.
This is what I get when launching Steam through terminal and try to launch Doom
terminal output
[olividir@HP ~]$ steam
Running Steam on manjarolinux 20.1 64-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
Steam client's requirements are satisfied
/home/olividir/.local/share/Steam/ubuntu12_32/steam
[2020-09-26 12:25:13] Startup - updater built Sep 24 2020 19:32:07
[2020-09-26 12:25:13] Opted in to client beta 'publicbeta' via beta file
You are in the 'publicbeta' client beta.
Installing breakpad exception handler for appid(steam)/version(1600993224)
[2020-09-26 12:25:13] Loading cached metrics from disk (/home/olividir/.local/share/Steam/package/steam_client_metrics.bin)
[2020-09-26 12:25:13] Using the following download hosts for Public, Realm steamglobal
[2020-09-26 12:25:13] 1. http://media4.steampowered.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2020-09-26 12:25:13] Verifying installation...
[2020-09-26 12:25:13] Verification complete
Loaded SDL version 2.0.13-5919606
STEAM_RUNTIME_HEAVY: ./steam-runtime-heavy
[0926/122514.670029:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: browser
[0926/122514.691732:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0926/122514.691779:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1600975939
[0926/122514.691785:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0926/122514.691788:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0926/122514.727755:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0926/122514.727803:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1600975939
[0926/122514.727807:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0926/122514.727811:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0926/122514.728307:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: gpu-process
[0926/122514.809856:ERROR:sandbox_linux.cc(372)] InitializeSandbox() called with multiple threads in process gpu-process.
[0926/122514.840593:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0926/122514.840642:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1600975939
[0926/122514.840647:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0926/122514.840652:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0926/122514.841164:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: utility
Warning: failed to set thread priority: set failed for 8: -1: setpriority() failed
Warning: failed to set thread priority: set failed for priority 8
Warning: support for elevated priorities is most likely unavailable, suppressing future warnings
CAppInfoCacheReadFromDiskThread took 39 milliseconds to initialize
CApplicationManagerPopulateThread took 59 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
Proceed to auto login
** (steam:8240): WARNING **: 12:25:15.169: Unknown device type 14
** (steam:8240): WARNING **: 12:25:15.169: Could not create object for /org/freedesktop/NetworkManager/Devices/1: unknown object type
Opted-in Controller Mask for AppId 0: 0
** (steam:8240): WARNING **: 12:25:15.394: Ignoring invalid property 'interface-name'
** (steam:8240): WARNING **: 12:25:15.395: Unknown setting 'proxy'
** (steam:8240): WARNING **: 12:25:15.395: Ignoring invalid property 'route-data'
** (steam:8240): WARNING **: 12:25:15.395: Ignoring invalid property 'address-data'
** (steam:8240): WARNING **: 12:25:15.395: Ignoring invalid property 'autoconnect-priority'
** (steam:8240): WARNING **: 12:25:15.396: Ignoring invalid property 'interface-name'
** (steam:8240): WARNING **: 12:25:15.396: Unknown setting 'proxy'
** (steam:8240): WARNING **: 12:25:15.396: Ignoring invalid property 'route-data'
** (steam:8240): WARNING **: 12:25:15.396: Ignoring invalid property 'address-data'
** (steam:8240): WARNING **: 12:25:15.398: Ignoring invalid property 'interface-name'
** (steam:8240): WARNING **: 12:25:15.398: Unknown setting 'proxy'
** (steam:8240): WARNING **: 12:25:15.399: Ignoring invalid property 'route-data'
** (steam:8240): WARNING **: 12:25:15.399: Ignoring invalid property 'address-data'
** (steam:8240): WARNING **: 12:25:15.399: Ignoring invalid property 'autoconnect-priority'
** (steam:8240): WARNING **: 12:25:15.399: Ignoring invalid property 'interface-name'
** (steam:8240): WARNING **: 12:25:15.399: Unknown setting 'proxy'
** (steam:8240): WARNING **: 12:25:15.400: Ignoring invalid property 'route-data'
** (steam:8240): WARNING **: 12:25:15.400: Ignoring invalid property 'address-data'
(steam:8240): Gtk-WARNING **: 12:25:15.504: gtk_disable_setlocale() must be called before gtk_init()
(steam:8240): LIBDBUSMENU-GLIB-WARNING **: 12:25:15.571: Trying to remove a child that doesn't believe we're it's parent.
(steam:8240): LIBDBUSMENU-GLIB-WARNING **: 12:25:15.572: Trying to remove a child that doesn't believe we're it's parent.
(steam:8240): LIBDBUSMENU-GLIB-WARNING **: 12:25:15.573: Trying to remove a child that doesn't believe we're it's parent.
roaming config store loaded successfully - 3245 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 9ms
[0926/122519.202497:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[0926/122519.267824:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[0926/122519.360136:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/olividir/.local/share/Steam/ubuntu12_32/steam'"
System startup time: 7.19 seconds
Warning: failed to set thread priority: set failed for 4: -1: setpriority() failed
Warning: failed to set thread priority: set failed for priority 4
[0926/122521.002396:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[0926/122521.005390:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
BuildCompleteAppOverviewChange: 122
RegisterForAppOverview 1: 6ms
RegisterForAppOverview 2: 6ms
[379720]Non-Steam Controller Configs Enabled: 1
GameAction [AppID 379720, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
Proton: Missing or invalid openvrpaths.vrpath file! [Errno 2] No such file or directory: '/home/olividir/.config/openvr/openvrpaths.vrpath'
ExecuteSteamURL: "steam://open/downloads"
Edit:
Steam finally “launched” the game, no video of it is being rendered
Summary
Pins up-to-date!
GameAction [AppID 379720, ActionID 1] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 379720, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 379720, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 379720, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 379720, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
Opted-in Controller Mask for AppId 379720: 0
Game update: AppID 379720 "", ProcID 10997, IP 0.0.0.0:0
ERROR: ld.so: object '/home/olividir/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
Starting app 379720
>>> Adding process 10997 for game ID 379720
GameAction [AppID 379720, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
>>> Adding process 10998 for game ID 379720
GameAction [AppID 379720, ActionID 1] : LaunchApp changed task to Completed with ""
>>> Adding process 13830 for game ID 379720
ERROR: ld.so: object '/home/olividir/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
>>> Adding process 13958 for game ID 379720
>>> Adding process 13960 for game ID 379720
>>> Adding process 13963 for game ID 379720
>>> Adding process 13965 for game ID 379720
>>> Adding process 13968 for game ID 379720
>>> Adding process 13977 for game ID 379720
>>> Adding process 13982 for game ID 379720
I have the same problem
When starting steam, it simply indicates in terminal that it does not start my dedicated video card (nvidia). I tried optimus and pvkrun, and both fail.
After starting and keeping steam started, I run nvidia-smi, and it tells me that I don’t have my video card booted up.
With the latest version of steam-manjaro (1.0.0.66-1), it returns the following error regarding my dedicated gpu:
PrimusVK: Searching for display GPU:
PrimusVK: 0x56731a60:
PrimusVK: Got integrated gpu!
PrimusVK: Device: Intel(R) HD Graphics 4000 (IVB GT2)
PrimusVK: Type: 1
PrimusVK: Searching for render GPU:
PrimusVK: 0x56731a60.
PrimusVK: No device for the rendering GPU found. Is the correct driver installed?
PrimusVK: VK_ICD_FILENAMES not set
vkCreateInstance failed with error -3
BInit - Unable to initialize Vulkan!
[0929/203723.960952:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[0929/203724.054021:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[0929/203724.172321:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
Installing breakpad exception handler for appid(steam)/version(1599174997)"
For now the only solution is to downgrade to version steam-manjaro 1.0.0.61
