Trying to fix some problems with pamac it seems I made them worse. I had some error messages (when refreshing databases) regarding missing or invalid pgp keys, when they went away the new error message is
Warning
unexpected system error
Failed to synchronize databases
I had an idea that reinstalling would be of help, so I did sudo pacman -R pamac-manager which resulted in:
the error message persists,
software icons are now missing in pamac’s listing
Now I’d like to reset pamac to “factory defaults” (the way it’s set up after a fresh install of Manjaro).
What is the correct way of achieving this?
checking dependencies...
:: removing libpamac breaks dependency 'libpamac' required by libpamac-flatpak-plugin
:: removing libpamac breaks dependency 'libpamac>=11' required by manjaro-application-utility
:: removing pamac-cli breaks dependency 'pamac-cli' required by manjaro-application-utility
:: removing pamac-gtk breaks dependency 'pamac-gtk' required by manjaro-application-utility
:: removing pamac-gtk breaks dependency 'pamac-gtk' required by pamac-tray-icon-plasma
:: removing libpamac breaks dependency 'libpamac' required by python-manjaro-sdk
I’m worried I’d get into a long list of manual removals and installs, so I tried removing just the config file first rm -r ~/.config/pamac, and after restarting I’m back to my initial error:
invalid or corrupted database (PGP signature)
I’ll see if this guide helps and report back here.
I ran that script 3 times now, but each time it just hangs after the following lines:
gpg: error retrieving 'build@manjaro.org' via WKD: No data
gpg: error reading key: No data
gpg: refreshing 1 key from hkps://keyserver.ubuntu.com
gpg: key 279E7CF5D8D56EC8: "Manjaro Build Server <build@manjaro.org>" not changed
gpg: Total number processed: 1
gpg: unchanged: 1
The script warns “it may take time”, but being stuck for hours seems a bit too much. Any suggestions?
Hijacking other topics is against the forum rules. Please avoid it in the future. I moved your post to this thread because it has the common topic.
Refreshing keys from a Key-Server may take time and can stuck due to the server load. It can just reject or throttle your request. It is purely optional, not entirely necessary, as I wrote you can just say no and skip the step. Try the aggressive method
Sorry about that, I thought since I was trying to achieve something a bit different from the thread title here it was more appropriate to ask about that script in that other thread. No intention of hijacking! Thanks for moving my post.
That finished in a reasonable time, thanks! And after rm -r ~/.config/pamac and starting again, software icons are back and refreshing databases from the pamac gui returns the “good old”
Warning
So I went back to this “recipe”:
Completely removed pamac and reinstalled. The unexpected system error persists.
Being rather convinced pamac is now at “factory default”, should I open a new thread for the system error, or continue investigating the issue here?
The system is up to date, with one exception: I held sane to version 1.1.1-2 because the newer version broke scanning from my HP AiO. But of course there are many tweaks.
I do use AUR for some packages, trying to follow this advice. The script probably was updated after I copied it.
Also, I did some adjustments for audio, following a guide from the user “ElizabethHarmon” (the link is now dead, I find).
Interesting thread which seems to be the same problem. I’m not sure which ownership / permission those files are supposed to have?
After removing and reinstalling pamac (albeit not touching any files in /var), ls -ld /var{,/tmp{,/pamac{,/dbs{,/sync}}}} returned
drwxr-xr-x 12 root root 4096 juli 27 11:26 /var
drwxrwxrwt 10 root root 4096 juli 27 19:41 /var/tmp
drwxrwxrwx 4 user user 4096 juli 27 12:48 /var/tmp/pamac
drwxrwxrwx 3 root root 4096 juli 27 22:26 /var/tmp/pamac/dbs
drwxrwxrwx 2 root root 4096 juli 27 22:26 /var/tmp/pamac/dbs/sync
Like in the other thread I tried to set me as owner (sudo chown -R user:user /var/tmp/pamac/dbs), but running pamac upgrade --force-refresh reverts ownership to root. It shouldn’t matter, though, since the permissions are “access for all” (drwxrwxrwx)?
But the upgrade does return errors:
Refreshing core.db...
Refreshing extra.db...
Refreshing community.db...
Refreshing multilib.db...
Error: multilib.db: GPGME error: No data
Refreshing core.files...
Refreshing extra.files...
Refreshing community.files...
Refreshing multilib.files...
Error: multilib.files: GPGME error: No data
Warning: sane: ignoring package upgrade (1.1.1-2 => 1.2.1-4)
