I use Manjaro linux distribution and updated nim-lang package through Manjaro’s package manager (pamac).
When I try to run a program, I get error: Error: cannot open '/usr/lib/nim/lib/system.nim
I checked and ‘system.nim’ is on ‘/usr/lib/nim/system.nim’ path, not as where vscodium is searching.
I asked on nim-lang forum and this is the reply i got:
Blockquote
This will be that package management changed from 2.0
pacman has worked around this by adding a symlink
PKGBUILD · main · Arch Linux / Packaging / Packages / nim · GitLab
Does pacman work on manjaro? Surely pamac is a wrapper
You’ll need to file a bug report with your distro, you can link them to the updated packaging guidelines Packaging Nim
