Hi, the output of inxi -zv8 is:
Kernel: 7.0.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-7.0-x86_64
root=UUID=5e116f94-6500-4ecf-a067-e962a50a7ba0 ro quiet apparmor=1
Desktop: KDE Plasma v: 6.6.5 tk: Qt v: N/A info: frameworks v: 6.26.0
wm: kwin_wayland vt: 1 dm: 1: LightDM v: 1.32.0 note: stopped 2: SDDM
Type: Desktop Mobo: Gigabyte model: X670 GAMING X AX V2
serial: <superuser required> uuid: <superuser required> Firmware: UEFI
vendor: American Megatrends LLC. v: F39 date: 01/15/2026
System RAM: total: 128 GiB available: 123.44 GiB used: 10.34 GiB (8.4%)
Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 32 GiB speed: 4800 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMH64GX5M2B6000Z30 serial: N/A
Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
Device-3: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MCP arch: Zen 5 gen: 5
level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
model-id: 0x44 (68) stepping: 0 microcode: 0xB404035
Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 smt: <unsupported> cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3792 min/max: 603/5272 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3792 2: 3792 3: 3792
4: 3792 5: 3792 6: 3792 7: 3792 8: 3792 bogomips: 75063
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
cmp_legacy constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc
cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx
ospke osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni
stibp succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale
umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme
vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves xtopology
Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
conditional; STIBP: disabled; PBRSB-eIBRS: Not affected; BHI: Not
affected
Type: vmscape mitigation: IBPB on VMEXIT
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: Sapphire NITRO+ driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2,
HDMI-A-1, HDMI-A-2, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c
class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Granite Ridge [Radeon Graphics]
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: none empty: DP-3, DP-4, DP-5, HDMI-A-3,
Writeback-2 bus-ID: 18:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 44.0 C
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: Samsung LS49AG95 serial: <filter> built: 2022
res: 3840x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.694 y: 0.294 green:
x: 0.275 y: 0.659 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
size: 1193x336mm (46.97x13.23") diag: 1239mm (48.8") modes: 5120x1440,
3840x1080, 3840x2160, 3440x1440, 2560x1440, 1920x1080, 1680x1050,
1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
832x624, 800x600, 720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 118 4: parse_edid:
unknown tag 112
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi
surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 7900 XTX (radeonsi navi31 ACO
DRM 3.64 7.0.10-1-MANJARO) device-ID: 1002:744c memory: 23.44 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.4.350 layers: 15 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 26.1.1-arch1.2
device-ID: 1002:744c surfaces: N/A device: 1 type: integrated-gpu name: AMD
Ryzen 7 9800X3D 8-Core Processor (RADV RAPHAEL_MENDOCINO)
driver: mesa radv v: 26.1.1-arch1.2 device-ID: 1002:13c0 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: amd-smi, corectrl, lact
wl: swaymsg,wayland-info x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-2: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 0e:00.0 chip-ID: 1102:0012 class-ID: 0403
Device-3: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
bus-ID: 18:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-4: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Gigabyte
bus-ID: 18:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-5: Z-Star Micro Zgmicro AUDIO driver: snd-usb-audio type: USB
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.1:16
chip-ID: 0ac8:9628 class-ID: 0102 serial: <filter>
Device-6: Z-Star Micro Zgmicro AUDIO driver: snd-usb-audio type: USB
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.4.3:13
API: ALSA v: k7.0.10-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.6 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8852CE PCIe 802.11ax Wireless Network
driver: rtw89_8852ce v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
port: d000 bus-ID: 0f:00.0 chip-ID: 10ec:c852 class-ID: 0280
IF: wlp15s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 10:00.0
IF: enp16s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Microsoft Xbox Wireless Adapter for Windows driver: xone-dongle
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3
chip-ID: 045e:02e6 class-ID: 0000 serial: <filter>
IF-ID-1: br-968c551c3df2 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Info: services: NetworkManager, nfsd, smbd, sshd, systemd-timesyncd
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-7:5 chip-ID: 0bda:0852
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.3
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 9.54 TiB used: 5.91 TiB (62.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 32.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 4B2QEXM7 temp: 39.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 480GB
size: 447.14 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 00RL scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 EVO 500GB
tech: SSD serial: <filter> fw-rev: DB6Q scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Toshiba model: HDWE160 size: 5.46 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: FS2A scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: SanDisk model: SSD PLUS 480GB
tech: SSD serial: <filter> fw-rev: 00RL scheme: MBR
ID-1: / raw-size: 952.85 GiB size: 936.82 GiB (98.32%)
used: 292.64 GiB (31.2%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:2
label: N/A uuid: 5e116f94-6500-4ecf-a067-e962a50a7ba0
ID-2: /boot/efi raw-size: 1.02 GiB size: 95 MiB (9.09%)
used: 299 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:1 label: N/A
uuid: C2A3-5115
ID-3: /mnt/Data raw-size: 5.46 TiB size: 5.46 TiB (100.00%)
used: 3.22 TiB (59.0%) fs: ntfs dev: /dev/sdc2 maj-min: 8:34 label: Data
uuid: D4EA1B7DEA1B5B56
ID-4: /mnt/Distrobox raw-size: 447.14 GiB size: 447.14 GiB (100.00%)
used: 240.88 GiB (53.9%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
label: DistroBox uuid: fd2ac1ed-efee-403f-a1bb-4c1f9d0f16c5
ID-5: /mnt/Emulatorgames raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 345.96 GiB (74.3%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
label: Emulatorgames uuid: 084cb307-2f1a-4460-837a-e5284435ded2
ID-6: /mnt/KVM-Drive raw-size: 447.14 GiB size: 439.05 GiB (98.19%)
used: 372.35 GiB (84.8%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49
label: KVM-Drive uuid: bac2609d-41fe-4af2-bc04-7ef6e836710f
ID-7: /mnt/Linux-Games raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 1.47 TiB (82.0%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:4
label: Linux-Games uuid: d0987242-5bfa-40e3-a07e-6f674fbc3e14
ID-1: /dev/sdc1 maj-min: 8:33 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-4:2 info: Valve Steam Controller Puck
type: abstract (modem),CDC-data,HID driver: cdc_acm,hid-generic,usbhid
interfaces: 7 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 28de:1304 class-ID: 0300 serial: <filter>
Device-2: 1-5:3 info: Microsoft Xbox Wireless Adapter for Windows
type: WiFi driver: xone-dongle interfaces: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-4: 3-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 3-2.1:16 info: Z-Star Micro Zgmicro AUDIO type: audio
driver: snd-usb-audio interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0ac8:9628 class-ID: 0102
serial: <filter>
Hub-5: 3-2.2:4 info: Texas Instruments ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0451:8242
Device-1: 3-2.3:10 info: Audeze LLC Maxwell XBOX Dongle type: HID
chip-ID: 3329:4b18 class-ID: 0300 serial: <filter>
Hub-6: 3-2.4:7 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 3-2.4.1:8 info: Wooting Two HE (ARM) type: HID,keyboard
driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 400mA chip-ID: 31e3:1232 class-ID: 0300
serial: <filter>
Device-2: 3-2.4.2:9 info: Corsair SCIMITAR RGB ELITE Gaming Mouse
type: mouse,HID,keyboard driver: usbfs interfaces: 4 rev: 2.0
chip-ID: 1b1c:1be3 class-ID: 0301 serial: <filter>
Device-3: 3-2.4.3:13 info: Z-Star Micro Zgmicro AUDIO type: audio
serial: <filter>
Device-4: 3-6:3 info: Integrated Express RGB LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
Device-5: 3-7:5 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:0852 class-ID: e001 serial: <filter>
Hub-7: 4-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-8: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-9: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-10: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-11: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-12: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-13: 9-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
System Temperatures: cpu: 48.8 C mobo: 35.0 C
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 52.0 C mem: 60.0 C fan: 149 watts: 34.00
device: amdgpu temp: 44.0 C
Packages: 2397 pm: pacman pkgs: 2348 libs: 522 tools: pamac,yay pm: flatpak
pkgs: 49
1: https://ftp.snt.utwente.nl/pub/linux/manjaro/testing/$repo/$arch
2: https://manjaro.mirror.garr.it/manjaro/testing/$repo/$arch
3: https://ct.mirror.garr.it/mirrors/manjaro/testing/$repo/$arch
4: https://mirror.nju.edu.cn/manjaro/testing/$repo/$arch
5: https://linorg.usp.br/manjaro/testing/$repo/$arch
6: https://mirrors.up.pt/pub/manjaro/testing/$repo/$arch
7: https://mirror.phoepsilonix.love/manjaro/testing/$repo/$arch
8: https://mirrors.sjtug.sjtu.edu.cn/manjaro/testing/$repo/$arch
Processes:
CPU top: 5 of 456
1: cpu: 6.0% command: zen pid: 4705 mem: 624.1 MiB (0.4%)
2: cpu: 3.0% command: vesktop.bin pid: 4034 mem: 497.6 MiB (0.3%)
3: cpu: 2.9% command: kwin_wayland pid: 2745 mem: 328.1 MiB (0.2%)
4: cpu: 2.6% command: zsh pid: 21450 mem: 10.7 MiB (0.0%)
5: cpu: 1.7% command: zen pid: 6427 mem: 762.3 MiB (0.6%)
Memory top: 5 of 456
1: mem: 1077.8 MiB (0.8%) command: clamd pid: 1440 cpu: 0.0%
2: mem: 762.3 MiB (0.6%) command: zen pid: 6427 cpu: 1.7%
3: mem: 625.0 MiB (0.4%) command: electron pid: 7450 cpu: 1.4%
4: mem: 624.1 MiB (0.4%) command: zen pid: 4705 cpu: 6.0%
5: mem: 587.1 MiB (0.4%) command: zen pid: 5889 cpu: 0.8%
Processes: 456 Power: uptime: 2h 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 49.31 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 260 default: graphical tool: systemctl
Compilers: clang: 22.1.5 gcc: 16.1.1 Shell: Zsh v: 5.9 running-in: yakuake
inxi: 3.3.40
