Hi, I installed Kernel 5.16 (I premise that I also tried all others Kernel 5*) and all DKMS modules on my system builds fine, except for on of these: 8814au, I got:
==> dkms install --no-depmod rtl8814au/r94.bdf80b5 -k 5.16.2-1-MANJARO
Deprecated feature: REMAKE_INITRD
Error! Bad return status for module build on kernel: 5.16.2-1-MANJARO (x86_64)
Consult /var/lib/dkms/rtl8814au/r94.bdf80b5/build/make.log for more information.
==> WARNING: `dkms install --no-depmod rtl8814au/r94.bdf80b5 -k 5.16.2-1-MANJARO' exited 10
Content of /var/lib/dkms/rtl8814au/r94.bdf80b5/build/make.log
Summary
DKMS make.log for rtl8814au-r94.bdf80b5 for kernel 4.14.262-1-MANJARO (x86_64)
mar 25 gen 2022, 21:48:21, CET
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/4.14.262-1-MANJARO/build M=/var/lib/dkms/rtl8814au/r94.bdf80b5/build modules
make[1]: Entering directory '/usr/lib/modules/4.14.262-1-MANJARO/build'
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_cmd.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_security.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_debug.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_io.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_ioctl_query.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_ioctl_set.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_ieee80211.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_mlme.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_mlme_ext.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_mi.o
/var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_mlme.c: In function ‘rtw_drv_scan_by_self’:
/var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_mlme.c:3130:17: warning: this ‘else’ clause does not guard... [-Wmisleading-indentation]
3130 | else
/var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_mlme.c:3133:25: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘else’
3133 | goto exit;
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_wlan_util.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_vht.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_pwrctrl.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_rf.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_chplan.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_recv.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_sta_mgt.o
/var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_recv.c: In function ‘validate_mp_recv_frame’:
/var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_recv.c:3575:25: warning: this ‘for’ clause does not guard... [-Wmisleading-indentation]
3575 | for (i = 0; i < precv_frame->u.hdr.len; i = i + 8)
In file included from /var/lib/dkms/rtl8814au/r94.bdf80b5/build/include/drv_types.h:60,
from /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_recv.c:17:
/var/lib/dkms/rtl8814au/r94.bdf80b5/build/include/rtw_debug.h:52:33: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘for’
52 | #define RTW_INFO(x,...) do {} while (0)
/var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_recv.c:3578:33: note: in expansion of macro ‘RTW_INFO’
3578 | RTW_INFO("#############################\n");
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_ap.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/mesh/rtw_mesh.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/mesh/rtw_mesh_pathtbl.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/mesh/rtw_mesh_hwmp.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_xmit.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_p2p.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_rson.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_tdls.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_br_ext.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_iol.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_sreset.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_btcoex_wifionly.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_btcoex.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_beamforming.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_odm.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_rm.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_rm_fsm.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/rtw_rm_util.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/efuse/rtw_efuse.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/osdep_service.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/linux/os_intfs.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/linux/usb_intf.o
/var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/efuse/rtw_efuse.c: In function ‘rtw_efuse_analyze’:
/var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/efuse/rtw_efuse.c:905:17: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]
905 | if (i % 16 == 0)
from /var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/efuse/rtw_efuse.c:17:
/var/lib/dkms/rtl8814au/r94.bdf80b5/build/include/rtw_debug.h:231:9: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
231 | do {\
/var/lib/dkms/rtl8814au/r94.bdf80b5/build/core/efuse/rtw_efuse.c:907:25: note: in expansion of macro ‘_RTW_PRINT_SEL’
907 | _RTW_PRINT_SEL(RTW_DBGDUMP, "%02X%s"
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/linux/usb_ops_linux.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/linux/ioctl_linux.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/linux/xmit_linux.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/linux/mlme_linux.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/linux/recv_linux.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/linux/ioctl_cfg80211.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/linux/rtw_cfgvendor.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/linux/wifi_regd.o
/var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/linux/ioctl_cfg80211.c: In function ‘rtw_cfg80211_ch_switch_notify’:
/var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/linux/ioctl_cfg80211.c:472:5: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]
472 | if (!rtw_cfg80211_allow_ch_switch_notify(adapter))
/var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/linux/ioctl_cfg80211.c:474:17: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
474 | cfg80211_ch_switch_notify(adapter->pnetdev, &chdef);
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/linux/rtw_android.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/linux/rtw_proc.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/linux/rtw_rhashtable.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/os_dep/linux/ioctl_mp.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/hal/hal_intf.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/hal/hal_com.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/hal/hal_com_phycfg.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/hal/hal_phy.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/hal/hal_dm.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/hal/hal_dm_acs.o
CC [M] /var/lib/dkms/rtl8814au/r94.bdf80b5/build/hal/hal_btcoex_wifionly.o
Is not an AUR problem, since on Kernel 4.14 this module compiles fine, as well others DKMS modules (eg tl88x2bu still from AUR).
What can I do?
