inxi-Fxxxz
System: Kernel: 5.7.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Desktop: i3 4.18.2 info: i3bar
dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X521IA_M533IA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X521IA v: 1.0 serial: <filter> UEFI: American Megatrends v: X521IA.300
date: 04/13/2020
Battery: ID-1: BAT0 charge: 10.3 Wh condition: 51.0/50.0 Wh (102%) volts: 11.9/11.9
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging cycles: 12
CPU: Topology: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP arch: Zen rev: 1
L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31958
Speed: 1397 MHz min/max: 1400/2000 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1397 3: 1397
4: 1397 5: 1397 6: 1397 7: 1397 8: 1397
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir vendor: ASUSTeK driver: amdgpu v: kernel
bus ID: 03:00.0 chip ID: 1002:1636
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus ID: 3-3:3
chip ID: 13d3:56a2 serial: <filter>
Display: x11 server: X.Org 1.20.8 driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: AMD RENOIR (DRM 3.37.0 5.7.14-1-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.5
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel v: kernel bus ID: 03:00.1
chip ID: 1002:1637
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 03:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.7.14-1-MANJARO
Network: Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: AzureWave
driver: rtl8821ce v: N/A port: f000 bus ID: 01:00.0 chip ID: 10ec:c821
Drives: Local Storage: total: 476.94 GiB used: 27.13 GiB (5.7%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLQ512HALU-00000 size: 476.94 GiB speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: FXV7000Q scheme: GPT
Partition: ID-1: / size: 459.50 GiB used: 27.13 GiB (5.9%) fs: ext4 dev: /dev/nvme0n1p2
Swap: ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 38 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 271 Uptime: 32m Memory: 15.13 GiB used: 1.37 GiB (9.0%) Init: systemd v: 245 Compilers:
gcc: 10.1.0 Packages: pacman: 993 Shell: Zsh v: 5.8 running in: termite inxi: 3.1.05
After booting the following error raised up:
[FAILED] Failed to start Light Display Manager.
So I’ve login from console (ctrl+alt+F2) and have typed startx
. At the beginning all seemed fine but after few seconds the laptop just frozen.
Any help would be appreciated.
Thanks
