Hey guys,
So I just ran the latest update and on reboot was met with “Failed to start CUPS Scheduler” and “Dependency failed for MakebPS printers available locally”
It won’t go past this point and I don’t see anything in grub to comment out.
I went through the CUPS Manual Intervention and did not find anything that helped me in my specific situation. However, I was able to go back to a previous version, prior to update, and bypass the error. So now I can work through the error.
So, I ran into this issue again. The CUPS Scheduler is becoming a pain. Fact is I don’t even use it because I could never figure out how to set it up. So could someone please tell me how to uninstall it from the Grub command line or, at the very least, bypass it from startup?
Not sure what you mean? I am unable to boot up. My pc stops at the CUPS Scheduler service failed to start. I am also unable to go back to a back up image for some reason, which worked last time.
So as I’m researching this issue across the web, I’m seeing others mentioning the latest update having issues with the Nvidia drivers. I have a 2080 and had no issues with it before the update. Should I be looking at it now?
