Start Root Applications Before Login
Good day, can anyone fill this command for CoreCtrl app for my rc.local? Thanks.
#!/bin/bash
/sbin/ip addr | grep inet\ | tail -n1 | awk '{ print $2 }' > /etc/issue
echo "" >> /etc/issue
exit 0
what rc.local ?
… seems you talk about a different init system - systemd is used in Arch/Manjaro
documenting my steps to decipher this:
which ip
yields:
/usr/bin/ip
so: that is not even the same path to begin with
but it will work because /sbin is a symlink to /usr/bin
where the ip command actually resides (in Manjaro)
what does it do?
That part of the command will give you your machines current IP and netmask -
the next part will then feed it into the file /etc/issue (which is only possible as root)
which is not the place to put that information
as that file has a different purpose (and content already)
and it will overwrite it, destroying the original content
That file will then be written to again, appending … nothing
to the now altered content
You will lose the original content of /etc/issue - and you will get no output in return
if you where asking what the command returns
Yeah forgot. Can you please fill in for me a crontab then?
Yes the app is in /usr/bin, just replace anything you must. I just want to run it before login with root privileges via root crontab.
Use @reboot
This might help:
I just want to sudo crontab -e and write @reboot something, no destructive time events, just always on. What is this @reboot something for the specific app? Thanks.
Something like this?
sudo (crontab -l ; echo "@reboot /path/to/your/script/script.sh") | crontab -
no, sorry
Just sudo crontab -e then edit with VI to something like @reboot sh /usr/bin/corectrl, but didn’t work. At any rate is there a simple way to start a root app before login so i get away without password?
This is ambiguous.
And possibly not a good way to do it.
Have you heard of the term “XY problem”?
https://xyproblem.info/
What is it that you want to achieve?
