Continuing the discussion from Manjaro Shutdown Time Sometimes Slow:
Hello
i installed Manjaro KDE plasma yesterday and I my machine is slow when i start, restart or shut down.
I’m fully noob and don’t know much about how to use the Linux operating system
The output to inxi --full --verbosity=7 --filter --no-host
is:
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1
Type: Desktop Mobo: ASRock model: Z370 Gaming K6
serial: <superuser required> UEFI: American Megatrends v: P1.20
date: 10/26/2017
RAM: total: 15.55 GiB used: 2.92 GiB (18.8%)
RAM Report:
Info: 6-Core model: Intel Core i7-8700K bits: 64 type: MT MCP
arch: Kaby Lake note: check rev: A cache: L1: 384 KiB L2: 1.5 MiB
L3: 12 MiB bogomips: 88824
Speed: 1923 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 800
2: 800 3: 865 4: 1936 5: 1677 6: 815 7: 1091 8: 1537 9: 2187
10: 1652 11: 1403 12: 800
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr hle ht hwp hwp_act_window hwp_epp hwp_notify ibpb
ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36
pti pts rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep smx ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1
xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: Micro-Star MSI
driver: nvidia v: 495.44 bus-ID: 01:00.0 chip-ID: 10de:1b80
class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: nvidia resolution: 1920x1080 s-dpi: 81
OpenGL: renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2
v: 4.6.0 NVIDIA 495.44 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f0
class-ID: 0403
Device-3: Creative Sound BlasterX H7 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1:2
chip-ID: 041e:3242 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8
class-ID: 0200
IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb
v: kernel port: c000 bus-ID: 05:00.0 chip-ID: 8086:1539
class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Local Storage: total: 1.38 TiB used: 25.5 GiB (1.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HAJQ-000H1
size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: EXA72H1Q temp: 38.9 C scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WD10EZRZ-00HTKB0
size: 931.51 GiB speed: 6.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: 1A01 scheme: MBR
ID-1: / size: 468.09 GiB used: 25.5 GiB (5.4%) fs: ext4
dev: /dev/nvme0n1p2 label: N/A
uuid: 1c8d7b9c-7d11-41f3-b9f3-8b660cf28d00
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1 label: NO_LABEL uuid: 340B-00F4
ID-1: /dev/sda1 size: 931.51 GiB fs: ntfs label: Karim
uuid: 9C700C9E700C816E
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-1:2 info: Creative Sound BlasterX H7 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 041e:3242 class-ID: 0300
serial: <filter>
Hub-2: 1-3:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
Device-1: 1-9:4 info: Corsair K95 RGB Platinum Keyboard [RGP0056]
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b2d
Device-2: 1-11:5 info: Cooler Master ARGB LED Controller
type: HID,Keyboard driver: hid-generic,usbhid interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 2516:1011
Hub-3: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
Hub-4: 2-7:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-2:2 info: ASUSTek ROG Gladius II Origin type: Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 0b05:1877 class-ID: 0300
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 29.0 C mobo: N/A gpu: nvidia temp: 59 C
Processes: 289 Uptime: 2h 10m wakeups: 0 Init: systemd v: 249
Compilers: gcc: 11.1.0 Packages: pacman: 1214 Shell: Zsh v: 5.8
default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.09
How should I proceed?
