Apparently starship-0.58.0-2 was built with the wrong version of libgit2. Well it doesn’t work. The libgit2 library used in starship v0.58.0 builds with libgit2 v1.2 by default.
It was built against and requires libgit2
1.2.
What do you mean “it doesn’t work”?
❯ starship
starship 0.58.0
Matan Kushner <hello@matchai.me>
The cross-shell prompt for astronauts. ☄🌌️
USAGE:
starship <SUBCOMMAND>
FLAGS:
-h, --help Prints help information
-V, --version Prints version information
SUBCOMMANDS:
bug-report Create a pre-populated GitHub issue with information about your configuration
completions Generate starship shell completions for your shell to stdout
config Edit the starship configuration
explain Explains the currently showing modules
help Prints this message or the help of the given subcommand(s)
init Prints the shell function used to execute starship
module Prints a specific prompt module
print-config Prints the computed starship configuration
prompt Prints the full starship prompt
session Generate random session key
timings Prints timings of all active modules
toggle Toggle a given starship module
https://github.com/starship/starship
» starship
starship: error while loading shared libraries: libgit2.so.1.1: cannot open shared object file: No such file or directory
Sounds like you may be in a partial upgrade state. You should have libgit2
1:1.2.0-1 installed. Try refreshing your mirrors and making sure you’re fully up to date:
sudo pacman-mirrors -f5 && sudo pacman -Syyu
Sorry, I found the error, it was up to me: In addition to the package, I had built starship with cargo, which now caused problems.
