I have noticed this bug for quite some time now; I have stacer
installed from the official repositories and set it to Quit
when I close the stacer window. In stead of that, the app continues to run in the system tray! When I right click the tray icon and select quit
from the menu, only then does stacer
quick.
Worth mentioning, stacer-bin
from AUR
doesn’t have this problem.
Can this be solved manually?
I just removed it as it’s no longer maintained. Use stacer-bin
from the AUR.
