Hello i686ers!
The most important aspect of this set is the update to the filesystem
package. The changes made should be checked carefully to ensure any customisation you have made is retained, in, for example:
/etc/hosts
/etc/hostname
/etc/locale.conf
/etc/locale.gen
/etc/vconsole.conf
There’s an update to glibc and GCC; everything should be working with the new glibc version, but keep an eye out.
There’s also the usual kernel updates, and in terms of other notable updates KDE 18.04 has arrived, along with updates to VirtualBox, WINE, and ZSH.
Anyone who would like to help out testing the upstream packages, please read the archlinux32 thread for details about how they automate their testing process and how to get involved:
https://bbs.archlinux32.org/viewtopic.php?id=171
(running this in an archlinux32 VM would be fine, there will hopefully be a way of doing this directly from within manjaro32 in the future)
Available kernels
Series | Version |
linux316 | 3.16.56 |
linux41 | 4.1.51 |
linux44 | 4.4.129 |
linux49 | 4.9.96 |
linux414 | 4.14.36 |
archlinux32
If you find manjaro32 useful please consider donating to, or helping out with, archlinux32. It’s a small team taking on a huge project and any help will no doubt be very much appreciated.
Why aren’t the available packages/package versions the same as x86_64?
archlinux32 packages are based on Arch packages but may need editing to build correctly. Builds of less-popular packages are lower priority.
Manjaro-specific packages may lag behind x86_64 because there aren’t as many packagers. If you notice an important package is lagging please report it; at the moment it’s only me packaging for i686:
I’m only packaging current LTS kernels. Any marked as EOL are dropped. I’ll not be building the mainline kernel.
What about security updates?
I cannot guarantee timely security updates on x32-stable. If this is critical for you I recommend you switch to x32-testing or cherry-pick those packages from x32-testing or x32-unstable as they become available.
Something broke. Isn’t this meant to be stable?
“Stable” means “infrequently changing”, not “everything will work perfectly all the time”. If you want it to mean everything works, you need to help test the things you’re interested in.
What about installer images?
Phil very kindly updated the preview installer images:
What about x32-testing
and x32-unstable
These are already available, and I recommend you use x32-testing
if you can to make sure testing is done.
x32-unstable should be used by anyone who wants to try and find any issues before they impact other people. If you have multiple/many machines you really should run one of those on x32-unstable.
Full list of changes
:: Different overlay package(s) in repository core i686
PACKAGE 2018-04-15 2018-04-28
filesystem 2017.06-4.5 2018.1-2
linux414 4.14.34-1 4.14.36-1
linux414-headers 4.14.34-1 4.14.36-1
linux44 4.4.127-1 4.4.129-1
linux44-headers 4.4.127-1 4.4.129-1
linux49 4.9.93-1 4.9.96-1
linux49-headers 4.9.93-1 4.9.96-1
manjaro-keyring 20171027-1 20171027-2
pacman-mirrors 4.10.1-2 4.10.1-3
procps-ng 3.3.14-0 3.3.14-1.1
:: Different sync package(s) in repository core i686
binutils 2.29.1-3.0 2.30-3.0
btrfs-progs 4.16-1.0 4.16-2.0
ca-certificates-mozilla 3.36-1.0 3.36.1-1.0
gcc 7.3.1+20180312-2.0 7.3.1+20180406-1.0
gcc-ada 7.3.1+20180312-2.0 7.3.1+20180406-1.0
gcc-fortran 7.3.1+20180312-2.0 7.3.1+20180406-1.0
gcc-go 7.3.1+20180312-2.0 7.3.1+20180406-1.0
gcc-libs 7.3.1+20180312-2.0 7.3.1+20180406-1.0
gcc-objc 7.3.1+20180312-2.0 7.3.1+20180406-1.0
glibc 2.26-11.0 2.27-2.0
gpgme 1.10.0-2.0 1.11.1-1.0
libldap 2.4.45-4 2.4.46-1.0
libnghttp2 1.31.0-1.0 1.31.1-1.0
linux-api-headers 4.14.8-1.0 4.16.1-1.0
nss 3.36-1.0 3.36.1-1.0
openldap 2.4.45-4 2.4.46-1.0
openvpn 2.4.5-1.0 2.4.6-1.0
perl 5.26.1-2.0 5.26.2-1.0
pinentry 1.1.0-1.0 1.1.0-2.0
procps-ng 3.3.13-1.0 3.3.14-1.0
python-gpgme 1.10.0-2.0 1.11.1-1.0
python2-gpgme 1.10.0-2.0 1.11.1-1.0
qgpgme 1.10.0-2.0 1.11.1-1.0
thin-provisioning-tools 0.7.5-1 0.7.6-1.0
libnsl - 1.2.0-1.0
:: Different overlay package(s) in repository extra i686
calamares 3.1.12-5 3.1.13-1
calamares-git3.2.0.r4494.031416a1d-13.2.0.r4537.b8fd5bdea-1
gtk3-classic 3.22.29-2 3.22.30-0.1
linux316-virtualbox-guest-modules 5.2.8-3 5.2.10-1
linux316-virtualbox-host-modules 5.2.8-3 5.2.10-1
linux41-virtualbox-guest-modules 5.2.8-3 5.2.10-1
linux41-virtualbox-host-modules 5.2.8-3 5.2.10-1
linux414-acpi_call 1.1.0-30 1.1.0-33
linux414-bbswitch 0.8-30 0.8-33
linux414-broadcom-wl 6.30.223.271-30 6.30.223.271-33
linux414-ndiswrapper 1.61-30 1.61-33
linux414-nvidia-304xx 1:304.137-30 1:304.137-33
linux414-nvidia-340xx 340.106-18 340.106-21
linux414-r8168 8.045.08-18 8.045.08-21
linux414-rt3562sta 2.4.1.1_r4-30 2.4.1.1_r4-33
linux414-spl 0.7.8-2 0.7.8-5
linux414-tp_smapi 0.41-30 0.41-33
linux414-vhba-module 20161009-30 20161009-33
linux414-virtualbox-guest-modules 5.2.8-10 5.2.10-2
linux414-virtualbox-host-modules 5.2.8-10 5.2.10-2
linux414-zfs 0.7.8-2 0.7.8-5
linux44-acpi_call 1.1.0-90 1.1.0-91
linux44-broadcom-wl 6.30.223.271-60 6.30.223.271-61
linux44-ndiswrapper 1.61-58 1.61-59
linux44-nvidia-304xx 1:304.137-25 1:304.137-26
linux44-nvidia-340xx 340.106-12 340.106-13
linux44-open-vm-tools-modules 2:2013.09.16-90 2:2013.09.16-91
linux44-r8168 8.045.08-12 8.045.08-13
linux44-rt3562sta 2.4.1.1_r4-58 2.4.1.1_r4-59
linux44-spl 0.7.8-1 0.7.8-2
linux44-vhba-module 20161009-58 20161009-59
linux44-virtualbox-guest-modules 5.2.8-5 5.2.10-2
linux44-virtualbox-host-modules 5.2.8-5 5.2.10-2
linux44-zfs 0.7.8-1 0.7.8-2
linux49-acpi_call 1.1.0-72 1.1.0-75
linux49-bbswitch 0.8-72 0.8-75
linux49-broadcom-wl 6.30.223.271-72 6.30.223.271-75
linux49-ndiswrapper 1.61-70 1.61-73
linux49-nvidia-304xx 1:304.137-31 1:304.137-34
linux49-nvidia-340xx 340.106-12 340.106-15
linux49-r8168 8.045.08-12 8.045.08-15
linux49-rt3562sta 2.4.1.1_r4-70 2.4.1.1_r4-73
linux49-spl 0.7.8-1 0.7.8-4
linux49-tp_smapi 0.41-72 0.41-75
linux49-vhba-module 20161009-70 20161009-73
linux49-virtualbox-guest-modules 5.2.8-6 5.2.10-3
linux49-virtualbox-host-modules 5.2.8-6 5.2.10-3
linux49-zfs 0.7.8-1 0.7.8-4
manjaro-gdm-check 20180101-1 20180421-1
manjaro-iso-profiles-base 17.1.4-1 17.1.7-1
manjaro-iso-profiles-community 17.1.4-1 17.1.7-1
manjaro-iso-profiles-official 17.1.4-1 17.1.7-1
manjaro-settings-manager 0.5.4-11 0.5.4-12
manjaro-settings-manager-kcm 0.5.4-11 0.5.4-12
manjaro-settings-manager-knotifier 0.5.4-11 0.5.4-12
manjaro-settings-manager-notifier 0.5.4-11 0.5.4-12
manjaro-settings-samba 20171125-1 20180423-1
manjaro-wallpapers-18.0 1.0-0.2 1.0-0.4
ndiswrapper-utils 1.61-30 1.61-33
polkit0.113+34+g29ba7af-1.1 0.114-1.1
python-pyparted 3.10.7-2 3.11.1-1
rt3562sta-common 2.4.1.1_r4-70 2.4.1.1_r4-73
xfce4-panel-gtk3 4.13.2-4 4.13.2-5
xfce4-pulseaudio-plugin 0.4.0-1 0.4.1-1.1
libnautilus-extension-legacy - 3.26.3.1-1
nautilus-legacy - 3.26.3.1-1
python2-pyparted - 3.11.1-1
thunar-shares-plugin-gtk3 - 0.3.0-1
:: Different sync package(s) in repository extra i686
accountsservice 0.6.46-1.0 0.6.47-1.0
akonadi 17.12.3-1.0 18.04.0-1.0
akonadi-calendar 17.12.3-1.0 18.04.0-1.0
akonadi-calendar-tools 17.12.3-1.0 18.04.0-1.0
akonadi-contacts 17.12.3-1.0 18.04.0-1.0
akonadi-import-wizard 17.12.3-1.0 18.04.0-1.0
akonadi-mime 17.12.3-1.0 18.04.0-1.0
akonadi-notes 17.12.3-1.0 18.04.0-1.0
akonadi-search 17.12.3-1.0 18.04.0-1.0
akonadiconsole 17.12.3-1.0 18.04.0-1.0
akregator 17.12.3-1.0 18.04.0-1.0
analitza 17.12.3-1.0 18.04.0-1.0
appstream-glib 0.7.4-1 0.7.7-1.0
archlinux-appstream-data 20180318-1.0 20180424-1.0
ark 17.12.3-1.0 18.04.0-1.0
artikulate 17.12.3-1.1 18.04.0-1.0
audiocd-kio 17.12.3-1.0 18.04.0-1.0
babl 0.1.44-2.0 0.1.46-1.0
baloo-widgets 17.12.3-1.0 18.04.0-1.0
bigloo 4.3a-1 4.3a-3.0
blinken 17.12.3-1.1 18.04.0-1.0
bomber 17.12.3-1.1 18.04.0-1.0
bovo 17.12.3-1.1 18.04.0-1.0
calendarsupport 17.12.3-1.0 18.04.0-1.0
calligra 3.1.0-4.0 3.1.0-6.0
cantor 17.12.3-3.0 18.04.0-1.0
cervisia 17.12.3-1.0 18.04.0-1.0
colord 1.4.2-3.1 1.4.3-1.0
colord-sane 1.4.2-3.1 1.4.3-1.0
desktop-file-utils 0.23-1 0.23+4+g92af410-1.0
dolphin 17.12.3-1.1 18.04.0-1.0
dolphin-plugins 17.12.3-1.0 18.04.0-1.0
dragon 17.12.3-1.0 18.04.0-1.0
ekiga 4.0.1-28.0 4.0.1-28.1
epiphany 3.28.1-1.0 3.28.1.1-1.0
ethtool 1:4.15-1.0 1:4.16-1.0
eventviews 17.12.3-1.0 18.04.0-1.0
fcgi 2.4.0-13.0 2.4.0-14.0
feh 2.25.1-1.0 2.26-1.0
ffmpegthumbs 17.12.3-1.0 18.04.0-1.0
filelight 17.12.3-1.0 18.04.0-1.0
finch 2.13.0-1.1 2.13.0-2.0
flatpak0.11.3+4+g633a9cbf-1.0 0.11.4-1.0
fluxbox 1.3.7-3.0 1.3.7-4.0
gconf 3.2.6-53.2.6+11+g07808097-3.0
gdome2 0.8.1-5.1 0.8.1-5.2
gegl 0.3.28-1.0 0.3.34-1.0
gnet 2.0.8-4 2.0.8-5.0
gnome-builder3.28.0+56+gc5dd7471b-1.0 3.28.1-1.0
gnome-desktop 1:3.28.1-1.11:3.28.1+3+g436ca8f0-1.0
gnumeric 1.12.38-1.0 1.12.39-1.0
gobject-introspection 1.56.0-1.0 1.56.1-1.0
gobject-introspection-runtime 1.56.0-1.0 1.56.1-1.0
goffice 0.10.38-1.0 0.10.39-1.0
gphoto2 2.5.15-1.0 2.5.17-1.0
granatier 17.12.3-1.1 18.04.0-1.0
grantlee-editor 17.12.3-1.0 18.04.0-1.0
grantleetheme 17.12.3-1.0 18.04.0-1.0
graphviz 2.40.1-10.0 2.40.1-11.0
gwenview 17.12.3-2.0 18.04.0-1.0
ibus 1.5.17-1 1.5.18-1.0
incidenceeditor 17.12.3-1.0 18.04.0-1.0
ipset 6.36-1.0 6.38-1.0
juk 17.12.3-1.0 18.04.0-1.0
k3b 1:17.12.3-1.0 1:18.04.0-1.0
kaccounts-integration 17.12.3-1.0 18.04.0-1.0
kaccounts-providers 17.12.3-1.0 18.04.0-1.0
kaddressbook 17.12.3-1.0 18.04.0-1.0
kajongg 17.12.3-1.1 18.04.0-1.0
kalarm 17.12.3-1.0 18.04.0-1.0
kalarmcal 17.12.3-1.0 18.04.0-1.0
kalgebra 17.12.3-1.1 18.04.0-1.0
kalzium 17.12.3-1.1 18.04.0-1.0
kamera 17.12.3-1.0 18.04.0-1.0
kamoso 3.2.4-1.1 18.04.0-1.0
kanagram 17.12.3-1.1 18.04.0-1.0
kapman 17.12.3-1.0 18.04.0-1.0
kapptemplate 17.12.3-1.0 18.04.0-1.0
kate 17.12.3-1.1 18.04.0-1.0
katomic 17.12.3-1.0 18.04.0-1.0
kbackup 1.0.1-1.1 18.04.0-1.0
kblackbox 17.12.3-1.0 18.04.0-1.0
kblocks 17.12.3-1.0 18.04.0-1.0
kblog 17.12.3-1.0 18.04.0-1.0
kbounce 17.12.3-1.0 18.04.0-1.0
kbreakout 17.12.3-1.0 18.04.0-1.0
kbruch 17.12.3-1.1 18.04.0-1.0
kcachegrind 17.12.3-3.0 18.04.0-1.0
kcachegrind-common 17.12.3-3.0 18.04.0-1.0
kcalc 17.12.3-1.0 18.04.0-1.0
kcalcore 17.12.3-1.0 18.04.0-1.0
kcalutils 17.12.3-1.0 18.04.0-1.0
kcharselect 17.12.3-1.0 18.04.0-1.0
kcolorchooser 17.12.3-1.0 18.04.0-1.0
kcontacts 17.12.3-1.0 18.04.0-1.0
kcron 17.12.3-1.1 18.04.0-1.0
kdav 17.12.3-1.0 18.04.0-1.0
kde-applications-meta 17.12-1.0 18.04-1.0
kde-dev-scripts 17.12.3-1.0 18.04.0-1.0
kde-dev-utils 17.12.3-1.0 18.04.0-1.0
kde-syndication 17.12.3-1.0 18.04.0-1.0
kdeaccessibility-meta 17.12-1.0 18.04-1.0
kdeadmin-meta 17.12-1.0 18.04-1.0
kdebase-meta 17.12-1.0 18.04-1.0
kdebugsettings 17.12.3-1.0 18.04.0-1.0
kdeedu-data 17.12.3-1.0 18.04.0-1.0
kdeedu-meta 17.12-1.0 18.04-1.0
kdegames-meta 17.12-1.0 18.04-1.0
kdegraphics-meta 17.12-1.0 18.04-1.0
kdegraphics-mobipocket 17.12.3-1.0 18.04.0-1.0
kdegraphics-thumbnailers 17.12.3-1.0 18.04.0-1.0
kdemultimedia-meta 17.12-1.0 18.04-1.0
kdenetwork-filesharing 17.12.3-1.0 18.04.0-1.0
kdenetwork-meta 17.12-1.0 18.04-1.0
kdenlive 17.12.3-1.0 18.04.0-1.0
kdepim-addons 17.12.3-1.0 18.04.0-1.0
kdepim-apps-libs 17.12.3-1.0 18.04.0-1.0
kdepim-meta 17.12-1.0 18.04-1.0
kdepim-runtime 17.12.3-1.0 18.04.0-1.0
kdesdk-kioslaves 17.12.3-1.0 18.04.0-1.0
kdesdk-meta 17.12-1.0 18.04-1.0
kdesdk-thumbnailers 17.12.3-1.0 18.04.0-1.0
kdeutils-meta 17.12-1.0 18.04-1.0
kdewebdev-meta 17.12-1.0 18.04-1.0
kdf 17.12.3-1.0 18.04.0-1.0
kdiagram 2.6.0-1 2.6.1-1.0
kdialog 17.12.3-1.1 18.04.0-1.0
kdiamond 17.12.3-1.0 18.04.0-1.0
keditbookmarks 17.12.3-1.1 18.04.0-1.0
kfind 17.12.3-1.1 18.04.0-1.0
kfloppy 17.12.3-1.0 18.04.0-1.0
kfourinline 17.12.3-1.0 18.04.0-1.0
kgeography 17.12.3-1.1 18.04.0-1.0
kget 17.12.3-1.0 18.04.0-1.0
kgoldrunner 17.12.3-1.0 18.04.0-1.0
kgpg 17.12.3-1.0 18.04.0-1.0
khangman 17.12.3-1.1 18.04.0-1.0
khelpcenter 17.12.3-1.1 18.04.0-1.0
kidentitymanagement 17.12.3-1.0 18.04.0-1.0
kig 17.12.3-1.1 18.04.0-1.0
kigo 17.12.3-1.0 18.04.0-1.0
killbots 17.12.3-1.0 18.04.0-1.0
kimagemapeditor 17.12.3-1.0 18.04.0-1.0
kimap 17.12.3-1.0 18.04.0-1.0
kio-extras 17.12.3-2.0 18.04.0-1.0
kiriki 17.12.3-1.0 18.04.0-1.0
kiten 17.12.3-1.1 18.04.0-1.0
kjumpingcube 17.12.3-1.0 18.04.0-1.0
kldap 17.12.3-1.0 18.04.0-1.0
kleopatra 17.12.3-1.0 18.04.0-1.0
klettres 17.12.3-1.1 18.04.0-1.0
klickety 17.12.3-1.0 18.04.0-1.0
klines 17.12.3-1.0 18.04.0-1.0
kmag 17.12.3-1.0 18.04.0-1.0
kmahjongg 17.12.3-1.0 18.04.0-1.0
kmail 17.12.3-1.0 18.04.0-1.0
kmail-account-wizard 17.12.3-1.0 18.04.0-1.0
kmailtransport 17.12.3-1.0 18.04.0-1.0
kmbox 17.12.3-1.0 18.04.0-1.0
kmime 17.12.3-1.0 18.04.0-1.0
kmines 17.12.3-1.0 18.04.0-1.0
kmix 17.12.3-1.0 18.04.0-1.0
kmousetool 17.12.3-1.0 18.04.0-1.0
kmouth 17.12.3-1.1 18.04.0-1.0
kmplot 17.12.3-1.1 18.04.0-1.0
knavalbattle 17.12.3-1.0 18.04.0-1.0
knetwalk 17.12.3-1.0 18.04.0-1.0
knotes 17.12.3-1.0 18.04.0-1.0
kolf 17.12.3-1.0 18.04.0-1.0
kollision 17.12.3-1.0 18.04.0-1.0
kolourpaint 17.12.3-1.0 18.04.0-1.0
kompare 17.12.3-1.0 18.04.0-1.0
konqueror 17.12.3-2.0 18.04.0-1.0
konquest 17.12.3-1.0 18.04.0-1.0
konsole 17.12.3-1.1 18.04.0-1.0
kontact 17.12.3-1.0 18.04.0-1.0
kontactinterface 17.12.3-1.0 18.04.0-1.0
kopete 17.08.3-1.1 18.04.0-1.0
korganizer 17.12.3-1.0 18.04.0-1.0
kpatience 17.12.3-1.0 18.04.0-1.0
kpimtextedit 17.12.3-1.0 18.04.0-1.0
kqtquickcharts 17.12.3-1.0 18.04.0-1.0
krdc 17.12.3-1.0 18.04.0-1.0
kreversi 17.12.3-1.0 18.04.0-1.0
krfb 17.12.3-1.0 18.04.0-1.0
kross-interpreters 17.12.3-1.1 18.04.0-1.0
kruler 17.12.3-1.0 18.04.0-1.0
kshisen 17.12.3-1.0 18.04.0-1.0
ksirk 17.12.3-1.0 18.04.0-1.0
ksmtp 17.12.3-1.0 18.04.0-1.0
ksnakeduel 17.12.3-1.0 18.04.0-1.0
kspaceduel 17.12.3-1.0 18.04.0-1.0
ksquares 17.12.3-1.0 18.04.0-1.0
ksudoku 17.12.3-1.0 18.04.0-1.0
ksystemlog 17.12.3-1.1 18.04.0-1.0
kteatime 17.12.3-1.0 18.04.0-1.0
ktexteditor 5.44.0-1.0 5.45.0-1.0
ktimer 17.12.3-1.0 18.04.0-1.0
ktouch 17.12.3-1.1 18.04.0-1.0
ktuberling 17.12.3-1.0 18.04.0-1.0
kturtle 17.12.3-1.1 18.04.0-1.0
kubrick 17.12.3-1.0 18.04.0-1.0
kwalletmanager 17.12.3-1.0 18.04.0-1.0
kwave 17.12.3-1.0 18.04.0-1.0
kwin 5.12.4-1.0 5.12.4-2.0
kwordquiz 17.12.3-1.1 18.04.0-1.0
kwrite 17.12.3-1.1 18.04.0-1.0
libbytesize 1.1-1.0 1.2-1.0
libdvdcss 1.4.1-1.0 1.4.2-1.0
libetonyek 0.1.7-1 0.1.8-1.0
libgit2 1:0.26.3-1.0 1:0.27.0-1.0
libgit2-glib 0.26.4-1.0 0.26.4-2.0
libgme 0.6.1-1 0.6.2-1.0
libgravatar 17.12.3-1.0 18.04.0-1.0
libgsf 1.14.42-1 1.14.43-1.0
libibus 1.5.17-1 1.5.18-1.0
libinput 1.10.4-1.0 1.10.5-1.0
libkcddb 17.12.3-1.0 18.04.0-1.0
libkcompactdisc 17.12.3-1.0 18.04.0-1.0
libkdcraw 17.12.3-1.0 18.04.0-1.0
libkdegames 17.12.3-1.0 18.04.0-1.0
libkdepim 17.12.3-1.0 18.04.0-1.0
libkeduvocdocument 17.12.3-1.0 18.04.0-1.0
libkexiv2 17.12.3-1.0 18.04.0-1.0
libkgapi 17.12.3-1.0 18.04.0-1.0
libkgeomap 17.12.3-1.0 18.04.0-1.0
libkipi 17.12.3-1.0 18.04.0-1.0
libkleo 17.12.3-1.0 18.04.0-1.0
libkmahjongg 17.12.3-1.0 18.04.0-1.0
libkomparediff2 17.12.3-1.0 18.04.0-1.0
libksane 17.12.3-1.0 18.04.0-1.0
libksieve 17.12.3-1.0 18.04.0-1.0
liblouis 3.4.0-1.0 3.5.0-1.0
libpurple 2.13.0-1.1 2.13.0-2.0
libraw 0.18.8-2.0 0.18.9-1.0
libsmbios 2.4.0-1.0 2.4.1-1.0
libtorrent-rasterbar 1:1.1.6-1.0 1:1.1.7-1.0
libunrar 1:5.6.2-1.0 1:5.6.3-1.0
libuv 1.20.0-1.0 1.20.1-1.0
libva-mesa-driver 18.0.0-4.0 18.0.1-1.0
libvncserver 0.9.11-2 0.9.11-3.0
link-grammar 5.4.3-1.0 5.4.4-1.0
llvm 6.0.0-4.0 6.0.0-4.1
llvm-libs 6.0.0-4.0 6.0.0-4.1
llvm-ocaml 6.0.0-4.0 6.0.0-4.1
lokalize 17.12.3-1.0 18.04.0-1.0
lskat 17.12.3-1.0 18.04.0-1.0
mailcommon 17.12.3-1.0 18.04.0-1.0
mailimporter 17.12.3-1.0 18.04.0-1.0
marble 17.12.3-1.1 18.04.0-1.0
marble-common 17.12.3-1.1 18.04.0-1.0
marble-qt 17.12.3-1.1 18.04.0-1.0
mbox-importer 17.12.3-1.0 18.04.0-1.0
mesa 18.0.0-4.0 18.0.1-1.0
mesa-vdpau 18.0.0-4.0 18.0.1-1.0
meson 0.45.1-1.0 0.46.0-1.0
messagelib 17.12.3-1.0 18.04.0-1.0
minuet 17.12.3-1.1 18.04.0-1.0
mono 5.10.1.16-1.0 5.10.1.47-1.0
mono-addins 1.3.3-1.0 1.3.3-2.0
net-snmp 5.7.3-7 5.7.3-8.0
nginx 1.12.2-2.0 1.14.0-1.0
nmap 7.70-1.0 7.70-2.0
noto-fonts-emoji 20180102-2.0 20180425-1.0
okteta 17.12.3-1.0 17.12.3-2.0
okular 17.12.3-1.0 18.04.0-1.0
opencl-mesa 18.0.0-4.0 18.0.1-1.0
orca 3.28.0-1.0 3.28.1-1.0
palapeli 17.12.3-1.0 18.04.0-1.0
parley 17.12.3-1.1 18.04.0-1.0
perl-async-interrupt 1.22-1.0 1.23-1.0
perl-test-pod 1.51-3 1.52-1.0
perl-uri 1.73-1.0 1.74-1.0
phonon-qt4 4.10.0-1.0 4.10.1-1.0
phonon-qt4-vlc 0.10.1-1.0 0.10.1-2.0
phonon-qt5 4.10.0-1.0 4.10.1-1.0
phonon-qt5-vlc 0.10.1-1.0 0.10.1-2.0
php 7.2.4-1.0 7.2.5-1.0
php-apache 7.2.4-1.0 7.2.5-1.0
php-cgi 7.2.4-1.0 7.2.5-1.0
php-dblib 7.2.4-1.0 7.2.5-1.0
php-embed 7.2.4-1.0 7.2.5-1.0
php-enchant 7.2.4-1.0 7.2.5-1.0
php-fpm 7.2.4-1.0 7.2.5-1.0
php-gd 7.2.4-1.0 7.2.5-1.0
php-imap 7.2.4-1.0 7.2.5-1.0
php-intl 7.2.4-1.0 7.2.5-1.0
php-odbc 7.2.4-1.0 7.2.5-1.0
php-pgsql 7.2.4-1.0 7.2.5-1.0
php-phpdbg 7.2.4-1.0 7.2.5-1.0
php-pspell 7.2.4-1.0 7.2.5-1.0
php-snmp 7.2.4-1.0 7.2.5-1.0
php-sodium 7.2.4-1.0 7.2.5-1.0
php-sqlite 7.2.4-1.0 7.2.5-1.0
php-tidy 7.2.4-1.0 7.2.5-1.0
php-xsl 7.2.4-1.0 7.2.5-1.0
picmi 17.12.3-1.0 18.04.0-1.0
pidgin 2.13.0-1.1 2.13.0-2.0
pim-data-exporter 17.12.3-1.0 18.04.0-1.0
pim-sieve-editor 17.12.3-1.0 18.04.0-1.0
pimcommon 17.12.3-1.0 18.04.0-1.0
poppler 0.63.0-1.0 0.63.0-1.1
poppler-glib 0.63.0-1.0 0.63.0-1.1
poppler-qt5 0.63.0-1.0 0.63.0-1.1
postfix 3.3.0-2.0 3.3.0-3.0
powerdevil 5.12.4-1.0 5.12.4-2.0
poxml 17.12.3-1.0 18.04.0-1.0
print-manager 17.12.3-1.0 18.04.0-1.0
psiconv 0.9.9-5.0 0.9.9-6.0
pstoedit 3.70-7.0 3.71-1.0
python 3.6.5-1.0 3.6.5-2.0
python-cairo 1.16.3-1.0 1.17.0-1.0
python2 2.7.14-2.0 2.7.14-3.0
python2-cairo 1.16.3-1.0 1.17.0-1.0
qcachegrind 17.12.3-3.0 18.04.0-1.0
qemu 2.11.1-1.0 2.11.1-2.2
qemu-arch-extra 2.11.1-1.0 2.11.1-2.2
qemu-block-gluster 2.11.1-1.0 2.11.1-2.2
qemu-block-iscsi 2.11.1-1.0 2.11.1-2.2
qemu-guest-agent 2.11.1-1.0 2.11.1-2.2
qemu-headless 2.11.1-1.0 2.11.1-2.2
qemu-headless-arch-extra 2.11.1-1.0 2.11.1-2.2
qt5-declarative 5.10.1-3.2 5.10.1-4.0
r 3.4.4-2.0 3.5.0-1.0
rocs 17.12.3-1.1 18.04.0-1.0
signon-kwallet-extension 17.12.3-1.0 18.04.0-1.0
spectacle 17.12.3-1.0 18.04.0-1.0
srt 1.3.0-1.0 1.3.0-2.0
step 17.12.3-3.0 18.04.0-1.0
suitesparse 5.1.0-1.0 5.2.0-1.0
sushi 3.24.0-1 3.28.3-1.0
svgpart 17.12.3-1.0 18.04.0-1.0
sweeper 17.12.3-1.0 18.04.0-1.0
syslog-ng 3.14.1-1.1 3.14.1-2.0
tcl 8.6.8-2.0 8.6.8-3.0
telepathy-kde-accounts-kcm 17.12.3-1.0 18.04.0-1.0
telepathy-kde-approver 17.12.3-1.0 18.04.0-1.0
telepathy-kde-auth-handler 17.12.3-1.0 18.04.0-1.0
telepathy-kde-call-ui 17.12.3-1.0 18.04.0-1.0
telepathy-kde-common-internals 17.12.3-1.0 18.04.0-1.0
telepathy-kde-contact-list 17.12.3-1.0 18.04.0-1.0
telepathy-kde-contact-runner 17.12.3-1.0 18.04.0-1.0
telepathy-kde-desktop-applets 17.12.3-1.0 18.04.0-1.0
telepathy-kde-filetransfer-handler 17.12.3-1.0 18.04.0-1.0
telepathy-kde-integration-module 17.12.3-1.0 18.04.0-1.0
telepathy-kde-meta 17.12-1.0 18.04-1.0
telepathy-kde-send-file 17.12.3-1.0 18.04.0-1.0
telepathy-kde-text-ui 17.12.3-1.0 18.04.0-1.0
tslib 1.15-1.0 1.16-1.0
umbrello 17.12.3-1.0 18.04.0-1.0
valgrind 3.13.0-6.0 3.13.0-7.0
varnish 5.2.1-2.0 5.2.1-3.0
vulkan-headers 1:1.1.72-1.0 1:1.1.73-1.0
vulkan-html-docs 1:1.1.72-1.0 1:1.1.73-1.0
vulkan-intel 18.0.0-4.0 18.0.1-1.0
vulkan-radeon 18.0.0-4.0 18.0.1-1.0
xdg-desktop-portal 0.10-1.0 0.11-1.0
xdg-desktop-portal-gtk 0.10-1.0 0.11-1.0
xerces-c 3.2.1-1.0 3.2.1-2.0
xfce4-pulseaudio-plugin 0.4.0-1.0 0.4.1-1.0
xfig 3.2.6.a-1.0 3.2.7-1.0
xine-lib 1.2.9-3.0 1.2.9-5.0
xkeyboard-config 2.23.1-2.0 2.23.1-3.0
xorg-server1.19.6+13+gd0d1a694f-2.01.19.6+13+gd0d1a694f-2.1
xorg-server-common1.19.6+13+gd0d1a694f-2.01.19.6+13+gd0d1a694f-2.1
xorg-server-devel1.19.6+13+gd0d1a694f-2.01.19.6+13+gd0d1a694f-2.1
xorg-server-xdmx1.19.6+13+gd0d1a694f-2.01.19.6+13+gd0d1a694f-2.1
xorg-server-xephyr1.19.6+13+gd0d1a694f-2.01.19.6+13+gd0d1a694f-2.1
xorg-server-xnest1.19.6+13+gd0d1a694f-2.01.19.6+13+gd0d1a694f-2.1
xorg-server-xvfb1.19.6+13+gd0d1a694f-2.01.19.6+13+gd0d1a694f-2.1
xorg-server-xwayland1.19.6+13+gd0d1a694f-2.01.19.6+13+gd0d1a694f-2.1
xterm 331-1.0 332-1.0
zeroconf-ioslave 17.12.3-1.0 18.04.0-1.0
zsh 5.5-1.0 5.5.1-1.0
zsh-doc 5.5-1.0 5.5.1-1.0
:: Different overlay package(s) in repository community i686
adapta-black-breath-theme 3.93.0.258-1 3.93.0.280-1
adapta-black-maia-theme 3.93.0.258-1 3.93.0.280-1
adapta-breath-theme 3.93.0.258-1 3.93.0.280-1
adapta-maia-theme 3.93.0.258-1 3.93.0.280-1
artwork-i3 20180127-1 20180423-1
awesome-wallpapers 20180301-1 20180305-1
bmenu 0.5-2 0.5-3
breeze-maia-icon-themes 5.43.0-1 5.44.0-1
bspwm-manjaro 0.9.4-8 0.9.4-11
bspwm-scripts 0.34-1 0.37-1
budgie-extras 0.4.2-1 0.4.4-1
cinnamon 3.6.7-2 3.6.7-5
conky-i3 20180113-1 20180426-1
deepin-draw 1.0.0-1 1.0.0-1.1
deepin-session-ui 4.3.7.1-1 4.3.7.2-1.1
gnome-shell-extension-unite 8-1 16-1
guayadeque0.4.5.r55.g7b6d34db-10.4.5.r55.g7b6d34db-1.0
i3-default-artwork 20180113-1 20180423-1
i3status-manjaro 2.11-3 2.11-5
inxi 3.0.04-1 3.0.07-1
lemonpanel 0.27.r188.b89a3c3-1 0.39.r203.e6ad27f-1
lightdm-settings 1.1.4-3 1.1.4-4
lightdm-slick-greeter 1.1.4-1 1.1.4-6
limepanel 0.33.r114.gca1e566-1 0.41.r123.g4a4023f-1
manjaro-architect 0.9.10-1 0.9.11-1
manjaro-architect-launcher 0.9.10-1 0.9.11-1
manjaro-awesome-settings 20180415-1 20180426-1
manjaro-bspwm-mate-settings 20180415-1 20180426-1
manjaro-bspwm-settings 20180415-1 20180426-1
manjaro-bspwm-settings-minimal 20180415-1 20180426-1
manjaro-budgie-settings 20180415-1 20180426-1
manjaro-i3-settings 20180415-2 20180423-1
manjaro-jwm-settings 20180415-1 20180426-1
manjaro-kde-minimal-settings 20180414-1 20180427-1.0
manjaro-kde-settings 20180414-1 20180427-1.0
manjaro-lxde-settings 20180415-1 20180426-1
manjaro-mate-settings 20180415-1 20180426-1
manjaro-openbox-common 1.0-2 1.1.10-1
manjaro-openbox-grub-theme 1.0-1 1.0-3
manjaro-openbox-settings 20180415-1 20180418-2
micro-manjaro 1.4.0-3 1.4.0-8
ms-office-online 18.01.0-1 18.04.2-1
octopi 0.8.11-1 0.8.12-1
octopi-cachecleaner 0.8.11-1 0.8.12-1
octopi-notifier-frameworks 0.8.11-1 0.8.12-1
octopi-notifier-qt5 0.8.11-1 0.8.12-1
octopi-pacmanhelper 0.8.11-1 0.8.12-1
octopi-repoeditor 0.8.11-1 0.8.12-1
pacui 1.10-1 1.10.1-1
papirus-maia-icon-theme 20180401-1 20180401-2
pix 1.6.2-11.6.2+master.mint19-1
python-jade-application-kit 0.a35-1 1.3.3-1
rofi-scripts 0.2-1 0.7-1
rootmenu 0.8-1 0.15-1
steam-manjaro 1.0.0.54-10 1.0.0.54-11
sterminal 0.4-1 0.8-1
timeshift v18.2-1 v18.4-1
update-notifier 0.7.4-1 0.7.5-1
vertex-maia-gtk3 20170702-1 20180425-1
vertex-maia-themes 20171126-1 20180425-1
vertex-themes 20171126-1 20180425-1
xfce-theme-greybird 3.22.5.r3.gff3f88e-1 3.22.8-1
yay 5.675-2 6.717-2
gnome-shell-extension-gsconnect - 11-1
gnome-terminal-fedora - 3.28.1-1
manjaro-cinnamon-settings-dev - 20180419-1
manjaro-gnome-extension-settings-17.0 - 20180426-1
manjaro-gnome-settings-17.0 - 20180426-1
manjaro-i3-settings-dev - 20180423-1
ob-autostart - 1-3
py-corners - 0.1-2
spotify - 1.0.72.117-1
thunar-shares-plugin - 0.2.0.git-5
ttf-font-logos - 0.10-3
ttf-polybar-icons - 1.0-1
udevil - 0.4.4-4
vte-notification-common - 0.52.1-1
vte3-notification - 0.52.1-1
:: Different sync package(s) in repository community i686
absl-py 0.1.13-1.0 0.2.0-1.0
acetoneiso2 2.3-8 2.3-9.0
acpi_call-dkms 1.1.0-117.0 1.1.0-124.0
acpid 2.0.28-1 2.0.29-2.0
alsa-tools 1.1.5-1.1 1.1.6-1.0
amule 10990-6.0 10998-1.0
android-file-transfer 3.2-1 3.3-1.0
ansible 2.5.0-1.0 2.5.1-1.0
apm 1.19.0-2.0 1.19.0-4.0
atom 1.25.1-1.0 1.26.0-1.0
aubio 0.4.6-3.0 0.4.6-4.0
auditbeat 6.2.3-2.0 6.2.4-1.0
autossh 1.4e-1 1.4e-2.0
aws-cli 1.15.4-1.0 1.15.10-1.0
backuppc 4.1.5-4.0 4.2.0-1.0
bettercap 2.4-1.0 2.5-1.0
boinc 7.8.4-1.0 7.8.4-3.0
boinc-nox 7.8.4-1.0 7.8.4-3.0
cabal-helper 0.8.0.2-5.0 0.8.0.2-6.0
cabal-install 2.0.0.1-47.0 2.0.0.1-49.0
cadence 0.9.0-1.0 0.9.0-2.0
calibre 3.21.0-1.0 3.22.1-1.0
ccache 3.4.1-1.0 3.4.2-1.0
cgrep 6.6.23-21.0 6.6.23-22.0
cinnamon 3.6.7-1.0 3.8.0-1.0
cinnamon-control-center 3.6.5-1 3.8.0-1.0
cinnamon-desktop 3.6.2-1 3.8.0-1.0
cinnamon-menus 3.6.0-1 3.8.0-1.0
cinnamon-screensaver 3.6.1-1 3.8.0-1.0
cinnamon-session 3.6.1-1.0 3.8.1-1.0
cinnamon-settings-daemon 3.6.2-1.0 3.8.0-1.0
cinnamon-translations 3.6.4-1.0 3.8.0-1.0
containerd 1.0.3-1.0 1.1.0-1.0
coq 8.7.2-1.0 8.8.0-1.0
coq-doc 8.7.2-1.0 8.8.0-1.0
coqide 8.7.2-1.0 8.8.0-1.0
cppcheck 1.82-1.0 1.83-1.0
cryptol 2.5.0-47.0 2.5.0-48.0
darcs 2.14.0-4.0 2.14.0-6.0
darktable 2:2.4.2-1.0 2:2.4.3-1.0
deepin-api 3.1.22-1.0 3.1.23-1.0
deepin-launcher 4.3.2-1.0 4.3.2.2-1.0
deepin-session-ui 4.3.3-1.0 4.3.7.2-1.0
displaycal 3.5.2.0-1.0 3.5.3.0-1.0
docker 1:18.03.0-1.0 1:18.04.0-1.0
dokuwiki 20170219_e-1 20180422-1.0
drupal 8.5.1-1.0 8.5.3-1.0
dub 1.3.0-1 1.8.1-1.0
ejabberd 18.03-1.0 18.04-1.0
elasticsearch 6.2.3-1.0 6.2.4-1.0
electrum 3.1.2-1.0 3.1.3-1.0
eolie 0.9.28-1.0 0.9.29-1.0
exim 4.90.1-1.1 4.90.1-2.0
fail2ban 0.10.2-1.0 0.10.3.1-1.0
fasm 1.73.01-1.0 1.73.03-1.0
fig2dev 3.2.6.a-1.0 3.2.7-1.0
filebeat 6.2.3-2.0 6.2.4-1.0
fio 3.5-1.0 3.6-1.0
firefox-adblock-plus 3.0.1-2 3.0.4-1.0
firefox-developer-edition-i18n-ach 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-af 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-an 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-ar 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-as 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-ast 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-az 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-be 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-bg 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-bn-bd 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-bn-in 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-br 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-bs 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-ca 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-cak 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-cs 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-cy 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-da 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-de 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-dsb 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-el 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-en-gb 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-en-us 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-en-za 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-eo 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-es-ar 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-es-cl 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-es-es 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-es-mx 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-et 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-eu 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-fa 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-ff 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-fi 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-fr 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-fy-nl 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-ga-ie 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-gd 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-gl 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-gn 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-gu-in 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-he 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-hi-in 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-hr 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-hsb 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-hu 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-hy-am 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-id 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-is 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-it 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-ja 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-ka 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-kab 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-kk 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-km 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-kn 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-ko 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-lij 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-lt 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-lv 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-mai 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-mk 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-ml 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-mr 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-ms 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-my 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-nb-no 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-nl 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-nn-no 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-or 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-pa-in 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-pl 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-pt-br 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-pt-pt 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-rm 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-ro 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-ru 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-si 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-sk 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-sl 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-son 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-sq 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-sr 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-sv-se 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-ta 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-te 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-th 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-tr 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-uk 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-ur 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-uz 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-vi 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-xh 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-zh-cn 60.0b12-1.0 60.0b15-1.0
firefox-developer-edition-i18n-zh-tw 60.0b12-1.0 60.0b15-1.0
firefox-extension-privacybadger 2018.3.21-2.0 2018.4.10-2.0
flake8 1:3.5.0-1 1:3.5.0-2.0
flickcurl 1.26-2.1 1.26-2.2
freeradius 3.0.16-1.0 3.0.17-1.0
gdal 2.2.3-4.0 2.2.4-2.0
geany-plugins 1.33-2.0 1.33-3.0
git-annex 6.20180316-23.0 6.20180409-8.0
gitlab 10.6.4-1.0 10.7.1-1.0
gitlab-gitaly 0.96.1-1.0 0.97.0-2.0
gitlab-shell 2:7.1.2-1.0 2:7.1.2-2.0
gitlab-workhorse 4.1.0-1.0 4.1.0-2.0
glusterfs 1:3.13.2-2.0 1:4.0.1-1.0
gnokii 0.6.31-15.0 0.6.31-16.0
gnome-screensaver 3.6.1-14.0 3.6.1-15.0
gnu-apl 1.7-4 1.7-5.0
go-ethereum 1.8.3-1.0 1.8.6-1.0
gopass 1.6.10-1.0 1.6.11-1.0
gradle 4.6-1.0 4.7-1.0
gradle-doc 4.6-1.0 4.7-1.0
gradle-src 4.6-1.0 4.7-1.0
grails 3.3.4-1.0 3.3.5-1.0
grails-docs 3.3.4-1.0 3.3.5-1.0
gtkd 3.8.0-1.0 3.8.2-1.0
guake 3.2.0-1.0 3.2.1-1.0
gwenhywfar 4.18.0-3.0 4.20.0-2.0
haskell-adjunctions 4.4-12.0 4.4-13.0
haskell-authenticate 1.3.4-81.0 1.3.4-84.0
haskell-aws 0.19-51.0 0.19-55.0
haskell-bifunctors 5.5.2-7.0 5.5.2-8.0
haskell-brick 0.36-2.0 0.36-4.0
haskell-cheapskate 0.1.1-64.0 0.1.1-67.0
haskell-checkers 0.4.9.5-16.0 0.4.10-2.0
haskell-comonad 5.0.3-2.0 5.0.3-3.0
haskell-concise 0.1.0.1-16.0 0.1.0.1-17.0
haskell-conduit-combinators 1.1.2-48.0 1.1.2-49.0
haskell-config-ini 0.2.2.0-33.0 0.2.2.0-34.0
haskell-contravariant 1.4.1-2.0 1.4.1-3.0
haskell-contravariant-extras 0.3.4-1.0 0.3.4-2.0
haskell-criterion 1.4.0.0-19.0 1.4.0.0-21.0
haskell-dav 1.3.2-39.0 1.3.2-41.0
haskell-dbus 1.0.1-3.0 1.0.1-5.0
haskell-dbus0.10 0.10.15-2.0 0.10.15-3.0
haskell-descriptive 0.9.4-94.0 0.9.4-95.0
haskell-dns 3.0.2-14.0 3.0.2-15.1
haskell-either 5-36.0 5-37.0
haskell-extra 1.6.5-1.0 1.6.6-1.0
haskell-fdo-notify 0.3.1-42.0 0.3.1-44.0
haskell-foldl 1.3.7-6.0 1.3.7-7.0
haskell-free 4.12.4-56.0 4.12.4-57.0
haskell-glib 0.13.5.0-5.0 0.13.6.0-1.0
haskell-gtk 0.14.8-7.0 0.14.8-8.0
haskell-hakyll 4.11.0.0-61.0 4.11.0.0-71.0
haskell-hasql 1.1.1-56.0 1.1.1-57.0
haskell-hasql-pool 0.4.3-56.0 0.4.3-57.0
haskell-hasql-transaction 0.5.2-56.0 0.5.2-57.0
haskell-hjsonschema 1.7.2-59.0 1.7.2-64.0
haskell-hledger-lib 1.9-4.0 1.9-5.0
haskell-hopenpgp 2.5.5-195.0 2.5.5-197.0
haskell-hpack 0.27.0-37.0 0.27.0-39.0
haskell-hspec-smallcheck 0.5.1-1.0 0.5.2-1.0
haskell-hspec-wai 0.9.0-49.0 0.9.0-51.0
haskell-hspec-wai-json 0.9.0-55.0 0.9.0-57.0
haskell-http 4000.3.11-10.0 4000.3.11-12.0
haskell-http-client 0.5.12-2.0 0.5.12.1-1.0
haskell-http-client-tls 0.3.5.3-32.0 0.3.5.3-33.0
haskell-http-conduit 2.2.4-78.0 2.2.4-81.0
haskell-incremental-parser 0.2.5.3-19.0 0.2.5.3-21.0
haskell-ini 0.3.5-16.0 0.3.6-1.0
haskell-insert-ordered-containers 0.2.1.0-67.0 0.2.1.0-68.0
haskell-iproute 1.7.3-3.0 1.7.4-1.0
haskell-jose 0.6.0.3-55.0 0.6.0.3-56.0
haskell-js-jquery 3.3.1-41.0 3.3.1-43.0
haskell-kan-extensions 5.1-14.0 5.1-15.0
haskell-keys 3.12-13.0 3.12-14.0
haskell-lens 4.15.4-27.0 4.15.4-28.0
haskell-lens-aeson 1.0.2-48.0 1.0.2-49.0
haskell-lrucache 1.2.0.0-25.0 1.2.0.0-26.0
haskell-lucid 2.9.10-1.0 2.9.10-2.0
haskell-mono-traversable 1.0.8.1-14.0 1.0.8.1-15.0
haskell-pango 0.13.4.0-9.0 0.13.4.0-10.0
haskell-pipes-http 1.0.5-120.0 1.0.5-121.0
haskell-pointed 5.0.1-15.0 5.0.1-16.0
haskell-profunctors 5.2.2-10.0 5.2.2-11.0
haskell-rebase 1.2.3-36.0 1.2.3-37.0
haskell-reducers 3.12.2-20.0 3.12.2-21.0
haskell-rerebase 1.2.1-44.0 1.2.1-45.0
haskell-sbv 7.6-9.0 7.6-10.0
haskell-semigroupoids 5.2.2-14.0 5.2.2-15.0
haskell-servant-server 0.12-90.0 0.12-94.1
haskell-servant-swagger 1.1.4-64.0 1.1.4-65.0
haskell-shake 0.16.4-1.0 0.16.4-4.0
haskell-statevar 1.1.0.4-7.0 1.1.1.0-1.0
haskell-store 0.4.3.2-74.0 0.4.3.2-76.0
haskell-swagger2 2.2.1-1.0 2.2.1-2.0
haskell-tasty-rerun 1.1.10-9.0 1.1.10-10.0
haskell-trifecta 1.7.1.1-52.0 1.7.1.1-53.0
haskell-turtle 1.5.7-1.0 1.5.8-2.0
haskell-vector-instances 3.4-44.0 3.4-45.0
haskell-wai-app-static 3.1.6.2-9.0 3.1.6.2-13.1
haskell-wai-extra 3.0.22.0-37.1 3.0.22.0-39.2
haskell-wai-handler-launch 3.0.2.3-51.0 3.0.2.3-53.1
haskell-wai-logger 2.3.2-19.0 2.3.2-20.0
haskell-warp 3.2.18.2-4.0 3.2.18.2-6.1
haskell-warp-tls 3.2.4.2-38.0 3.2.4.3-2.1
haskell-wl-pprint-extras 3.5.0.5-35.0 3.5.0.5-36.0
haskell-wl-pprint-terminfo 3.7.1.4-35.0 3.7.1.4-36.0
haskell-xcffib 0.6.0-14.0 0.6.0-15.0
haskell-yesod 1.4.5-244.0 1.4.5-252.1
haskell-yesod-auth 1.4.21-136.0 1.4.21-143.0
haskell-yesod-core 1.4.37.3-53.0 1.4.37.3-60.1
haskell-yesod-default 1.2.0-290.0 1.2.0-295.0
haskell-yesod-form 1.4.16-138.0 1.4.16-146.1
haskell-yesod-persistent 1.4.3-113.0 1.4.3-121.1
haskell-yesod-static 1.5.3.1-125.0 1.5.3.1-132.1
haskell-yesod-test 1.5.9.1-99.0 1.5.9.1-107.1
hcloud 1.3.2-1.0 1.4.0-1.0
heartbeat-elastic 6.2.3-2.0 6.2.4-1.0
hercules 3.13.00-1.0 3.13.00-3.0
hiawatha 10.8-1.0 10.8.1-1.0
hindent 5.2.5-20.0 5.2.5-21.0
hledger 1.9-4.0 1.9-6.0
hledger-api 1.9-2.0 1.9-11.0
hledger-ui 1.9-5.0 1.9-8.0
hledger-web 1.9-2.0 1.9.1-7.0
hlint 2.1.1-3.0 2.1.3-1.0
hoogle 5.0.16-53.0 5.0.16-60.0
hopenpgp-tools 0.19.5-114.0 0.19.5-117.0
ibus-rime 1.2-1 1.3.0-1.0
idris 1.2.0-57.0 1.2.0-61.0
java-rxtx 2.2pre2-4 2.2pre2-5.0
jenkins 2.117-1.0 2.118-1.0
jmol 14.29.12-1.0 14.29.13-1.0
jruby 9.1.16.0-1.0 9.1.17.0-1.0
julia 2:0.6.2-2.0 2:0.6.2-7.0
julia-docs 2:0.6.2-2.0 2:0.6.2-7.0
kde-development-environment-meta 20170718-1 20180423-1.0
kea 1.3.0-7.0 1.3.0-9.0
kea-devel-docs 1.3.0-2.0 1.3.0-3.0
keepalived 1.4.2-1.0 1.4.3-1.0
kibana 6.2.3-1.0 6.2.4-1.0
kio-gdrive 1.2.2-1.0 1.2.3-1.0
kotlin 1.2.31-1.0 1.2.40-1.0
kstars 1:2.9.4-3.0 1:2.9.5-1.0
latte-dock 0.7.4-1.0 0.7.5-1.0
libfm 1.2.5-2.1 1.3.0-1.0
libfm-extra 1.2.5-2.1 1.3.0-1.0
libfm-gtk2 1.2.5-2.1 1.3.0-1.0
libfm-gtk3 1.2.5-2.1 1.3.0-1.0
libindi 1.7.1-2.0 1.7.2-1.0
libmodsecurity 20170611-3.0 1:3.0.2-1.0
libnids 1.24-3.1 1.24-4.0
libpackagekit-glib 1.1.9-1.0 1.1.10-1.0
libpinyin 2.1.91-1.0 2.2.0-1.0
libringclient2:20180414.2.2c51f89-1.02:20180419.1.01da897-1.0
libsavitar 2.7.0-1.0 3.2.1-1.0
libsigrokdecode 0.5.0-1 0.5.1-1.0
libspf2 1.2.10-3.1 1.2.10-4.0
libwrap 7.6.24-3.1 7.6.24-4.0
lockdev 1.0.3_1.6-4 1.0.3_1.6-5.0
log4cplus 1.2.1-1.0 2.0.0-1.0
log4cpp 1.1.1-2 1.1.3-1.0
logstash 6.2.3-1.0 6.2.4-1.0
lolcat 99.9.9-1.0 99.9.11-1.0
matrix-synapse 0.27.3-1.0 0.27.4-1.0
metasploit 4.16.49-1.0 4.16.51-1.0
metricbeat 6.2.3-2.0 6.2.4-1.0
midori 0.5.11-6 0.5.11-7.0
minio 2018.01.02-1.0 2018.04.19-5.0
miniupnpc 2.0.20180406-1.0 2.0.20180410-1.0
miniupnpd 2.0.20180222-1.0 2.0.20180422-1.0
mod_passenger 5.2.2-1.0 5.2.3-3.0
muffin 3.6.0-1 3.8.0-1.0
mysql-workbench 6.3.10-4.0 6.3.10-5.0
navit 0.5.0-2 0.5.1-1.0
nemo 3.6.5-1.0 3.8.0-1.0
neofetch 3.4.0-1.0 3.4.0-2.0
nextcloud 13.0.1-1.0 13.0.2-1.0
nginx-mod-auth-pam 1.5.1-3 1.5.1-4.0
nginx-mod-echo 0.61-2 0.61-3.0
nginx-mod-geoip2 2.0-3 2.0-4.0
nginx-mod-headers-more 0.33-1 0.33-2.0
nginx-mod-memc 0.18-3 0.19-1.0
nginx-mod-modsecurity 1:1.0.0-1.0 1:1.0.0-2.0
nginx-mod-naxsi 0.55.3-3 0.55.3-4.0
nginx-mod-ndk 0.31+0.3.0-3 0.32+0.3.0-1.0
nginx-mod-njs 0.1.12-2 0.2.0-1.0
nginx-mod-passenger 5.2.2-1.0 5.2.3-3.0
nginx-mod-redis 0.3.8-3 0.3.8-4.0
nginx-mod-redis2 0.14-3 0.15-1.0
nginx-mod-set-misc 0.31+0.3.0-3 0.32+0.3.0-1.0
nginx-mod-srcache 0.31-3 0.31-4.0
nodejs-emojione 3.1.2-1 3.1.3-1.0
notepadqq 1.2.0-2.0 1.3.6-1.0
npm-check-updates 2.14.1-1.0 2.14.2-1.0
nuitka 0.5.29.4-1.0 0.5.29.5-1.0
oniguruma 6.8.1-1.0 6.8.2-1.0
opendht 1:1.7.0-1.0 1:1.7.1-1.0
packagekit 1.1.9-1.0 1.1.10-1.0
packer-io 1.2.2-1.0 1.2.3-1.0
packetbeat 6.2.3-2.0 6.2.4-1.0
pandoc 2.1.3-19.0 2.1.3-21.0
pandoc-citeproc 0.13.0.1-61.0 0.13.0.1-63.0
pandoc-crossref 0.3.0.3-20.0 0.3.1.0-2.0
parallel 20180322-1.0 20180422-1.0
pcmanfm 1.2.5-2 1.3.0-1.0
pcmanfm-gtk3 1.2.5-2 1.3.0-1.0
perl-data-random 0.12-3 0.13-1.0
perl-module-build-xsutil 0.18-1.0 0.19-1.0
pgadmin4 2.1-1.0 3.0-1.0
phpmyadmin 4.8.0-1.0 4.8.0.1-1.0
pigar 0.7.1-1 0.7.2-1.0
postgrest 0.4.4.0-107.0 0.4.4.0-116.0
psi 1.3-3.0 1.3-5.0
psi-nowebkit 1.3-2.0 1.3-4.0
psi-plugins 1.3-3.0 1.3-4.0
python-aiohttp 3.1.2-1.0 3.1.3-1.0
python-ansible 2.5.0-1.0 2.5.1-1.0
python-async_generator 1.8-1.0 1.9-1.0
python-aubio 0.4.6-3.0 0.4.6-4.0
python-boto3 1.7.4-1.0 1.7.10-1.0
python-botocore 1.10.4-1.0 1.10.10-1.0
python-braintree 3.44.0-1.0 3.45.0-1.0
python-certifi 2018.1.18-1.0 2018.4.16-1.0
python-cheroot 6.2.3-1.0 6.2.4-1.0
python-cherrypy 14.0.1-1.0 14.2.0-1.0
python-cysignals 1.7.0-1.0 1.7.1-1.0
python-decorator 4.2.1-1.0 4.3.0-1.0
python-django-extensions 2.0.6-1.0 2.0.7-1.0
python-docker 3.2.1-1.0 3.3.0-1.0
python-docker-pycreds 0.2.2-1.0 0.2.3-1.0
python-flask 0.12.2-4.0 1.0-1.0
python-gcp-devrel-py-tools 0.0.13-1.0 0.0.14-1.0
python-gmpy2 2.1.0a2-1.0 2.1.0a2-2.0
python-html5-parser 0.4.4-1 0.4.5-1.0
python-hypothesis 3.55.1-1.0 3.56.5-1.0
python-jedi 0.11.1-1.0 0.12.0-1.0
python-keystoneauth1 3.4.0-1.0 3.5.0-1.0
python-keystoneclient 3.15.0-1.0 3.16.0-1.0
python-ldap3 2.4.1-1.0 2.5-1.0
python-multidict 4.1.0-1.0 4.2.0-1.0
python-nose2 0.7.4-1.0 0.7.4-2.0
python-novaclient 10.1.0-1.0 10.2.0-1.0
python-oslo-concurrency 3.26.0-1.0 3.27.0-1.0
python-oslo-config 6.0.2-1.0 6.2.0-1.0
python-oslo-db 4.35.0-1.0 4.37.0-1.0
python-oslo-utils 3.36.0-1.0 3.36.1-1.0
python-parso 0.1.1-1 0.2.0-1.0
python-peewee 3.2.3-1.0 3.2.5-1.0
python-phonenumbers 8.9.3-1.0 8.9.4-1.0
python-pyassert 0.4.2-3.1 0.4.2-4.0
python-pybuilder 0.11.10-1 0.11.17-1.0
python-pycryptodomex 3.6.0-1.0 3.6.1-1.0
python-pyfix 0.2.3-3.1 0.2.3-4.0
python-pygit2 0.26.4-1.0 0.27.0-1.0
python-pytest 3.5.0-1.0 3.5.1-1.0
python-pytest-subtesthack 0.1.1-4.0 0.1.1-5.0
python-pytest-xprocess 0.12.1-1.0 0.12.1-2.0
python-pytools 2018.3-1.1 2018.4-1.0
python-raven 6.6.0-1.0 6.7.0-1.0
python-simplejson 3.13.2-1.0 3.14.0-1.0
python-softlayer 5.4.3-1.0 5.4.4-1.0
python-sortedcontainers 1.5.9-1.0 1.5.10-1.0
python-sphinx 1.7.2-1.0 1.7.3-1.0
python-sqlalchemy 1.2.6-1.0 1.2.7-1.0
python-subunit 1.2.0-2 1.3.0-1.0
python-tenacity 4.10.0-1.0 4.11.0-1.0
python-testfixtures 6.0.0-1.0 6.0.1-1.0
python-vobject 0.9.5-3.0 0.9.5-4.0
python-xapp 1.0.1-2 1.2.0-1.0
python-zope-hookable 4.1.0-1 4.2.0-1.0
python2-aubio 0.4.6-3.0 0.4.6-4.0
python2-boto3 1.7.4-1.0 1.7.10-1.0
python2-botocore 1.10.4-1.0 1.10.10-1.0
python2-braintree 3.44.0-1.0 3.45.0-1.0
python2-certifi 2018.1.18-1.0 2018.4.16-1.0
python2-cheroot 6.2.3-1.0 6.2.4-1.0
python2-cherrypy 14.0.1-1.0 14.2.0-1.0
python2-cysignals 1.7.0-1.0 1.7.1-1.0
python2-decorator 4.2.1-1.0 4.3.0-1.0
python2-django-extensions 2.0.6-1.0 2.0.7-1.0
python2-docker 3.2.1-1.0 3.3.0-1.0
python2-docker-pycreds 0.2.2-1.0 0.2.3-1.0
python2-faulthandler 3.0-1.0 3.1-1.0
python2-flake8 1:3.5.0-1 1:3.5.0-2.0
python2-flask 0.12.2-4.0 1.0-1.0
python2-gcp-devrel-py-tools 0.0.13-1.0 0.0.14-1.0
python2-gmpy2 2.1.0a2-1.0 2.1.0a2-2.0
python2-html5-parser 0.4.4-1 0.4.5-1.0
python2-hypothesis 3.55.1-1.0 3.56.5-1.0
python2-jedi 0.11.1-1.0 0.12.0-1.0
python2-keystoneauth1 3.4.0-1.0 3.5.0-1.0
python2-keystoneclient 3.15.0-1.0 3.16.0-1.0
python2-ldap3 2.4.1-1.0 2.5-1.0
python2-nose2 0.7.4-1.0 0.7.4-2.0
python2-novaclient 10.1.0-1.0 10.2.0-1.0
python2-oslo-concurrency 3.26.0-1.0 3.27.0-1.0
python2-oslo-config 6.0.2-1.0 6.2.0-1.0
python2-oslo-db 4.35.0-1.0 4.37.0-1.0
python2-oslo-utils 3.36.0-1.0 3.36.1-1.0
python2-pam 0.1.4-3.1 1.8.3-1.0
python2-parso 0.1.1-1 0.2.0-1.0
python2-peewee 3.2.3-1.0 3.2.5-1.0
python2-phonenumbers 8.9.3-1.0 8.9.4-1.0
python2-pigar 0.7.1-1 0.7.2-1.0
python2-pycryptodomex 3.6.0-1.0 3.6.1-1.0
python2-pygame-sdl21:2.1.0.r328.ce2578c-11:2.1.0.r347.795941a-1.0
python2-pygit2 0.26.4-1.0 0.27.0-1.0
python2-pypdf 1.13-4 1.13-5.0
python2-pytest 3.5.0-1.0 3.5.1-1.0
python2-pytest-xprocess 0.12.1-1.0 0.12.1-2.0
python2-pytools 2018.3-1.1 2018.4-1.0
python2-raven 6.6.0-1.0 6.7.0-1.0
python2-simplejson 3.13.2-1.0 3.14.0-1.0
python2-softlayer 5.4.3-1.0 5.4.4-1.0
python2-sortedcontainers 1.5.9-1.0 1.5.10-1.0
python2-sphinx 1.7.2-1.0 1.7.3-1.0
python2-sqlalchemy 1.2.6-1.0 1.2.7-1.0
python2-subunit 1.2.0-2 1.3.0-1.0
python2-tenacity 4.10.0-1.0 4.11.0-1.0
python2-testfixtures 6.0.0-1.0 6.0.1-1.0
python2-vobject 0.9.5-3.0 0.9.5-4.0
python2-xapp 1.0.1-2 1.2.0-1.0
python2-zope-hookable 4.1.0-1 4.2.0-1.0
quassel-client 0.12.4-4.0 0.12.5-1.0
quassel-client-small 0.12.4-4.0 0.12.5-1.0
quassel-core 0.12.4-4.0 0.12.5-1.0
quassel-monolithic 0.12.4-4.0 0.12.5-1.0
radicale 2.1.8-4.0 2.1.9-2.0
ring-daemon2:20180414.2.2c51f89-1.02:20180420.2.ac1aac4-1.0
ring-gnome3:20180414.2.2c51f89-1.03:20180420.2.ac1aac4-2.0
rkt 1.29.0-1 1.30.0-1.0
rmlint 2.6.1-1 2.7.0-1.0
rmlint-shredder 2.6.1-1 2.7.0-1.0
ruby-async 1.5.0-1.0 1.6.0-1.0
ruby-faraday 0.14.0-1.0 0.15.0-1.0
ruby-iconv 1.0.4-6.0 1.0.5-1.0
ruby-mini_mime 0.1.4-2.0 1.0.0-1.0
ruby-mustache 1.0.3-3.0 1.0.5-1.0
ruby-pkg-config 1.2.8-2.0 1.3.0-1.0
ruby-rack 2.0.4-1.0 2.0.5-1.0
ruby-rdoc 6.0.1-1.0 6.0.3-1.0
ruby-term-ansicolor 1.4.0-3.0 1.6.0-1.0
ruby-treetop 1.6.8-3.0 1.6.10-1.0
shotwell 2:0.28.0-1.0 2:0.28.2-1.0
singular 4.1.1.p1-2.0 4.1.1.p2-1.0
sink 0.6.0-1.0 0.6.0-2.0
smplayer 18.3.0-1.0 18.4.0-1.0
solidity 0.4.21-1.0 0.4.23-1.0
squid 3.5.27-2.0 3.5.27-3.0
stack 1.6.5-71.0 1.6.5-77.0
strip-nondeterminism 0.040-1 0.041-1.0
stunnel 5.44-2.0 5.44-3.0
subsurface 4.7.8-1.0 4.7.8-2.0
sweethome3d 5.7-1.0 5.7-2.0
sylpheed 3.7.0-1.0 3.7.0-2.0
tamarin-prover 1.2.3-33.0 1.2.3-41.0
tcp-wrappers 7.6.24-3.1 7.6.24-4.0
termite 13-2.0 13-3.0
termite-terminfo 13-2.0 13-3.0
tesseract 3.05.01-3 3.05.01-4.1
testssl.sh 2.9.5.4-1.0 2.9.5.5-1.0
thefuck 3.25-1.0 3.26-1.0
three.js r91-1.0 r92-1.0
tinyxml2 6.0.0-1.0 6.2.0-1.0
tmuxp 1.4.0-2.0 1.4.0-3.0
transcode 1.1.7-24.1 1.1.7-25.0
ttf-symbola 10.24-1.0 11.00-1.0
tup 0.7.5-1 0.7.6-1.0
typescript 2.8.1-1.0 2.8.3-1.0
uglify-js 3.3.21-1.0 3.3.22-1.0
unifdef 2.11-1 2.11-2.0
unrealircd 4.0.17-2.0 4.0.17-3.0
v2ray 3.18.1-1.0 3.21-1.0
vagrant 2.0.3-1.0 2.0.4-1.0
vim-gitgutter 491.3724e1c-1.0 493.ad25925-1.0
virtualbox 5.2.8-1.0 5.2.10-1.1
virtualbox-ext-vnc 5.2.8-1.0 5.2.10-1.1
virtualbox-guest-dkms 5.2.8-1.0 5.2.10-1.1
virtualbox-guest-iso 5.2.8-1.0 5.2.10-1.0
virtualbox-guest-utils 5.2.8-1.0 5.2.10-1.1
virtualbox-guest-utils-nox 5.2.8-1.0 5.2.10-1.1
virtualbox-host-dkms 5.2.8-1.0 5.2.10-1.1
virtualbox-sdk 5.2.8-1.0 5.2.10-1.1
vsftpd 3.0.3-3 3.0.3-4.0
weston 3.0.0-2.1 4.0.0-1.0
wine 3.5-1.0 3.6-1.0
wireguard-dkms 0.0.20180413-1.0 0.0.20180420-1.0
wireguard-tools 0.0.20180413-1.0 0.0.20180420-1.0
wireshark-cli 2.5.1-1.0 2.6.0-1.0
wireshark-common 2.5.1-1.0 2.6.0-1.0
wireshark-gtk 2.5.1-1.0 2.6.0-1.0
wireshark-qt 2.5.1-1.0 2.6.0-1.0
xapps 1.0.4-2.0 1.2.0-1.0
xmobar 0.26-3.0 0.26-7.0
yrd 0.5.2-1 0.5.3-1.0
yubico-pam 2.25-2.0 2.26-1.0
yubikey-manager 0.6.1-1.0 0.6.1-2.0
yubikey-personalization 1.18.1-2.0 1.19.0-1.0
broadcom-wl - 6.30.223.271-11.0
deepin-draw - 1.0.0-1.0
eclipse-common - 4.7.3.a-1.1
eclipse-cpp - 4.7.3.a-1.1
eclipse-java - 4.7.3.a-1.1
eclipse-javascript - 4.7.3.a-1.1
eclipse-jee - 4.7.3.a-1.1
eclipse-php - 4.7.3.a-1.1
firefox-developer-edition-i18n-ia - 60.0b15-1.0
firefox-developer-edition-i18n-ne-np - 60.0b15-1.0
gnome-mpv - 0.14-2.0
gnome-usage - 3.28.0-1.0
gpxsee - 5.9-1.0
gscan2pdf - 2.0.3-1.0
gtksourceview4 - 4.0.0-2.0
neverball - 1.6.0-3.0
perl-cairo-gobject - 1.004-6.0
perl-config-general - 2.63-3.0
perl-data-uuid - 1.221-4.0
perl-devel-cycle - 1.12-2.0
perl-filesys-df - 0.92-7.0
perl-glib-object-introspection - 0.044-1.0
perl-goocanvas2 - 0.06-1.0
perl-gtk3 - 0.033-2.0
perl-gtk3-simplelist - 0.17-2.0
perl-image-sane - 0.14-1.0
perl-padwalker - 2.3-1.0
perl-pdf-api2 - 2.033-2.0
perl-set-intspan - 1.19-7.0
perl-test-memory-cycle - 1.06-1.0
python-antlr4 - 4.7.1-1.0
python-gdal - 2.2.4-2.0
python-latexcodec - 1.0.5-1.0
python-oset - 0.1.3-1.0
python-owslib - 0.16.0-2.0
python-pybtex - 0.21-3.0
python-sphinx-testing - 0.7.2-1.0
python2-gdal - 2.2.4-2.0
python2-latexcodec - 1.0.5-1.0
python2-oset - 0.1.3-1.0
python2-owslib - 0.16.0-2.0
python2-pybtex - 0.21-3.0
python2-sphinx-testing - 0.7.2-1.0
qextserialport - 1.2rc-7.0
qgis - 3.0.2-1.0
qwtpolar - 1.1.1-4.0
spatialindex - 1.8.5-2.0
Any problems?
- No issues, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes I am currently experiencing an issue due to the update. (Please post about it)
0 voters
