[Stable Update x32] 2018-03-22 - Kernels, Curl, Chromium
update
stable
manjaro32
#1
Hello i686ers!
This is a small update set to bring over the curl security update as well as new kernel versions. There’s not much else of note beyond a few package version bumps (mainly Haskell modules).
Oh - Phil also spun and uploaded a new 32-bit installer image! Yay!
Anyone who would like to help out testing the upstream packages, please read the archlinux32 thread for details about how they automate their testing process and how to get involved:
https://bbs.archlinux32.org/viewtopic.php?id=171
(running this in an archlinux32 VM would be fine)
Available kernels
Series Version
linux316 3.16.56
linux41 4.1.49
linux44 4.4.122
linux49 4.9.88
linux414 4.14.29
archlinux32
If you find manjaro32 useful please consider donating to, or helping out with, archlinux32. It’s a small team taking on a huge project and any help will no doubt be very much appreciated.
Why aren’t the available packages/package versions the same as x86_64?
archlinux32 packages are based on Arch packages but may need editing to build correctly. Builds of less-popular packages are lower priority.
Manjaro-specific packages may lag behind x86_64 because there aren’t as many packagers. If you notice an important package is lagging please report it; at the moment it’s only me packaging for i686:
I’m only packaging current LTS kernels. Any marked as EOL are dropped. I’ll not be building the mainline kernel.
What about security updates?
I cannot guarantee timely security updates on x32-stable. If this is critical for you I recommend you switch to x32-testing or cherry-pick those packages from x32-testing or x32-unstable as they become available.
Something broke. Isn’t this meant to be stable?
“Stable” means “infrequently changing”, not “everything will work perfectly all the time”. If you want it to mean everything works, you need to help test the things you’re interested in.
What about installer images?
Phil very kindly updated the preview installer images:
What about x32-testing and x32-unstable?
These are already available, and I recommend you use x32-testing if you can to make sure testing is done.
x32-unstable should be used by anyone who wants to try and find any issues before they impact other people. If you have multiple/many machines you really should run one of those on x32-unstable.
Full list of changes
:: Different overlay package(s) in repository core i686
                             PACKAGE           2018-03-17           2018-03-22
                            linux316            3.16.55-1            3.16.56-1
                    linux316-headers            3.16.55-1            3.16.56-1
                            linux414            4.14.27-1            4.14.29-1
                    linux414-headers            4.14.27-1            4.14.29-1
                             linux44            4.4.121-1            4.4.122-1
                     linux44-headers            4.4.121-1            4.4.122-1
                             linux49             4.9.87-1             4.9.88-1
                     linux49-headers             4.9.87-1             4.9.88-1
                      manjaro-system           20180318-1           20180320-1
:: Different sync package(s) in repository core i686
                                curl           7.58.0-2.0           7.59.0-2.0
                                 gcc            7.3.0-1.1   7.3.1+20180312-1.0
                             gcc-ada            7.3.0-1.1   7.3.1+20180312-1.0
                         gcc-fortran            7.3.0-1.1   7.3.1+20180312-1.0
                              gcc-go            7.3.0-1.1   7.3.1+20180312-1.0
                            gcc-libs            7.3.0-1.1   7.3.1+20180312-1.0
                            gcc-objc            7.3.0-1.1   7.3.1+20180312-1.0
                              libpsl           0.20.0-1.0           0.20.1-1.0
                            libtirpc            1.0.2-3.0            1.0.3-1.0
                             libtool2.4.6+40+g6ca5e224-4.02.4.6+40+g6ca5e224-5.0
:: Different overlay package(s) in repository extra i686
                        gtk3-classic            3.22.28-1            3.22.29-2
                  linux316-acpi_call             1.1.0-40             1.1.0-41
                linux316-broadcom-wl      6.30.223.271-19      6.30.223.271-20
                linux316-ndiswrapper              1.61-19              1.61-20
                     linux316-nvidia           1:390.42-1           1:390.42-2
               linux316-nvidia-304xx         1:304.137-10         1:304.137-11
               linux316-nvidia-340xx            340.106-5            340.106-6
      linux316-open-vm-tools-modules      2:2013.09.16-39      2:2013.09.16-40
                      linux316-r8168           8.045.08-5           8.045.08-6
                  linux316-rt3562sta        2.4.1.1_r4-19        2.4.1.1_r4-20
                        linux316-spl              0.7.6-1              0.7.6-2
                linux316-vhba-module          20161009-19          20161009-20
   linux316-virtualbox-guest-modules              5.2.8-2              5.2.8-3
    linux316-virtualbox-host-modules              5.2.8-2              5.2.8-3
                        linux316-zfs              0.7.6-1              0.7.6-2
                  linux414-acpi_call             1.1.0-25             1.1.0-26
                   linux414-bbswitch               0.8-25               0.8-26
                linux414-broadcom-wl      6.30.223.271-25      6.30.223.271-26
                linux414-ndiswrapper              1.61-25              1.61-26
                     linux414-nvidia           1:390.42-2           1:390.42-3
               linux414-nvidia-304xx         1:304.137-25         1:304.137-26
               linux414-nvidia-340xx           340.106-13           340.106-14
                      linux414-r8168          8.045.08-13          8.045.08-14
                  linux414-rt3562sta        2.4.1.1_r4-25        2.4.1.1_r4-26
                        linux414-spl              0.7.6-3              0.7.6-4
                   linux414-tp_smapi              0.41-25              0.41-26
                linux414-vhba-module          20161009-25          20161009-26
   linux414-virtualbox-guest-modules              5.2.8-5              5.2.8-6
    linux414-virtualbox-host-modules              5.2.8-5              5.2.8-6
                        linux414-zfs              0.7.6-3              0.7.6-4
                   linux44-acpi_call           1.1.0-86.1             1.1.0-87
                 linux44-broadcom-wl    6.30.223.271-56.1      6.30.223.271-57
                 linux44-ndiswrapper            1.61-54.1              1.61-55
                      linux44-nvidia         1:390.42-1.1           1:390.42-2
                linux44-nvidia-304xx       1:304.137-21.1         1:304.137-22
                linux44-nvidia-340xx          340.106-8.1            340.106-9
       linux44-open-vm-tools-modules    2:2013.09.16-86.1      2:2013.09.16-87
                       linux44-r8168         8.045.08-8.1           8.045.08-9
                   linux44-rt3562sta      2.4.1.1_r4-54.1        2.4.1.1_r4-55
                         linux44-spl            0.7.6-1.1              0.7.6-2
                 linux44-vhba-module        20161009-54.1          20161009-55
    linux44-virtualbox-guest-modules            5.2.8-1.1              5.2.8-2
     linux44-virtualbox-host-modules            5.2.8-1.1              5.2.8-2
                         linux44-zfs            0.7.6-1.1              0.7.6-2
                   linux49-acpi_call             1.1.0-68             1.1.0-69
                    linux49-bbswitch               0.8-68               0.8-69
                 linux49-broadcom-wl      6.30.223.271-68      6.30.223.271-69
                 linux49-ndiswrapper              1.61-66              1.61-67
                      linux49-nvidia           1:390.42-1           1:390.42-2
                linux49-nvidia-304xx         1:304.137-27         1:304.137-28
                linux49-nvidia-340xx            340.106-8            340.106-9
                       linux49-r8168           8.045.08-8           8.045.08-9
                   linux49-rt3562sta        2.4.1.1_r4-66        2.4.1.1_r4-67
                         linux49-spl              0.7.6-2              0.7.6-3
                    linux49-tp_smapi              0.41-68              0.41-69
                 linux49-vhba-module          20161009-66          20161009-67
    linux49-virtualbox-guest-modules              5.2.8-2              5.2.8-3
     linux49-virtualbox-host-modules              5.2.8-2              5.2.8-3
                         linux49-zfs              0.7.6-2              0.7.6-3
                   ndiswrapper-utils              1.61-25              1.61-26
                    rt3562sta-common        2.4.1.1_r4-66        2.4.1.1_r4-67
                               libnm                    -          1.10.6-2.01
                          libnm-glib                    -          1.10.6-2.01
                      networkmanager                    -          1.10.6-2.01
:: Different sync package(s) in repository extra i686
                          artikulate          17.12.3-1.0          17.12.3-1.1
                                asio             1.10.8-1           1.12.0-1.0
                             blinken          17.12.3-1.0          17.12.3-1.1
                              bomber          17.12.3-1.0          17.12.3-1.1
                                bovo          17.12.3-1.0          17.12.3-1.1
                              cantor          17.12.3-1.0          17.12.3-1.1
                               cmake           3.10.2-2.0           3.10.3-1.0
                              colord 1.4.1+6+gf08c25d-1.0            1.4.2-1.0
                             dnsmasq             2.78-2.0             2.79-1.0
                             dolphin          17.12.3-1.0          17.12.3-1.1
                       enlightenment           0.22.1-1.0           0.22.2-1.0
                              exempi   2.4.3+2+g65a8492-1            2.4.5-1.0
                             firefox           59.0.1-1.0           59.0.1-1.1
                    firefox-i18n-ach           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-af           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-an           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-ar           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-as           59.0.1-1.0           59.0.1-1.1
                    firefox-i18n-ast           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-az           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-be           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-bg           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-bn-bd           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-bn-in           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-br           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-bs           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-ca           59.0.1-1.0           59.0.1-1.1
                    firefox-i18n-cak           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-cs           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-cy           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-da           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-de           59.0.1-1.0           59.0.1-1.1
                    firefox-i18n-dsb           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-el           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-en-gb           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-en-us           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-en-za           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-eo           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-es-ar           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-es-cl           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-es-es           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-es-mx           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-et           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-eu           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-fa           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-ff           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-fi           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-fr           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-fy-nl           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-ga-ie           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-gd           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-gl           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-gn           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-gu-in           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-he           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-hi-in           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-hr           59.0.1-1.0           59.0.1-1.1
                    firefox-i18n-hsb           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-hu           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-hy-am           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-id           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-is           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-it           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-ja           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-ka           59.0.1-1.0           59.0.1-1.1
                    firefox-i18n-kab           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-kk           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-km           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-kn           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-ko           59.0.1-1.0           59.0.1-1.1
                    firefox-i18n-lij           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-lt           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-lv           59.0.1-1.0           59.0.1-1.1
                    firefox-i18n-mai           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-mk           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-ml           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-mr           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-ms           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-my           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-nb-no           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-nl           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-nn-no           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-or           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-pa-in           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-pl           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-pt-br           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-pt-pt           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-rm           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-ro           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-ru           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-si           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-sk           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-sl           59.0.1-1.0           59.0.1-1.1
                    firefox-i18n-son           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-sq           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-sr           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-sv-se           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-ta           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-te           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-th           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-tr           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-uk           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-ur           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-uz           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-vi           59.0.1-1.0           59.0.1-1.1
                     firefox-i18n-xh           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-zh-cn           59.0.1-1.0           59.0.1-1.1
                  firefox-i18n-zh-tw           59.0.1-1.0           59.0.1-1.1
                     flatpak-builder           0.10.6-1.0           0.10.9-1.0
                             freetds            1.00.44-1          1.00.83-1.0
                        gnu-efi-libs              3.0.6-1            3.0.8-1.0
                             gparted             0.30.0-3           0.31.0-1.0
                           granatier          17.12.3-1.0          17.12.3-1.1
                            harfbuzz            1.7.6-1.0            1.7.6-1.1
                        harfbuzz-icu            1.7.6-1.0            1.7.6-1.1
                               hplip          3.17.11-1.0           3.18.3-1.0
                        imagemagick6         6.9.9.38-1.0         6.9.9.39-2.0
                                js52           52.7.0-1.0           52.7.0-1.1
                             kajongg          17.12.3-1.0          17.12.3-1.1
                            kalgebra          17.12.3-1.0          17.12.3-1.1
                             kalzium          17.12.3-1.0          17.12.3-1.1
                            kanagram          17.12.3-1.0          17.12.3-1.1
                                kate          17.12.3-1.0          17.12.3-1.1
                              kbruch          17.12.3-1.0          17.12.3-1.1
                               kcron          17.12.3-1.0          17.12.3-1.1
                             kdialog          17.12.3-1.0          17.12.3-1.1
                      keditbookmarks          17.12.3-1.0          17.12.3-1.1
                               kfind          17.12.3-1.0          17.12.3-1.1
                          kgeography          17.12.3-1.0          17.12.3-1.1
                            khangman          17.12.3-1.0          17.12.3-1.1
                         khelpcenter          17.12.3-1.0          17.12.3-1.1
                                 kig          17.12.3-1.0          17.12.3-1.1
                               kiten          17.12.3-1.0          17.12.3-1.1
                            klettres          17.12.3-1.0          17.12.3-1.1
                              kmouth          17.12.3-1.0          17.12.3-1.1
                              kmplot          17.12.3-1.0          17.12.3-1.1
                             konsole          17.12.3-1.0          17.12.3-1.1
                  kross-interpreters          17.12.3-1.0          17.12.3-1.1
                          ksystemlog          17.12.3-1.0          17.12.3-1.1
                              ktouch          17.12.3-1.0          17.12.3-1.1
                             kturtle          17.12.3-1.0          17.12.3-1.1
                           kwordquiz          17.12.3-1.0          17.12.3-1.1
                              kwrite          17.12.3-1.0          17.12.3-1.1
                           libbluray              1.0.1-1            1.0.2-1.0
                  libhttpseverywhere            0.8.1-1.0            0.8.2-1.0
                             libical            3.0.1-1.0            3.0.3-1.0
                          libmagick6         6.9.9.38-1.0         6.9.9.39-2.0
                         libmicrodns            0.0.8-1.0           0.0.10-1.0
                               libnm           1.10.6-1.0           1.10.6-2.0
                          libnm-glib           1.10.6-1.0           1.10.6-2.0
                             libpqxx            6.1.0-1.0            6.1.1-1.0
                             librsvg         2:2.42.3-1.1         2:2.42.3-1.2
                            libxcomp         3.5.0.33-2.0        3.5.99.16-1.0
                              marble          17.12.3-1.0          17.12.3-1.1
                       marble-common          17.12.3-1.0          17.12.3-1.1
                           marble-qt          17.12.3-1.0          17.12.3-1.1
                              minuet          17.12.3-1.0          17.12.3-1.1
                                mono          5.4.1.7-2.0       5.10.0.160-1.0
                      networkmanager           1.10.6-1.0           1.10.6-2.0
                                nmap               7.60-1             7.70-1.0
                    noto-fonts-emoji         20180102-1.0         20180102-2.0
                          nx-headers         3.5.0.33-2.0        3.5.99.16-1.0
                              nx-x11         3.5.0.33-2.0        3.5.99.16-1.0
                             nxagent         3.5.0.33-2.0        3.5.99.16-1.0
                             nxproxy         3.5.0.33-2.0        3.5.99.16-1.0
                              parley          17.12.3-1.0          17.12.3-1.1
                            perl-dbi            1.640-1.0            1.641-1.0
                         perl-libwww             6.31-1.0             6.33-1.0
                     perl-xml-simple               2.24-3             2.25-1.0
                   publicsuffix-list20180225.652.d311456-1.020180320.657.a39f111-1.0
                        python-cairo           1.16.2-1.0           1.16.3-1.0
                 python-cryptography            2.1.4-1.0            2.2.1-1.0
                        python-numpy           1.14.1-1.0           1.14.2-1.0
                   python-setuptools         1:38.6.0-1.0         1:39.0.1-1.0
                       python2-cairo           1.16.2-1.0           1.16.3-1.0
                python2-cryptography            2.1.4-1.0            2.2.1-1.0
                       python2-numpy           1.14.1-1.0           1.14.2-1.0
                  python2-setuptools         1:38.6.0-1.0         1:39.0.1-1.0
                     qt5-declarative           5.10.1-3.0           5.10.1-3.2
                                rocs          17.12.3-1.0          17.12.3-1.1
                                step          17.12.3-1.0          17.12.3-1.1
                           syslog-ng           3.14.1-1.0           3.14.1-1.1
                              trayer            1.1.7-1.0            1.1.8-1.0
                            unixodbc            2.3.5-1.0            2.3.6-1.0
                        vim-spell-af           20150901-1         20180224-1.0
                        vim-spell-am           20150901-1         20180224-1.0
                        vim-spell-bg           20150901-1         20180224-1.0
                        vim-spell-br           20150901-1         20180224-1.0
                        vim-spell-ca           20150901-1         20180224-1.0
                        vim-spell-cs           20150901-1         20180224-1.0
                        vim-spell-cy           20150901-1         20180224-1.0
                        vim-spell-da           20150901-1         20180224-1.0
                        vim-spell-de           20150901-1         20180224-1.0
                        vim-spell-el           20150901-1         20180224-1.0
                        vim-spell-en           20150901-1         20180224-1.0
                        vim-spell-eo           20150901-1         20180224-1.0
                        vim-spell-es           20150901-1         20180224-1.0
                        vim-spell-fo           20150901-1         20180224-1.0
                        vim-spell-fr           20150901-1         20180224-1.0
                        vim-spell-ga           20150901-1         20180224-1.0
                        vim-spell-gd           20150901-1         20180224-1.0
                        vim-spell-gl           20150901-1         20180224-1.0
                        vim-spell-he           20150901-1         20180224-1.0
                        vim-spell-hr           20150901-1         20180224-1.0
                        vim-spell-hu           20150901-1         20180224-1.0
                        vim-spell-id           20150901-1         20180224-1.0
                        vim-spell-it           20150901-1         20180224-1.0
                        vim-spell-ku           20150901-1         20180224-1.0
                        vim-spell-la           20150901-1         20180224-1.0
                        vim-spell-lt           20150901-1         20180224-1.0
                        vim-spell-lv           20150901-1         20180224-1.0
                        vim-spell-mg           20150901-1         20180224-1.0
                        vim-spell-mi           20150901-1         20180224-1.0
                        vim-spell-ms           20150901-1         20180224-1.0
                        vim-spell-nb           20150901-1         20180224-1.0
                        vim-spell-nl           20150901-1         20180224-1.0
                        vim-spell-nn           20150901-1         20180224-1.0
                        vim-spell-ny           20150901-1         20180224-1.0
                        vim-spell-pl           20150901-1         20180224-1.0
                        vim-spell-pt           20150901-1         20180224-1.0
                        vim-spell-ro           20150901-1         20180224-1.0
                        vim-spell-ru           20150901-1         20180224-1.0
                        vim-spell-rw           20150901-1         20180224-1.0
                        vim-spell-sk           20150901-1         20180224-1.0
                        vim-spell-sl           20150901-1         20180224-1.0
                        vim-spell-sv           20150901-1         20180224-1.0
                        vim-spell-sw           20150901-1         20180224-1.0
                       vim-spell-tet           20150901-1         20180224-1.0
                        vim-spell-th           20150901-1         20180224-1.0
                        vim-spell-tl           20150901-1         20180224-1.0
                        vim-spell-tn           20150901-1         20180224-1.0
                        vim-spell-uk           20150901-1         20180224-1.0
                        vim-spell-yi           20150901-1         20180224-1.0
                        vim-spell-zu           20150901-1         20180224-1.0
                                wget           1.19.4-2.0           1.19.4-3.0
                      xfce4-settings           4.12.2-1.0           4.12.3-1.0
                          xorg-xinit            1.4.0-2.0            1.4.0-3.0
:: Different overlay package(s) in repository community i686
      deepin-desktop-schemas-manjaro              3.2.7-1              3.2.8-1
:: Different sync package(s) in repository community i686
                               abcde            2.8.1-3.0            2.9.1-1.0
                      acpi_call-dkms          1.1.0-111.0          1.1.0-112.0
                         agda-stdlib               0.14-1             0.15-1.0
                           auditbeat            6.2.2-1.0            6.2.3-1.0
                           bettercap              2.2-1.0              2.3-1.0
                                c2hs          0.28.3-16.0          0.28.3-17.0
                       cabal-install         2.0.0.1-35.1         2.0.0.1-38.0
                             caprine            2.9.0-1.0           2.10.0-1.0
                             certbot           0.22.0-1.0           0.22.2-1.0
                      certbot-apache           0.22.0-1.0           0.22.2-1.0
              certbot-dns-cloudflare           0.22.0-1.0           0.22.2-1.0
                certbot-dns-cloudxns           0.22.0-1.0           0.22.2-1.0
            certbot-dns-digitalocean           0.22.0-1.0           0.22.2-1.0
                certbot-dns-dnsimple           0.22.0-1.0           0.22.2-1.0
             certbot-dns-dnsmadeeasy           0.22.0-1.0           0.22.2-1.0
                  certbot-dns-google           0.22.0-1.0           0.22.2-1.0
                  certbot-dns-luadns           0.22.0-1.0           0.22.2-1.0
                   certbot-dns-nsone           0.22.0-1.0           0.22.2-1.0
                 certbot-dns-rfc2136           0.22.0-1.0           0.22.2-1.0
                 certbot-dns-route53           0.22.0-1.0           0.22.2-1.0
                       certbot-nginx           0.22.0-1.0           0.22.2-1.0
                             cryptol           2.5.0-37.0           2.5.0-39.0
                              cython             0.28-1.0           0.28.1-1.0
                             cython2             0.28-1.0           0.28.1-1.0
                               darcs 2.12.5.20170909-57.1 2.12.5.20170909-60.0
                          deepin-api           3.1.21-1.0           3.1.22-1.0
                   deepin-calculator            1.0.2-1.0            1.0.2-1.1
                       deepin-daemon           3.2.10-2.0           3.2.11-1.0
              deepin-desktop-schemas            3.2.8-1.0            3.2.9-1.0
                       deepin-go-lib            1.2.5-1.0            1.2.6-1.0
                               dingo               0.13-3             0.13-4.0
                      docker-compose           1.19.0-2.0           1.20.0-1.0
                             dovecot          2.3.0.1-2.0          2.3.0.1-3.0
                       elasticsearch            6.2.2-1.0            6.2.3-1.0
                            electron            1.8.2-1.0            1.8.4-1.0
                                eric            18.02-1.0            18.03-1.0
                         eric-common            18.02-1.0            18.03-1.0
                        eric-i18n-de            18.02-1.0            18.03-1.0
                        eric-i18n-en            18.02-1.0            18.03-1.0
                        eric-i18n-es            18.02-1.0            18.03-1.0
                        eric-i18n-ru            18.02-1.0            18.03-1.0
                              eslint           4.19.0-1.0           4.19.0-1.1
                              facter            3.9.5-1.0           3.10.0-1.0
                            filebeat            6.2.2-1.0            6.2.3-1.0
  firefox-extension-https-everywhere        2018.2.26-1.0        2018.3.13-1.0
                         geckodriver           0.20.0-1.0           0.20.0-1.1
                           git-annex       6.20180316-1.0       6.20180316-7.0
                              glider            0.5.0-1.0            0.5.1-1.0
                              gnunet          0.10.1-11.0          0.10.1-12.0
                               gnurl           7.58.0-2.0           7.58.0-3.0
                       haskell-brick          0.34.1-16.0          0.34.1-17.0
                       haskell-cairo         0.13.4.2-4.0         0.13.4.2-4.1
         haskell-conduit-combinators           1.1.2-42.0           1.1.2-43.0
               haskell-conduit-extra         1.2.3.2-25.0         1.2.3.2-26.0
                    haskell-cracknum              1.9-3.0              2.0-1.0
                   haskell-criterion          1.4.0.0-8.0         1.4.0.0-11.0
          haskell-cryptohash-conduit          0.1.1-150.0          0.1.1-151.0
          haskell-cryptonite-conduit           0.2.2-43.0           0.2.2-44.0
      haskell-data-accessor-template         0.2.1.14-4.0         0.2.1.15-1.0
                         haskell-dns            3.0.2-8.0            3.0.2-9.0
                   haskell-esqueleto           2.5.3-80.0           2.5.3-81.0
                        haskell-feed         1.0.0.0-39.0         1.0.0.0-40.0
                        haskell-glib         0.13.5.0-4.0         0.13.5.0-4.1
                      haskell-gnuidn           0.2.2-24.0           0.2.2-25.0
                      haskell-hjsmin         0.2.0.2-22.0         0.2.0.2-23.0
                 haskell-hjsonschema           1.7.2-49.0           1.7.2-52.0
                    haskell-hopenpgp          2.5.5-187.0          2.5.5-190.0
                   haskell-hspec-wai           0.9.0-43.0           0.9.0-44.0
              haskell-hspec-wai-json           0.9.0-48.0           0.9.0-49.0
                        haskell-http        4000.3.10-2.0        4000.3.11-2.0
                haskell-http-conduit           2.2.4-67.0           2.2.4-70.0
          haskell-incremental-parser         0.2.5.3-17.0         0.2.5.3-18.0
                 haskell-ixset-typed          0.3.1.1-9.0         0.3.1.1-10.0
                   haskell-js-jquery           3.3.1-30.0           3.3.1-33.0
                 haskell-juicypixels          3.2.9.4-3.0          3.2.9.5-1.0
         haskell-language-javascript         0.6.0.10-7.0         0.6.0.11-1.0
                haskell-monad-logger         0.3.28.2-2.0         0.3.28.2-3.0
           haskell-monoid-subclasses            0.4.4-7.0            0.4.6-1.0
       haskell-network-protocol-xmpp           0.4.8-29.0           0.4.8-30.0
                       haskell-nonce            1.0.7-2.0            1.0.7-3.0
                haskell-pandoc-types        1.17.3.1-16.0         1.17.4.2-1.0
                       haskell-pango         0.13.4.0-8.0         0.13.4.0-8.1
                  haskell-persistent         2.7.3.1-33.0         2.7.3.1-34.0
           haskell-persistent-sqlite           2.6.4-59.0           2.6.4-61.0
         haskell-persistent-template         2.5.3.1-32.0            2.5.4-1.0
            haskell-project-template         0.2.0.1-20.0         0.2.0.1-21.0
                    haskell-safecopy            0.9.4-1.0          0.9.4.1-1.0
                         haskell-sbv             7.5-24.0              7.6-1.0
              haskell-servant-server            0.12-79.0            0.12-82.0
                   haskell-setlocale          1.0.0.6-1.0          1.0.0.6-1.1
                       haskell-shake          0.16.3-16.0          0.16.3-19.0
                      haskell-shelly            1.7.1-3.0            1.7.2-1.0
             haskell-simple-sendfile          0.2.27-17.0          0.2.27-18.0
               haskell-stringbuilder            0.5.1-3.0            0.5.1-3.1
                     haskell-texmath        0.10.1.1-14.0        0.10.1.1-16.0
               haskell-typed-process          0.2.1.0-5.0          0.2.2.0-1.0
                    haskell-unliftio          0.2.5.0-1.0          0.2.6.0-1.0
                         haskell-vty             5.20-5.0             5.21-1.0
                         haskell-wai         3.2.1.1-31.0          3.2.1.2-1.0
              haskell-wai-app-static        3.1.6.1-168.0          3.1.6.2-2.0
                 haskell-wai-conduit         3.0.0.3-19.0          3.0.0.4-2.0
                    haskell-wai-cors           0.2.6-21.0           0.2.6-22.0
                   haskell-wai-extra        3.0.22.0-31.0        3.0.22.0-32.0
          haskell-wai-handler-launch         3.0.2.3-41.0         3.0.2.3-43.0
                  haskell-wai-logger            2.3.2-6.0            2.3.2-8.0
       haskell-wai-middleware-static           0.8.1-34.0           0.8.1-35.0
              haskell-wai-websockets         3.0.1.1-60.0          3.0.1.2-2.0
                        haskell-warp         3.2.18.1-6.0         3.2.18.1-8.0
                    haskell-warp-tls         3.2.4.2-28.0         3.2.4.2-30.0
                 haskell-xml-conduit         1.7.1.2-20.0         1.7.1.2-21.0
                  haskell-xml-hamlet         0.4.1.1-45.0         0.4.1.1-46.0
                   heartbeat-elastic            6.2.2-1.0            6.2.3-1.0
                         hledger-api             1.5-99.0            1.5-102.0
                      hopenpgp-tools         0.19.5-103.0         0.19.5-106.0
                                 inn            2.6.1-6.0            2.6.2-1.0
                             jenkins            2.111-1.0            2.112-1.0
                             jnettop             0.13.0-5           0.13.0-5.1
                                  jq                1.5-5              1.5-6.0
                             kbibtex              0.7-1.0  0.7.git20180320-1.0
                              kibana            6.2.2-1.0            6.2.3-1.0
                                lash       0.6.0~rc2-11.0       0.6.0~rc2-12.0
                      libcurl-compat           7.58.0-2.0           7.59.0-1.0
                      libcurl-gnutls           7.58.0-2.0           7.59.0-1.0
                            libmatio           1.5.11-1.1           1.5.12-1.0
      libreoffice-extension-texmaths             0.45-1.0             0.45-1.1
                             librime         1:1.2.10-1.0          1:1.3.0-1.0
                            librsync            1:1.0.0-1          1:2.0.2-1.0
                            logstash            6.2.2-1.0            6.2.3-1.0
                      matrix-synapse           0.26.0-1.0           0.26.1-1.0
                         mcollective           2.11.4-8.0           2.11.4-9.0
                            mednafen             0.9.48-1           1.21.1-1.0
                          metasploit          4.16.44-1.0          4.16.45-1.0
                          metricbeat            6.2.2-1.0            6.2.3-1.0
                                 nbd             3.17-1.0             3.17-3.0
                      nginx-mainline           1.13.9-1.0          1.13.10-1.0
                              octave            4.2.1-9.0            4.2.2-1.0
                           oniguruma            6.8.0-1.0            6.8.1-1.0
                     owncloud-client            2.4.1-1.0            2.4.1-2.0
                          packetbeat            6.2.2-1.0            6.2.3-1.0
                                  pd           0.48.0-3.0           0.48.1-3.0
                    perl-net-dns-sec             1.04-2.0             1.05-1.0
                  perl-text-template             1.51-1.0             1.52-1.0
                         pidgin-sipe           1.23.1-1.0           1.23.2-1.0
                              pifpaf            2.1.0-1.0            2.1.1-1.0
                           postgrest         0.4.4.0-92.0         0.4.4.0-96.0
                               pound                2.7-5              2.7-7.0
                              puppet            5.3.5-1.0            5.4.0-1.0
                             pyflame              1.3.1-1            1.6.3-1.0
                         python-acme           0.22.0-1.0           0.22.2-1.0
         python-cryptography-vectors            2.1.4-1.0            2.2.1-1.0
                       python-docker            3.1.1-1.0            3.1.3-1.0
                python-elasticsearch            6.1.1-1.0            6.2.0-1.0
                   python-hypothesis           3.49.1-1.0           3.50.2-1.0
                       python-imdbpy              6.4-1.0            6.4.1-1.0
                         python-mox3           0.25.0-1.0           0.25.0-1.1
                     python-oauthlib              2.0.6-1            2.0.7-1.0
                      python-oslo-db           4.34.0-1.0           4.35.0-1.0
                 python-phonenumbers            8.9.1-1.0            8.9.2-1.0
                       python-pipenv           11.0.3-1.0           11.9.0-1.0
                  python-pycontracts            1.8.2-1.0            1.8.3-1.0
                     python-pygithub             1.37-1.0             1.38-1.0
                python-pytest-flake8              0.9.1-1            1.0.0-1.0
                python-pytest-runner              4.0-1.0              4.2-1.0
               python-pytest-twisted                1.5-1            1.7.1-1.0
                      python-pytools           2018.3-1.0           2018.3-1.1
               python-setuptools-scm           1.15.7-1.0           1.17.0-1.0
                         python-tqdm           4.19.8-1.0           4.19.8-1.1
                         python-xlib             0.22-1.0             0.22-1.1
                     python-zeroconf           0.20.0-1.0           0.20.0-2.0
                        python2-acme           0.22.0-1.0           0.22.2-1.0
        python2-cryptography-vectors            2.1.4-1.0            2.2.1-1.0
                      python2-docker            3.1.1-1.0            3.1.3-1.0
               python2-elasticsearch            6.1.1-1.0            6.2.0-1.0
                        python2-eric            18.02-1.0            18.03-1.0
                  python2-hypothesis           3.49.1-1.0           3.50.2-1.0
                        python2-ldap            3.0.0-1.0            3.0.0-1.1
                        python2-mox3           0.25.0-1.0           0.25.0-1.1
                    python2-oauthlib              2.0.6-1            2.0.7-1.0
                     python2-oslo-db           4.34.0-1.0           4.35.0-1.0
                python2-phonenumbers            8.9.1-1.0            8.9.2-1.0
                      python2-pifpaf            2.1.0-1.0            2.1.1-1.0
                      python2-pipenv           11.0.3-1.0           11.9.0-1.0
                 python2-pycontracts            1.8.2-1.0            1.8.3-1.0
                    python2-pygithub             1.37-1.0             1.38-1.0
               python2-pytest-flake8              0.9.1-1            1.0.0-1.0
               python2-pytest-runner              4.0-1.0              4.2-1.0
              python2-pytest-twisted                1.5-1            1.7.1-1.0
                     python2-pytools           2018.3-1.0           2018.3-1.1
              python2-setuptools-scm           1.15.7-1.0           1.17.0-1.0
                        python2-tqdm           4.19.8-1.0           4.19.8-1.1
                       python2-twine           1.10.0-1.0           1.11.0-1.0
                        python2-xlib             0.22-1.0             0.22-1.1
                        python2-yapf           0.20.2-1.0           0.21.0-1.0
                         qutebrowser            1.2.0-1.0            1.2.1-1.0
                              rclone             1.39-1.0             1.40-1.0
                                rofi            1.5.0-2.0            1.5.1-1.0
                       roundcubemail            1.3.4-1.0            1.3.5-1.0
                          ruby-async            1.2.2-1.0            1.3.0-1.0
                       ruby-async-io            1.3.0-1.0            1.4.0-1.0
                          ruby-cairo          1.15.12-1.0          1.15.12-1.1
                      ruby-nats-pure            0.2.4-2.0            0.4.0-1.0
                          ruby-nio4r            2.2.0-1.0            2.3.0-1.0
                            shotwell         2:0.26.4-1.0         2:0.28.0-1.0
                            smplayer           18.2.2-1.0           18.3.0-1.0
                               stack           1.6.5-44.0           1.6.5-50.0
                            startdde           3.1.25-1.0           3.1.26-1.0
                              stella              5.0.2-1            5.1.1-1.0
                      tamarin-prover           1.2.3-21.0           1.2.3-25.0
                              tt-rss1:17.4.r180.g820873de-1.01:17.4.r441.ge35a4673-1.0
                           uglify-js           3.3.15-1.0           3.3.16-1.0
                          vdirsyncer           0.16.4-2.0           0.16.4-3.0
                       vim-gitgutter      487.7222649-1.0      490.37bdd03-1.0
                             weechat            2.0.1-2.0              2.1-1.0
                                wine              3.4-1.0              3.4-1.1
                        wine-staging              3.4-1.0              3.4-1.1
                   wine-staging-nine              3.3-2.0              3.4-1.0
                       wireshark-cli            2.5.0-1.0            2.5.1-1.0
                    wireshark-common            2.5.0-1.0            2.5.1-1.0
                       wireshark-gtk            2.5.0-1.0            2.5.1-1.0
                        wireshark-qt            2.5.0-1.0            2.5.1-1.0
                              xmobar            0.25-14.0            0.25-17.0
                             yakuake            3.0.4-2.0            3.0.4-2.1
                                zbar            0.10-12.0             0.20-1.0
                                 zim             0.68-1.0             0.68-1.1
Any problems?
  • No issues, everything went smoothly
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
  • Yes I am currently experiencing an issue due to the update. (Please post about it)
0 voters
[Testing Update x32] 2018-03-20 - Kernels, Curl
#2
Known issues and solutions
#3
And… here’s Chromium too…
                             PACKAGE          x32-testing         x32-unstable
                               bftpd              4.8-1.0              4.9-1.0
                  chrome-gnome-shell               10-2.0             10.1-1.0
                            chromium    65.0.3325.162-1.0    65.0.3325.181-1.0
                      eclipse-common            4.7.2-1.0            4.7.3-1.0
                         eclipse-cpp            4.7.2-1.0            4.7.3-1.0
                        eclipse-java            4.7.2-1.0            4.7.3-1.0
                  eclipse-javascript            4.7.2-1.0            4.7.3-1.0
                         eclipse-jee            4.7.2-1.0            4.7.3-1.0
                         eclipse-php            4.7.2-1.0            4.7.3-1.0
                               hplip           3.18.3-1.0           3.18.3-2.0
                         imagemagick         7.0.7.26-1.0         7.0.7.27-1.0
                     imagemagick-doc         7.0.7.26-1.0         7.0.7.27-1.0
                               krita            3.3.3-2.0            4.0.0-3.0
                              libdrm           2.4.91-2.0           2.4.91-3.0
                           libdvbpsi            1:1.3.1-1          1:1.3.2-1.0
                             libgit2           1:0.26.0-1         1:0.26.3-1.0
                           libmagick         7.0.7.26-1.0         7.0.7.27-1.0
                               meson           0.45.0-1.0           0.45.1-1.0
                                mono       5.10.0.160-1.0       5.10.0.179-1.0
                    opengl-man-pages           20170404-1         20180321-1.0
                         qt5-wayland           5.10.1-2.0           5.10.1-3.0
                              unison          2.48.15-3.0           2.51.2-1.0
                 xf86-input-libinput             0.26.0-1           0.27.0-2.0
                             zziplib          0.13.68-1.0          0.13.69-1.0
                      acpi_call-dkms          1.1.0-112.0          1.1.0-113.0
                             ansible          2.4.3.0-3.0          2.4.3.0-4.0
                         asciidoctor          1.5.6.1-3.0          1.5.6.2-1.0
                                cimg            2.1.7-1.0            2.2.1-1.0
                           darktable          2:2.4.1-3.0          2:2.4.2-1.0
                     deepin-calendar            1.2.1-1.0            1.2.2-1.0
               deepin-control-center            4.4.1-1.0            4.4.2-1.0
                       deepin-daemon           3.2.11-1.0           3.2.12-1.0
                         deepin-dock            4.6.1-1.0            4.6.2-1.0
                 deepin-file-manager        1:4.4.8.2-1.0        1:4.4.8.3-1.0
                   deepin-icon-theme         15.12.53-1.0         15.12.54-1.0
                 deepin-image-viewer           1.2.17-1.0           1.2.18-1.0
                         deepin-menu            3.3.0-1.0            3.3.1-1.0
                       deepin-mutter          3.20.28-1.0          3.20.29-1.0
                deepin-notifications            3.2.0-1.0            3.2.1-1.0
               deepin-qt5dxcb-plugin          1.1.8.3-1.0          1.1.8.4-1.0
                   deepin-session-ui            4.3.1-1.0            4.3.2-1.0
                           deepin-wm           1.9.23-1.0           1.9.24-1.0
                      docker-compose           1.20.0-1.0           1.20.1-1.0
                          erlang-nox             20.3-1.0           20.3.1-1.0
                              eslint           4.19.0-1.1           4.19.1-1.0
     firefox-extension-privacybadger        2018.1.22-2.0        2018.3.21-2.0
                            geogebra        6.0.432.0-1.3        6.0.445.0-1.0
                              gitlab           10.5.4-1.0           10.6.0-1.0
                       gitlab-gitaly           0.90.0-1.0           0.91.0-1.0
                        gitlab-shell          2:6.0.4-1.0          2:7.1.0-1.0
                haskell-authenticate           1.3.4-69.0           1.3.4-72.0
                         haskell-aws            0.19-39.0            0.19-42.0
              haskell-binary-orphans         0.1.8.0-22.0         0.1.8.0-23.0
               haskell-blaze-builder          0.4.0.2-9.0          0.4.1.0-1.0
                  haskell-blaze-html         0.9.0.1-13.0         0.9.0.1-14.0
                haskell-blaze-markup          0.8.2.0-8.0          0.8.2.0-9.0
                       haskell-brick          0.34.1-17.0          0.34.1-20.0
            haskell-case-insensitive         1.2.0.10-9.0         1.2.0.11-1.0
                     haskell-cassava         0.5.1.0-22.0         0.5.1.0-23.0
                  haskell-cheapskate           0.1.1-58.0           0.1.1-59.0
                     haskell-concise         0.1.0.1-14.0         0.1.0.1-15.0
               haskell-conduit-extra         1.2.3.2-26.0         1.2.3.2-27.0
                  haskell-config-ini         0.2.2.0-26.0         0.2.2.0-27.0
                  haskell-data-clist          0.1.1.0-8.0          0.1.2.1-1.0
             haskell-data-serializer            0.3.4-3.0            0.3.4-4.0
                haskell-data-textual         0.3.0.2-44.0         0.3.0.2-45.0
                         haskell-dav           1.3.2-30.1           1.3.2-31.0
                haskell-doctemplates           0.2.1-20.0           0.2.1-21.0
                      haskell-hakyll        4.11.0.0-45.0        4.11.0.0-52.0
                       haskell-hasql           1.1.1-47.0           1.1.1-48.0
                  haskell-hasql-pool           0.4.3-47.0           0.4.3-48.0
           haskell-hasql-transaction           0.5.2-47.0           0.5.2-48.0
                haskell-hjsonpointer           1.3.0-21.0           1.3.0-23.0
                 haskell-hledger-lib             1.5-27.1             1.5-29.0
                       haskell-hslua         0.9.5.1-10.0         0.9.5.1-11.0
           haskell-hslua-module-text         0.1.2.1-22.0         0.1.2.1-23.0
                haskell-html-conduit         1.2.1.2-29.1         1.2.1.2-30.0
               haskell-http-api-data            0.3.8-2.0            0.3.8-3.0
                 haskell-http-client          0.5.10-12.0          0.5.10-13.0
             haskell-http-client-tls         0.3.5.3-27.0         0.3.5.3-28.0
                haskell-http-conduit           2.2.4-70.0           2.2.4-71.0
                  haskell-http-media          0.7.1.2-3.0          0.7.1.2-4.0
                  haskell-http-types           0.9.1-18.0           0.9.1-19.0
                       haskell-http2           1.6.3-20.0           1.6.3-21.0
                 haskell-interpolate            0.2.0-2.0            0.2.0-3.0
                        haskell-jose         0.6.0.3-51.0         0.6.0.3-52.0
         haskell-language-javascript         0.6.0.11-1.0         0.6.0.11-2.0
                  haskell-megaparsec            6.4.1-4.0            6.4.1-5.0
             haskell-microlens-aeson            2.3.0-2.0            2.3.0-3.0
                haskell-monad-logger         0.3.28.2-3.0         0.3.28.2-4.0
                  haskell-network-ip         0.3.0.2-32.0         0.3.0.2-33.0
                     haskell-parsers          0.12.8-17.0          0.12.8-18.0
                  haskell-persistent         2.7.3.1-34.0         2.7.3.1-35.0
           haskell-persistent-sqlite           2.6.4-61.0           2.6.4-62.0
         haskell-persistent-template            2.5.4-1.0            2.5.4-2.0
           haskell-postgresql-binary          0.12.1-62.0          0.12.1-63.0
        haskell-quickcheck-instances           0.3.18-3.0           0.3.18-4.0
                     haskell-servant          0.12.1-31.0          0.12.1-32.0
                 haskell-shakespeare          2.0.15-16.0          2.0.15-17.0
             haskell-simple-sendfile          0.2.27-18.0          0.2.27-19.0
                 haskell-skylighting             0.6-10.0             0.6-11.0
           haskell-streaming-commons           0.1.19-6.0           0.1.19-7.0
                    haskell-swagger2             2.2-37.0             2.2-38.0
           haskell-tagstream-conduit        0.5.5.3-133.1        0.5.5.3-136.0
         haskell-tamarin-prover-term            1.2.3-7.0            1.2.3-8.0
        haskell-tamarin-prover-utils            1.2.3-2.0            1.2.3-3.0
                 haskell-text-latin1            0.3.1-1.0            0.3.1-2.0
                haskell-text-printer             0.5-15.0             0.5-16.0
                  haskell-text-short            0.1.2-7.0            0.1.2-8.0
                    haskell-trifecta         1.7.1.1-48.0         1.7.1.1-50.0
              haskell-uri-bytestring          0.3.1.1-7.0          0.3.1.1-8.0
                         haskell-vty             5.21-1.0             5.21-2.0
                         haskell-wai          3.2.1.2-1.0          3.2.1.2-2.0
              haskell-wai-app-static          3.1.6.2-2.0          3.1.6.2-3.0
                 haskell-wai-conduit          3.0.0.4-2.0          3.0.0.4-3.0
                   haskell-wai-extra        3.0.22.0-32.0        3.0.22.0-33.0
                  haskell-wai-logger            2.3.2-8.0           2.3.2-10.0
                        haskell-warp         3.2.18.1-8.0         3.2.18.1-9.0
                    haskell-warp-tls         3.2.4.2-30.0         3.2.4.2-31.0
                  haskell-websockets         0.12.4.0-3.0         0.12.4.0-5.0
                 haskell-xml-conduit         1.7.1.2-21.0         1.7.1.2-22.0
                  haskell-xml-hamlet         0.4.1.1-46.0         0.4.1.1-47.0
                       haskell-yesod          1.4.5-226.0          1.4.5-229.0
                  haskell-yesod-auth         1.4.21-118.0         1.4.21-123.0
                  haskell-yesod-core        1.4.37.3-43.0        1.4.37.3-46.0
               haskell-yesod-default          1.2.0-280.0          1.2.0-282.0
                  haskell-yesod-form         1.4.16-121.0         1.4.16-125.0
            haskell-yesod-persistent           1.4.3-97.0          1.4.3-101.0
                haskell-yesod-static        1.5.3.1-113.0        1.5.3.1-117.0
                  haskell-yesod-test         1.5.9.1-82.0         1.5.9.1-85.0
                             hledger             1.5-38.0             1.5-40.0
                          hledger-ui             1.5-58.0             1.5-62.0
                         hledger-web            1.5.1-6.0           1.5.1-12.0
                              hoogle          5.0.16-41.0          5.0.16-45.0
                               i3-wm             4.14.1-2             4.15-1.0
                               idris           1.2.0-51.0           1.2.0-52.0
                                 m2r           0.1.13-1.0           0.1.14-1.0
                              nodejs            9.8.0-2.0            9.9.0-1.0
                                 ois                1.3-4              1.4-1.0
                            openshot              2.4.1-1            2.4.1-2.0
                              pandoc           2.1.2-20.0            2.1.3-6.0
                     pandoc-citeproc        0.13.0.1-41.0        0.13.0.1-46.0
                     pandoc-crossref         0.3.0.1-76.0          0.3.0.3-6.0
                              picard       2.0.0beta1-1.0       2.0.0beta2-1.0
                      python-aiohttp            3.0.9-1.0            3.1.0-1.0
                      python-ansible          2.4.3.0-3.0          2.4.3.0-4.0
                    python-bitvector            3.4.7-1.0            3.4.8-1.0
                       python-docker            3.1.3-1.0            3.1.4-1.0
                       python-igraph        0.7.1.post6-3      0.7.1.post6-4.0
                           python-py            1.5.2-1.0            1.5.3-1.0
                  python-ruamel-yaml          0.15.35-1.0          0.15.37-1.0
                   python-s3transfer           0.1.13-2.0           0.1.13-3.0
                   python2-bitvector            3.4.7-1.0            3.4.8-1.0
                      python2-docker            3.1.3-1.0            3.1.4-1.0
                      python2-igraph        0.7.1.post6-3      0.7.1.post6-4.0
                         python2-m2r           0.1.13-1.0           0.1.14-1.0
                          python2-py            1.5.2-1.0            1.5.3-1.0
                         rawtherapee              1:5.3-1            1:5.4-1.0
                          ruby-async            1.3.0-1.0            1.4.0-1.0
                              rustup           1.11.0-1.0           1.11.0-2.0
                             sdlmame            0.195-3.0            0.195-4.0
                sugar-activity-paint                 66-1               67-1.0
                sugar-activity-write               98.3-1             98.4-1.0
                       supercollider            3.9.1-3.0            3.9.1-4.0
                    telegram-desktop           1.2.12-2.0           1.2.14-1.0
                           terraform           0.11.4-1.0           0.11.5-1.0
                         uboot-tools          2018.01-1.0          2018.03-1.0
                            valabind              1.4.0-1            1.6.0-1.0
                               vault            0.9.5-1.0            0.9.6-1.0
                              xmonad            0.13-13.0            0.13-13.1
                      xmonad-contrib            0.13-11.0            0.13-11.1
#4
No problems with xfce4. Thank you.
#5
Update on 1 Machine and 1 VB without Problems.
DK3
#6
when we gonna see manjaro 32 bit .iso(s) side by side 64 bit ones to download on repos? that will be ?
I wanna download community lqxt version due to less consumption of resources but worry about not to get support of arch32 repos
#7
Probably never. Use the Xfce installer, install whichever DE you want, then remove Xfce.
Or you could try the Architect install - that might work.
#8
This topic was automatically closed after 3 days. New replies are no longer allowed.
