[Stable Update i686] 2019-08-03 - GCC, systemd, Chromium, Palemoon, Kernels
Something went very wrong with this update. I got a bunch of errors related with systemd not finding a specific library. I tried to downgrade systemd packages to no avail. I knew rebooting would go bad, but I did it anyway and was dumped to a rootfs shell.
I currently don't have access to that machine. Later I'll burn a thumb drive and I'll post the errors I got.
Cheers,
That sounds like a partial upgrade state...
But the update went through to the end!
It can also be caused by one of the repos being behind the others on the mirror (e.g. [core] being ahead of [extra]).
Maybe... I always change mirrors before an update (ex.: pacman-mirrors -f5 && pacman -Syyu). Can it still happen?
It shouldn't... but I'm not sure. I can't think of another reason for having wrong library versions (e.g. it tested OK for me).
Ok, I chrooted and updated linux414, systemd, systemd-libs and systemd-sysvcompat. Everything working now.
