[Stable Update i686] 2019-03-13 - pacman, systemd, KDE, LibreOffice Fresh, Chromium
update
stable
manjaro32
#1
Hello i686ers!
This is a medium-sized update with around 1,500 updated packages, including a number of security fixes.
The other notable updates are to pacman, systemd, KDE, LibreOffice Fresh, and Chromium.
Also, kernels.
Full list of changes
Available here.
Anyone who would like to help out testing the upstream packages, please read the archlinux32 thread for details about how they automate their testing process and how to get involved:
https://bbs.archlinux32.org/viewtopic.php?id=171
(running this in an archlinux32 VM would be fine, there will hopefully be a way of doing this directly from within manjaro32 in the future)
Available kernels
Series Version PAE
linux316 3.16.63 No
linux318 3.18.136 No
linux44 4.4.176 No
linux49 4.9.162 No
linux414 4.14.105 No
linux419 4.19.28 Yes
archlinux32
If you find manjaro32 useful please consider donating to, or helping out with, archlinux32. It’s a small team taking on a huge project and any help will no doubt be very much appreciated.
Why aren’t the available packages/package versions the same as x86_64?
archlinux32 packages are based on Arch packages but may need editing to build correctly. Builds of less-popular packages are lower priority.
Manjaro-specific packages may lag behind x86_64 because there aren’t as many packagers. If you notice an important package is lagging please report it; at the moment it’s only me packaging for i686:
I’m only packaging current LTS kernels. Any marked as EOL are dropped. I’ll not be building the mainline kernel.
What about security updates?
I cannot guarantee timely security updates on x32-stable. If this is critical for you I recommend you switch to x32-testing or cherry-pick those packages from x32-testing or x32-unstable as they become available.
Something broke. Isn’t this meant to be stable?
“Stable” means “infrequently changing”, not “everything will work perfectly all the time”. If you want it to mean everything works, you need to help test the things you’re interested in.
What about installer images?
What about x32-testing and x32-unstable?
These are already available, and I recommend you use x32-testing if you can to make sure testing is done.
x32-unstable should be used by anyone who wants to try and find any issues before they impact other people. If you have multiple/many machines you really should run one of those on x32-unstable.
Any problems?
  • No issues, everything went smoothly
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
  • Yes I am currently experiencing an issue due to the update. (Please post about it)
0 voters
[Testing Update i686] 2019-02-27 to 03-13 - Kernels, systemd, KDE, LibreOffice Fresh, Chromium
#2
Known issues and solutions
Pamac is buggy for some users
Pamac appears to be causing some users a lot of issues for updates. Please use pacman to avoid any potential problems.
To make doubly certain, log out of any graphical sessions and run via a TTY.
Replace xorg-mkfontdir with extra/xorg-mkfontscale?
Yes.
DNS resolution stops working
systemd-resolve enabled DNSSEC support but should fall back if it’s not supported by the DNS server. However, sometime this doesn’t work.
To disable DNSSEC, edit /etc/systemd/resolved.conf and change DNSSEC=allow-downgrade to DNSSEC=no.
#4
Update on 1 System and 1 VB without Problems.
DK3
closed #5
