Sorry in advance for the double post. I had originally posted this issue under Manjaro-support (can’t include link here for some reason) when it first happened, but it happened
and I just realized that maybe I should post this on the Cinnamon-specific part of the forum.
In any case, twice now my screen has just stopped responding. The mouse works fine (it even reacts to elements on screen based off on hovering a clickable icon or not) but everything else on the screen is frozen.
After the screen froze I immediately switched to TTY2. The issue happened at 9:50 and you can see the output from journalctl
below:
Apr 07 09:49:17 np900 systemd[861]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Apr 07 09:49:17 np900 systemd[861]: gpg-agent.socket: Succeeded.
Apr 07 09:49:17 np900 systemd[861]: Closed GnuPG cryptographic agent and passphrase cache.
Apr 07 09:49:17 np900 systemd[861]: p11-kit-server.socket: Succeeded.
Apr 07 09:49:17 np900 systemd[861]: Closed p11-kit server.
Apr 07 09:49:17 np900 systemd[861]: pipewire.socket: Succeeded.
Apr 07 09:49:17 np900 systemd[861]: Closed Multimedia System.
Apr 07 09:49:17 np900 systemd[861]: pulseaudio.socket: Succeeded.
Apr 07 09:49:17 np900 systemd[861]: Closed Sound System.
Apr 07 09:49:17 np900 systemd[861]: Removed slice User Application Slice.
Apr 07 09:49:17 np900 systemd[861]: Reached target Shutdown.
Apr 07 09:49:17 np900 systemd[861]: systemd-exit.service: Succeeded.
Apr 07 09:49:17 np900 systemd[861]: Finished Exit the Session.
Apr 07 09:49:17 np900 systemd[861]: Reached target Exit the Session.
Apr 07 09:49:17 np900 systemd[862]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknow>
Apr 07 09:49:17 np900 systemd[1]: user@969.service: Succeeded.
Apr 07 09:49:17 np900 systemd[1]: Stopped User Manager for UID 969.
Apr 07 09:49:17 np900 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? t>
Apr 07 09:49:17 np900 kernel: audit: type=1131 audit(1617814157.578:88): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/>
Apr 07 09:49:17 np900 systemd[1]: Stopping User Runtime Directory /run/user/969...
Apr 07 09:49:17 np900 systemd[1]: run-user-969.mount: Succeeded.
Apr 07 09:49:17 np900 systemd[977]: run-user-969.mount: Succeeded.
Apr 07 09:49:17 np900 systemd[1]: user-runtime-dir@969.service: Succeeded.
Apr 07 09:49:17 np900 systemd[1]: Stopped User Runtime Directory /run/user/969.
Apr 07 09:49:17 np900 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostnam>
Apr 07 09:49:17 np900 kernel: audit: type=1131 audit(1617814157.588:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/>
Apr 07 09:49:17 np900 systemd[1]: Removed slice User Slice of UID 969.
Apr 07 09:49:18 np900 systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 1779 (AUTHENTICATE)
Apr 07 09:49:18 np900 systemd[1]: Mounting Arbitrary Executable File Formats File System...
Apr 07 09:49:18 np900 systemd[1]: Mounted Arbitrary Executable File Formats File System.
Apr 07 09:49:19 np900 gnome-keyring-daemon[988]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
Apr 07 09:49:20 np900 gnome-keyring-daemon[988]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
-- Boot 434d56fa79074bf8a1bd3787ee6f985d --
Apr 07 09:50:15 np900 systemd[1]: Started Getty on tty2.
Apr 07 09:50:15 np900 kernel: audit: type=1130 audit(1617814215.327:155): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/syste>
Apr 07 09:50:15 np900 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=>
Apr 07 09:50:15 np900 kernel: fbcon: Taking over console
Apr 07 09:50:15 np900 kernel: Console: switching to colour frame buffer device 240x67
Apr 07 09:50:18 np900 audit[13703]: USER_AUTH pid=13703 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_p>
Apr 07 09:50:18 np900 dbus-daemon[395]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.90' (uid=0 pid=13703>
Apr 07 09:50:18 np900 dbus-daemon[395]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 07 09:50:18 np900 login[13703]: pam_systemd_home(login:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 07 09:50:18 np900 kernel: audit: type=1100 audit(1617814218.910:156): pid=13703 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_securetty,p>
Apr 07 09:50:18 np900 kernel: audit: type=1101 audit(1617814218.910:157): pid=13703 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix>
Apr 07 09:50:18 np900 audit[13703]: USER_ACCT pid=13703 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="t>
Apr 07 09:50:18 np900 audit[13703]: CRED_ACQ pid=13703 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pa>
Apr 07 09:50:18 np900 login[13703]: pam_unix(login:session): session opened for user tomas(uid=1000) by LOGIN(uid=0)
I don’t really see anything that gives me the culprit there. Any ideas?
Thank you!
