[Stable Update i686] 2018-08-04 - OpenJDK 10, Chromium, Racket
update
stable
manjaro32
#1
Hello i686ers!
A relatively small update for OpenJDK 10 and an updated Chromium. Racket 7.0 was released, and there are loads of Haskell package updates once more.
Also, kernels.
Kernel 4.1 has become EOL so will be dropped “soon”. If you’re using it, switch up to kernel 4.4.
Finally, there will be some larger rebuild sets coming up due to GCC 8.2, Python 3.7, and Perl 5.28. This means I might be pushing smaller updates to x32-stable over the next week or so up until the rebuilds start to happen, then there will be a longish gap until everything has settled down.
Anyone who would like to help out testing the upstream packages, please read the archlinux32 thread for details about how they automate their testing process and how to get involved:
https://bbs.archlinux32.org/viewtopic.php?id=171
(running this in an archlinux32 VM would be fine, there will hopefully be a way of doing this directly from within manjaro32 in the future)
Available kernels
Series Version
linux316 3.16.56
linux41 4.1.52 [EOL]
linux44 4.4.146
linux49 4.9.118
linux414 4.14.61
archlinux32
If you find manjaro32 useful please consider donating to, or helping out with, archlinux32. It’s a small team taking on a huge project and any help will no doubt be very much appreciated.
Why aren’t the available packages/package versions the same as x86_64?
archlinux32 packages are based on Arch packages but may need editing to build correctly. Builds of less-popular packages are lower priority.
Manjaro-specific packages may lag behind x86_64 because there aren’t as many packagers. If you notice an important package is lagging please report it; at the moment it’s only me packaging for i686:
I’m only packaging current LTS kernels. Any marked as EOL are dropped. I’ll not be building the mainline kernel.
What about security updates?
I cannot guarantee timely security updates on x32-stable. If this is critical for you I recommend you switch to x32-testing or cherry-pick those packages from x32-testing or x32-unstable as they become available.
Something broke. Isn’t this meant to be stable?
“Stable” means “infrequently changing”, not “everything will work perfectly all the time”. If you want it to mean everything works, you need to help test the things you’re interested in.
What about installer images?
Phil very kindly updated the preview installer images:
What about x32-testing and x32-unstable?
These are already available, and I recommend you use x32-testing if you can to make sure testing is done.
x32-unstable should be used by anyone who wants to try and find any issues before they impact other people. If you have multiple/many machines you really should run one of those on x32-unstable.
Full list of changes
:: Different overlay package(s) in repository core i686
                             PACKAGE           x32-stable          x32-testing
                      linux-firmware   20180525.7518922-1                    -
                            linux414            4.14.58-1            4.14.59-1
                    linux414-headers            4.14.58-1            4.14.59-1
                             linux44            4.4.143-1            4.4.145-1
                     linux44-headers            4.4.143-1            4.4.145-1
                             linux49            4.9.115-1            4.9.116-1
                     linux49-headers            4.9.115-1            4.9.116-1
                      manjaro-system           20180716-1           20180801-1
:: Different sync package(s) in repository core i686
                             iputils   20161105.1f2bb12-2 20180629.f6aac8d-2.0
                      linux-firmware 20180606.d114732-1.0 20180717.8d69bab-1.0
                     zd1211-firmware              1.5-2.0                    -
:: Different overlay package(s) in repository extra i686
                  linux414-acpi_call             1.1.0-51             1.1.0-52
                   linux414-bbswitch               0.8-51               0.8-52
                linux414-broadcom-wl      6.30.223.271-51      6.30.223.271-52
                linux414-ndiswrapper              1.61-51              1.61-52
               linux414-nvidia-304xx         1:304.137-51         1:304.137-52
               linux414-nvidia-340xx           340.107-10           340.107-11
               linux414-nvidia-390xx             390.77-3             390.77-4
                      linux414-r8168          8.045.08-39          8.045.08-40
                  linux414-rt3562sta        2.4.1.1_r4-51        2.4.1.1_r4-52
                        linux414-spl             0.7.9-15             0.7.9-16
                   linux414-tp_smapi              0.41-51              0.41-52
                linux414-vhba-module          20161009-51          20161009-52
   linux414-virtualbox-guest-modules             5.2.16-3             5.2.16-4
    linux414-virtualbox-host-modules             5.2.16-3             5.2.16-4
                        linux414-zfs             0.7.9-15             0.7.9-16
                   linux44-acpi_call            1.1.0-100            1.1.0-102
                 linux44-broadcom-wl      6.30.223.271-70      6.30.223.271-72
                    linux44-catalyst    1:15.201.1151-100    1:15.201.1151-102
                 linux44-ndiswrapper              1.61-68              1.61-70
                linux44-nvidia-304xx         1:304.137-35         1:304.137-37
                linux44-nvidia-340xx            340.107-5            340.107-7
                linux44-nvidia-390xx             390.77-1             390.77-3
                       linux44-r8168          8.045.08-22          8.045.08-24
                   linux44-rt3562sta        2.4.1.1_r4-68        2.4.1.1_r4-70
                         linux44-spl              0.7.9-8             0.7.9-10
                 linux44-vhba-module          20161009-68          20161009-70
    linux44-virtualbox-guest-modules             5.2.16-1             5.2.16-3
     linux44-virtualbox-host-modules             5.2.16-1             5.2.16-3
                         linux44-zfs              0.7.9-8             0.7.9-10
                   linux49-acpi_call             1.1.0-88             1.1.0-89
                    linux49-bbswitch               0.8-88               0.8-89
                 linux49-broadcom-wl      6.30.223.271-88      6.30.223.271-89
                    linux49-catalyst     1:15.201.1151-88     1:15.201.1151-89
                 linux49-ndiswrapper              1.61-86              1.61-87
                linux49-nvidia-304xx         1:304.137-47         1:304.137-48
                linux49-nvidia-340xx            340.107-7            340.107-8
                linux49-nvidia-390xx             390.77-3             390.77-4
                       linux49-r8168          8.045.08-28          8.045.08-29
                   linux49-rt3562sta        2.4.1.1_r4-86        2.4.1.1_r4-87
                         linux49-spl             0.7.9-12             0.7.9-13
                    linux49-tp_smapi              0.41-88              0.41-89
                 linux49-vhba-module          20161009-86          20161009-87
    linux49-virtualbox-guest-modules             5.2.16-3             5.2.16-4
     linux49-virtualbox-host-modules             5.2.16-3             5.2.16-4
                         linux49-zfs             0.7.9-12             0.7.9-13
                   ndiswrapper-utils              1.61-51              1.61-52
                    rt3562sta-common        2.4.1.1_r4-86        2.4.1.1_r4-87
                            chromium                    -       68.0.3440.84-0
:: Different sync package(s) in repository extra i686
                          bubblewrap            0.2.1-1.0            0.3.0-1.0
                              clamav          0.100.0-2.0          0.100.1-1.0
                              colord            1.4.3-1.0            1.4.3-2.0
                         colord-sane            1.4.3-1.0            1.4.3-2.0
                           evolution           3.28.4-1.0           3.28.5-1.0
                evolution-bogofilter           3.28.4-1.0           3.28.5-1.0
               evolution-data-server           3.28.4-1.0           3.28.5-1.0
                       evolution-ews           3.28.4-1.0           3.28.5-1.0
              evolution-spamassassin           3.28.4-1.0           3.28.5-1.0
                             fribidi            1.0.4-1.0            1.0.5-1.0
                         fuse-common            3.2.4-2.0            3.2.5-1.0
                               fuse2              2.9.7-4            2.9.8-1.0
                               fuse3            3.2.4-2.0            3.2.5-1.0
                                gcin            2.8.5-3.0                    -
                            geoclue2           2.4.10-1.0           2.4.11-1.0
                     gnome-bluetooth           3.28.1-1.0           3.28.2-1.0
                             gtk-vnc            0.7.2-1.0            0.8.0-1.0
                               gupnp 1.0.2+4+g47b1010-1.0            1.0.3-1.0
                       jdk10-openjdk       10.0.1.u10-1.0       10.0.2.u13-1.0
                       jre10-openjdk       10.0.1.u10-1.0       10.0.2.u13-1.0
              jre10-openjdk-headless       10.0.1.u10-1.0       10.0.2.u13-1.0
                           libdazzle           3.28.4-1.0           3.28.5-1.0
                    libxnvctrl-390xx           390.67-2.0           390.77-1.0
                          libxnvctrl           396.24-1.0           396.45-1.0
               nvidia-390xx-settings           390.67-2.0           390.77-1.0
                       openjdk10-doc       10.0.1.u10-1.0       10.0.2.u13-1.0
                       openjdk10-src       10.0.1.u10-1.0       10.0.2.u13-1.0
                               pango           1.42.2-1.0           1.42.3-1.0
                             paprefs0.9.10+16+g534d20a-1.0              1.0-1.0
                         pcmciautils              018-8.0                    -
                        perl-net-dns             1.16-1.0             1.17-1.0
                       python-django            2.0.7-2.0            2.0.8-1.0
                       python2-scour             0.36-1.1             0.37-2.0
                             tracker            2.1.0-1.0            2.1.1-1.0
                             udisks2            2.7.6-1.1            2.7.7-1.0
                            visualvm              1.3.9-1            1.4.1-1.0
                   wayland-protocols             1.14-1.0             1.15-1.0
                               xfwm4             4.12.4-1           4.12.5-1.0
                        zabbix-agent           3.4.11-1.0           3.4.12-1.0
                 zabbix-frontend-php           3.4.11-1.0           3.4.12-1.0
                        zabbix-proxy           3.4.11-1.0           3.4.12-1.0
                       zabbix-server           3.4.11-1.0           3.4.12-1.0
                     hunspell-es_any                    -            1:2.3-2.0
                      hunspell-es_ar                    -            1:2.3-2.0
                      hunspell-es_bo                    -            1:2.3-2.0
                      hunspell-es_cl                    -            1:2.3-2.0
                      hunspell-es_co                    -            1:2.3-2.0
                      hunspell-es_cr                    -            1:2.3-2.0
                      hunspell-es_cu                    -            1:2.3-2.0
                      hunspell-es_do                    -            1:2.3-2.0
                      hunspell-es_ec                    -            1:2.3-2.0
                      hunspell-es_es                    -            1:2.3-2.0
                      hunspell-es_gt                    -            1:2.3-2.0
                      hunspell-es_hn                    -            1:2.3-2.0
                      hunspell-es_mx                    -            1:2.3-2.0
                      hunspell-es_ni                    -            1:2.3-2.0
                      hunspell-es_pa                    -            1:2.3-2.0
                      hunspell-es_pe                    -            1:2.3-2.0
                      hunspell-es_pr                    -            1:2.3-2.0
                      hunspell-es_py                    -            1:2.3-2.0
                      hunspell-es_sv                    -            1:2.3-2.0
                      hunspell-es_uy                    -            1:2.3-2.0
                      hunspell-es_ve                    -            1:2.3-2.0
                           pacrunner                    -             0.14-1.0
                           zxing-cpp                    -      git20180320-2.0
:: Different sync package(s) in repository community i686
               aarch64-linux-gnu-gcc            8.1.0-1.0            8.2.0-1.0
                      acpi_call-dkms          1.1.0-145.0          1.1.0-146.0
                                agda            2.5.4-9.0           2.5.4-10.0
                         aircrack-ng              1.2-4.0              1.3-1.0
                          alsa-tools            1.1.6-1.0            1.1.6-2.0
                             ansible            2.6.1-1.0            2.6.2-1.0
                   arm-none-eabi-gcc            8.1.0-1.0            8.2.0-1.0
                             avr-gcc            8.1.0-1.0            8.2.0-1.0
                bash-language-server            1.4.0-1.0            1.4.1-1.0
                          blinksocks            3.3.5-1.0            3.3.6-1.0
                         broadcom-wl    6.30.223.271-32.0    6.30.223.271-33.0
                             busybox           1.28.4-2.0           1.29.2-1.0
                                c2hs          0.28.5-14.0          0.28.5-15.0
                       cabal-install         2.2.0.0-50.0         2.2.0.0-51.0
                             cadence            0.9.0-2.0            0.9.0-3.0
                               carla           1.9.8-10.0            1.9.9-2.0
                              catch2            2.2.3-1.0            2.3.0-1.0
                              cddlib             094i-1.0          1:0.94j-1.1
                               cgrep          6.6.25-57.0          6.6.25-58.0
                             cryptol  2.5.0.20180515-57.0  2.5.0.20180515-58.0
                               darcs          2.14.1-29.0          2.14.1-30.0
                             dbeaver            5.1.0-1.0            5.1.3-1.0
               dbeaver-plugin-office           1.1.22-1.0           1.1.25-1.0
           dbeaver-plugin-svg-format           1.0.21-2.0           1.0.24-1.0
              deepin-desktop-schemas           3.2.15-1.0           3.2.18-1.0
              deepin-go-dbus-factory            0.0.5-1.0            0.0.6-1.0
                       deepin-go-lib           1.2.14-1.0           1.2.15-1.0
                    deepin-gtk-theme          17.10.7-1.0          17.10.8-1.0
                     deepin-metacity          3.22.19-2.0          3.22.20-1.0
                       deepin-mutter          3.20.31-1.0          3.20.32-1.0
              deepin-qt-dbus-factory            1.0.3-1.0            1.0.4-1.0
               deepin-qt5dxcb-plugin          1.1.9.2-1.0           1.1.10-1.0
                            ejabberd            18.06-2.0            18.06-3.0
                              elixir            1.7.1-1.0            1.7.1-1.1
                                 fio              3.7-1.0              3.8-1.0
                             fractal           3.29.4-1.0           3.29.5-1.0
                           git-annex       6.20180719-2.0       6.20180719-4.0
                          git-repair      1.20170626-41.0      1.20170626-42.0
                       gitlab-gitaly          0.113.0-1.0          0.114.0-1.0
                       gitlab-runner           11.1.0-1.0           11.1.0-2.0
                           glusterfs          1:4.1.1-1.0          1:4.1.2-1.0
                           gogglesmm            1.2.0-1.0            1.2.1-1.0
                 haskell-adjunctions             4.4-44.0             4.4-45.0
                       haskell-aeson         1.3.1.1-24.0         1.3.1.1-25.0
         haskell-aeson-better-errors         0.9.1.0-75.0         0.9.1.0-76.0
                haskell-aeson-compat           0.3.8-12.0           0.3.8-13.0
                haskell-aeson-pretty           0.8.7-27.0           0.8.7-28.0
                    haskell-aeson-qq           0.8.2-62.0           0.8.2-63.0
               haskell-asn1-encoding           0.9.5-62.0           0.9.5-63.0
                  haskell-asn1-parse           0.9.4-73.0           0.9.4-74.0
                  haskell-asn1-types           0.3.2-69.0           0.3.2-70.0
                  haskell-attoparsec        0.13.2.2-24.0        0.13.2.2-25.0
          haskell-attoparsec-iso8601         1.0.0.0-41.0         1.0.0.0-42.0
                haskell-authenticate          1.3.4-146.0          1.3.4-147.0
          haskell-authenticate-oauth             1.6-30.0             1.6-31.0
                         haskell-aws            0.20-54.0            0.20-55.0
       haskell-base-compat-batteries          0.10.1-16.0          0.10.1-17.0
                haskell-base-orphans              0.8-5.0              0.8-6.0
                  haskell-bifunctors            5.5.3-6.0            5.5.3-7.0
              haskell-binary-conduit             1.3-34.0             1.3-35.0
              haskell-binary-orphans         0.1.8.0-49.0         0.1.8.0-50.0
               haskell-binary-tagged           0.1.5-18.0           0.1.5-19.0
                  haskell-blaze-html          0.9.1.1-3.0          0.9.1.1-4.0
                haskell-blaze-markup         0.8.2.1-11.0         0.8.2.1-12.0
                  haskell-bower-json         1.0.0.1-73.0         1.0.0.1-74.0
                       haskell-brick             0.38-3.0             0.39-1.0
   haskell-bytestring-strict-builder         0.4.5.1-22.0         0.4.5.1-23.0
                     haskell-cassava         0.5.1.0-36.0         0.5.1.0-37.0
                  haskell-cheapskate          0.1.1-109.0          0.1.1-110.0
                    haskell-checkers          0.4.10-30.0          0.4.10-31.0
                  haskell-cipher-aes          0.2.11-62.0          0.2.11-63.0
               haskell-clientsession         0.9.1.2-69.0         0.9.1.2-70.0
                     haskell-comonad            5.0.4-9.0           5.0.4-10.0
                     haskell-concise         0.1.0.1-55.0         0.1.0.1-56.0
                     haskell-conduit         1.3.0.3-20.0         1.3.0.3-21.0
               haskell-conduit-extra           1.3.0-40.0           1.3.0-41.0
                  haskell-config-ini         0.2.2.0-69.0         0.2.2.0-70.0
                  haskell-configfile           1.1.4-33.0           1.1.4-34.0
                haskell-configurator         0.3.0.0-47.0         0.3.0.0-48.0
             haskell-configurator-ng         0.0.0.1-35.0         0.0.0.1-36.0
                  haskell-connection           0.2.8-89.0           0.2.8-90.0
                 haskell-constraints           0.10.1-5.0           0.10.1-6.0
                   haskell-cprng-aes           0.6.1-65.0           0.6.1-66.0
                   haskell-criterion          1.5.0.0-6.0          1.5.0.0-7.0
         haskell-crypto-cipher-types           0.0.9-62.0           0.0.9-63.0
              haskell-crypto-numbers           0.2.7-64.0           0.2.7-65.0
               haskell-crypto-pubkey           0.2.8-76.0           0.2.8-77.0
         haskell-crypto-pubkey-types           0.4.3-65.0           0.4.3-66.0
               haskell-crypto-random           0.0.9-66.0           0.0.9-67.0
                  haskell-cryptohash          0.11.9-72.0          0.11.9-73.0
          haskell-cryptohash-conduit          0.1.1-201.0          0.1.1-202.0
        haskell-cryptohash-cryptoapi           0.1.4-20.0           0.1.4-21.0
                  haskell-cryptonite            0.25-16.0            0.25-17.0
          haskell-cryptonite-conduit           0.2.2-95.0           0.2.2-96.0
                    haskell-css-text         0.1.3.0-22.0         0.1.3.0-23.0
                  haskell-data-dword         0.3.1.2-18.0         0.3.1.2-19.0
             haskell-data-serializer           0.3.4-26.0           0.3.4-27.0
                haskell-data-textual         0.3.0.2-67.0         0.3.0.2-68.0
                         haskell-dav          1.3.2-102.0          1.3.2-103.0
                        haskell-dbus           1.0.1-51.0           1.0.1-52.0
                    haskell-dbus0.10         0.10.15-30.0         0.10.15-31.0
                 haskell-descriptive          0.9.4-127.0          0.9.4-128.0
                haskell-distributive              0.6-2.0              0.6-3.0
                         haskell-dns           3.0.4-23.0           3.0.4-24.0
                haskell-doctemplates         0.2.2.1-31.0         0.2.2.1-32.0
                     haskell-doctest           0.16.0-1.0           0.16.0-2.0
                        haskell-drbg           0.5.5-21.0           0.5.5-22.0
                      haskell-either           5.0.1-12.0           5.0.1-13.0
              haskell-email-validate          2.3.2.6-6.0          2.3.2.6-7.0
         haskell-enclosed-exceptions            1.0.3-2.0            1.0.3-3.0
                   haskell-esqueleto  2.5.3.20180402-47.0  2.5.3.20180402-48.0
                  haskell-fdo-notify           0.3.1-90.0           0.3.1-91.0
                        haskell-feed         1.0.0.0-93.0         1.0.0.0-94.0
                  haskell-file-embed         0.0.10.1-5.0           0.0.11-1.0
                       haskell-foldl           1.4.2-11.0           1.4.2-12.0
                  haskell-foundation           0.0.21-5.0           0.0.21-6.0
                        haskell-free             5.1-10.0             5.1-11.0
                    haskell-fsnotify          0.3.0.1-5.0          0.3.0.1-6.0
                       haskell-gauge            0.2.3-4.0            0.2.3-5.0
            haskell-generic-deriving           1.12.2-7.0           1.12.2-8.0
                      haskell-gnuidn           0.2.2-58.0           0.2.2-59.0
                    haskell-graphviz      2999.20.0.2-8.0      2999.20.0.2-9.0
            haskell-hackage-security         0.5.3.0-23.0         0.5.3.0-24.0
             haskell-haddock-library            1.6.0-3.0            1.6.0-4.0
                      haskell-hakyll        4.12.3.0-73.0        4.12.3.0-75.0
                       haskell-hasql          1.1.1-108.0          1.1.1-109.0
                  haskell-hasql-pool          0.4.3-108.0          0.4.3-109.0
           haskell-hasql-transaction          0.5.2-111.0          0.5.2-112.0
                    haskell-hedgehog             0.6-25.0             0.6-26.0
                        haskell-here          1.2.13-32.0          1.2.13-33.0
                haskell-hjsonpointer           1.4.0-26.0           1.4.0-27.0
                 haskell-hjsonschema           1.9.0-56.0           1.9.0-58.0
                 haskell-hledger-lib             1.10-6.0             1.10-7.0
                    haskell-hopenpgp            2.7.1-3.0            2.7.1-4.0
                   haskell-hourglass          0.2.11-17.0          0.2.11-18.0
                       haskell-hpack           0.29.5-1.0           0.29.5-2.0
                    haskell-hslogger          1.2.10-36.0          1.2.10-37.0
                       haskell-hslua         0.9.5.2-13.0         0.9.5.2-14.0
           haskell-hslua-module-text         0.1.2.1-38.0         0.1.2.1-39.0
                   haskell-hsopenssl       0.11.4.14-14.0       0.11.4.14-15.0
                       haskell-hspec            2.5.5-1.0            2.5.5-2.0
               haskell-hspec-contrib           0.5.0-18.0           0.5.0-19.0
                  haskell-hspec-core            2.5.5-1.0            2.5.5-2.0
            haskell-hspec-smallcheck           0.5.2-21.0           0.5.2-22.0
                   haskell-hspec-wai           0.9.0-90.0           0.9.0-91.0
              haskell-hspec-wai-json          0.9.0-105.0          0.9.0-106.0
                haskell-html-conduit           1.3.1-22.0           1.3.1-23.0
                        haskell-http       4000.3.12-31.0       4000.3.12-32.0
               haskell-http-api-data         0.3.8.1-30.0         0.3.8.1-31.0
                 haskell-http-client        0.5.13.1-11.0        0.5.13.1-12.0
             haskell-http-client-tls         0.3.5.3-64.0         0.3.5.3-65.0
                 haskell-http-common         0.8.2.0-20.0         0.8.2.0-21.0
                haskell-http-conduit           2.3.2-20.0           2.3.2-21.0
                   haskell-http-date            0.0.8-1.0            0.0.8-2.0
                haskell-http-streams         0.8.6.1-44.0         0.8.6.1-45.0
                  haskell-http-types          0.12.1-17.0          0.12.1-18.0
                  haskell-httpd-shed         0.4.0.3-32.0         0.4.0.3-33.0
          haskell-incremental-parser         0.3.1.1-30.0         0.3.1.1-31.0
                         haskell-ini           0.3.6-12.0           0.3.6-13.0
   haskell-insert-ordered-containers        0.2.1.0-107.0        0.2.1.0-108.0
                 haskell-interpolate           0.2.0-36.0           0.2.0-37.0
    haskell-interpolatedstring-perl6           1.0.0-71.0           1.0.0-72.0
                  haskell-io-streams         1.5.0.1-23.0         1.5.0.1-24.0
          haskell-io-streams-haproxy         1.0.0.2-22.0         1.0.0.2-23.0
                     haskell-iproute           1.7.5-23.0           1.7.5-24.0
                        haskell-jose         0.7.0.0-41.0         0.7.0.0-42.0
                   haskell-js-jquery          3.3.1-101.0          3.3.1-102.0
              haskell-kan-extensions             5.2-12.0             5.2-13.0
                        haskell-keys          3.12.1-13.0          3.12.1-14.0
                        haskell-lens            4.17-10.0            4.17-11.0
                  haskell-lens-aeson           1.0.2-89.0           1.0.2-90.0
                      haskell-libmpd         0.9.0.8-29.0         0.9.0.8-30.0
                haskell-lifted-async        0.10.0.2-20.0        0.10.0.2-21.0
                 haskell-lifted-base        0.2.3.12-15.0        0.2.3.12-16.0
              haskell-logging-facade           0.3.0-21.0           0.3.0-22.0
                       haskell-lucid          2.9.10-27.0          2.9.10-28.0
                  haskell-megaparsec           6.5.0-19.0           6.5.0-20.0
                      haskell-memory         0.14.16-22.0         0.14.16-23.0
                    haskell-memotrie           0.6.9-14.0           0.6.9-15.0
             haskell-microlens-aeson           2.3.0-31.0           2.3.0-32.0
                 haskell-microstache         1.0.1.1-51.0         1.0.1.1-52.0
                    haskell-missingh         1.4.0.1-42.0         1.4.0.1-43.0
                     haskell-mockery           0.3.5-27.0           0.3.5-28.0
               haskell-monad-control         1.0.2.3-15.0         1.0.2.3-16.0
               haskell-monad-journal           0.8.1-18.0           0.8.1-19.0
                haskell-monad-logger        0.3.28.5-46.0        0.3.28.5-47.0
                haskell-monad-unlift           0.2.0-40.0           0.2.0-41.0
            haskell-mono-traversable         1.0.8.1-49.0         1.0.8.1-50.0
                    haskell-mustache           2.3.0-59.0           2.3.0-60.0
          haskell-neat-interpolation          0.3.2.2-8.0          0.3.2.2-9.0
                      haskell-nettle           0.3.0-10.0           0.3.0-11.0
                     haskell-network          2.7.0.2-5.0          2.7.0.2-6.0
                  haskell-network-ip         0.3.0.2-55.0         0.3.0.2-56.0
           haskell-network-multicast           0.2.0-34.0           0.2.0-35.0
       haskell-network-protocol-xmpp           0.4.8-69.0           0.4.8-70.0
            haskell-newtype-generics           0.5.3-14.0           0.5.3-15.0
                       haskell-nonce           1.0.7-22.0           1.0.7-23.0
          haskell-openpgp-asciiarmor            0.1.1-9.0           0.1.1-10.0
             haskell-openssl-streams         1.2.1.3-21.0         1.2.1.3-22.0
                haskell-pandoc-types        1.17.5.1-12.0        1.17.5.1-13.0
                     haskell-parsers           0.12.9-5.0           0.12.9-6.0
                        haskell-path           0.6.1-56.0           0.6.1-57.0
                     haskell-path-io            1.4.0-1.0            1.4.0-2.0
                  haskell-pcre-heavy         1.0.0.2-26.0         1.0.0.2-27.0
                         haskell-pem           0.2.4-22.0           0.2.4-23.0
                  haskell-persistent           2.8.2-49.0           2.8.2-50.0
           haskell-persistent-sqlite         2.8.1.2-50.0         2.8.1.2-51.0
         haskell-persistent-template           2.5.4-74.0           2.5.4-75.0
                haskell-pgp-wordlist         0.1.0.2-19.0         0.1.0.2-20.0
                  haskell-pipes-http          1.0.5-152.0          1.0.5-153.0
                     haskell-pointed           5.0.1-48.0           5.0.1-49.0
           haskell-postgresql-binary        0.12.1.1-36.0        0.12.1.1-37.0
               haskell-prettyprinter            1.2.1-9.0           1.2.1-10.0
 haskell-prettyprinter-ansi-terminal         1.1.1.2-19.0         1.1.1.2-20.0
haskell-prettyprinter-convert-ansi-wl-pprint             1.1-16.0             1.1-17.0
              haskell-process-extras           0.7.4-23.0           0.7.4-24.0
                 haskell-profunctors              5.3-8.0              5.3-9.0
            haskell-project-template         0.2.0.1-70.0         0.2.0.1-71.0
       haskell-quickcheck-assertions           0.3.0-26.0           0.3.0-27.0
                      haskell-rebase           1.2.4-27.0           1.2.4-28.0
                    haskell-reducers          3.12.3-11.0          3.12.3-12.0
                    haskell-rerebase           1.2.2-27.0           1.2.2-28.0
                      haskell-resolv          0.1.1.1-9.0         0.1.1.1-10.0
               haskell-resource-pool         0.2.3.2-43.0         0.2.3.2-44.0
                   haskell-resourcet           1.2.1-17.0           1.2.1-18.0
                       haskell-retry         0.7.6.2-34.0         0.7.6.2-35.0
                         haskell-rio          0.1.4.0-4.0          0.1.4.0-5.0
                         haskell-rsa           2.3.0-22.0           2.3.0-23.0
             haskell-safe-exceptions         0.1.7.0-23.0         0.1.7.0-24.0
                       haskell-sandi           0.4.2-36.0           0.4.2-37.0
                         haskell-sbv             7.10-1.0             7.10-2.0
                   haskell-securemem          0.1.10-24.0          0.1.10-25.0
               haskell-semigroupoids           5.3.1-10.0           5.3.1-11.0
                     haskell-servant        0.13.0.1-26.0        0.13.0.1-27.0
              haskell-servant-server        0.13.0.1-54.0        0.13.0.1-56.0
             haskell-servant-swagger           1.1.5-45.0           1.1.5-46.0
                       haskell-shake          0.16.4-65.0          0.16.4-66.0
                 haskell-shakespeare          2.0.15-47.0          2.0.15-48.0
                      haskell-shelly           1.8.1-16.0           1.8.1-17.0
        haskell-should-not-typecheck           2.1.0-16.0           2.1.0-17.0
             haskell-simple-sendfile          0.2.27-66.0          0.2.27-67.0
                 haskell-skylighting           0.7.2-15.0           0.7.2-16.0
            haskell-skylighting-core           0.7.2-15.0           0.7.2-16.0
                   haskell-snap-core         1.0.3.2-23.0         1.0.3.2-24.0
                 haskell-snap-server         1.1.0.0-36.0         1.1.0.0-38.0
                       haskell-socks           0.5.6-30.0           0.5.6-31.0
                   haskell-sourcemap           0.1.6-83.0           0.1.6-84.0
                    haskell-src-exts          1.20.2-17.0          1.20.2-18.0
               haskell-src-exts-util           0.2.3-14.0           0.2.3-15.0
                    haskell-src-meta         0.8.0.3-12.0         0.8.0.3-13.0
                  haskell-statistics        0.14.0.2-62.0        0.14.0.2-63.0
              haskell-storable-tuple         0.0.3.3-17.0         0.0.3.3-18.0
                       haskell-store        0.4.3.2-130.0        0.4.3.2-131.0
           haskell-streaming-commons          0.2.1.0-3.0          0.2.1.0-4.0
               haskell-stringbuilder           0.5.1-27.0           0.5.1-28.0
                     haskell-success           0.2.6-25.0           0.2.6-26.0
                    haskell-swagger2           2.2.2-43.0           2.2.2-44.0
           haskell-tagstream-conduit        0.5.5.3-187.0        0.5.5.3-188.0
         haskell-tamarin-prover-term           1.4.0-13.0           1.4.0-14.0
       haskell-tamarin-prover-theory           1.4.0-29.0           1.4.0-30.0
                       haskell-tasty          1.1.0.2-2.0          1.1.0.3-1.0
      haskell-tasty-expected-failure        0.11.1.1-10.0        0.11.1.1-11.0
                haskell-tasty-golden            2.3.2-4.0            2.3.2-5.0
              haskell-tasty-hedgehog         0.2.0.0-37.0         0.2.0.0-38.0
                 haskell-tasty-hunit        0.10.0.1-22.0        0.10.0.1-23.0
            haskell-tasty-quickcheck            0.10-14.0            0.10-15.0
                 haskell-tasty-rerun          1.1.12-29.0          1.1.12-30.0
            haskell-tasty-smallcheck           0.8.1-16.0           0.8.1-17.0
                    haskell-tasty-th           0.1.7-29.0           0.1.7-30.0
                   haskell-temporary              1.3-7.0              1.3-8.0
                     haskell-texmath        0.11.0.1-22.0        0.11.0.1-23.0
                  haskell-text-short           0.1.2-21.0           0.1.2-22.0
                  haskell-th-orphans           0.13.6-5.0           0.13.6-6.0
                haskell-th-utilities         0.2.0.1-52.0         0.2.0.1-53.0
                         haskell-tls           1.4.1-34.0           1.4.1-35.0
         haskell-tls-session-manager         0.0.0.2-61.0         0.0.0.2-62.0
           haskell-transformers-base         0.4.5.2-13.0         0.4.5.2-14.0
                   haskell-tree-diff           0.0.1-35.0           0.0.1-36.0
                    haskell-trifecta         1.7.1.1-96.0         1.7.1.1-97.0
                      haskell-turtle          1.5.10-14.0          1.5.10-15.0
               haskell-typed-process         0.2.2.0-18.0         0.2.2.0-19.0
                   haskell-unixutils          1.54.1-52.0          1.54.1-53.0
                    haskell-unliftio         0.2.7.0-17.0         0.2.7.0-18.0
              haskell-uri-bytestring         0.3.2.0-10.0         0.3.2.0-11.0
            haskell-vector-instances             3.4-79.0             3.4-80.0
                         haskell-vty             5.22-3.0           5.23.1-1.0
                         haskell-wai         3.2.1.2-28.0         3.2.1.2-29.0
              haskell-wai-app-static         3.1.6.2-76.0         3.1.6.2-78.0
                 haskell-wai-conduit         3.0.0.4-49.0         3.0.0.4-50.0
                    haskell-wai-cors           0.2.6-52.0           0.2.6-53.0
                   haskell-wai-extra         3.0.23.0-3.0         3.0.23.0-4.0
          haskell-wai-handler-launch         3.0.2.4-46.0         3.0.2.4-47.0
                  haskell-wai-logger           2.3.2-95.0           2.3.2-97.0
       haskell-wai-middleware-static           0.8.2-27.0           0.8.2-28.0
              haskell-wai-websockets         3.0.1.2-38.0         3.0.1.2-39.0
                        haskell-warp           3.2.23-6.0           3.2.23-7.0
                    haskell-warp-tls         3.2.4.3-59.0         3.2.4.3-60.0
                  haskell-websockets        0.12.5.1-12.0        0.12.5.1-13.0
               haskell-with-location           0.1.0-21.0           0.1.0-22.0
         haskell-wl-pprint-annotated         0.1.0.0-17.0         0.1.0.0-18.0
            haskell-wl-pprint-extras         3.5.0.5-64.0         3.5.0.5-65.0
          haskell-wl-pprint-terminfo         3.7.1.4-64.0         3.7.1.4-65.0
                   haskell-word-wrap           0.4.1-22.0           0.4.1-23.0
                        haskell-wreq         0.5.2.1-45.0         0.5.2.1-46.0
                        haskell-x509           1.7.3-26.0           1.7.3-27.0
                  haskell-x509-store           1.6.6-25.0           1.6.6-26.0
                 haskell-x509-system           1.6.6-54.0           1.6.6-55.0
             haskell-x509-validation          1.6.10-25.0          1.6.10-26.0
                      haskell-xcffib           0.6.0-57.0           0.6.0-58.0
                 haskell-xml-conduit           1.8.0-42.0           1.8.0-43.0
                  haskell-xml-hamlet           0.5.0-35.0           0.5.0-36.0
                haskell-xss-sanitize            0.3.6-1.0            0.3.6-2.0
                        haskell-yaml            0.9.0-6.0            0.9.0-7.0
                       haskell-yesod           1.6.0-70.0           1.6.0-71.0
                  haskell-yesod-auth           1.6.3-67.0           1.6.3-69.0
                  haskell-yesod-core            1.6.6-4.0            1.6.6-5.0
               haskell-yesod-default          1.2.0-359.0          1.2.0-360.0
                  haskell-yesod-form            1.6.2-4.0            1.6.2-5.0
            haskell-yesod-persistent           1.6.0-63.0           1.6.0-64.0
                haskell-yesod-static           1.6.0-58.0           1.6.0-60.0
                  haskell-yesod-test            1.6.5-2.0            1.6.5-3.0
                 haskell-zip-archive            0.3.3-3.0            0.3.3-4.0
                           hedgewars        0.9.24.1-42.0        0.9.24.1-43.0
                             hindent            5.2.7-2.0            5.2.7-3.0
                             hledger             1.10-8.0            1.10-10.0
                         hledger-api            1.10-16.0            1.10-18.0
                          hledger-ui            1.10-12.0            1.10-17.0
                         hledger-web            1.10-20.0            1.10-22.0
                               hlint           2.1.8-12.0           2.1.8-13.0
                              hoogle        5.0.17.3-56.0        5.0.17.3-57.0
                      hopenpgp-tools          0.21.1-53.0           0.21.2-1.0
                                hugo             0.44-1.0           0.45.1-1.0
                               idris           1.3.0-40.0           1.3.0-41.0
                             ipython            6.3.1-1.0            6.5.0-1.0
                            ipython2            5.6.0-1.0            5.8.0-1.0
                             jenkins            2.134-1.0            2.135-1.0
                                josm            14026-1.0            14066-1.0
                         libutf8proc            2.1.1-2.0            2.1.1-4.0
               matrix-appservice-irc            0.9.1-1.0           0.10.1-1.0
                                mcdp               0.4b-3             0.4b-4.0
                      mongo-c-driver           1.11.0-1.0           1.12.0-1.0
                         nodejs-less            3.7.1-1.0            3.8.0-1.0
                                 nsd           4.1.22-1.0           4.1.23-1.0
                              nuitka         0.5.31.0-1.0         0.5.32.1-1.0
                             oidentd            2.3.1-1.0            2.3.1-2.0
                              openmw           0.43.0-4.0           0.44.0-1.0
                              pandoc          2.2.2.1-2.0          2.2.2.1-3.0
                     pandoc-citeproc        0.14.3.1-94.0        0.14.3.1-95.0
                     pandoc-crossref         0.3.2.1-47.0         0.3.2.1-49.0
                                  pd           0.48.1-4.0           0.48.1-5.0
                                pfff               0.29-9                    -
                                 pm2            3.0.2-1.0            3.0.3-1.0
                           postgrest        0.4.4.0-212.0        0.4.4.0-214.0
                          python-ass              0.4.2-2                    -
                    python-blessings            1.6.1-1.0              1.7-1.0
                       python-jaraco       2018.07.20-1.0       2018.07.31-1.0
                      python-serpent             1.25-1.0             1.27-1.0
                      python-wtforms            2.2.1-1.0            2.2.1-3.0
                         python2-ass              0.4.2-2                    -
                   python2-blessings            1.6.1-1.0              1.7-1.0
                      python2-jaraco       2018.07.20-1.0       2018.07.31-1.0
                    python2-psycopg1             1.1.21-9                    -
                     python2-serpent             1.25-1.0             1.27-1.0
                     python2-wtforms            2.2.1-1.0            2.2.1-3.0
                                qmmp            1.2.2-1.0            1.2.3-1.0
                                qtox           1.16.3-1.0           1.16.3-2.0
                              racket             6.12-1.0              7.0-1.0
                         racket-docs             6.12-1.0              7.0-1.0
                      racket-minimal             6.12-1.0              7.0-1.0
                             remmina       1:1.2.30.1-1.1       1:1.2.31.2-1.0
                       roundcubemail            1.3.6-3.0            1.3.7-1.0
                               s3cmd            2.0.1-2.0            2.0.2-1.0
                           seamonkey           2.49.3-1.1           2.49.4-1.0
                                serd           0.28.0-2.0           0.30.0-1.0
                          shellcheck           0.5.0-60.0           0.5.0-61.0
                         shellharden              3.2-1.0            4.0.0-1.0
                            shotwell         2:0.28.3-1.0         2:0.28.4-1.0
                               sigil            0.9.9-2.0           0.9.10-1.0
                             snapper            0.5.4-2.0            0.5.6-1.0
                                sord           0.16.0-2.0           0.16.2-1.0
                              sratom            0.6.0-2.0            0.6.2-1.0
                               stack           1.7.1-86.0           1.7.1-88.0
                     stylish-haskell         0.9.2.0-43.0         0.9.2.0-45.0
                                suil           0.10.0-2.0           0.10.0-3.0
                           syncthing          0.14.48-1.0          0.14.49-1.0
                  syncthing-relaysrv          0.14.48-1.0          0.14.49-1.0
                      tamarin-prover           1.4.0-68.0           1.4.0-70.0
                    telegram-desktop           1.3.10-1.0           1.3.10-2.0
                                 tig            2.3.3-1.0            2.4.1-1.0
                             toxcore          1:0.2.3-1.0          1:0.2.4-1.0
                              trojan            1.5.0-1.0            1.5.1-1.0
                          typescript            2.9.2-1.0            3.0.1-1.0
                           uglify-js            3.4.5-1.0            3.4.6-1.0
                               v2ray           3.31.1-1.0           3.32.1-1.0
          vapoursynth-plugin-mvtools                 19-1               20-1.0
                      wireguard-dkms     0.0.20180718-1.0     0.0.20180731-1.0
                     wireguard-tools     0.0.20180718-1.0     0.0.20180731-1.0
                              xmobar            0.26-63.0            0.26-64.0
                                yarn            1.7.0-1.0            1.9.2-1.0
                          youtube-dl       2018.07.10-1.0       2018.07.29-1.0
                        zerotier-one           1.2.10-1.0           1.2.12-1.0
                                amtk                    -            5.0.0-1.0
                 appstream-generator                    -            0.7.3-1.1
                           autorandr                    -              1.6-2.0
         deepin-community-wallpapers                    -          1:1.7.5-2.0
                deepin-network-utils                    -            0.0.4-1.0
                        eclipse-rust                    -              4.8-2.0
                             freeciv                    -            2.6.0-1.0
                      haskell-hsyaml                    -          0.1.1.2-1.0
                                pius                    -            2.2.6-1.0
                       python-genshi                    -              0.7-5.0
                       python-kajiki                    -            0.7.2-1.0
                     python-logutils                    -            0.3.5-2.0
                         python-nine                    -            1.0.0-3.0
                      python-random2                    -            1.0.1-1.0
                  python-xvfbwrapper                    -            0.2.9-1.0
                      python2-kajiki                    -            0.7.2-1.0
                    python2-logutils                    -            0.3.5-2.0
                        python2-nine                    -            1.0.0-3.0
                            qmidictl                    -            0.5.2-1.0
                             qxgedit                    -            0.5.2-1.0
                            ring-kde                    -            3.0.0-2.0
                              solaar                    -           0.9.2-10.0
               uwsgi-plugin-notfound                    -         2.0.17.1-2.0
Any problems?
  • No issues, everything went smoothly
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
  • Yes I am currently experiencing an issue due to the update. (Please post about it)
0 voters
[Testing Update i686] 2018-07-28 to 08-01 - Racket, OpenJDK 10
#2
Known issues and solutions
libutf8proc: /usr/lib/libutf8proc.so.2 exists in filesystem
There’s an update to manjaro-system which should automatically fix this issue.
If you still have the issue you can easily resolve it manually with:
sudo pacman -Syu --overwrite usr/lib/libutf8proc.so.2
#3
Like these:
                            chromium       68.0.3440.84-0                    -
                            chromium     68.0.3440.75-1.0     68.0.3440.84-1.0
                            composer            1.6.5-1.0            1.7.0-1.0
                               geoip             1.6.11-1           1.6.12-1.0
                            harfbuzz            1.8.4-1.0            1.8.5-1.0
                        harfbuzz-icu            1.8.4-1.0            1.8.5-1.0
                          libgphoto2           2.5.18-1.0           2.5.19-1.0
                   libva-mesa-driver           18.1.4-1.0           18.1.5-1.0
                           mercurial            4.6.2-1.0              4.7-1.0
                                mesa           18.1.4-1.0           18.1.5-1.0
                          mesa-vdpau           18.1.4-1.0           18.1.5-1.0
                              mutter           3.28.3-1.0           3.28.3-2.0
                         opencl-mesa           18.1.4-1.0           18.1.5-1.0
                            pipewire            0.2.0-1.0            0.2.2-1.0
                      python2-django          1.11.13-1.0          1.11.15-1.0
                        vulkan-intel           18.1.4-1.0           18.1.5-1.0
                       vulkan-radeon           18.1.4-1.0           18.1.5-1.0
                  xdg-desktop-portal             0.99-1.0             0.99-2.0
              xdg-desktop-portal-kde           5.13.3-3.0           5.13.3-4.0
          aarch64-linux-gnu-binutils             2.31-1.0           2.31.1-1.0
                          alsa-tools            1.1.6-2.0            1.1.6-3.0
              arm-none-eabi-binutils             2.31-1.0           2.31.1-1.0
                              autofs            5.1.4-2.0            5.1.4-3.0
                        avr-binutils             2.31-1.0           2.31.1-1.0
                       cabal-install         2.2.0.0-51.0         2.2.0.0-52.0
                                cgit              1.2-1.0            1.2.1-1.1
                               cgrep          6.6.25-58.0          6.6.25-59.0
                             cryptol  2.5.0.20180515-58.0  2.5.0.20180515-59.0
                              csound           6.11.0-3.0           6.11.0-5.0
                          csound-doc           6.11.0-3.0           6.11.0-5.0
                               darcs          2.14.1-30.0          2.14.1-31.0
                                 dep            0.4.1-3.0            0.5.0-1.0
                           git-annex       6.20180719-4.0       6.20180719-7.0
                              glider            0.6.3-1.0            0.6.5-1.0
                              gopass            1.8.2-1.0            1.8.2-2.0
                haskell-authenticate          1.3.4-147.0          1.3.4-148.0
                         haskell-aws            0.20-55.0            0.20-56.0
              haskell-binary-conduit             1.3-35.0             1.3-36.0
                  haskell-cheapskate          0.1.1-110.0          0.1.1-111.0
                    haskell-checkers          0.4.10-31.0           0.4.11-1.0
                     haskell-conduit         1.3.0.3-21.0         1.3.0.3-22.0
               haskell-conduit-extra           1.3.0-41.0           1.3.0-42.0
                   haskell-criterion          1.5.0.0-7.0          1.5.0.0-8.0
          haskell-cryptohash-conduit          0.1.1-202.0          0.1.1-203.0
          haskell-cryptonite-conduit           0.2.2-96.0           0.2.2-97.0
                         haskell-dav          1.3.2-103.0          1.3.2-104.0
                   haskell-esqueleto  2.5.3.20180402-48.0  2.5.3.20180402-49.0
                        haskell-feed         1.0.0.0-94.0         1.0.0.0-95.0
                      haskell-hakyll        4.12.3.0-75.0        4.12.3.0-77.0
                 haskell-hjsonschema           1.9.0-58.0           1.9.0-60.0
                    haskell-hopenpgp            2.7.1-4.0            2.7.1-6.0
                       haskell-hpack           0.29.5-2.0           0.29.5-3.0
                   haskell-hspec-wai           0.9.0-91.0           0.9.0-92.0
              haskell-hspec-wai-json          0.9.0-106.0          0.9.0-107.0
                haskell-html-conduit           1.3.1-23.0           1.3.1-24.0
                        haskell-http       4000.3.12-32.0       4000.3.12-33.0
                haskell-http-conduit           2.3.2-21.0           2.3.2-22.0
          haskell-incremental-parser         0.3.1.1-31.0         0.3.1.1-32.0
                   haskell-js-jquery          3.3.1-102.0          3.3.1-103.0
                haskell-monad-logger        0.3.28.5-47.0        0.3.28.5-48.0
            haskell-mono-traversable         1.0.8.1-50.0          1.0.9.0-1.0
                    haskell-mustache           2.3.0-60.0           2.3.0-61.0
                  haskell-persistent           2.8.2-50.0           2.8.2-51.0
           haskell-persistent-sqlite         2.8.1.2-51.0         2.8.1.2-52.0
         haskell-persistent-template           2.5.4-75.0           2.5.4-76.0
            haskell-project-template         0.2.0.1-71.0         0.2.0.1-72.0
                         haskell-rio          0.1.4.0-5.0          0.1.5.0-1.0
                       haskell-sandi           0.4.2-37.0           0.4.2-38.0
                         haskell-sbv             7.10-2.0             7.10-3.0
              haskell-servant-server        0.13.0.1-56.0        0.13.0.1-58.0
                       haskell-shake          0.16.4-66.0          0.16.4-67.0
             haskell-simple-sendfile          0.2.27-67.0          0.2.27-68.0
                       haskell-store        0.4.3.2-131.0        0.4.3.2-132.0
           haskell-tagstream-conduit        0.5.5.3-188.0        0.5.5.3-189.0
              haskell-wai-app-static         3.1.6.2-78.0         3.1.6.2-80.0
                 haskell-wai-conduit         3.0.0.4-50.0         3.0.0.4-51.0
                   haskell-wai-extra         3.0.23.0-4.0         3.0.24.0-1.0
          haskell-wai-handler-launch         3.0.2.4-47.0         3.0.2.4-48.0
                  haskell-wai-logger           2.3.2-97.0           2.3.2-98.0
                        haskell-warp           3.2.23-7.0           3.2.23-8.0
                    haskell-warp-tls         3.2.4.3-60.0         3.2.4.3-61.0
                 haskell-xml-conduit           1.8.0-43.0           1.8.0-44.0
                  haskell-xml-hamlet           0.5.0-36.0           0.5.0-37.0
                        haskell-yaml            0.9.0-7.0            0.9.0-8.0
                       haskell-yesod           1.6.0-71.0           1.6.0-74.0
                  haskell-yesod-auth           1.6.3-69.0           1.6.3-72.0
                  haskell-yesod-core            1.6.6-5.0            1.6.6-8.0
               haskell-yesod-default          1.2.0-360.0          1.2.0-363.0
                  haskell-yesod-form            1.6.2-5.0            1.6.2-8.0
            haskell-yesod-persistent           1.6.0-64.0           1.6.0-67.0
                haskell-yesod-static           1.6.0-60.0           1.6.0-63.0
                  haskell-yesod-test            1.6.5-3.0            1.6.5-6.0
                           hedgewars        0.9.24.1-43.0        0.9.24.1-44.0
                             hindent            5.2.7-3.0            5.2.7-4.0
                         hledger-api            1.10-18.0            1.10-20.0
                         hledger-web            1.10-22.0            1.10-25.0
                               hlint           2.1.8-13.0           2.1.8-14.0
                              hoogle        5.0.17.3-57.0        5.0.17.3-59.0
                      hopenpgp-tools           0.21.2-1.0           0.21.2-3.0
                                hugo           0.45.1-1.0             0.46-1.0
                               idris           1.3.0-41.0           1.3.0-42.0
                                knot            2.6.8-1.0            2.7.0-1.0
                              kotlin           1.2.51-1.0           1.2.60-1.0
                       libringclient2:20180718.1.af8399f-1.02:20180802.5.14d8a66-1.0
                        man-pages-de              2.3-1.0              2.3-2.0
                      matrix-synapse           0.33.0-1.0           0.33.1-1.0
                              nodejs           10.7.0-1.0           10.8.0-1.0
                                 npm            6.2.0-1.0            6.3.0-1.0
                             opendht          1:1.7.3-1.0          1:1.7.4-1.0
                    otf-font-awesome            5.1.1-1.0            5.2.0-1.0
                              pandoc          2.2.2.1-3.0          2.2.2.1-4.0
                     pandoc-citeproc        0.14.3.1-95.0        0.14.3.1-96.0
                     pandoc-crossref         0.3.2.1-49.0         0.3.2.1-50.0
                           postgrest        0.4.4.0-214.0        0.4.4.0-216.0
                         ring-daemon2:20180718.1.af8399f-1.02:20180802.5.14d8a66-1.0
                          ring-gnome3:20180718.1.af8399f-1.03:20180802.5.14d8a66-1.0
                                rust         1:1.27.2-1.0         1:1.28.0-1.0
                           rust-docs         1:1.27.2-1.0         1:1.28.0-1.0
                          shellcheck           0.5.0-61.0           0.5.0-62.0
                               stack           1.7.1-88.0           1.7.1-90.0
                     stylish-haskell         0.9.2.0-45.0         0.9.2.0-46.0
                      tamarin-prover           1.4.0-70.0           1.4.0-73.0
                                tinc             1.0.33-1           1.0.34-1.0
                    ttf-font-awesome            5.1.1-1.0            5.2.0-1.0
                               v2ray           3.32.1-1.0             3.33-1.0
                            vbam-sdl            2.1.0-1.0            2.1.0-2.0
                             vbam-wx            2.1.0-1.0            2.1.0-2.0
                      wireguard-dkms     0.0.20180731-1.0     0.0.20180802-1.0
                     wireguard-tools     0.0.20180731-1.0     0.0.20180802-1.0
                              xmobar            0.26-64.0            0.26-65.0
                     python-influxdb                    -            5.2.0-2.0
#4
@jonathon
the update has yet to propagate to mirrors :thinking:
#5
All three branches are currently in-sync so it’s your current mirror at fault. :slight_smile:
#6
@jonathon
nah it wasn’t at 6:22 PM cus I did sudo pacman-mirrors -g && sudo pacman -Syu
getting it rn
cheers mate :grinning:
#7
Update on 1 Machine and 1 VB without Problems.
DK3
#8
Why not have some kernels too, given there’s a security update in there:
                             PACKAGE          x32-testing         x32-unstable
                            linux414            4.14.59-1            4.14.61-1
                    linux414-headers            4.14.59-1            4.14.61-1
                             linux44            4.4.145-1            4.4.146-1
                     linux44-headers            4.4.145-1            4.4.146-1
                             linux49            4.9.116-1            4.9.118-1
                     linux49-headers            4.9.116-1            4.9.118-1
                              pacman              5.1.1-1              5.1.1-2
                  linux414-acpi_call             1.1.0-52             1.1.0-53
                   linux414-bbswitch               0.8-52               0.8-53
                linux414-broadcom-wl      6.30.223.271-52      6.30.223.271-53
                linux414-ndiswrapper              1.61-52              1.61-53
               linux414-nvidia-304xx         1:304.137-52         1:304.137-53
               linux414-nvidia-340xx           340.107-11           340.107-12
               linux414-nvidia-390xx             390.77-4             390.77-5
                      linux414-r8168          8.045.08-40          8.045.08-41
                  linux414-rt3562sta        2.4.1.1_r4-52        2.4.1.1_r4-53
                        linux414-spl             0.7.9-16             0.7.9-17
                   linux414-tp_smapi              0.41-52              0.41-53
                linux414-vhba-module          20161009-52          20161009-53
   linux414-virtualbox-guest-modules             5.2.16-4             5.2.16-5
    linux414-virtualbox-host-modules             5.2.16-4             5.2.16-5
                        linux414-zfs             0.7.9-16             0.7.9-17
                   linux44-acpi_call            1.1.0-102            1.1.0-104
                 linux44-broadcom-wl      6.30.223.271-72      6.30.223.271-74
                 linux44-ndiswrapper              1.61-70              1.61-72
                linux44-nvidia-304xx         1:304.137-37         1:304.137-39
                linux44-nvidia-340xx            340.107-7            340.107-9
                linux44-nvidia-390xx             390.77-3             390.77-5
                       linux44-r8168          8.045.08-24          8.045.08-26
                   linux44-rt3562sta        2.4.1.1_r4-70        2.4.1.1_r4-72
                         linux44-spl             0.7.9-10             0.7.9-12
                 linux44-vhba-module          20161009-70          20161009-72
    linux44-virtualbox-guest-modules             5.2.16-3             5.2.16-5
     linux44-virtualbox-host-modules             5.2.16-3             5.2.16-5
                         linux44-zfs             0.7.9-10             0.7.9-12
                   linux49-acpi_call             1.1.0-89             1.1.0-90
                    linux49-bbswitch               0.8-89               0.8-90
                 linux49-broadcom-wl      6.30.223.271-89      6.30.223.271-90
                    linux49-catalyst     1:15.201.1151-89     1:15.201.1151-90
                 linux49-ndiswrapper              1.61-87              1.61-88
                linux49-nvidia-304xx         1:304.137-48         1:304.137-49
                linux49-nvidia-340xx            340.107-8            340.107-9
                linux49-nvidia-390xx             390.77-4             390.77-5
                       linux49-r8168          8.045.08-29          8.045.08-30
                   linux49-rt3562sta        2.4.1.1_r4-87        2.4.1.1_r4-88
                         linux49-spl             0.7.9-13             0.7.9-14
                    linux49-tp_smapi              0.41-89              0.41-90
                 linux49-vhba-module          20161009-87          20161009-88
    linux49-virtualbox-guest-modules             5.2.16-4             5.2.16-5
     linux49-virtualbox-host-modules             5.2.16-4             5.2.16-5
                         linux49-zfs             0.7.9-13             0.7.9-14
                   ndiswrapper-utils              1.61-52              1.61-53
                    rt3562sta-common        2.4.1.1_r4-87        2.4.1.1_r4-88
                  xfce4-session-gtk3             4.13.0-6             4.13.1-1
#9
Just letting you know that the problem i wrote about [Stable Update i686] 2018-07-26 - KDE applications, Pulseaudio, VirtualBox, Chromium is a mainline one. Already reported a bug. Whoever works with Samba by using cifs should know that the last usable kernel is 4.14.50
#10
Updated after more than a month, engranpa.tap removed, all OK
