[Stable Update] 2026-05-19 - Kernels, Plasma 6, KDE Gear, KDE Frameworks, COSMIC, Vulkan
I think the major upgrade of nettle should be mentioned in “Notable Package Updates”. I had to fix my pi-hole installation. But the update could also have side-effects elsewere.
No issue for me but 2 new .pacnew:
etc/mkinitcpio.conf.pacnew
/ect/httpd/conf/httpd.conf.pacnew
911 packages up and no problem.
Of Interest/Related:
In a recent DeLinuxCo thread:
Shouldn’t ntfs-3g be uptdated with latest patch?
See NTFS 3G Release History · tuxera/ntfs-3g Wiki · GitHub
Stable version 2026.2.25 (April 21, 2026)
ntfs-3g version 2022.10.3-2 is in all Manjaro repositories (as I write) – I imagine we need to wait for Arch to include it.
Edit:- The same (older) version appears to be in Arch stable:
mbn info ntfs-3g -q
Branch         : archlinux
Version        : 2022.10.3-2
Repository     : extra
Build Date     : Tue 29 Apr 2025 08:28:57
Packager       : T.J. Townsend <blakkheim@archlinux.org>
Branch         : unstable
Repository     : extra
Branch         : testing
Repository     : extra
Branch         : stable
Repository     : extra
Do they know?
I’d be surprised if they didn’t.
Arch has released latest version of ntfs-3g to extra-testing branch
Arch Linux - ntfs-3g 2026.2.25-1 (x86_64)
No real problem, but there was a small, quirk we can call it.
I couldn’t create a Timeshift (GUI) snapshot after upgrade, I tried 3 times and Timeshift crashed just before finishing.
Log showed exit 0 which I will assume mean success.
I started the GUI from terminal to see if I could see some error but than it successfully created a snapshot.
I’ve just noticed that since updating, the kernel has been spamming the journal with messages about “binder”.
It seems to start with:
May 22 20:09:24 antwerp kernel: binder: 168525:168525 ioctl c00c620f 7ffcbdbdb6d8 returned -22
May 22 20:09:28 antwerp kernel: binder: 168525:168525 cannot find target node
May 22 20:09:28 antwerp kernel: binder: 168525:168525 transaction async to 0:0 failed 21495/29189/-22, code 2 size 92-0 line 3236
May 22 20:09:29 antwerp kernel: binder: 168525:168525 cannot find target node
May 22 20:09:29 antwerp kernel: binder: 168525:168525 transaction async to 0:0 failed 25446/29189/-22, code 2 size 92-0 line 3236
May 22 20:09:57 antwerp kernel: binder: undelivered death notification, 0000000000000001
May 22 20:14:36 antwerp kernel: binder: undelivered death notification, 0000000000000001
May 22 20:14:43 antwerp kernel: binder: undelivered death notification, 0000000000000001
May 22 20:16:11 antwerp kernel: binder: 167510:173966 cannot find target node
May 22 20:16:11 antwerp kernel: binder: 167510:173966 transaction call to 0:0 failed 163405/29189/-22, code 1599098439 size 0-0 line 3236
May 22 20:16:11 antwerp kernel: binder: 173915:173974 cannot find target node
May 22 20:16:11 antwerp kernel: binder: 173915:173974 transaction call to 0:0 failed 163406/29189/-22, code 1599098439 size 0-0 line 3236
Then continues hundreds of thousands of times with
May 23 17:41:14 antwerp kernel: binder: 167510:167510 cannot find target node
May 23 17:41:14 antwerp kernel: binder: 167510:167510 transaction call to 0:0 failed 500874/29189/-22, code 1599098439 size 0-0 line 3236
May 23 17:41:15 antwerp kernel: binder: 175321:175371 cannot find target node
May 23 17:41:15 antwerp kernel: binder: 175321:175371 transaction call to 0:0 failed 500875/29189/-22, code 1599098439 size 0-0 line 3236
May 23 17:41:15 antwerp kernel: binder: 167510:167510 cannot find target node
May 23 17:41:15 antwerp kernel: binder: 167510:167510 transaction call to 0:0 failed 500876/29189/-22, code 1599098439 size 0-0 line 3236
Most of the numbers seem to be getting larger as it goes on.
I haven’t actually seen any noticeable effects apart from the messages. This is with kernel 7.0.9; I haven’t been able to test with other installed kernels yet as I can’t reboot at present.
Updated install medias including this update:
Bian-May 26.1.0-pre (2026-05-23)
Download XFCE
Full
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260523-linux70.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260523-linux70.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260523-linux70.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260523-linux70.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260523-linux70.iso.torrent
Minimal
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux70.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux70.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux70.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux70.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux70.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux70.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux618.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux618.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux618.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux618.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux618.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux612.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux612.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux612.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux612.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux612.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux612.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260523-linux70.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260523-linux70.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260523-linux70.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260523-linux70.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260523-linux70.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260523-linux70.iso.pkgs
Minimal
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux70.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux70.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux70.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux70.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux70.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux70.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux618.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux618.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux618.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux618.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux618.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux612.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux612.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux612.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux612.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux612.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux612.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260523-linux70.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260523-linux70.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260523-linux70.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260523-linux70.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260523-linux70.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260523-linux70.iso.pkgs
Minimal
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux70.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux70.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux70.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux70.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux70.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux70.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux618.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux618.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux618.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux618.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux618.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux612.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux612.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux612.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux612.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux612.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux612.iso.pkgs
@Aragorn
To be honest, I forgot doing. I just refresh the list in pamac before upgrading. Could that be the reason for this problem? I’ll take care of that in future, thanks!
@nikgnomic
Sure about that? If I check this now, this is what I get:
Unit pulseaudio.socket could not be found.
Unit pulseaudio.service could not be found.
Mod edit: Consecutive posts merged. Please edit your previous post(s) instead to add further information.
A mirror that hasn’t (fully) synchronized yet could indeed lead to all sorts of problems. Given the time elapsing between bundled updates, it is always best to refresh one’s mirror list first.
If system is using PipeWire and Wireplumber instead of PulseAudio
systemctl --user status -l --no-pager pipewire pipewire-pulse wireplumber
maybe it’s one extra step, but I like to check the mirrors status before attempting to refresh them… pacman-mirrors --status
if the status is --, the mirrors are NOT in sync…
Local mirror status for stable branch
Mirror #1   --  05:48   Canada  https://mirror.csclub.uwaterloo.ca/manjaro/
Mirror #2   --  01:58   Canada  https://mirror.xenyth.net/manjaro/
Mirror #3   --  01:35   Canada  https://muug.ca/mirror/manjaro/
if the status is OK, the mirrors are in sync… and it’s a good time to refresh
Mirror #1   OK  05:48   Canada  https://mirror.csclub.uwaterloo.ca/manjaro/
Mirror #2   OK  01:58   Canada  https://mirror.xenyth.net/manjaro/
Mirror #3   OK  01:35   Canada  https://muug.ca/mirror/manjaro/
Minimally at least one server must be listed as OK before a refresh… just know that refreshing without all servers being sync’d will drop the out of sync ones… having only sync’d servers in the list typically eliminates errors during update package download.
That’s really helpful! I’ll do so. Thanks!
I even go a step further, i always check, and if the first server is not ok, i resort the mirrors (sudo pacman-mirrors -f) because this sorts only servers that are ok.
Although this always never happens with the global servers, those are practically always ok.
binder? that’s android. Are you using custom manjaro+android hybrid, some kind of android emulator with kernel module, or what could cause that?
AH! Thank you. The penny drops; I experimented with Waydroid shortly after the update (but dumped it because frankly, scrcpy works better). I probably need a reboot to clear something hanging around after my experimentation.
2 posts were split to a new topic: Unable to satisfy dependency libnettle, libhogweed
