I now also applied the update on my cinnamon edition and I can confirm it went smoothly with no error
As for ‘copy-fail’ I thought I read early in this post that the patch has only been applied to the ‘Unstable’ branch with an update for the stable branch coming soon?, but when I run the command
lsmod | grep algif_aead
The result was a blank line! which I think mean it’s not loaded? so it appears the kernel patch had be added to the ‘Stable’ branch as well!? Am I correct?
That is correct. Not everyone had that module loaded. I didn’t either.
I could be wrong, but I believe it only gets loaded if you have the encrypt or sd-encrypt hooks in /etc/mkinitcpio.conf, or otherwise put, if you’re using an encrypted filesystem.
Manjaro KDE user here, update has completely unresponsive input to keyboard and mouse at the log in screen. System now completely dead, can’t even switch to a terminal to troubleshoot. Perfect…
nova_core taking priority over nouveau utterly broke my laptop’s ability to put the dGPU to sleep, along with gpu passthrough to VM(nova can’t handle gpu handover/resets it seems, flawless going back to nouveau). Had to blacklist nova_core to get my laptop to work properly again.
After the update my ntfs partitions mounted via veracrypt stopped mounting with error fsconfig() failed: ntfs3: Unknown parameter 'big_writes', so I disabled the option hoping the high cpu issues I was running into wouldn’t come back. To make things weirder big_writes seems to be deprecated since 2016 and always enabled now, I have no idea why it was working before hahaha
Since neither ntfs-3g nor veracrypt packages updated, the suspects are fuse3 or the linux kernel, which is integrating native support for NTFS. I don’t believe it’s the kernel because I now have version 7.0.3-1, while the ntfs integration should be added at version 7.1.
That’s right, installed went fine, boot process fine, keyboard has lights that say it’s connected just fine, but nothing works to move the cursor or otherwise enter my password to log in. All input is ignored, including ctrl+shift+F keys. I tried plugging in a different mouse, no change. Eventually the screen turns off due to no input.
Normal login I believe would be SDDM. The system has been updated successfully for several years now without issue, so this is a significant and unexpected problem.
I am booting on a USB stick today once I’m done work to try and fix things.
Konsole and some other application experiences flickering. I.e. konsole renders flickering while I typing. I tried disabling firmware, wayland, vulcan, tried different kernels, changed adaptive sync and refresg rate - nothing helped. No flickering before the update.
after this update sddm login showed a strange behaviour: sometimes the password is not recognized.
I have four users; if I select the user icon and type the password for some users it is refused, for other it is accepted.
The users for which the the password is refused change everytime.
Rebooting don’t solve the problem,
WORKAROUND: click the “other” icon and type username and password (it is always accepted)
I’ve tried kernel 6.19 on previous update and i’ve reverted back to 6.18 because it didn’t work at all.
I’m keeping 6.18, for now. I’ve not tried 7.0, yet.
The update was smooth with kernel 6.18, thank you.
