[Stable Update] 2026-05-02 - Kernels, Plasma, GNOME, Mesa, Systemd, VirtualBox, LibreOffice
had troubles with updating cuz of NVIDIA, i have a card which requires 580xx version, mhwd was saying “580xx does not exist” before the update so i had to just IgnorePkg some of the packages and install the 580xx packages after the update, which i did and the update went well
[CLOSED: sorry, just found out there’s a linux-nvidia-580xx-meta package] But now ive only got one unapdated package - linux-nvidia-meta, which i cant update since it strongly requires nvidia-utils-595. What do i do with this package? [CLOSED]
You can safely remove linux-nvidia-meta. It is not a required package - its only purpose is to ensure that nvidia users are not running out-of-date drivers on their system.
also had a trouble with some pgps like “invalid or corrupted package”, fixed it by reinstalling archlinux-keyring before updating
My 9th Gen INTeL 15-9500 running at 4.1GHz took about 5 hrs 15 minutes to compile webkit2gtk using clang++ !
Didn’t use much ram though.
Do you actually need webkit2gtk from the AUR? Maybe run the following command to see if anything is actually using it:
pamac info webkit2gtk | grep -E "Required By|Optional For"
I notice that the AUR’s webkit2gtk package provides:
libjavascriptcoregtk-4.0.so libwebkit2gtk-4.0.so
However, there is another package in the repos called webkit2gtk-4.1 which provides the following:
libjavascriptcoregtk-4.1.so=0-64 libwebkit2gtk-4.1.so=0-64
Could that package do the job for you?
6 posts were split to a new topic: Whether to remove orphans/foreign packages before, or after, updating?
one abnormal thing after the update is with Dolphin. Usually, when I press the right-mouse, it opens the menu without selecting anything, when choosing a menu item, the full directory is the target. Now the right-mouse selects the file/folder at the point. A behavior change in Dolphin?
The only strange thing I can report for this update was that I had a prompt to download a required key
downloading required keys...
:: Import PGP key "Jonathan Grotelüschen <tippfehlr@archlinux.org>"? [Y/n]
I looked up anything regarding this and found nothing, so is this fine to do/required for my update?
EDIT: Edited out the numbers just in case that mattered
A post was merged into an existing topic: Whether to remove orphans/foreign packages before, or after, updating?
  • Graphics card: RX 9060XT.
  • I haven’t found a workaround yet. I just noticed another oddity: if a program running in the terminal is scrolling text, the lag decreases during that time. In other words, the lag is more pronounced when most of the text on the screen is static.
Translated by Google
At a guess, it probably means that you’ve got Perl in the ignore list in /etc/pacman.conf.
Konsole is buggy for me (Plasma under Wayland)
  • Configuration windows may disappear when focus switches to another window and the only way to get back to that window is via Alt-Tab or clicking the Konsole icon. This is very confusing because configuration in Konsole is done via popup windows and if the “top” popup window disappears, nothing works in other windows. Clicking buttons have no effect.
  • If I use Meta+left or Meta+right to snap a Konsole window, it becomes unmovable and unresizable until I maximize and de-maximize using the window buttons.
Update: something triggers this behaviour. After closing/opening Konsole a few times, I can no longer replicate.
Manjaro GNOME here.
After the update, I was stuck in a GDM loop: I would type the password, but it would not take me to the desktop, instead, it would simply start GDM again.
This is what I had in my log:
mai 04 09:04:29 hmcezar-thinkpad kernel: kvm_amd: CPU 0 isn't AMD or Hygon
mai 04 09:04:29 hmcezar-thinkpad systemd-modules-load[445]: Failed to find module 'acpi_call'
mai 04 09:04:32 hmcezar-thinkpad dbus-broker-launch[1602]: Ignoring duplicate name 'ca.desrt.dconf' in service file '/usr/share//dbus-1/services/ca.desrt.dconf.service'
..... [many entries of "Ignoring duplicate"]
mai 04 09:04:32 hmcezar-thinkpad dbus-broker-launch[1602]: Ignoring duplicate name 'org.x.StatusNotifierWatcher' in service file '/usr/share//dbus-1/services/org.x.StatusNotifierWatcher.service'
mai 04 09:04:32 hmcezar-thinkpad bluetoothd[1606]: Failed to set default system config for hci0
mai 04 09:04:40 hmcezar-thinkpad gdm-password][2978]: gkr-pam: unable to locate daemon control file
mai 04 09:04:40 hmcezar-thinkpad bluetoothd[1606]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
mai 04 09:04:41 hmcezar-thinkpad gnome-session-i[3700]: A graphical session is already running!
mai 04 09:04:41 hmcezar-thinkpad systemd-coredump[3767]: Process 3700 (gnome-session-i) of user 1000 dumped core.
                                                         Stack trace of thread 3700:
                                                         #0  0x00007fd0e8a98a2c n/a (libc.so.6 + 0x98a2c)
                                                         #1  0x00007fd0e8a3e1a0 raise (libc.so.6 + 0x3e1a0)
                                                         #2  0x00007fd0e8a255fe abort (libc.so.6 + 0x255fe)
                                                         #3  0x00007fd0e8de10f9 n/a (libglib-2.0.so.0 + 0x1e0f9)
                                                         #4  0x00007fd0e8e283a0 g_log_default_handler (libglib-2.0.so.0 + 0x653a0)
                                                         #5  0x00007fd0e8e28649 g_logv (libglib-2.0.so.0 + 0x65649)
                                                         #6  0x00007fd0e8e289e4 g_log (libglib-2.0.so.0 + 0x659e4)
                                                         #7  0x00005652ed709961 n/a (/usr/lib/gnome-session-init-worker + 0x2961)
                                                         #8  0x00007fd0e8a276c1 n/a (libc.so.6 + 0x276c1)
                                                         #9  0x00007fd0e8a277f9 __libc_start_main (libc.so.6 + 0x277f9)
                                                         #10 0x00005652ed709bc5 n/a (/usr/lib/gnome-session-init-worker + 0x2bc5)
                                                         Stack trace of thread 3765:
                                                         #0  0x00007fd0e8a9ef32 n/a (libc.so.6 + 0x9ef32)
                                                         #1  0x00007fd0e8a9339c n/a (libc.so.6 + 0x9339c)
                                                         #2  0x00007fd0e8a933e4 n/a (libc.so.6 + 0x933e4)
                                                         #3  0x00007fd0e8b0d2f6 ppoll (libc.so.6 + 0x10d2f6)
                                                         #4  0x00007fd0e8e23734 n/a (libglib-2.0.so.0 + 0x60734)
                                                         #5  0x00007fd0e8e239c7 g_main_loop_run (libglib-2.0.so.0 + 0x609c7)
                                                         #6  0x00007fd0e90936a4 n/a (libgio-2.0.so.0 + 0x1196a4)
                                                         #7  0x00007fd0e8e594fc n/a (libglib-2.0.so.0 + 0x964fc)
                                                         #8  0x00007fd0e8a9697a n/a (libc.so.6 + 0x9697a)
                                                         #9  0x00007fd0e8b1a2bc n/a (libc.so.6 + 0x11a2bc)
                                                         Stack trace of thread 3764:
                                                         #5  0x00007fd0e8e23815 g_main_context_iteration (libglib-2.0.so.0 + 0x60815)
                                                         #6  0x00007fd0e8e23862 n/a (libglib-2.0.so.0 + 0x60862)
                                                         Stack trace of thread 3763:
                                                         #0  0x00007fd0e8b1806d syscall (libc.so.6 + 0x11806d)
                                                         #1  0x00007fd0e8e4fdee g_cond_wait (libglib-2.0.so.0 + 0x8cdee)
                                                         #2  0x00007fd0e8de922d n/a (libglib-2.0.so.0 + 0x2622d)
                                                         #3  0x00007fd0e8e599c7 n/a (libglib-2.0.so.0 + 0x969c7)
                                                         #4  0x00007fd0e8e594fc n/a (libglib-2.0.so.0 + 0x964fc)
                                                         #5  0x00007fd0e8a9697a n/a (libc.so.6 + 0x9697a)
                                                         #6  0x00007fd0e8b1a2bc n/a (libc.so.6 + 0x11a2bc)
And this is my system:
  Host: hmcezar-thinkpad Kernel: 6.18.26-1-MANJARO arch: x86_64 bits: 64
  Desktop: GNOME v: 50.1 Distro: Manjaro Linux
  Type: Convertible System: LENOVO product: 20VK0020MX
    v: ThinkPad L13 Yoga Gen 2 serial: <superuser required>
  Mobo: LENOVO model: 20VK0020MX v: SDK0J40697 WIN
    serial: <superuser required> Firmware: UEFI vendor: LENOVO
    v: R1FET39W (1.13 ) date: 11/18/2021
  ID-1: BAT0 charge: 35.4 Wh (88.6%) condition: 39.9/46 Wh (86.8%)
  Info: quad core 11th Gen Intel Core i5-1135G7 [MT MCP] speed (MHz):
    avg: 2400 min/max: 400/4200
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
  Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
    compositor: gnome-shell driver: X: loaded: modesetting dri: iris gpu: i915
    resolution: 1: 5120x2880~60Hz 2: 3072x1728~60Hz
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 26.0.6-arch1.1
    renderer: Mesa Intel Iris Xe Graphics (TGL GT2)
  Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi
  Device-2: Intel Ethernet I219-V driver: e1000e
  Local Storage: total: 476.94 GiB used: 385.88 GiB (80.9%)
  Memory: total: 16 GiB note: est. available: 15.29 GiB used: 7.23 GiB (47.3%)
  Processes: 314 Uptime: 22m Shell: Zsh inxi: 3.3.40
I managed to isolate the problem to something in .config. I moved the config folder to a backup folder, which enabled me to login.
Then I restored some of the config folders for apps I still use, and it’s working. I didn’t restore any “system” apps configs.
Not sure what the problem was. I’ll just reconfigure GNOME to my taste again.
Post-update, but not before.
Anyway, everything went fine, it just asked me to confirm that I wanted to replace libakonadi.
I’ve uninstalled libkcompactdisc since the dependency has been been removed in the new version.
It would be better if the package manager had removed it automatically since it was marked as installed by a dependency.
I’m having ttrouble updating these 2 libraries
lib32-gst-plugins-base-libs
lib32-gstreamer
getting this error
could not satisfy dependencies:
  • unable to satisfy dependency ‘lib32-gstreamer=1.28.1-1’ required by lib32-gst-plugins-base-libs
Those packages are no longer in the repositories, and they are not required by anything. You should remove them.
You are correct; the reason is to prevent lyrion-music-server from failing after perl update. But “internal” version updates won’t break it so this only flagged a possible problem. I’d forgotten I’d done this, so thanks.
UPDATE: Did some research and deemed this to be safe. Upgrade went well. Thank you!
Went to the TTY do perform the update with
sudo pacman -Syu
Downloaded 860 packages and then was asked…
Import PGP key 8DFDB575B0538C5D, “Jonathan Groteluschen”, tippfehlr@archlinux.org [Y/n]
Is this expected and safe to answer yes to?
did that, but the installation is still around 1GB bigger like machion said
i updated via terminal and it showed me “after the process it is going to be 900MB bigger”
The size usually only differs by a few MB after the update.
before: 472,2 GiB free space.
now: 471,2 GiB free space
i deleted the update files.
and in times where SSDs are kinda expensive it would be nice to know what causes this
Seems mostly good, but just one minor annoyance; I have a news-ticker widget which used to sit immediately above my bottom panel. This now won’t go any closer than about 8px above it. Presumably something to do with the new plasmashell version.
Though I’m probably the only person this will affect…
