I’m reading a lot about PulseAudio/Pipewire problems in the discussion. That’s why I haven’t updated yet. I checked inxi -Ax which confirms I seem to be running PulseAudio but Pipewire is installed as well.
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
driver: snd_hda_intel v: kernel bus-ID: 08:00.1
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 0a:00.4
API: ALSA v: k6.6.80-1-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.2.7 status: off
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
Will I run into the same described problems?
I’ve never meddled with the sound system myself. It’s all stock like how it came since installing Manjaro in '23 and doing all the ‘Stable updates’ over time.
Is installing manjaro-pipewire the recommend solution (as @jezek writes in his/her post) for cases with running PulseAudio but existing Pipewire installation? Should this be done prior to the stable update?
Is Pipewire the go-to solution now or do you recommend staying with PulseAudio?
EDIT: I have to add that I’m not an audio guru or run any sound editing software. The fanciest audio thing I’ve done is playing some mp3’s with MPV. ![]()
