I got a small issue, but running sudo pacman-mirrors -c Germany
before upgrading worked for me. Probably not all mirrors haven’t seeded this update yet.
It seems that after this update all widgets are gone from my desktop. One of them - “sticky note” - had a plenty of data on it… Not so critical but please take it into account
After this update, google-chrome
does not load.
I removed ~/.config/google-chrome
and ~/.cache/google-chrome
. Then, it works but when I login into my google account the browser crashes after 5 seconds and goes into not-responding mode! I’ve also tried --disable-gpu
and --disable-software-rasterizer
switches but they didn’t help.
When I use strace
to follow system calls it get stuck in the following line:
futex(0x560a482d80e0, FUTEX_WAIT_PRIVATE, 2, NULL
Any suggestion are welcome.
I agree the discussion is only moderately offensive compared to other comments elsewhere
But I do not recall other comments being linked to a Manjaro release announcement
The 2 incorrect allegations are not KDE-specific and could be deemed insulting/defamatory to the Manjaro community
IMO those comments appear to be strategic equivocation that is counterproductive to, and distracting from, the core KDE issues
If the off-topic comments about Manjaro community were removed I would have no further interest in the KDE-specific issues
… and weren’t pursued further in the discussion …
If I were to open a website against fake news (let’s call it: “What the fact!”) I could list the original post from over there. But I could as well get a package of sugar and travel to the Atlantic trying to make a sweet water out of it, no?
I think there is one good thing that we can learn from politicians: if it does not escalate, ignore it.
After upgrading I can not start Openshot. If I try to start it from a terminal I get the following message ( I use MATE Desktop)
openshot-qt %F or /usr/bin/openshot-qt
Loaded modules from: /usr/lib/python3.9/site-packages/openshot_qt
INFO app: ------------------------------------------------
INFO app: Tue Oct 19 09:11:22 2021
INFO app: Starting new session
ERROR app: OpenShotApp::Import Error
File "/usr/lib/python3.9/site-packages/openshot_qt/classes/app.py", line 99, in __init__
from classes import settings, project_data, updates
File "/usr/lib/python3.9/site-packages/openshot_qt/classes/project_data.py", line 48, in <module>
import openshot
File "/usr/lib/python3.9/site-packages/openshot.py", line 15, in <module>
import _openshot
ImportError: /usr/lib/libopenshot.so.21: undefined symbol: _ZN2cv3dnn14dnn4_v202106083Net20setPreferableBackendEi
File "/usr/bin/openshot-qt", line 33, in <module>
sys.exit(load_entry_point('openshot-qt==2.6.1', 'gui_scripts', 'openshot-qt')())
File "/usr/lib/python3.9/site-packages/openshot_qt/launch.py", line 186, in main
app = OpenShotApp(argv)
import openshot
import _openshot
INFO app: OpenShot's session ended
INFO app: ================================================
Bug in kio-extras. Fixed-in: 21.08.3
Bug 443983 - khelpcenter man:btrfs-replace(8)
SUMMARY
error in opening man page
STEPS TO REPRODUCE
- open Help
- type “btrfs-replace” in search field and press enter
- go to page “man:btrfs-replace(8)”
OBSERVED RESULT
Error dialog box
EXPECTED RESULT
man page
SOFTWARE/OS VERSIONS
Windows:
macOS:
Linux/KDE Plasma:
(available in About System)
KDE Plasma Version: 5.22.5
KDE Frameworks Version: 5.87.0
Qt Version: 5.15.2ADDITIONAL INFORMATION
I switched today from 5.10 LTSC to 5.14 stable branch and get a new error from journalctl -p 3 -xb:
-- Journal begins at Wed 2021-04-28 04:57:37 CEST, ends at Tue 2021-10-19 22:04:51 CEST. --
Oct 19 22:03:22 koboldx-z170 kernel: x86/cpu: SGX disabled by BIOS.
Anyone know what that means?
Other than one minor issue, went well, didn’t notice anything. Unlike last time, the 5.13 kernel wasn’t forced, so I ended up still running 5.10 (which I want, because otherwise I seem to lose sound).
The minor issue: Just like after the previous update, when I click Sleep
in the Application Launcher, I don’t see the confirmation menu which I still see when I want to restart. The computer goes directly to sleep.
there is an issue with firefox and kde after the latest update. while using several opened windows/instances of firefox it appears that frequently one window gets transparent and does not respond anymore. i can close all other instances but this one will stay on, its not shown up if i search with ‘ps -ax | grep fire*’ in the console, so i get no pid to kill it.
Qt Version: 5.15.2
Kernel Version: 5.14.10-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 8 × Intel® Core™ i5-8300H CPU @ 2.30GHz
Memory: 31.2 GiB of RAM
Graphics Processor: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 ```
Everything went smoothly, but somethings happened to SSL certificates, and now filezilla won’t connect to any servers.
Error: Failed to extract certificate trust path
I tried some linux guides but I need manjaro specific…any help please?
I have no experience with this, but I did find this online - https://www.tenforums.com/antivirus-firewalls-system-security/101389-sgx-setting-choose-bios.html
Maybe the new kernel is just reporting this feature’s (SGX) status now. Just a guess on my part.
I’m seeing issues connecting to my phone with KDE Connect since the update. My phone will be online but not recognize that my computer is and my computer says my phone isn’t online.
- Your computer and phone must be in the same location network (IP range).
- Try to disable KDE firewall.
The articel shows thats a feature from CPU’s above kabylake, but i have skylake.
The message you’re getting, SGX disabled by BIOS, indicates SGX is supported on your system. Is this condition causing a problem or are you just curious about the message ?
I’m just curious about it. I just want to know if this could lead to a security problem.
Hm, why your favorite search engine fails to show you that on whole Internet?
Consider try a better than yours: kernel x86 cpu SGX disabled by BIOS at DuckDuckGo shows the Kernel reports 2 intel module error messages on every boot / Kernel & Hardware / Arch Linux Forums as first item. Or that was not enough?
I had a scary Nvidia GPU issue on my system since updating, I think I should share it here.
