Unfortunately, before I proceed to download the update I get this message on pamac GUI.
conflicting dependencies:
- virtualbox-guest-utils and virtualbox-guest-utils-nox are in conflict
What should be done in this case?
Hello, I had the same issue, just try installing plasma-desktop with :
sudo pacman -S plasma-desktop
And when it asks you to replace it because it is in conflict with primex, choose yes.
Hello, i had the nvidia problem with the black screen on boot. Using dual 1440p monitors with DP. Seems that the new nvidia-āstableā update pushed is not very āstableā at the end. Well, iāll downgrading the nvidia drivers when i have a chance.
Hi,
The update went fine but I still have the amd gpu issue and the solution you give doesnāt work for me, it makes my laptop freeze at the asus boot screen, so I had to chroot to bring eveerything back to ānormalā, I did this change in /etc/default/grub btw :
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3 amdgpu.dc=0"
I havenāt updated yet, but as an nvidia GTX 1080 user with 2 displayport monitors, all these reports make me a bit nervous. Would it be worth holding off on updating until a working driver is released?
My DP monitors are both 1080p by the way, with an additional 1080p monitor connected by DVI. It does seem like most of the people running into issues with DP are either running high resolution or high refresh rate monitors. Can anyone confirm whether 1080p monitors connected via DP are causing problems?
Update: Since installing your build of PipeWire 0.3.28, Iāve had 5 zoom meetings, slept overnight with my PC idle, watched several YouTube videos, switched between my speakers and my headphones many times, rebooted once for an unrelated reason, and been running PulseEffects the whole time, with it affecting both speaker output (equalizer) and microphone input (RNNoise noise reduction). At no time so far has the audio stopped working, with either recording or playback. I think for me personally, itās safe to say that PipeWire 0.3.28 is significantly more stable and usable than 0.3.26 and 0.3.27 were. I have not had to manually restart it or PulseEffects once.
That being said, I have not tested Bluetooth audio equipment, since I donāt use any Bluetooth audio equipment currently. For audio output (playback), I use 3.5mm jack output directly from my motherboard for my speakers and headphones, and for audio input (recording), I use a small USB sound card with its own 3.5mm jack into which I plug my microphone. So, my test results in this post are for handling USB and motherboard 3.5mm audio jacks only.
yea, you have to choose yes.
Also try the following commands, as it looks like that should fix the issue:
sudo pacman -Rdd plasma-desktop-primex
sudo pacman -Syu plasma-desktop
(28/34) Changing NetworkManager Connectivity-Ping to manjaro.org
what??
Thanks. Rebuilt compiz-easy-patch and it still isnāt starting.
Iāve just run the update and got the same message, Iām going to choose not to upgrade virtualbox-guest-utils-nox or perhaps virtualbox altogether at this time and see if I can find another solution.
Have you had any luck resolving this issue yet? If so, would you care to share please.
Thanks in advance
Update : So I had to remove virtualbox and its dependencies, reboot the computer - then I could run this update without any problems. Have re-installed virtualbox but wont test it until tomorrow.
Mine was 1080 display port on a 1060 6gb, produced a no-boot situation, not a black screen situation
If you note, the warning states, DP and/or high res
Had to rescue with liveUSB and chroot
I rebooted it, and sddm failed to load its theme. After I logged in, it brought me to a black screen only with a mouse cursor.
EDIT: I re-installed KDE Plasma and it still remained the same.
EDIT 2: I removed all the git packages and installed non-git alternatives. Now itās finally working.
alright yeah, I suspected as much. thanks for letting me know, looks like Iāll be avoiding this update for the time being.
Xfce, Kernel 4.14.
I just want to say that Iām using Pamac 10.1.2-2
(installed from testing branch) and despite this minor bug (Title bar buttons are not fully visible. (#1037) Ā· Issues Ā· Applications / pamac Ā· GitLab) works flawlessly:
Thatās easy - to rewind a backup, if itās broken you can restore your backup. Everyone keeps a backup of system/config files, donāt they?
Snap - sticky this one!!! Brings back the feeling I had using PPAās back with Linux Mint - inviting the broken system.
Iām using pipewire and, after this update, my sound doesnāt work when I resume from suspend. Is anyone else experiencing this?
Kernel: 5.4.118-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
Type: Desktop System: Micro-Star product: MS-7B51 v: 1.0 serial: <filter>
Mobo: Micro-Star model: MPG Z390 GAMING PLUS (MS-7B51) v: 1.0
serial: <filter> UEFI: American Megatrends v: 1.10 date: 08/22/2018
Device-1: hidpp_battery_0 model: Logitech K520 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M510 serial: N/A
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Info: 6-Core model: Intel Core i7-8700K bits: 64 type: MT MCP
arch: Kaby Lake note: check rev: A cache: L2: 12 MiB
bogomips: 88824
Speed: 800 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Device-1: NVIDIA TU106 [GeForce RTX 2070 Rev. A] vendor: Micro-Star MSI
driver: nvidia v: 460.80 bus-ID: 01:00.0 chip-ID: 10de:1f07 class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-5:5 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.11 driver: loaded: nvidia resolution:
1: 2560x1440 2: 1920x1080~75Hz s-dpi: 96
OpenGL: renderer: GeForce RTX 2070/PCIe/SSE2 v: 4.6.0 NVIDIA 460.80
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a348
class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
Device-3: JMTek LLC. JOUNIVO JV605PRO type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:3 chip-ID: 0c76:605d
class-ID: 0300 serial: <filter>
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.4.118-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.27 running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: 3.2.6-k port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Device-2: Realtek RTL88x2bu [AC1200 Techkey] type: USB driver: rtl88x2bu
bus-ID: 1-10:9 chip-ID: 0bda:b812 class-ID: 0000 serial: <filter>
IF: wlp0s20f0u10 state: up mac: <filter>
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-4.3:8 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 1.42 TiB used: 138.13 GiB (9.5%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDH31000G size: 931.51 GiB
speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 70RL scheme: GPT
ID-2: /dev/sdb vendor: SanDisk model: SDSSDH3500G size: 465.76 GiB
ID-3: /dev/sdc type: USB vendor: Generic model: Flash Disk size: 58.59 GiB
rotation: SSD serial: <filter> rev: 8.07 scheme: MBR
ID-1: / size: 34.18 GiB used: 20.81 GiB (60.9%) fs: btrfs dev: /dev/sda3
ID-2: /boot/efi size: 123 MiB used: 562 KiB (0.4%) fs: vfat dev: /dev/sda1
ID-3: /home size: 874.36 GiB used: 117.31 GiB (13.4%) fs: ext4
dev: /dev/sda4
ID-4: /var/log size: 34.18 GiB used: 20.81 GiB (60.9%) fs: btrfs
dev: /dev/sda3
ID-1: swap-1 type: partition size: 7.81 GiB used: 17.3 MiB (0.2%)
priority: -2 dev: /dev/sda2
System Temperatures: cpu: 49.0 C mobo: N/A gpu: nvidia temp: 62 C
Processes: 358 Uptime: 8h 17m wakeups: 216 Memory: 15.58 GiB
used: 3.91 GiB (25.1%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: pacman: 1252 Shell: Zsh v: 5.8 running-in: xfce4-terminal
inxi: 3.3.04
So, Iām probably a prime candidate for this nvidia issue. DP and 4K monitors
Before I upgrade, do you recommend just ignoring the nvidia packages, to be on the safe side? Will that side step the issue?
So these are the nvidia packages I see that it wants to upgrade. I can add them to the āignore upgrades forā list:
nvidia-utils
mhwd-nvidia
lib32-nvidia-utils
and the various kernel ones like linux512-nvidia
Am I missing one? Can someone confirm? The main one Iām iffy about is the kernel ones like linux512-nvidia.
