[Stable Update] 2020-02-10 - Kernels, KDE Apps, Gnome Settings
Hello community,
here is another Stable Update.
With Pamac 9.4 series we added flatpak support ...
Some feature-updates:
  • Most of the Kernels got updated
  • KDE Apps got updated to 19.12.2
  • Small adjustments to the upcoming Gnome Edition
  • The usual upstream fixes
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev, which we build on a regular basis against kde-git master packages. Also check out our current 19.0-pre5 ISOs and give us the needed feedback. You might also want to give our latest spin with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch updated their default compression to zstd. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
wget https://pkgbuild.com/~eschwartz/repo/x86_64-extracted/pacman-static
chmod +x pacman-static
sudo ./pacman-static -Syyu
Our current supported kernels
  • linux316 3.16.81
  • linux44 4.4.213
  • linux49 4.9.213
  • linux414 4.14.170
  • linux419 4.19.102
  • linux53 5.3.18 [EOL]
  • linux54 5.4.18
  • linux55 5.5.2
  • linux419-rt 4.19.94_rt39
  • linux54-rt 5.4.10_rt5
Package Changes (Fri Feb 7 09:34:20 CET 2020)
  • stable community x86_64: 112 new and 110 removed package(s)
  • stable core x86_64: 20 new and 20 removed package(s)
  • stable extra x86_64: 325 new and 325 removed package(s)
  • stable multilib x86_64: 5 new and 5 removed package(s)
:: Different overlay package(s) in repository community x86_64
                             PACKAGE           2020-02-06           2020-02-10
                             cpu-x 3.2.4.r179.gf42551e-1 3.2.4.r180.g18c5027-1
                         edid-decode       r386.c29b943-1       r388.b27dc54-1
                              etcher             1.5.73-1             1.5.76-1
           gnome-layout-switcher-dev              0.6.6-2                    -
                            libcpuid 0.4.1.r26.g7b36063-1 0.4.1.r29.g5f6a9bf-1
manjaro-gnome-extension-settings-17.0          20181012-1                    -
manjaro-gnome-extension-settings-18.0          20200130-1           20200206-1
         manjaro-gnome-settings-17.0           20181012-1                    -
         manjaro-gnome-settings-18.0           20200130-1           20200206-1
:: Different sync package(s) in repository community x86_64
                      acpi_call-dkms            1.1.0-283            1.1.0-286
                         aircrack-ng              1.5.2-1                1.6-1
                             aws-cli             1.17.9-1            1.17.11-1
                           bleachbit                3.0-2              3.2.0-1
                               broot             0.12.2-1             0.13.0-1
                             certbot              1.1.0-1              1.2.0-1
                      certbot-apache              1.1.0-1              1.2.0-1
              certbot-dns-cloudflare              1.1.0-1              1.2.0-1
                certbot-dns-cloudxns              1.1.0-1              1.2.0-1
            certbot-dns-digitalocean              1.1.0-1              1.2.0-1
                certbot-dns-dnsimple              1.1.0-1              1.2.0-1
             certbot-dns-dnsmadeeasy              1.1.0-1              1.2.0-1
                  certbot-dns-gehirn              1.1.0-1              1.2.0-1
                  certbot-dns-google              1.1.0-1              1.2.0-1
                  certbot-dns-linode              1.1.0-1              1.2.0-1
                  certbot-dns-luadns              1.1.0-1              1.2.0-1
                   certbot-dns-nsone              1.1.0-1              1.2.0-1
                     certbot-dns-ovh              1.1.0-1              1.2.0-1
                 certbot-dns-rfc2136              1.1.0-1              1.2.0-1
                 certbot-dns-route53              1.1.0-1              1.2.0-1
             certbot-dns-sakuracloud              1.1.0-1              1.2.0-1
                       certbot-nginx              1.1.0-1              1.2.0-1
                              choqok              1.6.0-2              1.7.0-1
                             clojure             1.10.1-3             1.10.1-4
                             cockpit              211.1-1                212-1
                   cockpit-dashboard              211.1-1                212-1
                         cockpit-pcp              211.1-1                212-1
                      cockpit-podman                 12-1                 13-1
                              cython            0.29.14-4            0.29.15-1
                             cython2            0.29.14-4            0.29.15-1
                                dino              0.1.0-2              0.1.0-3
                              erlang               22.2-1             22.2.4-1
                          erlang-nox               22.2-1             22.2.4-1
                     erlang-unixodbc               22.2-1             22.2.4-1
                 firefox-dark-reader              4.8.8-1              4.8.9-1
               firefox-ublock-origin             1.24.2-1             1.24.4-1
                                gqrx             2.11.5-9             2.12.1-1
                             grafana              6.6.0-1              6.6.1-1
                                grpc             1.26.0-4             1.27.0-2
                            grpc-cli             1.26.0-4             1.27.0-2
                            gsignond              1.2.0-2              1.2.0-3
                               gummi            2:0.8.0-1            2:0.8.1-1
                      home-assistant            0.104.3-1            0.105.2-1
                                hugo             0.63.2-1             0.64.0-1
                              hwinfo              21.68-1              21.68-2
                                josm              15628-1              15806-1
                                 k9s             0.13.6-1             0.13.8-1
                          libalkimia              8.0.2-2              8.0.3-1
                              libasr              1.0.3-1              1.0.4-1
                           libmysofa              0.9.1-1                1.0-1
                           libx86emu                2.4-1                3.1-1
                                nrpe              3.2.1-3              4.0.0-1
                          obs-studio             24.0.5-2             24.0.6-1
                               opera       66.0.3515.44-1       66.0.3515.72-1
                            opusfile               0.11-1               0.11-2
                            pageedit              1.0.0-1              1.1.0-1
                     parity-ethereum              2.7.1-1              2.7.2-1
         perl-alien-base-modulebuild               1.08-1               1.10-1
                    perl-net-dns-sec               1.14-1               1.15-1
                            php-grpc             1.26.0-4             1.27.0-2
                         php-mongodb              1.7.0-1              1.7.1-1
                           plan9port           20190923-1           20200205-1
                         python-acme              1.1.0-1              1.2.0-1
                        python-boto3             1.11.9-1            1.11.11-1
                     python-botocore             1.14.9-1            1.14.11-1
                       python-docker              4.1.0-3              4.2.0-1
                  python-flask-babel             0.12.2-4              1.0.0-1
                       python-grpcio             1.26.0-4             1.27.0-2
                        python-jieba               0.42-1             0.42.1-1
                  python-marshmallow              3.3.0-1              3.4.0-1
               python-musicbrainzngs                0.6-6              0.7.1-1
              python-mysql-connector             8.0.18-3             8.0.19-2
                      python-pexpect              4.7.0-3              4.8.0-1
            python-typing_extensions              3.7.4-4            3.7.4.1-1
                     python-waitress              1.4.2-1              1.4.3-1
               python-wsgi-intercept              1.9.1-1              1.9.2-1
                     python2-pexpect              4.7.0-3              4.8.0-1
                    python2-waitress              1.4.2-1              1.4.3-1
                         rawtherapee              1:5.7-3              1:5.8-1
          riscv64-linux-gnu-binutils             2.33.1-1               2.34-1
                              rspamd                2.2-1                2.3-1
                             shotcut           19.12.23-1           19.12.31-1
                               sigil              1.0.0-1              1.1.0-1
                           skk-jisyo           20191208-1           20200202-1
                                 snd               20.0-1               20.1-1
                            soapyuhd              0.3.4-6              0.3.4-7
                           sqlcipher              4.2.0-1              4.3.0-1
                                sway              1:1.4-6              1:1.4-7
                           syncthing              1.3.3-1              1.3.4-1
                  syncthing-relaysrv              1.3.3-1              1.3.4-1
                               tdlib              0.5.0-3              0.5.0-4
                         tidalcycles              1.4.7-5              1.4.8-1
                                 tlp              1.3.0-2              1.3.1-1
                             tlp-rdw              1.3.0-2              1.3.1-1
                  ttf-jetbrains-mono              1.0.1-1              1.0.2-1
                                 upx               3.95-1               3.96-1
         v2ray-domain-list-community       202002011020-1       202002051516-1
                         v2ray-geoip       202002040102-1       202002050239-1
                              viking                1.7-3                1.8-1
                                yarn             1.21.1-1             1.22.0-1
                               zcash              2.1.1-2            2.1.1_1-1
                                crun                    -               0.12-1
                            easyjson                    -              0.7.0-1
                       python-snappy                    -              0.5.4-1
                              srslte                    -              19.12-1
                         srslte-avx2                    -              19.12-1
:: Different overlay package(s) in repository core x86_64
                       amd-ucode   20200204.c2df39a-1 20200206.r1574.5351afe-1
                  linux-firmware   20200204.c2df39a-1 20200206.r1574.5351afe-1
                            linux414           4.14.169-1           4.14.170-1
                    linux414-headers           4.14.169-1           4.14.170-1
                            linux419           4.19.101-1           4.19.102-1
                    linux419-headers           4.19.101-1           4.19.102-1
                             linux44            4.4.212-1            4.4.213-1
                     linux44-headers            4.4.212-1            4.4.213-1
                             linux49            4.9.212-1            4.9.213-1
                     linux49-headers            4.9.212-1            4.9.213-1
                             linux54             5.4.17-1             5.4.18-1
                     linux54-headers             5.4.17-1             5.4.18-1
:: Different sync package(s) in repository core x86_64
                               bison                3.5-1              3.5.1-1
                              gnutls           3.6.11.1-1             3.6.12-1
                            iana-etc           20191231-1           20200117-1
                            libtasn1             4.15.0-1             4.16.0-1
                                make              4.2.1-4                4.3-1
                                nspr               4.24-1               4.25-1
                              s-nail            14.9.16-2            14.9.17-1
                              shadow                4.8-1              4.8.1-1
:: Different overlay package(s) in repository extra x86_64
                  linux414-acpi_call            1.1.0-141            1.1.0-142
                   linux414-bbswitch              0.8-141              0.8-142
                linux414-broadcom-wl     6.30.223.271-141     6.30.223.271-142
                linux414-ndiswrapper              1.62-36              1.62-37
               linux414-nvidia-340xx           340.108-10           340.108-11
               linux414-nvidia-390xx           390.132-18           390.132-19
               linux414-nvidia-430xx            430.64-16            430.64-17
               linux414-nvidia-435xx            435.21-26            435.21-27
               linux414-nvidia-440xx             440.59-1             440.59-3
                   linux414-nvidiabl             0.88-141             0.88-142
                      linux414-r8168           8.048.00-4           8.048.00-5
                  linux414-rt3562sta       2.4.1.1_r4-141       2.4.1.1_r4-142
                   linux414-tp_smapi              0.43-33              0.43-34
                linux414-vhba-module           20200106-4           20200106-5
   linux414-virtualbox-guest-modules              6.1.2-5              6.1.2-6
    linux414-virtualbox-host-modules              6.1.2-5              6.1.2-6
                        linux414-zfs              0.8.3-3              0.8.3-4
                  linux419-acpi_call             1.1.0-91             1.1.0-92
                   linux419-bbswitch               0.8-91               0.8-92
                linux419-broadcom-wl      6.30.223.271-90      6.30.223.271-91
                linux419-ndiswrapper              1.62-40              1.62-41
               linux419-nvidia-340xx           340.108-11           340.108-12
               linux419-nvidia-390xx           390.132-20           390.132-21
               linux419-nvidia-418xx           418.113-19           418.113-20
               linux419-nvidia-430xx            430.64-19            430.64-20
               linux419-nvidia-435xx            435.21-30            435.21-31
               linux419-nvidia-440xx             440.59-1             440.59-2
                   linux419-nvidiabl              0.88-90              0.88-91
                      linux419-r8168           8.048.00-5           8.048.00-6
                  linux419-rtl8723bu           20200126-2           20200126-3
                   linux419-tp_smapi              0.43-40              0.43-41
                linux419-vhba-module           20200106-5           20200106-6
   linux419-virtualbox-guest-modules              6.1.2-6              6.1.2-7
    linux419-virtualbox-host-modules              6.1.2-6              6.1.2-7
                        linux419-zfs              0.8.3-4              0.8.3-5
                   linux44-acpi_call            1.1.0-142            1.1.0-143
                    linux44-bbswitch              0.8-142              0.8-143
                 linux44-broadcom-wl     6.30.223.271-112     6.30.223.271-113
                 linux44-ndiswrapper              1.62-24              1.62-25
                linux44-nvidia-340xx            340.108-6            340.108-7
                linux44-nvidia-390xx           390.132-12           390.132-13
                linux44-nvidia-418xx           418.113-11           418.113-12
                linux44-nvidia-430xx            430.64-10            430.64-11
                linux44-nvidia-435xx            435.21-12            435.21-13
                linux44-nvidia-440xx             440.59-1             440.59-3
                    linux44-nvidiabl             0.88-142             0.88-143
                       linux44-r8168           8.048.00-3           8.048.00-4
                    linux44-tp_smapi              0.43-21              0.43-22
                 linux44-vhba-module           20200106-3           20200106-4
    linux44-virtualbox-guest-modules              6.1.2-3              6.1.2-4
     linux44-virtualbox-host-modules              6.1.2-3              6.1.2-4
                         linux44-zfs              0.8.3-1              0.8.3-3
                   linux49-acpi_call            1.1.0-156            1.1.0-157
                    linux49-bbswitch              0.8-156              0.8-157
                 linux49-broadcom-wl     6.30.223.271-156     6.30.223.271-157
                 linux49-ndiswrapper              1.62-26              1.62-27
                linux49-nvidia-340xx            340.108-6            340.108-7
                linux49-nvidia-390xx           390.132-13           390.132-14
                linux49-nvidia-418xx           418.113-12           418.113-13
                linux49-nvidia-430xx            430.64-11            430.64-12
                linux49-nvidia-435xx            435.21-18            435.21-19
                linux49-nvidia-440xx             440.59-1             440.59-2
                    linux49-nvidiabl             0.88-156             0.88-157
                       linux49-r8168           8.048.00-3           8.048.00-4
                    linux49-tp_smapi              0.43-24              0.43-25
                 linux49-vhba-module           20200106-3           20200106-4
    linux49-virtualbox-guest-modules              6.1.2-3              6.1.2-4
     linux49-virtualbox-host-modules              6.1.2-3              6.1.2-4
                         linux49-zfs              0.8.3-2              0.8.3-3
                   linux54-acpi_call             1.1.0-20             1.1.0-21
                    linux54-bbswitch               0.8-20               0.8-21
                 linux54-broadcom-wl      6.30.223.271-20      6.30.223.271-21
                 linux54-ndiswrapper              1.62-20              1.62-21
                linux54-nvidia-340xx           340.108-12           340.108-13
                linux54-nvidia-390xx           390.132-20           390.132-21
                linux54-nvidia-418xx           418.113-20           418.113-21
                linux54-nvidia-430xx            430.64-20            430.64-21
                linux54-nvidia-435xx            435.21-20            435.21-21
                linux54-nvidia-440xx             440.59-1             440.59-2
                    linux54-nvidiabl              0.88-20              0.88-21
                       linux54-r8168           8.048.00-5           8.048.00-6
                   linux54-rtl8723bu           20200126-2           20200126-3
                    linux54-tp_smapi              0.43-20              0.43-21
                 linux54-vhba-module           20200106-5           20200106-6
    linux54-virtualbox-guest-modules              6.1.2-6              6.1.2-7
     linux54-virtualbox-host-modules              6.1.2-6              6.1.2-7
                         linux54-zfs              0.8.3-4              0.8.3-5
                          webkit2gtk           2.26.2-2.1                    -
                           boxit-arm                    -              2.1.3-1
:: Different sync package(s) in repository extra x86_64
                             akonadi            19.12.1-2            19.12.2-1
                    akonadi-calendar            19.12.1-1            19.12.2-1
              akonadi-calendar-tools            19.12.1-1            19.12.2-1
                    akonadi-contacts            19.12.1-1            19.12.2-1
               akonadi-import-wizard            19.12.1-1            19.12.2-1
                        akonadi-mime            19.12.1-1            19.12.2-1
                       akonadi-notes            19.12.1-1            19.12.2-1
                      akonadi-search            19.12.1-1            19.12.2-1
                      akonadiconsole            19.12.1-1            19.12.2-1
                           akregator            19.12.1-1            19.12.2-1
                            analitza            19.12.1-1            19.12.2-1
                                 ark            19.12.1-1            19.12.2-1
                          artikulate            19.12.1-1            19.12.2-1
                         audiocd-kio            19.12.1-1            19.12.2-1
                        avogadrolibs             1.92.1-1             1.93.0-1
                       baloo-widgets            19.12.1-1            19.12.2-1
                             blinken            19.12.1-1            19.12.2-1
                              bomber            19.12.1-1            19.12.2-1
                                bovo            19.12.1-1            19.12.2-1
                     calendarsupport            19.12.1-1            19.12.2-1
                              cantor            19.12.1-1            19.12.2-1
                            cervisia            19.12.1-1            19.12.2-1
                               cmake             3.16.3-1             3.16.4-1
                             dolphin            19.12.1-1            19.12.2-1
                     dolphin-plugins            19.12.1-1            19.12.2-1
                              dragon            19.12.1-1            19.12.2-1
                               elisa            19.12.1-1            19.12.2-1
                          eventviews            19.12.1-1            19.12.2-1
                        ffmpegthumbs            19.12.1-1            19.12.2-1
                           filelight            19.12.1-1            19.12.2-1
                             flatpak              1.6.0-1              1.6.1-1
                  foomatic-db-engine           4:4.0.13-1         4:20200206-1
                           granatier            19.12.1-1            19.12.2-1
                     grantlee-editor            19.12.1-1            19.12.2-1
                       grantleetheme            19.12.1-1            19.12.2-1
                            gwenview            19.12.1-1            19.12.2-1
                     incidenceeditor            19.12.1-1            19.12.2-1
                                 juk            19.12.1-1            19.12.2-1
                                 k3b          1:19.12.1-1          1:19.12.2-1
               kaccounts-integration            19.12.1-1            19.12.2-1
                 kaccounts-providers            19.12.1-2            19.12.2-1
                        kaddressbook            19.12.1-1            19.12.2-1
                             kajongg            19.12.1-1            19.12.2-1
                              kalarm            19.12.1-1            19.12.2-1
                           kalarmcal            19.12.1-1            19.12.2-1
                            kalgebra            19.12.1-1            19.12.2-1
                             kalzium            19.12.1-1            19.12.2-1
                              kamera            19.12.1-1            19.12.2-1
                              kamoso            19.12.1-1            19.12.2-1
                            kanagram            19.12.1-1            19.12.2-1
                              kapman            19.12.1-1            19.12.2-1
                        kapptemplate            19.12.1-1            19.12.2-1
                                kate            19.12.1-1            19.12.2-1
                             katomic            19.12.1-1            19.12.2-1
                             kbackup            19.12.1-1            19.12.2-1
                           kblackbox            19.12.1-1            19.12.2-1
                             kblocks            19.12.1-1            19.12.2-1
                               kblog            19.12.1-1            19.12.2-1
                             kbounce            19.12.1-1            19.12.2-1
                           kbreakout            19.12.1-1            19.12.2-1
                              kbruch            19.12.1-1            19.12.2-1
                         kcachegrind            19.12.1-1            19.12.2-1
                  kcachegrind-common            19.12.1-1            19.12.2-1
                               kcalc            19.12.1-1            19.12.2-1
                           kcalutils            19.12.1-1            19.12.2-1
                         kcharselect            19.12.1-1            19.12.2-1
                       kcolorchooser            19.12.1-1            19.12.2-1
                               kcron            19.12.1-1            19.12.2-1
                                kdav            19.12.1-1            19.12.2-1
                     kde-dev-scripts            19.12.1-1            19.12.2-1
                       kde-dev-utils            19.12.1-1            19.12.2-1
                      kdebugsettings            19.12.1-1            19.12.2-1
                         kdeedu-data            19.12.1-1            19.12.2-1
              kdegraphics-mobipocket            19.12.1-1            19.12.2-1
            kdegraphics-thumbnailers            19.12.1-1            19.12.2-1
              kdenetwork-filesharing            19.12.1-1            19.12.2-1
                            kdenlive            19.12.1-3            19.12.2-1
                       kdepim-addons            19.12.1-1            19.12.2-1
                    kdepim-apps-libs            19.12.1-1            19.12.2-1
                      kdepim-runtime            19.12.1-1            19.12.2-1
                    kdesdk-kioslaves            19.12.1-1            19.12.2-1
                 kdesdk-thumbnailers            19.12.1-1            19.12.2-1
                                 kdf            19.12.1-1            19.12.2-1
                             kdialog            19.12.1-1            19.12.2-1
                            kdiamond            19.12.1-1            19.12.2-1
                      keditbookmarks            19.12.1-1            19.12.2-1
                               kfind            19.12.1-1            19.12.2-1
                             kfloppy            19.12.1-1            19.12.2-1
                         kfourinline            19.12.1-1            19.12.2-1
                          kgeography            19.12.1-1            19.12.2-1
                                kget            19.12.1-1            19.12.2-1
                         kgoldrunner            19.12.1-1            19.12.2-1
                                kgpg            19.12.1-1            19.12.2-1
                            khangman            19.12.1-1            19.12.2-1
                         khelpcenter            19.12.1-1            19.12.2-1
                 kidentitymanagement            19.12.1-1            19.12.2-1
                                 kig            19.12.1-2            19.12.2-1
                                kigo            19.12.1-1            19.12.2-1
                            killbots            19.12.1-1            19.12.2-1
                     kimagemapeditor            19.12.1-1            19.12.2-1
                               kimap            19.12.1-1            19.12.2-1
                          kio-extras            19.12.1-1            19.12.2-1
                        kipi-plugins            19.12.1-1            19.12.2-1
                    kirigami-gallery            19.12.1-1            19.12.2-1
                              kiriki            19.12.1-1            19.12.2-1
                               kiten            19.12.1-1            19.12.2-1
                          kitinerary            19.12.1-3            19.12.2-1
                        kjumpingcube            19.12.1-1            19.12.2-1
                               kldap            19.12.1-1            19.12.2-1
                           kleopatra            19.12.1-1            19.12.2-1
                            klettres            19.12.1-1            19.12.2-1
                            klickety            19.12.1-1            19.12.2-1
                              klines            19.12.1-1            19.12.2-1
                                kmag            19.12.1-1            19.12.2-1
                           kmahjongg            19.12.1-1            19.12.2-1
                               kmail            19.12.1-1            19.12.2-1
                kmail-account-wizard            19.12.1-1            19.12.2-1
                      kmailtransport            19.12.1-1            19.12.2-1
                               kmbox            19.12.1-1            19.12.2-1
                               kmime            19.12.1-1            19.12.2-1
                              kmines            19.12.1-1            19.12.2-1
                                kmix            19.12.1-1            19.12.2-1
                          kmousetool            19.12.1-1            19.12.2-1
                              kmouth            19.12.1-1            19.12.2-1
                              kmplot            19.12.1-1            19.12.2-1
                        knavalbattle            19.12.1-1            19.12.2-1
                            knetwalk            19.12.1-1            19.12.2-1
                             knights            19.12.1-1            19.12.2-1
                              knotes            19.12.1-1            19.12.2-1
                                kolf            19.12.1-1            19.12.2-1
                           kollision            19.12.1-1            19.12.2-1
                         kolourpaint            19.12.1-1            19.12.2-1
                             kompare            19.12.1-1            19.12.2-1
                           konqueror            19.12.1-1            19.12.2-1
                            konquest            19.12.1-1            19.12.2-1
                             konsole            19.12.1-1            19.12.2-1
                             kontact            19.12.1-1            19.12.2-1
                    kontactinterface            19.12.1-1            19.12.2-1
                              kopete            19.12.1-1            19.12.2-1
                          korganizer            19.12.1-1            19.12.2-1
                           kpatience            19.12.1-1            19.12.2-1
                        kpimtextedit            19.12.1-1            19.12.2-1
                             kpkpass            19.12.1-1            19.12.2-1
                      kqtquickcharts            19.12.1-1            19.12.2-1
                                krdc            19.12.1-1            19.12.2-1
                            kreversi            19.12.1-1            19.12.2-1
                                krfb            19.12.1-1            19.12.2-1
                  kross-interpreters            19.12.1-1            19.12.2-1
                              kruler            19.12.1-1            19.12.2-1
                             kshisen            19.12.1-1            19.12.2-1
                               ksirk            19.12.1-1            19.12.2-1
                               ksmtp            19.12.1-1            19.12.2-1
                          ksnakeduel            19.12.1-1            19.12.2-1
                          kspaceduel            19.12.1-1            19.12.2-1
                            ksquares            19.12.1-1            19.12.2-1
                             ksudoku            19.12.1-1            19.12.2-1
                          ksystemlog            19.12.1-1            19.12.2-1
                            kteatime            19.12.1-1            19.12.2-1
                              ktimer            19.12.1-1            19.12.2-1
                               ktnef            19.12.1-1            19.12.2-1
                              ktouch            19.12.1-1            19.12.2-1
                          ktuberling            19.12.1-1            19.12.2-1
                             kturtle            19.12.1-1            19.12.2-1
                             kubrick            19.12.1-1            19.12.2-1
                       kuserfeedback             0.9.90-1              1.0.0-1
                      kwalletmanager            19.12.1-1            19.12.2-1
                               kwave            19.12.1-1            19.12.2-1
                           kwordquiz            19.12.1-1            19.12.2-1
                              kwrite            19.12.1-1            19.12.2-1
                          libakonadi            19.12.1-2            19.12.2-1
                              libcdr              0.1.5-3              0.1.6-1
                         libgravatar            19.12.1-1            19.12.2-1
                            libkcddb            19.12.1-1            19.12.2-1
                     libkcompactdisc            19.12.1-1            19.12.2-1
                           libkdcraw            19.12.1-1            19.12.2-1
                         libkdegames            19.12.1-1            19.12.2-1
                           libkdepim            19.12.1-1            19.12.2-1
                  libkeduvocdocument            19.12.1-1            19.12.2-1
                           libkexiv2            19.12.1-1            19.12.2-1
                            libkgapi            19.12.1-1            19.12.2-1
                          libkgeomap            19.12.1-1            19.12.2-1
                             libkipi            19.12.1-1            19.12.2-1
                             libkleo            19.12.1-1            19.12.2-1
                        libkmahjongg            19.12.1-1            19.12.2-1
                     libkomparediff2            19.12.1-1            19.12.2-1
                            libksane            19.12.1-1            19.12.2-1
                           libksieve            19.12.1-1            19.12.2-1
                            lokalize            19.12.1-1            19.12.2-1
                               lskat            19.12.1-1            19.12.2-1
                          mailcommon            19.12.1-1            19.12.2-1
                        mailimporter            19.12.1-1            19.12.2-1
                              marble            19.12.1-1            19.12.2-1
                       marble-common            19.12.1-1            19.12.2-1
                           marble-qt            19.12.1-1            19.12.2-1
                       mbox-importer            19.12.1-1            19.12.2-1
                          messagelib            19.12.1-1            19.12.2-1
                              minuet            19.12.1-1            19.12.2-1
                              okular            19.12.1-2            19.12.2-1
                              openal             1.20.1-1             1.20.1-2
                     openal-examples             1.20.1-1             1.20.1-2
                            palapeli            19.12.1-1            19.12.2-1
                              parley            19.12.1-1            19.12.2-1
                               picmi            19.12.1-1            19.12.2-1
                   pim-data-exporter            19.12.1-1            19.12.2-1
                    pim-sieve-editor            19.12.1-1            19.12.2-1
                           pimcommon            19.12.1-1            19.12.2-1
                               poxml            19.12.1-1            19.12.2-1
                       print-manager            19.12.1-1            19.12.2-1
                            protobuf             3.11.2-1             3.11.3-1
                     python-protobuf             3.11.2-1             3.11.3-1
                         qcachegrind            19.12.1-1            19.12.2-1
                           qtcreator             4.11.0-4             4.11.1-1
                                rocs            19.12.1-1            19.12.2-1
            signon-kwallet-extension            19.12.1-1            19.12.2-1
                           spectacle            19.12.1-1            19.12.2-1
                                step            19.12.1-1            19.12.2-1
                             svgpart            19.12.1-1            19.12.2-1
                             sweeper            19.12.1-1            19.12.2-1
          telepathy-kde-accounts-kcm            19.12.1-1            19.12.2-1
              telepathy-kde-approver            19.12.1-1            19.12.2-1
          telepathy-kde-auth-handler            19.12.1-1            19.12.2-1
               telepathy-kde-call-ui            19.12.1-1            19.12.2-1
      telepathy-kde-common-internals            19.12.1-1            19.12.2-1
          telepathy-kde-contact-list            19.12.1-1            19.12.2-1
        telepathy-kde-contact-runner            19.12.1-1            19.12.2-1
       telepathy-kde-desktop-applets            19.12.1-1            19.12.2-1
  telepathy-kde-filetransfer-handler            19.12.1-1            19.12.2-1
    telepathy-kde-integration-module            19.12.1-1            19.12.2-1
             telepathy-kde-send-file            19.12.1-1            19.12.2-1
               telepathy-kde-text-ui            19.12.1-1            19.12.2-1
                            umbrello            19.12.1-3            19.12.2-1
                      wireguard-dkms       0.0.20200128-1       0.0.20200205-1
                     wireguard-tools       1.0.20200121-1       1.0.20200206-2
                    xkeyboard-config               2.28-1               2.29-1
                               xterm                352-1                353-1
                             yakuake            19.12.1-1            19.12.2-1
                    zeroconf-ioslave            19.12.1-1            19.12.2-1
:: Different sync package(s) in repository multilib x86_64
              lib32-fontconfig 2:2.13.91+24+g75eadca-1 2:2.13.91+24+g75eadca-2
                          lib32-gtk3            3.24.13-1            3.24.13-2
                      lib32-libtasn1             4.15.0-1             4.16.0-1
                          lib32-nspr               4.24-1               4.25-1
                   lib32-openssl-1.0            1.0.2.t-1            1.0.2.u-1
0 voters
Known issues and solutions
(2020-02-14) Can't boot into a graphical session anymore
Quoting philm:
We deeply apologize for the inconvenience this error on our side may have caused.
Even if your graphical session, you should still be able to access into a TTY session with CTRL+ALT+F3 (and other similar key combo) and be able to run the command above.
Older issues
several flatpaks have issues to get a secure connection
This is a known bug and related to p11-kit update to 0.23.19. With 0.23.20-1 that issue is fixed. Please update to that version as soon our mirrors synced.
wpa_supplicant update broke Wifi for Broadcom
By enabling new features in revision 4 of v2.9 by Arch a connection with a Broadcom Wifi card was not possible anymore. This is a known bug. Either try to downgrade to revision 3 or upgrade to revision 5.
sudo pacman -U https://archive.archlinux.org/packages/w/wpa_supplicant/wpa_supplicant-2%3A2.9-3-x86_64.pkg.tar.xz
sudo pacman -U https://archive.archlinux.org/packages/w/wpa_supplicant/wpa_supplicant-2%3A2.9-5-x86_64.pkg.tar.zst
(From Arch Linux) rsync compatibility
(2020-01-15, by Christian Hesse)
(This is relevant on Manjaro, as Manjaro imports rsync package directly from Arch Linux.)
Our rsync package was shipped with bundled zlib to provide compatibility with the old-style --compress option up to version 3.1.0. Version 3.1.1 was released on 2014-06-22 and is shipped by all major distributions now.
So we decided to finally drop the bundled library and ship a package with system zlib . This also fixes security issues, actual ones and in future. Go and blame those running old versions if you encounter errors with rsync 3.1.3-3 .
Source: https://www.archlinux.org/news/rsync-compatibility/
Weird font glitches (see screenshots below).
If you have weird glitches like below...
Screenshots
string3
strings%20mismatch
... have you tried turning it off and on again?
More seriously, so far, people that reported to have such issue noticed that the problem goes away at next boot.
Installing xorgproto (2019.2-2) breaks dependency of a package
If you run into an issue because of xorgproto please DON'T follow the Arch suggestion as Manjaro uses the xorgproto-transfer package to make this automatic. If you have an issue, please report and wait for an update from us!
AUR Rebuilds required after updating python 3.7 to 3.8
Packages that depend on python from the AUR will need to be rebuilt after everything else has been updated. You can rebuild some of them with the following:
sudo pacman -S --needed --noconfirm expac yay
yay -S --rebuildtree $(pacman -Qmq $(expac %N python))
You can find other packages that need to be rebuilt by looking at the folders/files in
/usr/lib/python3.7/site-packages/
To find out what package owns a folder/file in that, you can use the following:
pacman -Qo folder_or_filename
If no package owns a file, it can probably be ignored.
System Settings and kinfocenter crash when entering Night Color settings randomly
Remove entire [NightColor] section of ~/.config/kwinrc
No solution yet ─ please edit as soon as a workaround is found.
xfce4-power-manager does not open / upower fails
Install kernel 4.14 or higher (4.14, 4.19, 5.2 [EOL], 5.3)
There is an issue with upower 0.99.11-1 on kernels 4.4 and 4.9.
xfce4-terminal / guake / gnome-terminal does not open
Update to vte3 0.58.2-1 or install kernel 4.14 or higher (4.14, 4.19, 5.2 [EOL], 5.3)
There is an issue with vte3 0.58.1-1 on kernels 4.4 and 4.9.
Replace linux52 with community/linux-latest ?
linux52 is EOL and has been removed from the repositories. It will be replaced by a metapackage which will from now on keep you on a maintained kernel.
If you want to keep the old kernel and modules then include them in your pacman.conf's IgnorePkg.
Pamac-Qt is not compatible to 9.0 API of Pamac
Pamac Qt 0.3 pre-RC: Towards the release, needs help in testing
gnome-shell-extension-desktop-icons
the pkgver 19.10.1 ship with an hook to remove the capability from gnome-shell. A message is present during install but essentially you need to reboot the system to show correctly the icons in the desktop. More info here
I would hereby also like to make the recommendation, for those of us who use btrfs, to edit your /etc/fstab and replace the default compression in the btrfs mount options from lzo to zstd.
zstd offers similarly snappy speed to lzo but with a higher compression ratio, and as you continue updating your Manjaro system and more files under /usr and /opt get replaced over time, you will start seeing a significant decrease in the amount of storage space used on your btrfs partition(s), while performance remains just as snappy as before. :wink:
Very nice on the Flatpak support in Pamac. No more need of Discover or other backends for Flatpaks.
No problems on 2 KDE machines. Thanks!
same here, update 2 KDE machine and all went smooth and fine!
3 updates on 3 computer went fine!
2 * KDE and 1 * XFCE.
Thanks!
Since this update:
journalctl -p err -b
-- Logs begin at Fri 2019-12-20 16:01:09 CET, end at Mon 2020-02-10 14:40:42 CET. --
Feb 10 14:40:29 Horizen systemd[1]: Failed to start Load AppArmor profiles.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
My fault: I installed Firefox 73 from Ubuntu .deb with "debtap".
Systemd-Manager told me "why" this error ocured...
BTW: Ubuntu contains /etc/apparmor.d/usr.bin.firefox
Manjaro does not.
You need to delete the entries:
"#include <abstractions/ubuntu-browsers.d/firefox>
and
#include <local/usr.bin.firefox>
then it works in Manjaro (FrickelFrickelFrickel...) [Solved]
No issue with the update for KDE installation on Dell Latitude E5520. The latest kernel update appears to have resolved an issue where digikam was malfunctioning (reported by some other users for the 1.30.2020 update)
Can anybody explain to me how update works or what it depends on?
I have two machines with Gnome.
LenovoP50 got full update, it looks like, kernel 5.4.18.1 while MacBook Air has still 5.4.17.1 and only few packages were updated like layouts (what is now broken)
both are setup for Germany servers.
On MacBook Air when running Syyuu it wants to update 5.4.18.1, why is that?
Possible one's mirrors is not fully synced. Do this
sudo pacman-mirrors -f 5 && sudo pacman -Syyu
Thank you I did -Syyuu cancelled while downloading then I did -Syyu and update went thru.
-Syyuu allows for downgrades. You should use -Syyu instead after refreshing the mirror list, and you should use -Syu for normal updates whereby you did not refresh the mirror list. See... :arrow_lower_left:
man pacman
... for details.
Can you elaborate on why or how that is supposed to make a difference?
Updated entire network of 5 machines. No issues to report.
As always thank you for your great work team manjaro.
regards
Well, it's very logical. :slight_smile:
When you install updates, the way pacman works is that it will remove the old package first and then install the newer package in its stead. So if you have your btrfs filesystem(s) mounted with zstd compression, then these newer packages will be installed with zstd compression, whereas the older versions were still installed with lzo compression.
Remember: the compression option set at mount time is not for reading files but for creating files. btrfs supports multiple compression algorithms for reading, and will autodetect the one in use for each file. However, for creating files, it'll use the compression algorithm set in the mount options.
I have personally seen the benefits of switching to zstd here on my system. Earlier on, my /usr filesystem ─ which is on a separate partition ─ had about 9 GiB worth of data on it, and at an earlier point in time, even over 10 GiB. Right now, after having been using zstd for a while already, only 7.7 GiB of my /usr is in use.
Of course, you cannot expect to gain the full benefit right away. A system update does not replace all packages in the system. But over time, all packages will eventually get replaced by newer versions, and these newer versions will then have been installed with zstd compression.
As I wrote higher up already, zstd is about as fast as lzo, but with the default compression ─ which is level 3 ─ you gain a significantly higher compression ratio than with lzo, without sacrificing system performance.
Gnome Layout looks incomplete.
Seems some SVG files are missing. We will upload a fixed version ...
And now, after having applied today's updates, my /usr filesystem has only 7.2 GiB worth of data on it anymore. :wink: :+1:
Had a problem with CLI sudo pamac update but I solved it with the GUI, so everything worked out
