[Stable Update] 2019-08-13 - Kernels, XFCE 4.14, KDE, LibreOffice 6.3, Discord, Mesa
This is the panel Separator. You can right-click and change the style to transparency to get rid of the line. On 4.12 the separator styles did not work so it was always transparent.
update went smoothly with tty on KDE linux52
You may use the --overwrite switch or delete those files. See also here.
cheers. I did not manage to get --overwrite to work After an hour of trying to figure out how to glob the 2 files and then finding a post that says you have to omit the leading forward slash (for some reason) Many conflicting files for pacman update it still would not work.
i ended up just deleting the 2 files then updating, seems to have worked.
Perfect update via tty.
LXQT (60 Package) with kernel 4.19 and NVIDIA nonfree
XFCE (103 Package) with Kernel 5.2 and AMD free
Thanks!
Updated all 5 machines via tty. No issues to report. And as always, excellent job team manjaro.
Greatly appreciated!
regards
I had the same error, I found that it wasn't installed through pacman but through pip so I uninstalled through pip and then updated then with pacman
Everything works fine; well done and thanks a lot
(Gnome, Kernel 5.2.8)
yea i tried pip first out, however it said pip show python-future did not exist , i also checked with yay -Qo /usr/bin/pasteurize and it said it did not belong to anything.
Linux really makes me scratch my head quite often but i'm ok now :slight_smile:
Another flawless update:
Computer: Asus ROG GL552VW Laptop
DE : KDE Plasma
Note:
After the update I left with three Orphan packages:
gtkspell3, python-pyenchant (which belonged to gaupol)
libnm-glib (which belonged to networkmanager)
I found out the first two, are no longer dependencies of gaupol, so I guess they are safe to remove.
But libnm-glib is a split package of networkmanager and I'm not sure what this means. Is it also safe to remove or not?
Once again...
Thanks, you mighty Manjaro Team !!!
PS: Why octopi always shows less upgradable packages, than pacman?
Update fine except my network manager now shows 'Wired connection 2' for my WIFI connections. Running kernel 5.2.8-1 after update for rtl8821ce WIFI card. Everything seems to work ok.
edit: one orphaned package libnm-glib
Fehler: Konnte den Vorgang nicht durchf├╝hren (In Konflikt stehende Dateien)
python-future: /usr/bin/futurize existiert im Dateisystem
python-future: /usr/bin/pasteurize existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future-0.17.1-py3.7.egg-info/PKG-INFO existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future-0.17.1-py3.7.egg-info/SOURCES.txt existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future-0.17.1-py3.7.egg-info/dependency_links.txt existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future-0.17.1-py3.7.egg-info/entry_points.txt existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future-0.17.1-py3.7.egg-info/top_level.txt existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/__pycache__/_markupbase.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/__pycache__/datetime.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/__pycache__/misc.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/__pycache__/socket.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/__pycache__/socketserver.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/__pycache__/total_ordering.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/_markupbase.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/datetime.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/_encoded_words.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/_header_value_parser.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/_parseaddr.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/_policybase.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/base64mime.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/charset.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/encoders.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/errors.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/feedparser.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/generator.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/header.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/headerregistry.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/iterators.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/message.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/parser.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/policy.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/quoprimime.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/__pycache__/utils.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/_encoded_words.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/_header_value_parser.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/_parseaddr.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/_policybase.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/base64mime.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/charset.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/encoders.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/errors.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/feedparser.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/generator.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/header.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/headerregistry.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/iterators.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/message.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/__pycache__/application.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/__pycache__/audio.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/__pycache__/base.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/__pycache__/image.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/__pycache__/message.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/__pycache__/multipart.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/__pycache__/nonmultipart.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/__pycache__/text.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/application.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/audio.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/base.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/image.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/message.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/multipart.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/nonmultipart.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/mime/text.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/parser.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/policy.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/quoprimime.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/email/utils.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/html/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/html/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/html/__pycache__/entities.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/html/__pycache__/parser.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/html/entities.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/html/parser.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/http/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/http/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/http/__pycache__/client.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/http/__pycache__/cookiejar.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/http/__pycache__/cookies.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/http/__pycache__/server.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/http/client.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/http/cookiejar.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/http/cookies.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/http/server.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/misc.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/socket.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/socketserver.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/__pycache__/pystone.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/__pycache__/ssl_servers.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/__pycache__/support.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/badcert.pem existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/badkey.pem existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/dh512.pem existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/https_svn_python_org_root.pem existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/keycert.passwd.pem existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/keycert.pem existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/keycert2.pem existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/nokia.pem existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/nullbytecert.pem existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/nullcert.pem existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/pystone.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/sha256.pem existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/ssl_cert.pem existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/ssl_key.passwd.pem existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/ssl_key.pem existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/ssl_servers.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/test/support.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/total_ordering.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/urllib/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/urllib/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/urllib/__pycache__/error.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/urllib/__pycache__/parse.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/urllib/__pycache__/request.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/urllib/__pycache__/response.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/urllib/__pycache__/robotparser.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/urllib/error.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/urllib/parse.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/urllib/request.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/urllib/response.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/urllib/robotparser.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/xmlrpc/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/xmlrpc/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/xmlrpc/__pycache__/client.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/xmlrpc/__pycache__/server.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/xmlrpc/client.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/backports/xmlrpc/server.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/builtins/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/builtins/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/builtins/__pycache__/disabled.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/builtins/__pycache__/iterators.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/builtins/__pycache__/misc.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/builtins/__pycache__/newnext.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/builtins/__pycache__/newround.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/builtins/__pycache__/newsuper.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/builtins/disabled.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/builtins/iterators.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/builtins/misc.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/builtins/newnext.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/builtins/newround.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/builtins/newsuper.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/__pycache__/_dummy_thread.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/__pycache__/_markupbase.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/__pycache__/_thread.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/__pycache__/builtins.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/__pycache__/collections.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/__pycache__/configparser.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/__pycache__/copyreg.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/__pycache__/itertools.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/__pycache__/pickle.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/__pycache__/queue.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/__pycache__/reprlib.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/__pycache__/socketserver.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/__pycache__/subprocess.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/__pycache__/sys.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/__pycache__/winreg.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/_dummy_thread.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/_markupbase.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/_thread.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/builtins.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/collections.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/configparser.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/copyreg.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/dbm/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/dbm/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/dbm/__pycache__/dumb.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/dbm/__pycache__/gnu.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/dbm/__pycache__/ndbm.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/dbm/dumb.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/dbm/gnu.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/dbm/ndbm.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/html/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/html/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/html/__pycache__/entities.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/html/__pycache__/parser.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/html/entities.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/html/parser.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/http/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/http/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/http/__pycache__/client.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/http/__pycache__/cookiejar.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/http/__pycache__/cookies.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/http/__pycache__/server.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/http/client.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/http/cookiejar.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/http/cookies.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/http/server.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/itertools.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/pickle.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/queue.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/reprlib.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/socketserver.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/subprocess.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/sys.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/test/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/test/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/test/__pycache__/support.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/test/support.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/__pycache__/colorchooser.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/__pycache__/commondialog.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/__pycache__/constants.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/__pycache__/dialog.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/__pycache__/dnd.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/__pycache__/filedialog.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/__pycache__/font.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/__pycache__/messagebox.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/__pycache__/scrolledtext.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/__pycache__/simpledialog.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/__pycache__/tix.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/__pycache__/ttk.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/colorchooser.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/commondialog.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/constants.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/dialog.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/dnd.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/filedialog.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/font.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/messagebox.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/scrolledtext.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/simpledialog.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/tix.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/tkinter/ttk.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/urllib/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/urllib/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/urllib/__pycache__/error.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/urllib/__pycache__/parse.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/urllib/__pycache__/request.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/urllib/__pycache__/response.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/urllib/__pycache__/robotparser.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/urllib/error.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/urllib/parse.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/urllib/request.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/urllib/response.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/urllib/robotparser.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/winreg.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/xmlrpc/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/xmlrpc/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/xmlrpc/__pycache__/client.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/xmlrpc/__pycache__/server.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/xmlrpc/client.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/moves/xmlrpc/server.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/standard_library/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/standard_library/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/tests/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/tests/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/tests/__pycache__/base.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/tests/base.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/__pycache__/newbytes.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/__pycache__/newdict.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/__pycache__/newint.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/__pycache__/newlist.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/__pycache__/newmemoryview.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/__pycache__/newobject.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/__pycache__/newopen.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/__pycache__/newrange.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/__pycache__/newstr.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/newbytes.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/newdict.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/newint.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/newlist.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/newmemoryview.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/newobject.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/newopen.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/newrange.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/types/newstr.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/utils/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/utils/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/utils/__pycache__/surrogateescape.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/future/utils/surrogateescape.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/__pycache__/fixer_util.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/__pycache__/main.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixer_util.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_UserDict.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_absolute_import.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_add__future__imports_except_unicode_literals.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_basestring.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_bytes.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_cmp.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_division.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_division_safe.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_execfile.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_future_builtins.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_future_standard_library.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_future_standard_library_urllib.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_metaclass.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_next_call.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_object.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_oldstr_wrap.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_order___future__imports.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_print.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_print_with_import.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_raise.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_remove_old__future__imports.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_unicode_keep_u.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_unicode_literals_import.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/__pycache__/fix_xrange_with_import.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_UserDict.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_absolute_import.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_add__future__imports_except_unicode_literals.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_basestring.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_bytes.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_cmp.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_division.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_division_safe.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_execfile.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_future_builtins.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_future_standard_library.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_future_standard_library_urllib.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_metaclass.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_next_call.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_object.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_oldstr_wrap.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_order___future__imports.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_print.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_print_with_import.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_raise.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_remove_old__future__imports.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_unicode_keep_u.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_unicode_literals_import.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/fixes/fix_xrange_with_import.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libfuturize/main.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/__pycache__/main.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/feature_base.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_add_all__future__imports.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_add_all_future_builtins.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_add_future_standard_library_import.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_annotations.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_division.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_features.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_fullargspec.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_future_builtins.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_getcwd.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_imports.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_imports2.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_kwargs.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_memoryview.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_metaclass.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_newstyle.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_next.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_printfunction.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_raise.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_raise_.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_throw.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/__pycache__/fix_unpacking.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/feature_base.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_add_all__future__imports.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_add_all_future_builtins.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_add_future_standard_library_import.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_annotations.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_division.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_features.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_fullargspec.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_future_builtins.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_getcwd.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_imports.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_imports2.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_kwargs.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_memoryview.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_metaclass.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_newstyle.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_next.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_printfunction.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_raise.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_raise_.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_throw.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/fixes/fix_unpacking.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/libpasteurize/main.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/builtins/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/builtins/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/builtins/__pycache__/misc.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/builtins/__pycache__/noniterators.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/builtins/misc.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/builtins/noniterators.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/tests/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/tests/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/translation/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/translation/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/types/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/types/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/types/__pycache__/basestring.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/types/__pycache__/olddict.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/types/__pycache__/oldstr.cpython-37.pyc existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/types/basestring.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/types/olddict.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/types/oldstr.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/utils/__init__.py existiert im Dateisystem
python-future: /usr/lib/python3.7/site-packages/past/utils/__pycache__/__init__.cpython-37.pyc existiert im Dateisystem
Fehler sind aufgetreten, keine Pakete wurden aktualisiert.
I know i installed glances via pip, and deinstalled it before want to update.
If i search fore python-future the package is not install.
deinstall python will deinstall manjaro-system
--overwrite ? how to do?
--overwrite usr/lib/* does not work, a new error :: Installation fortsetzen? [J/n] j
(142/142) Pr├╝fe Schl├╝ssel im Schl├╝sselring [##############################] 100%
(142/142) ├ťberpr├╝fe Paket-Integrit├Ąt [##############################] 100%
(142/142) Lade Paket-Dateien [##############################] 100%
(142/142) Pr├╝fe auf Dateikonflikte [##############################] 100%
i have never installed this package, python-future is not installed
I have to delete glances twice, one via pip uninstall and one via pacman, seems to be solved.
I had the problem reported with the separator in the panel, which I solved tweaking the properties of the panel.
No need to reinstall the system, it's rolling, but it would be nice to easily change the appearance of xfce to the current Manjaro customization if we wanted to.
Update on 12 Systems and 1 VB without Problems.
DK3
With xfce4-panel 4.14, the icons in the windows manager's panel plugin are too much small.
How can I make them looks like the gtk2 version?!
Circled in red:
After the update smplayer ignores stop button (space), forward buttons (arrows), it doesn't pause or stop when I click on the UI buttons with a mouse, it ignores the progress bar (the time line?). Also, now there is a delay (few seconds) on closing the smplayer.
Anyone else have this?
p.s. xfce
Also a bug afflict this version of the plugin: when tou list 2 equal windows, you can't right-click on them
Or this is not a bug, now I thinks this works differently
If you are referring to Window Buttons. You can change their size by going to Panel Preferences, Appearance tab, and under Icons, disable Adjust size automatically and change the size manually.
But this will make the other icons on the panel too large. So this needs to be fixed in the future.
You may need to play with panel row size to make it look the way you want. Also the notification area icons (on the far right) have their own size setting.
no , I'm referring to the windows buttons plugin (circled in red on the left in my screenshot)
You're referring to the ions on the left
The Window Buttons do not have a size setting. That is why you have to change the icon size for the whole panel.
