[Stable Update] 2019-02-19 - Kernels, KDE, LibreOffice, Systemd, VirtualBox, Deepin, Qt, Firmwares, Wine
update
stable
#245
Bridge interfaces with the same name on different machines now generate the same MAC address for the bridge. I use a bridge on several manjaro machines on the network so that I can use QEMU+TAP to allow my QEMU/KVM virtual machines to be on the ethernet network as if they are regular machines. I have used this setup for several years.
This changed after this updating to the 2019-02-19 stable update.
My setup is using the Network Manager UI, I edit connection create a bridge network using the wired network interface as slave and I name the bridge interface br0. The adapter comes up and is assigned an address via DHCP like normal. But the other machines on the network configured similarly with a bridge interface named br0 are now using the same MAC address instead of a random (which is how they used to work). ANd therefore step on each other on the network.
Only if I change the name of the bridge interface does it get a different a different MAC. So if i change the name to br1, I get a different MAC, but another machine on the network with a bridge interface named br1 will have the same MAC.
This happens whether I create the bridge network using Network Manager, NetCtl, or create the interface in systemd.
#246
I don’t think editing system files like this for normal operation is good practice. There is a new at package in unstable that fixes this. Please search for my other post above.
#247
@philm stated in a recent youtube video that pamac itself was not the issue. I still think it’s worth investigating systemd’s usage of ostree-system-generator (owned by package ostree) since that seems to be a focal point of x crashes. I looked up bash error code 127 – it appears to be a “command not found,” which is odd because the full path is listed and there doesn’t seem to be any misspelling. Searching around, I found an obscure reference to a project where cron is being used and remembered another issue we’ve been having: @kdemeoz – and usage of pamac upgrade with encrypted home partitions…anyway, the author in the github project implied home wasn’t logged in so the command resulted in a 127 error since it was encrypted. @guinux: is it possible that polkit/dbus is interfering with systemd’s access of an existing encrypted /usr/lib/*?
Question for anyone here: have you used pamac (or pamac cli) on an encrypted system and had no issues?
#248
You need a hug :hugs: Be the less annoying Daniel
#249
Yes, eg:
#251
My point of view is that the trouble doesn’t come from pamac but from systemd itself that can crash the graphical session (and all the running programs like pamac-gui) when it’s updated.
Is it possible to force user upgrade in TTY for specific packages?
#252
Same with Pamac and sudo pacman -Syyu
conflicting files:
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/__pycache__/__init__.cpython-37.pyc already exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/Compiler/__pycache__/__init__.cpython-37.pyc already exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/Compiler/__pycache__/compiler.cpython-37.pyc already exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/Compiler/__pycache__/indenter.cpython-37.pyc already exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/Compiler/__pycache__/misc.cpython-37.pyc already exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/Compiler/__pycache__/proxy_metaclass.cpython-37.pyc already exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/Compiler/__pycache__/qobjectcreator.cpython-37.pyc already exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/Compiler/__pycache__/qtproxies.cpython-37.pyc already exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/__pycache__/__init__.cpython-37.pyc already exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/__pycache__/exceptions.cpython-37.pyc already exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/__pycache__/icon_cache.cpython-37.pyc already exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/__pycache__/objcreator.cpython-37.pyc already exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/__pycache__/properties.cpython-37.pyc already exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/__pycache__/uiparser.cpython-37.pyc already exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/port_v3/__pycache__/__init__.cpython-37.pyc already exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/port_v3/__pycache__/as_string.cpython-37.pyc already exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/port_v3/__pycache__/ascii_upper.cpython-37.pyc already exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/port_v3/__pycache__/proxy_base.cpython-37.pyc already exists in filesystem
Manjaro KDE.
Error when updating. Update failed
EDIT:
Solved by renaming UIC folder to uic-bak and removing 1 file from pycache folder.
Thanks for the quick response Manjaro Team :smiley:
#253
Thank you in general for: a) all the work done b) providing changelog details with links c) providing trouble shooting, And thank you for updating texlive, exactly what I was in need. My printed LaTeX resource collection now grew to more than 2500 pages and I’m ready to replace office suites forever.
To come back to topic: texlive usage never worked as good as with this version, everything on first try.
Did a fresh install from XFCE 17.0.5 to XFCE 18.0.3. I’ve experienced the install process as perfect.
#254
Thanks.
I can confirm that this works.
#255
Thanks a lot @torvic! If I good remember, I edited myself this file by copying/pasting from https://wiki.archlinux.org/index.php/ClamAV#OnAccessScan. I have deleted this option (and commented it) but I do not find anywhere in the ClamAV documentation by what this option has been replaced. I do not find neither any clamav-milter.conf.pacnew or similar…
Thanks again (maybe this message should be moved somewhere else, but I do not know how to make it, sorry if it perturbs the thread)
#256
This is covered in the Known Issues post.
Please read it so the solution doesn’t have to be repeated/reposted multiple times.
#257
I tried this but still it shows conflict in file.
(1/1) checking for file conflicts                        [##############################] 100%
error: failed to commit transaction (conflicting files)
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/__pycache__/__init__.cpython-37.pyc exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/Compiler/__pycache__/__init__.cpython-37.pyc exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/Compiler/__pycache__/compiler.cpython-37.pyc exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/Compiler/__pycache__/indenter.cpython-37.pyc exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/Compiler/__pycache__/misc.cpython-37.pyc exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/Compiler/__pycache__/proxy_metaclass.cpython-37.pyc exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/Compiler/__pycache__/qobjectcreator.cpython-37.pyc exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/Compiler/__pycache__/qtproxies.cpython-37.pyc exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/__pycache__/__init__.cpython-37.pyc exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/__pycache__/exceptions.cpython-37.pyc exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/__pycache__/icon_cache.cpython-37.pyc exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/__pycache__/objcreator.cpython-37.pyc exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/__pycache__/properties.cpython-37.pyc exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/__pycache__/uiparser.cpython-37.pyc exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/port_v3/__pycache__/__init__.cpython-37.pyc exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/port_v3/__pycache__/as_string.cpython-37.pyc exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/port_v3/__pycache__/ascii_upper.cpython-37.pyc exists in filesystem
python-pyqt5: /usr/lib/python3.7/site-packages/PyQt5/uic/port_v3/__pycache__/proxy_base.cpython-37.pyc exists in filesystem
#258
Maybe you could use the search function?
#259
I was reading through this post only.
Thanks for the link.
#260
As someone who always reads the whole update thread before updating to get an overview of issues people encounter, I’d like to make a complaint that recent update threads have been increasing in size, with mostly generic discussion, if not complete off-topic.
I know this may come out ironic (I am not posting about a update issue myself) but it has to be said nonetheless.
#261
Did you know that @sueridgepipe really likes puppies?
#262
No, really? Tell me more about it. :wink:
(post withdrawn by author, will be automatically deleted in 24 hours unless flagged)
#263
More puppies! :smiley::+1:t2::partying_face:
#264
I got a really stupid question, but as it seems upgrading through TTY is materializing as the recommended way of doing updates, how can I enable scrolling on the TTY? I would like to read the messages spits out during update (errors and new additional dependancies).
I remember a long time ago I was able to scroll using some combination of ctrl + shift + page up, but I cant find a working way.
#265
Do u have Fn button?
For me I’m able to scroll but not to the start. For example if I type history inside tty, I’m able to scroll to like 300 line. But not to the start
