[Stable Update] 2019-02-09 - Kernels, Deepin, Firefox, Wine, Python, Haskell
update
stable
#1
Hi community,
Welcome to our fifth stable update for 2019. So what do we have with this one?
  • most of our Kernels got updated
  • newer packages to Deepin got added
  • Firefox got its second beta release of v66 series
  • Wine is now at v4.0
  • the usual Python and Haskell updates/rebuilds
We hope with all these changes Manjaro to be more efficient for you all.
CLT19
Manjaro will take part on the Chemnitz Linux Days in March this year. You may want to visit our booth with the latest Manjaro hardware and Core Developers present to answer your questions. Feel free to bring your devices if you want to have Manjaro installed on them or problems fixed from our experts.
Partnership with FCS Linux Aarhus
We are happy to announce a new partnership with FCS Linux Aarhus owned by @fhdk. This enables us to offer you Laptops with Manjaro pre-installed and Manjaro Stickers you can use on your own hardware or gift them to a friend. For each sale FCS will donate a percentage to the Manjaro project.
Manjaro v18.0.2 released!
To end the year with a high note we updated our flagship ISOs of Manjaro Illyria with the latest packages. It comes with refreshed packages and updated tools. You may want to download our XFCE Edition with the latest 4.13 packages, aswell as our most recent styling efforts. Our KDE fans may try our KDE Edition with the latest KDE v5.14 instead. And our GNOME fans may try our Gnome Edition with the latest GNOME v3.30.
Current supported Kernels
  • linux316 3.16.62
  • linux318 3.18.134 [EOL]
  • linux44 4.4.167 [FZN]
  • linux49 4.9.155
  • linux414 4.14.98
  • linux419 4.19.20
  • linux420 4.20.7
  • linux414-rt 4.14.93_rt53
  • linux418-rt 4.18.16_rt9
Package Updates (Sun Jan 27 11:05:41 CET 2019)
  • stable community x86_64: 1008 new and 990 removed package(s)
  • stable core x86_64: 18 new and 18 removed package(s)
  • stable extra x86_64: 208 new and 211 removed package(s)
  • stable multilib x86_64: 23 new and 21 removed package(s)
A detailed list of all package changes can be found here.
0 voters
Potential file conflict with new python-pyqt5 - Fix it with manjaro-system?
#2
Known issues and solutions
CanÔÇÖt update with linux417 or/and linux418 present
Since we have completely removed those kernel series you should remove those kernels before you upgrade. Most likely you will notice that as you may have extramodules like nvidia installed. Those got updated and therefore complain about dependency issues.
Notifications looking weird in XFCE
Since the package dunst includes now dunstfy in the main package notifications may not displayed properly in XFCE. Please uninstall that package to solve that issue. Normally not needed in that edition.
Potential issues with dunstify-1.3.2-1 package
Upstream decided to include dunstify now in the dunst package. However, they didnÔÇÖt add any replace, conflicts tags to that package, as Arch never packaged dunstify before. Therefore we try to remove dunstify automatically via manjaro-system package. On rare cases however, a manual user invention might be needed to remove the package. If that is the case, please issue the following command manually on your system: sudo pacman -Rdd dunstify && sudo pacman -Syu
Items from previous update sets
Warning: PACKAGE: directory permissions differ on FILENAME
A file or directory on your system has a set of permissions which is different to those in the new package. You can either ignore it (because you changed it yourself) or you can change them so they match.
For example, for this message:
Warning: blueman: directory permissions differ on /usr/share/polkit-1/rules.d/filesystem: 750  package: 755
you can change the local file to match the package with:
sudo chmod 755 /usr/share/polkit-1/rules.d/filesystem
How do I do updates via TTY-terminal?
  • Press CTRL+ALT+F2 (or F3, F4, F5, F6) to go into a pure command line interface.
  • Log in with your credentials.
  • Once logged in, youÔÇÖll have access to a CLI shell, like if you were using a terminal. Use pamac upgrade or sudo pacman -Syyu (or other equivalent command) to update your system.
To go back to your regular desktop, press CTRL+ALT+F7. On some systems, it can be CTRL+ALT+F1 instead.
i3 changed its default config path
It seems that (from version >= 4.16) i3 is looking for its configuration in ~/.config/i3/config instead of ~/.i3/config.
Copy your config to the new path and all should work as before. (reported from an i3-gaps user).
I canÔÇÖt open Nemo with elevated privileges (as root)
Workaround found: Use the dbus-x11 package instead of the regular dbus package. This package is available in the official repositories and provides dbus compiled without the --without-x option.
To replace dbus with dbus-x11 package, simply install dbus-x11 with your favorite package manager: dbus will be replaced by dbus-x11.
AMD-Ucode introduction
Unless youÔÇÖve already done this previously, All users of AMD-APUs/CPUs should install this update like this:
sudo pacman -Syyu
sudo pacman -S amd-ucode
sudo pacman -R intel-ucode
sudo update-grub
Step 3 is optional.
Rebuilding fontconfig cache: failed to write cache
Please ignore this message. Upstream already works on a solution. More about the issue here.
LibreOffice has no window decoration in KDE
New line export SAL_USE_VCLPLUGIN=gtk3_kde5, once merged into existing /etc/profile.d/libreoffice-fresh.sh , fixes a moderately longterm issue. If it doesnÔÇÖt work for you, you may use gtk instead of gtk3_kde5 as UI framework.
Installing glibc (2.28-4) breaks the dependency ÔÇťglibc=2.27ÔÇŁ required by lib32-glibc
Install the update either:
  • from terminal: sudo pacman -Syu or;
  • with Octopi instead of Pamac.
Something using Perl/Python/glibc broke
Rebuilds needed!
  • If itÔÇÖs an AUR package, try to reinstall it from AUR. It most likely needs to be rebuilt.
  • If itÔÇÖs a repo package, please report and check back regularly for updates.
IÔÇÖve lost a Thunderbird addon/feature
Thunderbird 60 disables incompatible addons by default. ThereÔÇÖs an about:config switch should you want to force-enable the addon, but many addons simply will not work with the newer Quantum-based Thunderbird.
Read more about Thunderbird 60 here: Thunderbird 60
Firefox - WebGL not working anymore
You may try the following solution:
Open about:config and set security.sandbox.content.read_path_whitelist to /sys/.
#3
Updated a pair of I7 multi monitor desktops from terminal. No problems at all. Still yet to do the laptop. Thanks Philm and the rest of the devs.
#4
Great work, everything is fine, thanks a lot!
#5
Updated but laptop is not booting anymore. gets stuck in a bootloop.
I edited grub to boot into runlevel 3 and performed sudo pacman -Syyuu. It said all up to date.
But it did not fix the issue. So I typed in startx and i got into the system. But I have to edit grub boot menu everytime to boot into text mode and then type in startx because if i boot normally it just gets stuck in a bootloop. Any advice would be helpful. Thank you :slight_smile:
#6
On Plasma:
Warning: can't obtain information about file for ...
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ace/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ak/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/am/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/an/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/as/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ast/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ay/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/az/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ba/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/be/LC_MESSAGES/iso_639_5.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/bg/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/bg/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/bn/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/bn/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/br/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/bs/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/bs/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ca/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ce/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ckb/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/crh/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/cs/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/cs/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/da/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/de/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/dv/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/dz/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/el/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/en/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/es/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/et/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/eu/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/eu/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ff/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/fi/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/frp/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/fur/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ga/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/gn/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/gu/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/gu/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ha/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ht/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/io/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/is/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/is/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/is/LC_MESSAGES/iso_639_5.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/it/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/it/LC_MESSAGES/iso_639_5.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ja/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ja/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/kab/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/kl/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/km/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/kn/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/kn/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/kn/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ko/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ko/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ko/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ko/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/kok/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/kv/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ky/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/lt/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/lt/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/lt/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/lv/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/lv/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/lv/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/lv/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/mhr/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/mi/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/mi/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/mi/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/mk/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/mn/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/mn/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/mr/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ms/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ms/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ms/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/mt/LC_MESSAGES/iso_639-3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/mt/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/mt/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/na/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/nb/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/nb/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/nb/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ne/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/nl/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/nl/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/nl/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/nl/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/nl/LC_MESSAGES/iso_639_5.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/nn/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/nn/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/nn/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/nso/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/nso/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/nso/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/oc/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/oc/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/or/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/or/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/or/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/pa/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/pa/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/pa/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/pap/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/pl/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/pl/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/pl/LC_MESSAGES/iso_639_5.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ps/LC_MESSAGES/iso_639-3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ps/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ps/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/pt/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/pt/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/pt/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/pt_BR/LC_MESSAGES/iso_3166-3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/pt_BR/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/pt_BR/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ro/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ro/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ro/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ru/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ru/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/rw/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/rw/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/rw/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sc/LC_MESSAGES/iso_3166-3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sc/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sc/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sc/LC_MESSAGES/iso_639-5.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sc/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sc/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sc/LC_MESSAGES/iso_639_5.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sk/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sk/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sk/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sl/LC_MESSAGES/iso_3166-3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sl/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sl/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sl/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/son/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sq/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sr/LC_MESSAGES/iso_3166-3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sr/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sr/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sr/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sr/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sr/LC_MESSAGES/iso_639_5.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sr@latin/LC_MESSAGES/iso_3166-3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sr@latin/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sr@latin/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sr@latin/LC_MESSAGES/iso_639-5.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sr@latin/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sr@latin/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sr@latin/LC_MESSAGES/iso_639_5.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sv/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sv/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sv/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/sv/LC_MESSAGES/iso_639_5.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ta/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ta/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ta/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/te/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/tg/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/th/LC_MESSAGES/iso_3166-2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/th/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/th/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ti/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ti/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ti/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/tig/LC_MESSAGES/iso_639-3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/tig/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/tig/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/tr/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/tr/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/tr/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/tr/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/tt/LC_MESSAGES/iso_639-3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/tt/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/tt/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/tt@iqtelif/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/tt@iqtelif/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/tt@iqtelif/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ug/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/uk/LC_MESSAGES/iso_3166-3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/uk/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/uk/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/uk/LC_MESSAGES/iso_639-5.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/uk/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/uk/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/uk/LC_MESSAGES/iso_639_5.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/uz/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ve/LC_MESSAGES/iso_3166-3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ve/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ve/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/ve/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/vi/LC_MESSAGES/iso_3166-2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/vi/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/vi/LC_MESSAGES/iso_639-3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/vi/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/vi/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/wa/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/wa/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/wa/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/wal/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/wo/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/xh/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/xh/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/zh_CN/LC_MESSAGES/iso_3166-1.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/zh_CN/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/zh_CN/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/zh_CN/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/zh_HK/LC_MESSAGES/iso_3166-3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/zh_HK/LC_MESSAGES/iso_3166.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/zh_TW/LC_MESSAGES/iso_3166-1.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/zh_TW/LC_MESSAGES/iso_3166_2.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/zh_TW/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/zu/LC_MESSAGES/iso_639-3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/zu/LC_MESSAGES/iso_639.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/locale/zu/LC_MESSAGES/iso_639_3.mo
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/xml/iso-codes/iso_3166.xml
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/xml/iso-codes/iso_3166_2.xml
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/xml/iso-codes/iso_639.xml
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/xml/iso-codes/iso_639_3.xml
ostrze┼╝enie: nie mo┼╝na uzyska─ç informacji o pliku dla usr/share/xml/iso-codes/iso_639_5.xml
#7
It really depends what exactly got updated. Can you be more specific? Can you check what systemctl may tell you? Which errors you may have with your X-Session? Check /var/log/Xorg.0.log for some clues. tac /var/log/pacman.log | less will give you a clue which packages got updated.
#8
when will go out systemd 240 on stable
#10
Since we have issues with that version, we have to skip it. You can search this forum for given reasons ÔÇŽ
#11
thank you
#12
libnm-gtk was removed from the repositories or something. I uninstalled it
#13
Perfect update, System after reboot works fine.
LXQT and XFCE with Kernel 4.20.
Thanks!
#14
This update went smoothly with one small hitch. I got an error about
/usr/share/icons/hicolor/scalable/actions/edit-delete.svg
already existing and the update came to a halt.
Simply delete the file and reapply the update. All went as expected from that point.
#15
Looks like you deleted those files yourself and so pacman couldnÔÇÖt find them.
This is a warning and so can probably be ignored, especially so if you deleted the files.
#16
Just curious, is something mistyped or I donÔÇÖt have specific font installed (updated without issues)?
#17
The issue is within pamac ÔÇŽ
#18
Oh, ok. Thanks for quick answer :slight_smile:
Regards :slight_smile:
split this topic #19
2 posts were split to a new topic: VMWare canÔÇÖt find kernel headers
split this topic #20
A post was merged into an existing topic: VMWare canÔÇÖt find kernel headers
#21
Very true. For you wondering ÔÇťwhat update I didnÔÇÖt get anythingÔÇŁ run this command sudo pacman-mirrors -f I didnÔÇÖt know about the update until seeing this thread because I had to do that.
