[Stable Update] 2018-12-23 - Kernels, Cinnamon, XFCE, Nvidia, Pamac, Firmware, Brave
update
stable
#42
Thanks for the hard work @philm
#43
Updated again but I get strange message;
Warning: linux-firmware: local (20181214.8aa9e3e-1) is newer than core (20181026.1cb4e51-1)
Starting full system upgrade...
_**Warning: linux-firmware: local (20181214.8aa9e3e-1) is newer than core (20181026.1cb4e51-1)**_
Resolving dependencies...
Checking inter-conflicts...
Downloading linux419 (4.19.12-2-x86_64)...
Downloading chromium (71.0.3578.98-0.2-x86_64)...
Checking keyring...
Checking integrity...
Loading package files...
Checking file conflicts...
Checking available disc space...
Running pre-transaction hooks...
Save Linux kernel modules
Upgrading chromium (71.0.3578.98-0 -> 71.0.3578.98-0.2)...
Upgrading linux419 (4.19.12-1 -> 4.19.12-2)...
Updating linux419 module dependencies...
Updating linux419 initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'default'
  -> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64.img
==> Starting build: 4.19.12-2-MANJARO
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [resume]
  -> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'fallback'
  -> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64-fallback.img
Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-4.19-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.19-x86_64.img
Found initrd fallback image: /boot/initramfs-4.19-x86_64-fallback.img
Found linux image: /boot/vmlinuz-4.18-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.18-x86_64.img
Found initrd fallback image: /boot/initramfs-4.18-x86_64-fallback.img
Found linux image: /boot/vmlinuz-4.17-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.17-x86_64.img
Found initrd fallback image: /boot/initramfs-4.17-x86_64-fallback.img
done
Updating icon theme caches...
Restore Linux kernel modules
e[1;1me[1;32m==>e[1;0me[1;1m Warning:
	 -> Kernel has been updated. Modules of the current kernel
	 -> have been backed up so you can continue to use your
	 -> computer. However, the new kernel will only work
	 -> at next boot.
	e[1;0m
	e[1;0m
Arming ConditionNeedsUpdate...
Updating the desktop file MIME type cache...
#44
Are there any plans to upgrade KDE Framework to 5.53 and KDE Apps to 18.12?
Btw thanks for the hard work you’re doing with this distro, it’s awesome
#45
Fixed!!!
[noxl@nox-pc ~]$ pacui
                  PacUI - Package manager
β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
β”‚ 1 Update System 2 Maintain System β”‚
β”‚ 3 Install Packages 4 Remove Packages and Deps β”‚
β”‚---------------------------------------------------------------β”‚
β”‚ 5 Dependency Tree 6 Reverse Dependency Tree β”‚
β”‚ 7 List Package Files 8 Search Package Files β”‚
β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
9 Roll Back System 10 Fix Pacman Errors
11 Edit Config Files 12 List Packages by Size
β”‚ 14 List Installed from AUR β”‚
Enter number or marked letter(s) - 00 Help - 0 Quit
9
[sudo] password for noxl:
loading packages…
warning: downgrading package linux-firmware (20181214.8aa9e3e-1 => 20181026.1cb4e51-1)
resolving dependencies…
Packages (1) linux-firmware-20181026.1cb4e51-1
Total Installed Size: 412.16 MiB
Net Upgrade Size: -4.43 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [######################] 100%
(1/1) checking package integrity [######################] 100%
(1/1) loading package files [######################] 100%
(1/1) checking for file conflicts [######################] 100%
(1/1) checking available disk space [######################] 100%
:: Running pre-transaction hooks…
(1/1) Save Linux kernel modules
:: Processing package changes…
(1/1) downgrading linux-firmware [######################] 100%
:: Running post-transaction hooks…
(1/3) Restore Linux kernel modules
==> Warning:
-> This computer hasn’t been restarted for a while.
-> You are running an old kernel. In order to use a
-> new version of the kernel, please restart your
-> computer as soon as possible.
(2/3) Creating temporary files…
(3/3) Arming ConditionNeedsUpdate…
System roll back finished. To return to PacUI press ENTER
#46
Any chance we can get Matcha dark themes in Kvantum Manager?
#47
No issues so far:
uname -a
Linux hermes 4.20.0-1-MANJARO #1 SMP PREEMPT Mon Dec 24 08:20:48 UTC 2018 x86_64 GNU/Linux
#48
Stable or unstable Kernel?
#49
@Ste74: do we have a schedule for Matcha Kvantum? We launched Sea, but I don’t know the progress on the other colours …
#50
Stable
#51
Just curious how did you update to that kernel via GUI or terminal?
#52
It showed up in Manjaro Settings Manager this morning and I installed right from that gui. Probably @philm Christmas present for us :slight_smile:
#53
Good to know thank you and merry christmas to you and all @philm the Manjaro comunity!!!
#54
As per normal for update ETAs etc.
#55
I have added the other colors of the matcha series in kvantum where the primary color is azul red ecc… We can invert the colors for the drop down menu for a dark version but as always any help is appreciated…
#56
I know that, but framdework 5.53 was released december 8 but it’s not in stable yet
#57
See also this …
#58
Using kernel 4.20 scheduler is set to cfq and multi-queue is not enable, going back to 4.19 reset on mq-deadline
#59
Thank you @philm
#60
Good catch, thank you for noticing it and the warning. Back to putting scsi_mod.use_blk_mq=1 on grub parameters.
#61
You’re welcome :grin::v:
