[Stable Update] 2018-12-23 - Kernels, Cinnamon, XFCE, Nvidia, Pamac, Firmware, Brave
update
stable
#21
Seems you were fine with linux-firmware 20181026.1cb4e51-1. On 20181214.8aa9e3e-1 no new amdgpu was added. I rather think the issue might be with amd-ucode package on your end, which may need the newer amdgpu firmware. We will see if others have similar issues.
#22
Seems the firmware was faulty. Therefore I’d removed them. Please issue a sudo pacman -Syyuu if you face similar issues.
Reverting Kernel update?
[Testing Update] 2018-12-22 - Systemd 239.370-2
#23
Hi, the stable update looks fine.
OS: Manjaro 18.0.1 Illyria
Kernel: x86_64 Linux 4.19.12-2-MANJARO
Uptime: 3m
Packages: 1167
Shell: bash 4.4.23
Resolution: 1366x768
DE: KDE 5.52.0 / Plasma 5.14.4
WM: KWin
WM Theme: Breath
GTK Theme: Breath [GTK2/3]
Icon Theme: maia
Font: Noto Sans Regular
CPU: AMD A8-7410 APU with AMD Radeon R5 Graphics @ 4x 2.2GHz
GPU: AMD MULLINS (DRM 2.50.0, 4.19.12-2-MANJARO, LLVM 7.0.0)
RAM: 997MiB / 3401MiB
:santa:
#24
You’re more than welcome to help, the more the merrier. :slight_smile:
#25
what exactly does pacman -Syyuu do compared to just pacman -Syyu?
Also I get this error when I go to update in the terminal with pacman -Syyu. Should I run -Syyu first then run -Syyuu or something?
warning: linux-firmware: local (20181214.8aa9e3e-1) is newer than core (20181026.1cb4e51-1)
resolving dependencies...
Packages (2) linux419-4.19.12-2  linux419-headers-4.19.12-2
Total Download Size:    84.16 MiB
Total Installed Size:  189.52 MiB
Net Upgrade Size:        0.00 MiB
#26
It synchronizes the databases and set everything in order. Newer packages than in the databases will be automatically downgraded with the second y applied.
#27
The second u allows for a downgrade.
The trick on reading the man page:
https://www.archlinux.org/pacman/pacman.8.html#_sync_options_apply_to_em_s_em_a_id_so_a
is to not search for uu (or yy for that matter), but to look for:
Pass this option twice to enable package downgrades; in this case, pacman will select sync packages whose versions do not match with the local versions. This can be useful when the user switches from a testing repository to a stable one.
Personally, if my system is working fine, I never downgrade.
#28
I’d point out that you could jump ahead with the firmware, depends on your issue.
Getting fresh install up and running by a Manjaro newbie
#29
Hi!
I just skipped an update from linux firmware 4.19.12.1 to 4.19.12.2. Work fine
Thanks
#30
Any plans for Virtual Box 6?
#31
telegram-desktop is out of date 1.4.3 and new one is 1.5.3
#32
No Problems on two XFCE Systems.
#33
Woke up this morning and realised that this is a common but spurious error with nvme disks; we can ignore the error or we can get rid of it by removing 60_memtest86+ from /etc/grub.d
See this topic for further clarifications. Sorry for my memory lapse. I wonder if it is Alzheimer (which I’m not aware of) or my senility kicking in. I like to think it is a trait of a genius. Everybody suffers from confirmation bias, Dunning-Kruger effect and cognitive dissonance. I’m no exception. :grinning:
Cheers.
#34
I don’t think this has anything to do with this particular update set?
However, you might read
#35
Maintained upstream in Arch.
These packages have been flagged as out of date almost a week ago but have not hit Arch Testing yet.
You can keep track of them here …
https://www.archlinux.org/packages/?sort=-last_update&arch=x86_64&q=virtualbox&maintainer=&flagged=
#36
I always had this warning. Not very important as everything works but my OCD would bite me each time I saw that message. Thank you for pointing me in the right direction to remove it. Kudos.
Tony
#37
Another smooth upgrade, Merry Christmas or Seasons Greetings to all and it still hasn’t helped
me play the piano!
#38
I was having issues with freezing right before the KDE login screen. As I understand it, it’s due to some issue with linux-firmware.
The suggestion by @Tomari in this thread to force a linux-firmware update to a more recent version was the only way that I was able to get 4.19.12-2 to boot. Downgrading the linux-firmware as suggested by @philm here did not allow me to start neither 4.19.12-1 nor 4.19.12-2 up.
Luckily for me, I was able to get back in via kernel 4.18.20-1 to force the update.
CPU: Ryzen 2700x
GPU: AMD RX560
#39
2 posts were split to a new topic: Can’t install VirtualBox extension pack
[partial solution] Can't install VirtualBox extension pack
#40
Have fun with it :smile:
