[Stable Update] 2018-12-02 - Kernels, Plasma, Mesa, Cinnamon, Gnome, Deepin, XFCE, Vulkan
update
stable
#63
Well, this updated failed for me on my laptop. First I updated by the terminal but it was the GUI terminal. Screen went black and after a while I saw the login window again.
Then I did the shortcut for the full screen terminal and did the upgrade and then a reboot. Then I could not login anymore, I login and immediately get kicked back out.
Went back to the terminal and with the update command I could a error about cinnamon-settings-daemon that could no be found.
I removed that package and with it 3 other dependency’s. I wanted to just reinstall that one package but I guess I had to remove it and the dependencies first.
Now I can’t reinstall because it finds conflicting files.
Any suggestions on how to proceed?
Edit: This is the error:
#64
Working fine here with Gnome!
#65
Those files normally belong to cinnamon-settings-daemon package. So what you could do is either remove those files, then install cinnamon-setting-daemon and other packages OR first install cinnamon-settings-daemon with pacman --overwrite and then install the rest without --overwrite.
--overwrite is not something you do in normal circumstances, but it seems appropriate for this particular situation.
See this article for pacman (Arch Wiki).
#66
I’m impressed, everything went suspiciously fine!
#67
try sudo pacman-mirrors -f3
first … then
sudo pacman -Syyu
#68
Any idea when there will be an ISO of Manjaro Deepin 18 with the 4.19 kernel series?
#69
Only @oberon can tell, as he’s the maintainer of this flavor.
#70
Everything updated and started up with no problem. I have yet to run into problems.
#71
No problem here.
Linux 419 & Qtile 0.12
#72
Sorry to hear of your hassle, but i just felt i wanted to point out that from your first post you are explicitly speaking of…
Manjaro GNOME 18.0
…& that nobody else reading your second post’s…
kernel 4.19.6-1-MANJARO that breaks suspend-to-RAM
…should mistakenly interpret that as implying a generic problem. --> My KDE Lappy, just now updated, continues to Suspend [ie, to RAM] with the latest kernel version.
Good luck.
#73
this kernel update will slow the system? as linus said.
#74
The Kernel Patch to disable Intel SMT will come with 4.20 afaik. The “Patch” got backported to 4.19, but then, they removed it again. If my information is right. But i don’t care, my Intel Core i5 CPU does not have SMT.
#75
how do you check if cpu has SMT ? online?
#76
Just check your CPU specs, if your CPU is HT/SMT capable. My Core i5 Haswell isn’t. Just Google for your CPU, if you are unsure.
#77
can you help me to find it
Essentials
    Product Collection Legacy Intel® Core™ Processors
    Code Name Products formerly Ivy Bridge
    Vertical Segment Mobile
    Processor Number i5-3317U
    Status Launched
    Launch Date Q2'12
    Lithography 22 nm
    Recommended Customer Price $225.00
Performance
    # of Cores 2
    # of Threads 4
    Processor Base Frequency 1.70 GHz
    Max Turbo Frequency 2.60 GHz
    Cache 3 MB SmartCache
    Bus Speed 5 GT/s DMI
    TDP 17 W
Supplemental Information
    Embedded Options Available No
    Datasheet View now
Memory Specifications
    Max Memory Size (dependent on memory type) 32 GB
    Memory Types DDR3/L/-RS 1333/1600
    Max # of Memory Channels 2
    Max Memory Bandwidth 25.6 GB/s
    ECC Memory Supported ‡ No
Processor Graphics
    Processor Graphics ‡ Intel® HD Graphics 4000
    Graphics Base Frequency 350 MHz
    Graphics Max Dynamic Frequency 1.05 GHz
    Graphics Output eDP/DP/HDMI/SDVO/CRT
    Intel® Quick Sync Video Yes
    Intel® InTru™ 3D Technology Yes
    Intel® Flexible Display Interface (Intel® FDI) Yes
    Intel® Clear Video HD Technology Yes
    # of Displays Supported ‡ 3
    Device ID 0x166
Expansion Options
    PCI Express Revision 2.0
    PCI Express Configurations ‡ 1x16, 2x8, 1x8 2x4
    Max # of PCI Express Lanes 16
Package Specifications
    Sockets Supported FCBGA1023
    Max CPU Configuration 1
    TJUNCTION 105 C
    Package Size 31.0mm x 24.0mm
Advanced Technologies
    Intel® Turbo Boost Technology ‡ 2.0
    Intel® vPro™ Platform Eligibility ‡ No
    Intel® Hyper-Threading Technology ‡ Yes
    Intel® Virtualization Technology (VT-x) ‡ Yes
    Intel® Virtualization Technology for Directed I/O (VT-d) ‡ Yes
    Intel® VT-x with Extended Page Tables (EPT) ‡ Yes
    Intel® 64 ‡ Yes
    Instruction Set 64-bit
    Instruction Set Extensions Intel® AVX
    Intel® My WiFi Technology Yes
    4G WiMAX Wireless Technology Yes
    Idle States Yes
    Enhanced Intel SpeedStep® Technology Yes
    Intel® Demand Based Switching No
    Thermal Monitoring Technologies Yes
    Intel® Fast Memory Access Yes
    Intel® Flex Memory Access Yes
    Intel® Identity Protection Technology ‡ Yes
Security & Reliability
    Intel® AES New Instructions Yes
    Secure Key Yes
    Intel® Trusted Execution Technology ‡ No
    Execute Disable Bit ‡ Yes
    Anti-Theft Technology Yes
#78
Last OT reply from my side :wink: It does have HT (most of the mobile CPU’s do use it) https://ark.intel.com/products/65707/Intel-Core-i5-3317U-Processor-3M-Cache-up-to-2-60-GHz-
But just wait, until 4.20 hit’s the market and we will see, how “much” performance we will loose over safety.
#79
after I updated the system, when I open the “Downloads” folder pcmanfm automatically crashes. I don’t know if this is related to the update but this didn’t occur before.
#80
areyou talking about Hyper-Threading right?
so i am waiting for a disaster ?
will manjaro include the patch on 4.19 ?
#81
Every time there is a huge update to XFCE-gtk3, the theming (icons in Thunar, theming of the panel/applets/notification area icons) all revert to gnome/adwaita and font size becomes tiny on my hidpi laptap. I’m sure it’s something to do with XFCE-gtk3 settings/configurations, but I don’t know what.
It always takes one or 2 updates after that to get it back to normal.
Everything works, it just looks terrible for a while.
My laptop used to run Unstable but I had switched back to Stable repo.
I haven’t updated my PC xfce-gtk3 install yet, but that one isn’t so noticeable because most of the time I’m logged into Budgie on that one.
(I haven’t updated my original xfce-gtk2 install but I don’t foresee issues with that. Never a problem there).
#82
Will I lose any desktop settings I tweaked with --overwrite? Or are my cinnamon settings stored somewhere else?
