[Stable Update] 2018-12-02 - Kernels, Plasma, Mesa, Cinnamon, Gnome, Deepin, XFCE, Vulkan
I can’t stress this one enough. Especially if you use the Gnome, Deepin, Cinnamon or KDE desktop environment, it is STRONGLY recommended NOT to update in a graphical user session. Therefore logout and switch to a TTY!
How do I do updates via TTY-terminal?
  • Press CTRL+ALT+F2 (or F3, F4, F5, F6) to go into a pure command line interface.
  • Log in with your credentials.
  • Once logged in, you’ll have access to a CLI shell, like if you were using a terminal. Use pamac upgrade or sudo pacman -Syyu (or other equivalent command) to update your system.
  • Keep an close eye on the update and only reboot after you had fixed issues!
To go back to your regular desktop, press CTRL+ALT+F7. On some systems, it can be CTRL+ALT+F1 instead.
Hi community,
Welcome to another stable update.
So what do we have with this one?
  • We updated most of our Kernels
  • Worked on a regression with Virtualbox and Pamac
  • Thunderbird is now at 60.3.2
  • Texlive got newer packages and regular package-cleanups were done
  • We updated Mesa to 18.2.6
  • Firefox is now at its 14th beta release of v64 development series
  • We updated Plasma to 5.14.4
  • Newer packages got added to Cinnamon, Gnome, Deepin and XFCE
  • Vulkan got a refresh
  • We updated Systemd to it’s latest stable-snapshot.
  • The linux-firmware got updated to 20181026.1cb4e51-1
  • Nvidia driver got updated again to 415.18
  • Lots of python and haskell updates. Most packages are rebuilds due to the BUILDINFO rebuild
We hope with all these changes Manjaro to be more efficient for you all.
The Iconic Spitfire: Now Quad-Core!
jpg%3Alarge
Visit StationX now!
Manjaro v18.0.1 RC1 released!
If you are curious about the latest Manjaro-Illyria 18.0.1 release, you now have the opportunity to download XFCE Edition with the latest 4.13 packages, aswell as our most recent styling efforts. Our KDE fans may try our KDE Edition with the latest KDE v5.14 instead. And our GNOME fans may try our Gnome Edition with the latest GNOME v3.30.
Current supported Kernels
  • linux316 3.16.61
  • linux318 3.18.128 [EOL]
  • linux44 4.4.166
  • linux49 4.9.142
  • linux414 4.14.85
  • linux417 4.17.19 [EOL]
  • linux418 4.18.20 [EOL]
  • linux419 4.19.6
  • linux414-rt 4.14.78_rt47
  • linux416-rt 4.16.18_rt11
  • linux418-rt 4.18.16_rt9
Sync Package Updates (Sun Dec 2 08:47:30 CET 2018)
  • stable community x86_64: 1620 new and 1568 removed package(s)
  • stable core x86_64: 43 new and 45 removed package(s)
  • stable extra x86_64: 722 new and 871 removed package(s)
  • stable multilib x86_64: 97 new and 101 removed package(s)
A detailed list of all changes can be found here.
0 voters
Known issues and solutions
When checking for updates, Pamac (GUI) freeze at a certain percentage.
Devs are aware of this problem.
Fortunately, this problem doesn’t happens everytime. If you have the patience to kill the process each time Pamac freezes, eventually, you should be able to get through the process and be able to apply updates.
As far as we know, Pamac CLI doesn’t seems to be affected by this problem at all.
Items from previous update sets
i3 changed its default config path
It seems that (from version >= 4.16) i3 is looking for its configuration in ~/.config/i3/config instead of ~/.i3/config.
Copy your config to the new path and all should work as before. (reported from an i3-gaps user).
I can’t open Nemo with elevated privileges (as root)
Workaround found: Use the dbus-x11 package instead of the regular dbus package. This package is available in the official repositories and provides dbus compiled without the --without-x option.
To replace dbus with dbus-x11 package, simply install dbus-x11 with your favorite package manager: dbus will be replaced by dbus-x11.
Pamac: “Failed to commit transaction - Transaction not prepared” at the end
So far, it has only been a false alarm: updates are applied successfully.
AMD-Ucode introduction
Unless you’ve already done this previously, All users of AMD-APUs/CPUs should install this update like this:
sudo pacman -Syyu
sudo pacman -S amd-ucode
sudo pacman -R intel-ucode
sudo update-grub
Step 3 is optional.
Rebuilding fontconfig cache: failed to write cache
Please ignore this message. Upstream already works on a solution. More about the issue here.
LibreOffice has no window decoration in KDE
New line export SAL_USE_VCLPLUGIN=gtk3_kde5, once merged into existing /etc/profile.d/libreoffice-fresh.sh , fixes a moderately longterm issue. If it doesn’t work for you, you may use gtk instead of gtk3_kde5 as UI framework.
Installing glibc (2.28-4) breaks the dependency “glibc=2.27” required by lib32-glibc
Install the update either:
  • from terminal: sudo pacman -Syu or;
  • with Octopi instead of Pamac.
Something using Perl/Python/glibc broke
Rebuilds needed!
  • If it’s an AUR package, try to reinstall it from AUR. It most likely needs to be rebuilt.
  • If it’s a repo package, please report and check back regularly for updates.
I’ve lost a Thunderbird addon/feature
Thunderbird 60 disables incompatible addons by default. There’s an about:config switch should you want to force-enable the addon, but many addons simply will not work with the newer Quantum-based Thunderbird.
Read more about Thunderbird 60 here: Thunderbird 60
Firefox - WebGL not working anymore
You may try the following solution:
Open about:config and set security.sandbox.content.read_path_whitelist to /sys/.
libutf8proc>=2.1.1-3 update may require manual intervention
This should normally be automatically fixed via manjaro-system update.
The libutf8proc package prior to version 2.1.1-3 had an incorrect soname link. This has been fixed in 2.1.1-3, so the upgrade will need to overwrite the untracked soname link created by ldconfig. If you get an error
libutf8proc: /usr/lib/libutf8proc.so.2 exists in filesystem
when updating, use
pacman -Suy --overwrite usr/lib/libutf8proc.so.2
to perform the upgrade.
Pamac: “Invalid or corrupted package.”
If you receive an “Invalid or corrupted package.” error message with Pamac and if the details contains an output similar to the following:
Details
Starting full system upgrade...
Preparing...
Resolving dependencies...
Checking inter-conflicts...
Downloading...
Downloading manjaro-system-20180716-1-any.pkg.tar.xz...
Checking keyring...
Checking integrity...
Loading packages files...
Checking file conflicts...
Checking available disk space...
Upgrading manjaro-system (20180702-1 -> 20180716-1)...
==> Fix libutf8proc upgrade ...
resolving dependencies...
Packages (1) libutf8proc-2.1.1-4
Total Download Size:   0.05 MiB
Total Installed Size:  0.32 MiB
Net Upgrade Size:      0.00 MiB
:: Retrieving packages...
downloading libutf8proc-2.1.1-4-x86_64.pkg.tar.xz...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
upgrading libutf8proc...
(1/1) Arming ConditionNeedsUpdate...
Warning: lock file missing /var/lib/pacman/db.lck
Error: could not open file /var/lib/pacman/local/libutf8proc-2.1.1-2/files: No such file or directory
Warning: could not fully load metadata for package libutf8proc-2.1.1-2
Failed to prepare transaction:
invalid or corrupted package
Try the following steps: close Pamac window first, then launch it again and start the update procedure again. It should continue from where it left off.
Issues with folder view widget in KDE v5.13
KDE introduced a new setting for icon sizes. Now you’re able to define also the size for your panel. If you have a high-DPI display, you may want to increase the value. This will fix the display issue with given widget.
icon-kde-513
Pulseaudio changes
With this update we have a /etc/pulse/default.pa.pacnew. It may be necessary to merge (some lines related to “GSettings” in /etc/pulse/default.pa ) if ‘default.pa’ has been customised.
File conflict engrampa.tap
thunar-archive-plugin: /usr/lib/xfce4/thunar-archive-plugin/engrampa.tap exists in filesystem (owned by engrampa-thunar-plugin)
thunar-archive-plugin has added native support for the Engrampa archive manager. engrampa-thunar-plugin is no longer needed. Remove engrampa-thunar-plugin to continue with the update.
No issues to report yet! Manjaro Deepin Edition, working great thank you!
All works fine here. Thanks to the Manjaro-Team :+1:
regards
caho
Update went fine, had to update in a terminal because Pamac froze at 45%.
i3wm ~690 MB , no problem.
Yup, this is a known bug unfortunately, but it doesn’t happens everytime. Eventually, it checks for updates without freezing (if you have the patience to kill Pamac each time it fails).
CLI Pamac seems not to be affected by this problem though.
This message came in the terminal after downloading the update:
Error: could not open file /var/lib/pacman/local/bolt-0.6-1/desc: No such file or directory
Not sure if it is important, everything seemed to have succeeded.
Yup but where’s Deepin 15.8?
You do realize, @oberon also has a private life?
https://www.deepin.org/en/developer-community/planning/
Release Plan
https://www.deepin.org/en/download/
deepin 15.6 June 2018
deepin 15.7 August 2018
deepin 15.8 November 2018
I added in wiki post some information about how to apply the following recommendation: " we recommend to do it within a TTY via pamac upgrade or sudo pacman -Syyu", as it might be something that some people are not aware of (or not exactly with those words).
Feel free to correct it or add more precision if needed.
Xfce updated from TTY, no issues.
Manjaro-Gnome (now) with Kernel 4.19.6.
Update via TTY (about 1.5 GB) worked fine. Puh! :smile:
Upgrade do fine with manjaro gnome. But i have crash with gnome-boxes :
Le processus 12637 (gnome-boxes) a généré un fichier « core »
Process 12637 (gnome-boxes) of user 1000 dumped core.
Stack trace of thread 12637:
#0  0x00007f6fb92d6c3d osinfo_list_get_nth (libosinfo-1.0.so.0)
#1  0x000055d4ec70bc17 n/a (gnome-boxes)
#2  0x000055d4ec76a7e5 n/a (gnome-boxes)
#3  0x00007f6fb95eb194 n/a (libgio-2.0.so.0)
#4  0x00007f6fb95edb77 n/a (libgio-2.0.so.0)
#5  0x000055d4ec73d297 n/a (gnome-boxes)
#6  0x000055d4ec73bab5 n/a (gnome-boxes)
#7  0x00007f6fb95eb194 n/a (libgio-2.0.so.0)
#8  0x00007f6fb95edb77 n/a (libgio-2.0.so.0)
#9  0x000055d4ec73bbf8 n/a (gnome-boxes)
#10 0x000055d4ec73bdba n/a (gnome-boxes)
#11 0x00007f6fba2013d5 g_closure_invoke (libgobject-2.0.so.0)
#12 0x00007f6fba1ee195 n/a (libgobject-2.0.so.0)
#13 0x00007f6fba1f201e g_signal_emit_valist (libgobject-2.0.so.0)
#14 0x00007f6fba1f2a80 g_signal_emit (libgobject-2.0.so.0)
#15 0x000055d4ec748fa3 n/a (gnome-boxes)
#16 0x000055d4ec745395 n/a (gnome-boxes)
#17 0x00007f6fb95eb194 n/a (libgio-2.0.so.0)
#18 0x00007f6fb95edb77 n/a (libgio-2.0.so.0)
#19 0x000055d4ec6f2612 n/a (gnome-boxes)
#20 0x00007f6fba117271 g_main_context_dispatch (libglib-2.0.so.0)
#21 0x00007f6fba118f89 n/a (libglib-2.0.so.0)
#22 0x00007f6fba118fce g_main_context_iteration (libglib-2.0.so.0)
#23 0x00007f6fb95c77ee g_application_run (libgio-2.0.so.0)
#24 0x000055d4ec74cf3a _vala_main (gnome-boxes)
#25 0x00007f6fba30f223 __libc_start_main (libc.so.6)
#26 0x000055d4ec6e719e _start (gnome-boxes)
Stack trace of thread 12638:
#0  0x00007f6fba3dbc21 __poll (libc.so.6)
#1  0x00007f6fba118ee0 n/a (libglib-2.0.so.0)
#2  0x00007f6fba118fce g_main_context_iteration (libglib-2.0.so.0)
#3  0x00007f6fba119022 n/a (libglib-2.0.so.0)
#4  0x00007f6fba0e23eb n/a (libglib-2.0.so.0)
#5  0x00007f6fba4b6a9d start_thread (libpthread.so.0)
#6  0x00007f6fba3e6b23 __clone (libc.so.6)
Stack trace of thread 12639:
#2  0x00007f6fba119f62 g_main_loop_run (libglib-2.0.so.0)
#3  0x00007f6fb9588c28 n/a (libgio-2.0.so.0)
Stack trace of thread 12652:
#0  0x00007f6fba3e14ed syscall (libc.so.6)
#1  0x00007f6fba0c7461 g_cond_wait (libglib-2.0.so.0)
#2  0x00007f6fba145cec n/a (libglib-2.0.so.0)
#3  0x00007f6fba0e9ba9 n/a (libglib-2.0.so.0)
Stack trace of thread 12644:
#0  0x00007f6fba4bce5b pthread_cond_timedwait@@GLIBC_2.3.2 (libpthread.so.0)
#1  0x00007f6fb06fc1bc _ZN3WTF15ThreadCondition9timedWaitERNS_5MutexENS_8WallTimeE (libjavascriptcoregtk-4.0.so.18)
#2  0x0000000100000000 n/a (n/a)
and when i run gnome-boxes with terminal i have
(gnome-boxes:13827): Gtk-WARNING **: 19:20:54.007: GtkFlowBox with a model will ignore sort and filter functions
(gnome-boxes:13827): Gtk-WARNING **: 19:20:54.008: GtkListBox with a model will ignore sort and filter functions
(gnome-boxes:13827): Boxes-WARNING **: 19:20:56.161: wizard-source.vala:450: Failed to find OS with ID 'http://redhat.com/rhel/7.6': Unknown OS ID 'http://redhat.com/rhel/7.6'
Workaround: downgrade of gnome-boxes
EDIT: there’s also a fix. Check the last three comments in the issue thread above.
https://bugs.archlinux.org/task/60898
So Arch/manjaro need update osinfo-db for fixe issue ?
Yes.
You can try osinfo-db-git from AUR.
Cinnamon with Kernel Kernel 4.19.6
Installed via TTY, but Cinnamon session has been terminated at the end:
journalctl:
Dez 02 19:08:37 GBi7 systemd[1]: ^[[0;1;39mFailed to get initial list of names: Connection timed out
Dez 02 19:08:37 GBi7 lightdm[773]: ^[[0;1;39mpam_systemd(lightdm-autologin:session): Failed to release session: Connection timed out
Dez 02 19:08:38 GBi7 systemd[778]: ^[[0;1;39mFailed to start Sound Service.
Dez 02 19:10:45 GBi7 cinnamon-session[8099]: ^[[0;1;39mGLib-GIO-CRITICAL: t+74,93653s: g_dbus_connection_call_sync_internal: assertion 'G_IS_DBUS_$
Dez 02 19:10:47 GBi7 kernel: ^[[0;1;39mwatchdog: watchdog0: watchdog did not stop!
After reboot everything seems okay.
pacman.log
[2018-12-02 19:03] [PACMAN] Running ‘pacman -Syyu’
[2018-12-02 19:03] [PACMAN] synchronizing package lists
[2018-12-02 19:03] [PACMAN] starting full system upgrade
[2018-12-02 19:05] [PACMAN] Running ‘pacman -Syyu’
[2018-12-02 19:05] [PACMAN] synchronizing package lists
[2018-12-02 19:05] [ALPM] transaction started
[2018-12-02 19:05] [ALPM] upgraded archlinux-keyring (20181031-1 -> 20181128-1)
[2018-12-02 19:05] [ALPM-SCRIPTLET] ==> Appending keys from archlinux.gpg…
[2018-12-02 19:05] [ALPM-SCRIPTLET] ==> Locally signing trusted keys in keyring…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Locally signing key DDB867B92AA789C165EEFA799B729B06A680C281…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Locally signing key 684148BB25B49E986A4944C55184252D824B18E8…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Locally signing key 91FFE0700E80619CEB73235CA88E23E377514E00…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Locally signing key AB19265E5D7D20687D303246BA1DFB64FFF979E7…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Locally signing key 0E8B644079F599DFC1DDC3973348882F6AC6A4C2…
[2018-12-02 19:05] [ALPM-SCRIPTLET] ==> Importing owner trust values…
[2018-12-02 19:05] [ALPM-SCRIPTLET] ==> Disabling revoked keys in keyring…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 7FA647CD89891DEDC060287BB9113D1ED21E1A55…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key D4DE5ABDE2A7287644EAC7E36D1A9E70E19DAA50…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 40440DC037C05620984379A6761FAD69BA06C6A9…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key B1F2C889CB2CCB2ADA36D963097D629E437520BD…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 5357F3B111688D88C1D88119FCF2CB179205AC90…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 5559BC1A32B8F76B3FCCD9555FA5E5544F010D48…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key BC1FBE4D2826A0B51E47ED62E2539214C6C11350…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 63F395DE2D6398BBE458F281F2DBB4931985A992…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 8F76BEEA0289F9E1D3E229C05F946DED983D4366…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 4FCF887689C41B09506BE8D5F3E1D5C5D30DB0AD…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key FB871F0131FEA4FB5A9192B4C8880A6406361833…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 81D7F8241DB38BC759C80FCE3A726C6170E80477…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 5E7585ADFF106BFFBBA319DC654B877A0864983E…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 50F33E2E5B0C3D900424ABE89BDCF497A4BBCC7F…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key E7210A59715F6940CF9A4E36A001876699AD6E84…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 65EEFE022108E2B708CBFCF7F9E712E59AF5F22A…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key F5A361A3A13554B85E57DDDAAF7EF7873CFD4BB6…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 40776A5221EF5AD468A4906D42A1DB15EC133BAD…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 8CF934E339CAD8ABF342E822E711306E3C4F88BC…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 5696C003B0854206450C8E5BE613C09CB4440678…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 5A2257D19FF7E1E0E415968CE62F853100F0D0F0…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 9515D8A8EAB88E49BB65EDBCE6B456CAF15447D5…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 4A8B17E20B88ACA61860009B5CED81B7C2E5C0D2…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 0B20CA1931F5DA3A70D0F8D2EA6836E1AB441196…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 34C5D94FE7E7913E86DC427E7FB1A3800C84C0A5…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 39F880E50E49A4D11341E8F939E4F17F295AFBF4…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 66BD74A036D522F51DD70A3C7F2A16726521E06D…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 07DFD3A0BC213FA12EDC217559B3122E2FA915EC…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 44D4A033AC140143927397D47EFD567D4C7EA887…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 27FFC4769E19F096D41D9265A04F9397CDFD6BB0…
[2018-12-02 19:05] [ALPM-SCRIPTLET] -> Disabling key 8840BD07FC24CB7CE394A07CCF7037A4F27FB7DA…
[2018-12-02 19:05] [ALPM-SCRIPTLET] ==> Updating trust database…
[2018-12-02 19:05] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2019-03-29
[2018-12-02 19:05] [ALPM] transaction completed
[2018-12-02 19:05] [ALPM] running ‘systemd-update.hook’…
[2018-12-02 19:05] [PACMAN] starting full system upgrade
[2018-12-02 19:06] [ALPM] running ‘firefox-pre.hook’…
[2018-12-02 19:06] [ALPM] running ‘thunderbird-pre.hook’…
[2018-12-02 19:06] [ALPM] transaction started
[2018-12-02 19:06] [ALPM] upgraded libcap (2.25-2 -> 2.26-1)
[2018-12-02 19:06] [ALPM] upgraded libsystemd (239.6-1 -> 239.303-1)
[2018-12-02 19:06] [ALPM] upgraded aalib (1.4rc5-12 -> 1.4rc5-13)
[2018-12-02 19:06] [ALPM] upgraded acpid (2.0.30-1 -> 2.0.31-1)
[2018-12-02 19:06] [ALPM] upgraded libcroco (0.6.12+4+g9ad7287-1 -> 0.6.12+4+g9ad7287-2)
[2018-12-02 19:06] [ALPM] upgraded libjpeg-turbo (2.0.0-1 -> 2.0.1-1)
[2018-12-02 19:06] [ALPM] upgraded libtiff (4.0.9-2 -> 4.0.10-1)
[2018-12-02 19:07] [ALPM] upgraded harfbuzz (2.1.1-1 -> 2.2.0-1)
[2018-12-02 19:07] [ALPM] upgraded libxrender (0.9.10-1 -> 0.9.10-2)
[2018-12-02 19:07] [ALPM] upgraded pixman (0.34.0-1 -> 0.36.0-1)
[2018-12-02 19:07] [ALPM] upgraded librsvg (2:2.44.8-1 -> 2:2.44.9-1)
[2018-12-02 19:07] [ALPM] upgraded adwaita-icon-theme (3.30.0-1 -> 3.30.1-1)
[2018-12-02 19:07] [ALPM] upgraded alsa-lib (1.1.7-1 -> 1.1.7-2)
[2018-12-02 19:07] [ALPM] upgraded amd-ucode (20181026.1cb4e51-0 -> 20181026.1cb4e51-1)
[2018-12-02 19:07] [ALPM] upgraded archlinux-appstream-data (20181016-1 -> 20181117-1)
[2018-12-02 19:07] [ALPM] upgraded babl (0.1.58-1 -> 0.1.60+11+g6b032aa-1)
[2018-12-02 19:07] [ALPM] upgraded bluez-tools (0.2.0-1 -> 0.2.0-2)
[2018-12-02 19:07] [ALPM] upgraded openssl (1.1.1-1 -> 1.1.1.a-1)
[2018-12-02 19:07] [ALPM] upgraded ca-certificates-utils (20180821-1 -> 20181109-1)
[2018-12-02 19:07] [ALPM] upgraded ca-certificates-mozilla (3.40-1 -> 3.40-2)
[2018-12-02 19:07] [ALPM] upgraded ca-certificates (20180821-1 -> 20181109-1)
[2018-12-02 19:07] [ALPM] upgraded cairomm (1.12.2-2 -> 1.12.2-3)
[2018-12-02 19:07] [ALPM] upgraded nss (3.40-1 -> 3.40-2)
[2018-12-02 19:07] [ALPM] upgraded iptables (1:1.8.0-1 -> 1:1.8.2-1)
[2018-12-02 19:07] [ALPM] upgraded hwids (20180518-1 -> 20180917-1)
[2018-12-02 19:07] [ALPM] upgraded keyutils (1.5.11-1 -> 1.6-1)
[2018-12-02 19:07] [ALPM] upgraded popt (1.16-9 -> 1.16-10)
[2018-12-02 19:07] [ALPM] upgraded systemd (239.6-1 -> 239.303-1)
[2018-12-02 19:07] [ALPM] upgraded pciutils (3.6.1-1 -> 3.6.2-1)
[2018-12-02 19:07] [ALPM] upgraded flac (1.3.2-1 -> 1.3.2-2)
[2018-12-02 19:07] [ALPM] upgraded giflib (5.1.4-1 -> 5.1.4-2)
[2018-12-02 19:07] [ALPM] upgraded libwebp (1.0.0-1 -> 1.0.1-1)
[2018-12-02 19:07] [ALPM] upgraded ttf-bitstream-vera (1.10-11 -> 1.10-12)
[2018-12-02 19:07] [ALPM] upgraded ttf-droid (20121017-5 -> 20121017-6)
[2018-12-02 19:07] [ALPM] upgraded ttf-liberation (2.00.1-7 -> 2.00.1-8)
[2018-12-02 19:07] [ALPM] upgraded libmodplug (0.8.9.0-1 -> 0.8.9.0-2)
[2018-12-02 19:07] [ALPM] upgraded libraw1394 (2.1.2-1 -> 2.1.2-2)
[2018-12-02 19:07] [ALPM] upgraded libxv (1.0.11-1 -> 1.0.11-2)
[2018-12-02 19:07] [ALPM] upgraded opencore-amr (0.1.5-1 -> 0.1.5-2)
[2018-12-02 19:07] [ALPM] upgraded speex (1.2.0-1 -> 1.2.0-2)
[2018-12-02 19:07] [ALPM] upgraded v4l-utils (1.16.1-1 -> 1.16.2-1)
[2018-12-02 19:07] [ALPM] upgraded libasyncns (0.8+3+g68cd5af-1 -> 0.8+3+g68cd5af-2)
[2018-12-02 19:07] [ALPM] upgraded libsndfile (1.0.28-1 -> 1.0.28-2)
[2018-12-02 19:07] [ALPM] upgraded libxi (1.7.9-1 -> 1.7.9-2)
[2018-12-02 19:07] [ALPM] upgraded libxtst (1.2.3-1 -> 1.2.3-2)
[2018-12-02 19:07] [ALPM] upgraded libsamplerate (0.1.9-1 -> 0.1.9-2)
[2018-12-02 19:07] [ALPM] upgraded libunwind (1.2.1-1 -> 1.2.1-2)
[2018-12-02 19:07] [ALPM] upgraded llvm-libs (7.0.0-1 -> 7.0.0-2)
[2018-12-02 19:07] [ALPM] upgraded mesa (18.2.5-0 -> 18.2.6-0)
[2018-12-02 19:07] [ALPM] upgraded libcanberra (0.30+2+gc0620e4-1 -> 0.30+2+gc0620e4-2)
[2018-12-02 19:07] [ALPM] upgraded wayland-protocols (1.16-1 -> 1.17-1)
[2018-12-02 19:07] [ALPM] upgraded chromium (70.0.3538.110-0 -> 70.0.3538.110-1)
[2018-12-02 19:07] [ALPM] upgraded libcanberra-pulse (0.30+2+gc0620e4-1 -> 0.30+2+gc0620e4-2)
[2018-12-02 19:07] [ALPM] upgraded libnotify (0.7.7-1 -> 0.7.7-2)
[2018-12-02 19:07] [ALPM] upgraded libwacom (0.31-1 -> 0.32-1)
[2018-12-02 19:07] [ALPM] upgraded iso-codes (3.79-1 -> 4.1-1)
[2018-12-02 19:07] [ALPM] upgraded libusbmuxd (1.0.10+13+gc724e70-1 -> 1.0.10+29+g9db5747-1)
[2018-12-02 19:07] [ALPM] upgraded usbmuxd (1.1.0+48+g1cc8b34-1 -> 1.1.0+48+g1cc8b34-2)
[2018-12-02 19:07] [ALPM] upgraded libimobiledevice (1.2.0+66+g5a85432-2 -> 1.2.0+87+g92c5462-1)
[2018-12-02 19:07] [ALPM] upgraded cinnamon-settings-daemon (4.0.1-1 -> 4.0.2-1)
[2018-12-02 19:07] [ALPM] upgraded libkeybinder3 (0.3.2-1 -> 0.3.2-2)
[2018-12-02 19:07] [ALPM] upgraded gobject-introspection-runtime (1.58.0+8+gfdaa3b1a-1 -> 1.58.1-1)
[2018-12-02 19:07] [ALPM] upgraded startup-notification (0.12-5 -> 0.12-6)
[2018-12-02 19:07] [ALPM] upgraded hunspell (1.6.2-1 -> 1.7.0-1)
[2018-12-02 19:07] [ALPM] upgraded enchant (2.2.3-1 -> 2.2.3-2)
[2018-12-02 19:07] [ALPM] upgraded harfbuzz-icu (2.1.1-1 -> 2.2.0-1)
[2018-12-02 19:07] [ALPM] upgraded webkit2gtk (2.22.3-1 -> 2.22.4-1)
[2018-12-02 19:07] [ALPM] upgraded muffin (4.0.1-1 -> 4.0.3-1)
[2018-12-02 19:07] [ALPM] upgraded xapps (1.4.1-1 -> 1.4.4-1)
[2018-12-02 19:07] [ALPM] upgraded fuse-common (3.2.6-1 -> 3.3.0-1)
[2018-12-02 19:07] [ALPM] upgraded mdadm (4.0-1 -> 4.0-2)
[2018-12-02 19:07] [ALPM] upgraded xfsprogs (4.18.0-1 -> 4.19.0-1)
[2018-12-02 19:07] [ALPM] upgraded nemo (4.0.1-1 -> 4.0.3-1)
[2018-12-02 19:07] [ALPM] upgraded python-cairo (1.17.0-2 -> 1.18.0-1)
[2018-12-02 19:07] [ALPM] upgraded pygobject-devel (3.30.2-1 -> 3.30.4-1)
[2018-12-02 19:07] [ALPM] upgraded python-gobject (3.30.2-1 -> 3.30.4-1)
[2018-12-02 19:07] [ALPM] upgraded cogl (1.22.2+11+g811f285a-1 -> 1.22.2+22+ge023a361-1)
[2018-12-02 19:07] [ALPM] upgraded clutter (1.26.2-1 -> 1.26.2-2)
[2018-12-02 19:07] [ALPM] upgraded mobile-broadband-provider-info (20170310-1 -> 20170310-2)
[2018-12-02 19:07] [ALPM] upgraded python-psutil (5.4.7-1 -> 5.4.8-1)
[2018-12-02 19:07] [ALPM] upgraded libssh2 (1.8.0-2 -> 1.8.0-3)
[2018-12-02 19:07] [ALPM] upgraded cinnamon (4.0.1-1 -> 4.0.3-1.1)
[2018-12-02 19:07] [ALPM] upgraded cinnamon-translations (4.0.0-0 -> 4.0.1-1)
[2018-12-02 19:07] [ALPM] upgraded ijs (0.35-1 -> 0.35-2)
[2018-12-02 19:07] [ALPM] upgraded cups-filters (1.21.3-3 -> 1.21.4-1)
[2018-12-02 19:07] [ALPM] upgraded cups-pk-helper (0.2.6-1 -> 0.2.6-2)
[2018-12-02 19:07] [ALPM] upgraded ecryptfs-utils (111-2 -> 111-3)
[2018-12-02 19:07] [ALPM] upgraded f2fs-tools (1.11.0-2 -> 1.12.0-2)
[2018-12-02 19:07] [ALPM] upgraded firefox (63.0.3-0 -> 63.0.3-1)
[2018-12-02 19:07] [ALPM] upgraded firefox-i18n-de (63.0.3-0 -> 63.0.3-1)
[2018-12-02 19:07] [ALPM] upgraded fprintd (0.8.1-1 -> 0.8.1-2)
[2018-12-02 19:07] [ALPM] upgraded galculator (2.1.4-3 -> 2.1.4-4)
[2018-12-02 19:07] [ALPM] upgraded libraw (0.19.0-1 -> 0.19.1-1)
[2018-12-02 19:07] [ALPM] upgraded metis (5.1.0.p3-1 -> 5.1.0.p3-2)
[2018-12-02 19:07] [ALPM] upgraded gegl (0.4.12-1 -> 0.4.12+62+gd2302106e-1)
[2018-12-02 19:07] [ALPM] upgraded libpaper (1.1.24-10 -> 1.1.24-11)
[2018-12-02 19:07] [ALPM] upgraded ghostscript (9.25-4 -> 9.26-1)
[2018-12-02 19:07] [ALPM] upgraded git (2.19.1-1 -> 2.19.2-1)
[2018-12-02 19:07] [ALPM] upgraded glib-perl (1.326-2 -> 1.328-1)
[2018-12-02 19:07] [ALPM] upgraded gnome-icon-theme-symbolic (3.12.0-4 -> 3.12.0-5)
[2018-12-02 19:07] [ALPM] upgraded gnome-icon-theme (3.12.0-4 -> 3.12.0-5)
[2018-12-02 19:07] [ALPM] upgraded python-setuptools (1:40.5.0-1 -> 1:40.6.2-1)
[2018-12-02 19:07] [ALPM] upgraded gobject-introspection (1.58.0+8+gfdaa3b1a-1 -> 1.58.1-1)
[2018-12-02 19:07] [ALPM] upgraded gperf (3.1-1 -> 3.1-2)
[2018-12-02 19:07] [ALPM] upgraded perl-libintl-perl (1.30-1 -> 1.31-1)
[2018-12-02 19:07] [ALPM] upgraded gprename (20160905-1 -> 20160905-2)
[2018-12-02 19:07] [ALPM] upgraded sdl (1.2.15-9 -> 1.2.15-10)
[2018-12-02 19:07] [ALPM] upgraded mjpegtools (2.1.0-3 -> 2.1.0-4)
[2018-12-02 19:07] [ALPM] upgraded libofa (0.9.3-7 -> 0.9.3-8)
[2018-12-02 19:07] [ALPM] upgraded rtmpdump (1:2.4.r96.fa8646d-3 -> 1:2.4.r96.fa8646d-4)
[2018-12-02 19:07] [ALPM] upgraded wildmidi (0.4.2-1 -> 0.4.3-1)
[2018-12-02 19:07] [ALPM] upgraded vulkan-icd-loader (1.1.85+2969+5abee6173-1 -> 1.1.92+2999+abe5c2b3c-1)
[2018-12-02 19:07] [ALPM] upgraded soundtouch (2.1.0-1 -> 2.1.1-1)
[2018-12-02 19:07] [ALPM] upgraded libdc1394 (2.2.5-1 -> 2.2.5-2)
[2018-12-02 19:07] [ALPM] upgraded libmpcdec (1:0.1+r475-1 -> 1:0.1+r475-2)
[2018-12-02 19:07] [ALPM] upgraded gst-plugins-bad (1.14.4-3 -> 1.14.4-4)
[2018-12-02 19:07] [ALPM] upgraded gtkmm (2.24.5-2 -> 1:2.24.5-3)
[2018-12-02 19:07] [ALPM] upgraded hdparm (9.57-1 -> 9.58-1)
[2018-12-02 19:07] [ALPM] upgraded intltool (0.51.0-3 -> 0.51.0-4)
[2018-12-02 19:07] [ALPM] upgraded ipw2100-fw (1.3-8 -> 1.3-9)
[2018-12-02 19:07] [ALPM] upgraded ipw2200-fw (3.1-6 -> 3.1-7)
[2018-12-02 19:07] [ALPM] upgraded tslib (1.17-1 -> 1.18-1)
[2018-12-02 19:07] [ALPM] upgraded kvantum-manjaro (0.11.0-1 -> 0.12.0-1)
[2018-12-02 19:07] [ALPM] upgraded ldb (1:1.3.6-1 -> 1:1.4.3-1)
[2018-12-02 19:07] [ALPM] upgraded lib32-flac (1.3.2-1 -> 1.3.2-2)
[2018-12-02 19:07] [ALPM] upgraded lib32-flex (2.6.4-1 -> 2.6.4-2)
[2018-12-02 19:07] [ALPM] upgraded lib32-gettext (0.19.8.1-1 -> 0.19.8.1-2)
[2018-12-02 19:07] [ALPM] upgraded lib32-gmp (6.1.2-1 -> 6.1.2-2)
[2018-12-02 19:07] [ALPM] upgraded lib32-zlib (1.2.11-1 -> 1.2.11-2)
[2018-12-02 19:07] [ALPM] upgraded lib32-harfbuzz (2.1.1-1 -> 2.2.0-1)
[2018-12-02 19:07] [ALPM] upgraded lib32-libasyncns (0.8+3+g68cd5af-1 -> 0.8+3+g68cd5af-2)
[2018-12-02 19:07] [ALPM] upgraded lib32-libcap (2.25-1 -> 2.25-2)
[2018-12-02 19:07] [ALPM] upgraded lib32-libsndfile (1.0.28-1 -> 1.0.28-2)
[2018-12-02 19:07] [ALPM] installed lib32-lz4 (1.8.3-1)
[2018-12-02 19:07] [ALPM] installed lib32-zstd (1.3.7-1)
[2018-12-02 19:07] [ALPM] upgraded lib32-libtiff (4.0.9-1 -> 4.0.10-1)
[2018-12-02 19:07] [ALPM] upgraded lib32-libxfixes (5.0.3-1 -> 5.0.3-2)
[2018-12-02 19:07] [ALPM] upgraded lib32-libxi (1.7.9-1 -> 1.7.9-2)
[2018-12-02 19:07] [ALPM] upgraded lib32-libxrender (0.9.10-1 -> 0.9.10-2)
[2018-12-02 19:07] [ALPM] upgraded lib32-libxrandr (1.5.1-1 -> 1.5.1-2)
[2018-12-02 19:07] [ALPM] upgraded lib32-libxtst (1.2.3-1 -> 1.2.3-2)
[2018-12-02 19:07] [ALPM] upgraded lib32-lm_sensors (3.4.0-1 -> 3.4.0-2)
[2018-12-02 19:07] [ALPM] upgraded lib32-mesa (18.2.5-0 -> 18.2.6-0)
[2018-12-02 19:07] [ALPM] upgraded lib32-mesa-vdpau (18.2.5-0 -> 18.2.6-0)
[2018-12-02 19:07] [ALPM] upgraded lib32-systemd (239.6-1 -> 239.303-1)
[2018-12-02 19:07] [ALPM] upgraded lib32-vulkan-icd-loader (1.1.85+2969+5abee6173-1 -> 1.1.92+2999+abe5c2b3c-1)
[2018-12-02 19:07] [ALPM] upgraded lib32-vulkan-intel (18.2.5-0 -> 18.2.6-0)
[2018-12-02 19:07] [ALPM] upgraded lib32-vulkan-radeon (18.2.5-0 -> 18.2.6-0)
[2018-12-02 19:07] [ALPM] upgraded libcaca (0.99.beta19-1 -> 0.99.beta19-2)
[2018-12-02 19:07] [ALPM] upgraded liblangtag (0.6.2-1 -> 0.6.2-2)
[2018-12-02 19:07] [ALPM] installed spirv-tools (2018.5-1)
[2018-12-02 19:07] [ALPM] installed glslang (7.9.2888-2)
[2018-12-02 19:07] [ALPM] installed shaderc (2018.0-2)
[2018-12-02 19:07] [ALPM] upgraded libplacebo (0.5.0-1 -> 0.6.0-1)
[2018-12-02 19:07] [ALPM] upgraded redland (1:1.0.17-4 -> 1:1.0.17-6)
[2018-12-02 19:07] [ALPM] upgraded lpsolve (5.5.2.5-2 -> 5.5.2.5-3)
[2018-12-02 19:07] [ALPM] upgraded libreoffice-fresh (6.1.3-1 -> 6.1.3-2)
[2018-12-02 19:07] [ALPM] upgraded libsidplay (1.36.59-8 -> 1.36.59-9)
[2018-12-02 19:07] [ALPM] upgraded libva-mesa-driver (18.2.5-0 -> 18.2.6-0)
[2018-12-02 19:07] [ALPM] upgraded libwbclient (4.8.5-1 -> 4.9.3-1)
[2018-12-02 19:07] [ALPM] upgraded libwmf (0.2.8.4-14 -> 0.2.10-1)
[2018-12-02 19:07] [ALPM] upgraded libxfce4ui (4.12.1-2 -> 4.12.1-3)
[2018-12-02 19:07] [ALPM] upgraded libxpm (3.5.12-1 -> 3.5.12-2)
[2018-12-02 19:07] [ALPM] upgraded libxvmc (1.0.10-1 -> 1.0.10-2)
[2018-12-02 19:07] [ALPM] upgraded linux-firmware (20181026.1cb4e51-0.1 -> 20181026.1cb4e51-1)
[2018-12-02 19:07] [ALPM] upgraded linux419 (4.19.4-1 -> 4.19.6-1)
[2018-12-02 19:07] [ALPM] upgraded lua52-socket (20160311-1 -> 20160311-2)
[2018-12-02 19:07] [ALPM] upgraded meld (3.19.0-3 -> 3.19.1-1)
[2018-12-02 19:07] [ALPM] upgraded memtest86+ (5.01-2 -> 5.01-3)
[2018-12-02 19:07] [ALPM] upgraded mesa-vdpau (18.2.5-0 -> 18.2.6-0)
[2018-12-02 19:07] [ALPM] upgraded mhwd-nvidia (1:410.78-1 -> 1:415.18-1)
[2018-12-02 19:07] [ALPM] upgraded mypaint-brushes (1.3.0-2 -> 1.3.0-3)
[2018-12-02 19:07] [ALPM] upgraded nano (3.1-1 -> 3.2-1)
[2018-12-02 19:07] [ALPM] upgraded openresolv (3.9.0-1 -> 3.9.0-2)
[2018-12-02 19:07] [ALPM] upgraded netctl (1.18-1 -> 1.19-1)
[2018-12-02 19:07] [ALPM] upgraded vpnc (0.5.3.svn550-2 -> 0.5.3.svn550-3)
[2018-12-02 19:07] [ALPM] upgraded openconnect (1:7.08-1 -> 1:7.08-2)
[2018-12-02 19:07] [ALPM] upgraded pamac (7.3.1-2 -> 7.3.1-4)
[2018-12-02 19:07] [ALPM-SCRIPTLET] ==> Enable Pamac Updates Indicator via
[2018-12-02 19:07] [ALPM-SCRIPTLET] Gnome Tweak
[2018-12-02 19:07] [ALPM] upgraded papirus-icon-theme (20181007-1 -> 20181120-1)
[2018-12-02 19:07] [ALPM] upgraded patch (2.7.6-6 -> 2.7.6-7)
[2018-12-02 19:07] [ALPM] upgraded perl-xml-namespacesupport (1.12-2 -> 1.12-3)
[2018-12-02 19:07] [ALPM] upgraded perl-xml-sax-base (1.09-2 -> 1.09-3)
[2018-12-02 19:07] [ALPM] upgraded perl-xml-sax-expat (0.51-5 -> 0.51-6)
[2018-12-02 19:07] [ALPM] upgraded pix (1.8.2-1 -> 2.0.0-1)
[2018-12-02 19:07] [ALPM] upgraded python-colorama (0.4.0-1 -> 0.4.1-1)
[2018-12-02 19:07] [ALPM] upgraded python-cryptography (2.4.1-1 -> 2.4.2-1)
[2018-12-02 19:07] [ALPM] upgraded python-keyring (16.0.2-1 -> 16.1.1-1)
[2018-12-02 19:07] [ALPM] upgraded python2-cairo (1.17.0-2 -> 1.18.0-1)
[2018-12-02 19:07] [ALPM] upgraded python2-gobject (3.30.2-1 -> 3.30.4-1)
[2018-12-02 19:07] [ALPM] upgraded rclone (1.43.1-1 -> 1.45-1)
[2018-12-02 19:07] [ALPM] upgraded rsnapshot (1.4.2-2 -> 1.4.2-3)
[2018-12-02 19:07] [ALPM] upgraded smbclient (4.8.5-1 -> 4.9.3-1)
[2018-12-02 19:07] [ALPM] upgraded samba (4.8.5-1 -> 4.9.3-1)
[2018-12-02 19:07] [ALPM] upgraded serf (1.3.9-2 -> 1.3.9-3)
[2018-12-02 19:07] [ALPM] upgraded sudo (1.8.25.p1-1 -> 1.8.26-2)
[2018-12-02 19:07] [ALPM] upgraded systemd-sysvcompat (239.6-1 -> 239.303-1)
[2018-12-02 19:07] [ALPM] upgraded taglib (1.11.1-1 -> 1.11.1-2)
[2018-12-02 19:07] [ALPM] upgraded tcl (8.6.8-3 -> 8.6.9-2)
[2018-12-02 19:07] [ALPM] upgraded ■■■■■■■ (3.27-2 -> 3.28-1)
[2018-12-02 19:07] [ALPM] upgraded thunderbird (60.3.1-0 -> 60.3.2-1)
[2018-12-02 19:07] [ALPM] upgraded thunderbird-i18n-de (60.3.1-0 -> 60.3.2-1)
[2018-12-02 19:07] [ALPM] upgraded tk (8.6.8-3 -> 8.6.9-2)
[2018-12-02 19:07] [ALPM] upgraded tree (1.7.0-2 -> 1.8.0-1)
[2018-12-02 19:07] [ALPM] upgraded vlc (3.0.4-6 -> 3.0.4-7)
[2018-12-02 19:07] [ALPM] upgraded vulkan-intel (18.2.5-0 -> 18.2.6-0)
[2018-12-02 19:07] [ALPM] upgraded vulkan-radeon (18.2.5-0 -> 18.2.6-0)
[2018-12-02 19:07] [ALPM] upgraded wine (3.20-1 -> 3.21-1)
[2018-12-02 19:07] [ALPM] upgraded wireless-regdb (2018.05.31-2 -> 2018.10.24-2)
[2018-12-02 19:07] [ALPM] upgraded xdg-user-dirs-gtk (0.10+9+g5b7efc6-1 -> 0.10+9+g5b7efc6-2)
[2018-12-02 19:07] [ALPM] upgraded xed (1.8.3-1 -> 2.0.0-1)
[2018-12-02 19:07] [ALPM] upgraded xf86-input-elographics (1.4.1-7 -> 1.4.1-8)
[2018-12-02 19:07] [ALPM] upgraded xf86-input-keyboard (1.9.0-2 -> 1.9.0-3)
[2018-12-02 19:07] [ALPM] upgraded xf86-input-void (1.4.1-3 -> 1.4.1-4)
[2018-12-02 19:07] [ALPM] upgraded xf86-video-intel (1:2.99.917+853+g0932a6b3-1 -> 1:2.99.917+855+g746ab3bb-1)
[2018-12-02 19:07] [ALPM] upgraded xorg-xauth (1.0.10-1 -> 1.0.10-2)
[2018-12-02 19:07] [ALPM] upgraded xorg-xrandr (1.5.0-1 -> 1.5.0-2)
[2018-12-02 19:07] [ALPM] upgraded xplayer (1.8.3-1 -> 2.0.0-1)
[2018-12-02 19:07] [ALPM] upgraded xreader (1.8.5-1 -> 2.0.1-1)
[2018-12-02 19:07] [ALPM] upgraded xviewer (1.8.1-1 -> 2.0.0-1)
[2018-12-02 19:07] [ALPM] transaction completed
[2018-12-02 19:07] [ALPM] running ‘60-linux419.hook’…
[2018-12-02 19:07] [ALPM] running ‘90-linux419.hook’…
[2018-12-02 19:07] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: ‘default’
[2018-12-02 19:07] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64.img
[2018-12-02 19:07] [ALPM-SCRIPTLET] ==> Starting build: 4.19.6-1-MANJARO
[2018-12-02 19:07] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2018-12-02 19:07] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2018-12-02 19:07] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2018-12-02 19:07] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2018-12-02 19:07] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2018-12-02 19:07] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2018-12-02 19:07] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2018-12-02 19:07] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2018-12-02 19:07] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2018-12-02 19:07] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64.img
[2018-12-02 19:07] [ALPM-SCRIPTLET] ==> Image generation successful
[2018-12-02 19:07] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: ‘fallback’
[2018-12-02 19:07] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64-fallback.img -S autodetect
[2018-12-02 19:07] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64-fallback.img
[2018-12-02 19:07] [ALPM] running ‘99-grub.hook’…
[2018-12-02 19:07] [ALPM-SCRIPTLET] Generating grub configuration file …
[2018-12-02 19:07] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-4.19-x86_64
[2018-12-02 19:07] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-4.19-x86_64.img
[2018-12-02 19:07] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-4.19-x86_64-fallback.img
[2018-12-02 19:07] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2018-12-02 19:07] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
[2018-12-02 19:07] [ALPM-SCRIPTLET] done
[2018-12-02 19:07] [ALPM] running ‘detect-old-perl-modules.hook’…
[2018-12-02 19:07] [ALPM] running ‘firefox-post.hook’…
[2018-12-02 19:07] [ALPM] running ‘fontconfig.hook’…
[2018-12-02 19:07] [ALPM] running ‘fontconfig-32.hook’…
[2018-12-02 19:07] [ALPM] running ‘gdk-pixbuf-query-loaders.hook’…
[2018-12-02 19:07] [ALPM] running ‘glib-compile-schemas.hook’…
[2018-12-02 19:07] [ALPM-SCRIPTLET] No such key “panels-resizable” in schema “org.cinnamon” as specified in override file “/usr/share/glib-2.0/schemas/99_manjaro-cinnamon.gschema.override”; ignoring override for this key.
[2018-12-02 19:07] [ALPM-SCRIPTLET] No such key “use-transparent-background” in schema “org.gnome.Terminal.Legacy.Profile” as specified in override file “/usr/share/glib-2.0/schemas/99_manjaro-cinnamon.gschema.override”; ignoring override for this key.
[2018-12-02 19:07] [ALPM-SCRIPTLET] No such key “background-transparency-percent” in schema “org.gnome.Terminal.Legacy.Profile” as specified in override file “/usr/share/glib-2.0/schemas/99_manjaro-cinnamon.gschema.override”; ignoring override for this key.
[2018-12-02 19:07] [ALPM] running ‘gtk-update-icon-cache.hook’…
[2018-12-02 19:08] [ALPM] running ‘systemd-binfmt.hook’…
[2018-12-02 19:08] [ALPM] running ‘systemd-catalog.hook’…
[2018-12-02 19:08] [ALPM] running ‘systemd-daemon-reload.hook’…
[2018-12-02 19:08] [ALPM] running ‘systemd-hwdb.hook’…
[2018-12-02 19:08] [ALPM] running ‘systemd-sysctl.hook’…
[2018-12-02 19:08] [ALPM] running ‘systemd-sysusers.hook’…
[2018-12-02 19:08] [ALPM] running ‘systemd-tmpfiles.hook’…
[2018-12-02 19:08] [ALPM] running ‘systemd-udev-reload.hook’…
[2018-12-02 19:08] [ALPM] running ‘systemd-update.hook’…
[2018-12-02 19:08] [ALPM] running ‘texinfo-install.hook’…
[2018-12-02 19:08] [ALPM] running ‘thunderbird-post.hook’…
[2018-12-02 19:08] [ALPM] running ‘update-ca-trust.hook’…
[2018-12-02 19:08] [ALPM] running ‘update-desktop-database.hook’…
[2018-12-02 19:08] [ALPM] running ‘update-mime-database.hook’…
[2018-12-02 19:08] [ALPM] running ‘update-vlc-plugin-cache.hook’…
[2018-12-02 19:08] [ALPM] running ‘xorg-mkfontdir.hook’…
Ok it works with osinfo-db-git in AUR.
But it’s temporary fixe. I hope osinfo-db will be updated soon in Arch/Manjaro
This update broke my system and it won’t boot. Here’s what happened. Some of it might be my fault (?).
  • I ran yay -Syu from the command line and agreed to the big update.
  • I went to make myself a coffee.
  • When I came back, the screen was locked so I unlocked it.
  • The terminal where the updates were being installed had vanished (yes, I look at all of my virtual desktops). Networkmanager had also been disabled.
  • I ran pacman -Su to finish installing the updates.
  • When I rebooted I got the following screen about an emergency shell. But I can’t even type in it!
I’m basically ready to give up on this computer, since it’s old anyway.
